John Deere 1023E 1026R Compact Utility Tractors Operators Manual OMLVU25251
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Compact Utility Tractors
Model: John Deere 1023E 1026R Compact Utility Tractors
Part Number: OMLVU25251
Number of Pages: 92 Pages
Introduction
Thank You for Purchasing a John Deere Product
Using Your Operators Manual
Special Messages
Attachments for Your Machine
Product Identification
Record Identification Numbers
Table of Contents
Safety Labels
Safety Label Location
Understanding The Machine Safety Labels
WARNING LVU22753
WARNING - LVU23279
DANGER T146103
WARNING M117557
WARNING ROPS R141735
CAUTION - LVU24222
DANGER - LVU14509
CAUTION iMatch
Emission Control System Certification Label
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely - Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operators Manuals for ISOBUS Implements
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Use a Safety Chain
Transport Towed Equipment at Safe Speeds
Use Caution On Slopes and Uneven Terrain
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Work in a Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Servicing Cooling System Safely
Service Tires Safety
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts / Nuts
Avoid High Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Dispose of Waste Properly
Operating Controls
Operators Station Controls
Operating
Daily Operating Checklist
Avoid Damage to Plastic and Painted Surfaces
Adjusting Seat
Using Seat Belt
Adjusting Tilt Steering Wheel (1026R)
Using Mower Height Control Knob
Using Light Switch
Using Key Switch
Using Instrument Panel
Using Turn Signal Switch
Testing Safety Systems
Testing the Neutral Start Switch
Testing the Rear Power-Take-Off/Reverse Implement Option (PTO/RIO) Switch
Testing the Seat Switch
Testing Reverse Implement Option (RIO)
Using Brake Pedal
Using Park Brake
Using Throttle
Using Fuel Gauge
Using Fuel Shut-Off Valve
Starting the Engine
Cold Weather Starting Aids
Warming and Idling the Engine
Starting a Stalled Engine
Stopping Machine
Operating the Hydrostatic Transmission
Using Reverse Implement Option (RIO)
Using Cruise Control - 1026R
Using Differential Lock (Traction Assist)
Using Mechanical Front Wheel Drive (MFWD)
Using the Power-Take-Off (PTO) Safely
Checking PTO Driveshaft Length
Using Rear and Mid Power-Take-Off (PTO)
Using Rear Hitch
Using 3-Point Hitch
Using Optional iMatch™ Quick-Attach Hitch System
Connecting Implement Hydraulic Hoses
Using Hydraulic Dual Selective Control Valve (SCV)
Using Selective Control Valve (SCV) Lock Lever
Ballasting Machine
Transporting Machine on Trailer
Towing Loads
Using Safety Chain
Raising and Lowering ROPS
Replacement Parts
Service Literature
Parts
Service Intervals
Servicing Your Machine
As Needed
After First 10 Hours
Every 10 Hours or Daily
After First 50 Hours
Every 50 Hours
Every 200 Hours
Every 400 Hours
Every 600 Hours
Annually
Every 1200 Hours
Every Two Years or 2000 Hours
Service Lubrication
Grease
Lubricating Machine Grease Fittings
Lubricating Hydraulic Selective Control Valve (SCV) Linkage
Lubricating 3-Point Hitch
Service Engine
Engine Warranty Maintenance Statement
Avoid Fumes
Engine Oil
Checking Engine Speeds
Checking Engine Oil Level
Changing Engine Oil and Filter
Cleaning Dust Unloading Valve
Checking Air Restriction Indicator (1026R only)
Servicing Air Filter Elements
Checking Air Filter Intake Hoses and Clamps
Service Cooling System Safely
Recommended Engine Coolant
Checking Radiator Hoses and Clamps
Cleaning Radiator Cooling Screen and Fins
Servicing the Alternator Belt
Checking and Cleaning Fuel Filter Sediment Bowl and Replacing Filter
Fuel Injection Pump
Fuel Injection Nozzles
Cleaning Front Grille Screens
Service Transmission
Transmission and Hydraulic Oil
Checking Front Axle Oil Level
Changing Front Axle Oil
Checking Transmission Oil Level
Changing Transmission Oil and Filter
Remove and Install Oil Suction Screen
Service Electrical
Service the Battery Safely
Checking Battery Electrolyte Level
Removing and Installing Battery
Cleaning Battery and Terminals
Using Booster Battery
Replacing Headlight Bulb
Replacing Taillight Bulb
Replacing Worklight Bulb (1026R)
Replacing Relays and Fuses
Service Steering & Brakes
Adjusting Brakes
Service Miscellaneous
Using Proper Fuel (Diesel)
Filling Fuel Tank
Raising and Lowering Hood
Removing and Installing Side Panels
Checking Wheel Bolts and Hardware
Removing and Installing Wheels
Checking Tire Pressure
Selecting Front Tire Rolling Direction
Cleaning Plastic Surfaces
Cleaning and Repairing Metal Surfaces
Troubleshooting
Using Troubleshooting Chart
Machine
Brakes
Steering
Storage
Storing Safety
Preparing Machine for Storage
Preparing Fuel and Engine For Storage
Removing Machine From Storage
Specifications
Drivetrain
Front Wheels and Tires
Rear Wheels and Tires
Front Tire Inflation Pressures (Maximum)
Rear Tire Inflation Pressures (Maximum)
Fluid Capacities
Ground Speeds
Dimensions
Weight
3-Point Hitch
Torque Values - Inch Fastener Hardware
Torque Values - Metric Hardware
Warranty
Product Warranty
Tire Warranty
Limited Battery Warranty
Index
John Deere Quality Statement
John Deere Quality
Service Record
Record Service Dates
Brand: John Deere
Introduction
Special Messages
Table of Contents
Safety Labels
WARNING LVU22753
WARNING - LVU23279
DANGER T146103
WARNING M117557
CAUTION - LVU24222
DANGER - LVU14509
CAUTION iMatch
Safety
Fire Prevention
Instructional Seat
Use a Safety Chain
Avoid Hot Exhaust
Park Machine Safely
Operating Controls
Operating
Adjusting Seat
Using Seat Belt
Using Light Switch
Using Key Switch
Using Brake Pedal
Using Park Brake
Using Throttle
Using Fuel Gauge
Starting the Engine
Stopping Machine
Using Rear Hitch
Using 3-Point Hitch
Ballasting Machine
Towing Loads
Using Safety Chain
Replacement Parts
Service Literature
Parts
Service Intervals
As Needed
Every 50 Hours
Every 200 Hours
Every 400 Hours
Every 600 Hours
Annually
Every 1200 Hours
Service Lubrication
Grease
Service Engine
Avoid Fumes
Engine Oil
Fuel Injection Pump
Service Electrical
Adjusting Brakes
Filling Fuel Tank
Troubleshooting
Machine
Brakes
Steering
Storage
Storing Safety
Specifications
Drivetrain
Fluid Capacities
Ground Speeds
Dimensions
Weight
3-Point Hitch
Warranty
Product Warranty
Tire Warranty
Index
John Deere Quality
Service Record
- JOHN DEERE CODE DTC LIST
