John Deere 1030 Integral Planters Operators Manual OMP74039
Format: HTML
Brand: John Deere
Type of Machine: Planters
Model: John Deere 1030 Integral Planters
Parts Number: OMP74039
Foreword
Machine Photo
To our customers
Section : 05-Safety
Safety Features
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prevent Machine Runaway
Operate Machine Safely
Keep Riders Off Machine
Avoid Tipovers
Prepare for Emergencies
Wear Protective Clothing
Granular Product Hopper Lid Fill Closed Handling System
Use Safety Lights and Devices
Transport Safety
Tow Loads Safely
Comply with the Transport Speed Limit
Service Machine Safely
Practice Safe Maintenance
Avoid High-Pressure Fluids
Store Attachments Safely
Charge Row Marker Hydraulic System
Dispose of Waste Properly
Section : 10-Safety Signs
Safety Signs
Section : 15-Preparing the Tractor
See Tractor Operator’s Manual
Front Counterweight
Rear Wheel Counterweight
Determine Planter/Tractor Compatibility
Determining Front End Ballast Without Implement Codes
Sway Blocks (If Equipped)
Stabilizer Bar (If Equipped)
Center Link Adjustment
Lift Links
Vertical Float Adjustment
Rockshaft Draft Control
Preparing Tractor Drawbar
Check Tire Inflation Pressure
Setting Position Control Lever Stop
Section : 25-Attaching the Implement
Attaching Machine to Tractor
Attaching Warning Light Harness
Connecting ComputerTrak™ Wiring Harness
Check Hydraulic System
Connecting Hydraulic System to Row-Crop Tractors (General Information)
Single Lever Hydraulic Lift Control
Connect Hydraulic Hoses
Section : 30-Attaching and Detaching the Planter
Tractor Three-Point Hitch
Install Rockshaft Hitch Pins
Attaching Planter to Tractor
Detaching from Tractor
Section : 35-Transporting
Transport Safely
Transporting
Sway Chains or Blocks
Section : 40-Operating Machine
General
Record Rate Values
Adjust Planting Depth
Adjusting Closing Wheel Down Force
Centering Closing Wheels
Adjusting Closing Wheel Spacing
Staggering Closing Wheels
Row Unit Locking System
Raising and Lowering the Machine
Leveling Integral Machines
Adjusting Marker Length
Adjusting Marker Disk
Marker Breakaway Bolts
Raising and Lowering Independent Markers
Raising and Lowering Automatic Markers
Filling Seed Hoppers
Cleanout and Inspection of Seed Hoppers and Metering Units
Section : 45-General Attachments
Seed Tubes
Heavy-Duty Scraper
Seedbed Preparer
Section : 50-Granular Chemical Attachment
Determine Application Rate and Initial Meter Setting
How to Use Planting Rate Charts
Seed Rate Table in Seeds/Meter (with Finger Pick-Up Metering Unit)
Seed Rate Table in Seeds/Meter (with Feed Cup Metering Unit)
Seed Rate Table in Seeds/Meter (with Radial Metering Unit)
Fertilizer Rate Table in kg per hectare
Changing Seeding Rate Sprocket Combinations
Insecticide Application Rates
Insecticide/Herbicide Meter Calibration
Section : 55-Assembly
Planting Unit to Main Frame
Pressure Springs
Seed Hopper
Opener Disk
Double-Disk Fertilizer Openers
Coulter Openers
Vee Openers
Penetration in Hard Ground, Conventional Till
Insecticide
Fertilizer Hopper
Installing Support Stand
Installing Markers
Installing Hydraulic Cylinder
Installing Hydraulic Cylinder Valve
Installing Slow-Moving Vehicle (SMV) Emblem
Installing Transport Lights
Leveling the Planter
Section : 60-Preparing the Plateless Meter
Plateless Meter Seed Hoppers
Seed Feed Cup Meter
Soybean Feed Cup
Low-Rate Sorghum1
Acid-Delinted Cotton and Small Soybeans1
Replacing Seed Feed Cup or Radial Meter With Pick-Up Fingers
Section : 65-Operating the Plateless Meter
Finger Pick-Up Meter Characteristics
Feed Cup Characteristics
Section : 66-Operating the Radial Metering Unit
Radial Seed Meter Characteristics
Drive Wheel Slip—Machines with Seed Transmission
Section : 70-Talc and Graphite-Based Lubricants
Use of Talc Lubricant
Using Powdered Graphite with Radial Bean Meters
Using Powdered Graphite with Finger Pick-Up Meters
Section : 75-Lubrication
Safe Lubrication and Maintenance of the Machine
Lubrication and Maintenance Procedures
Grease
Lubrication Symbols
Alternative Lubricants
Lubricating Pesticide Roller Chain and Sprocket
Lubrication of Fertilizer, Seed and Insecticide Meter Roller Chain and Sprocket
Lubrication and Maintenance Chart
Safe Maintenance Procedures
Section : 80-Troubleshooting
Frame
Drives
Row Units
Fertilizer System
Markers
Plateless Meter
Radial Bean Meter
Section : 85-Service
Service and Operate Chemical Sprayers Safely
Service Tires Safely
Wheel Bolt Torque
Chain Tension
Checking Bearings
Supporting Raised Machine
Changing Row Width
Row Width Change Tables for 4-Unit Planter
Row Width Change Tables for 6-Unit Planter
Section : 90-Service—As Required
Cleaning Seed Tube Sensor
Replacing Fingers—Finger Pick-Up Meter
Seed Belt Inspection—Finger Pick-Up Meter
Drive Shaft Bearing—Finger Pick-Up Meter
Adjusting Meter Drive Chain
Inspecting and Adjusting Opener Blades
Replacing Seed Opener Disks and Seed Tube Guard
Adjusting Gauge Wheels
Replacing Cotter Shear Pins
Servicing Wheel Bearings
Closing Disk Attachment
Section : 95-Service—Start of Season
Cleaning Meter Drive
Servicing the Chemical Meter
Section : 100-Service—Daily or 10 hours
Cleaning Insecticide and/or Herbicide Hoppers
Section : 105-Service—Every 50 Hours
Wheel Bolt Torque
Section : 110-Service—Every 100 Hours
106 L (3.0 bu.) Seed Hopper Latch
Finger Pick-Up Mechanism
Drive Wheels
Section : 120-Service—End of Season
Inspecting and Servicing Radial Meter
Cleaning Special Coupler Screen
Section : 125-Storage
Placing in Service After Storage
Storing Machine
Section : 130-Specifications
Specifications
Serial Number
Keep Proof of Ownership
Keep Machines Secure
Section : SERVLIT-John Deere Service Literature Available
Technical Information
Section : IBC-John Deere Service Keeps You On The Job
John Deere Is At Your Service
Format: HTML
Brand: John Deere
Foreword
Machine Photo
To our customers
Section : 05-Safety
Safety Features
Avoid Tipovers
Transport Safety
Tow Loads Safely
Safety Signs
Front Counterweight
Lift Links
Transport Safely
Transporting
General
Record Rate Values
Seed Tubes
Heavy-Duty Scraper
Seedbed Preparer
Pressure Springs
Seed Hopper
Opener Disk
Coulter Openers
Vee Openers
Insecticide
Fertilizer Hopper
Installing Markers
Seed Feed Cup Meter
Soybean Feed Cup
Low-Rate Sorghum1
Grease
Lubrication Symbols
Frame
Drives
Row Units
Fertilizer System
Markers
Plateless Meter
Radial Bean Meter
Wheel Bolt Torque
Chain Tension
Checking Bearings
Changing Row Width
Wheel Bolt Torque
Drive Wheels
Storing Machine
Specifications
Serial Number
- JOHN DEERE CODE DTC LIST
