John Deere 100 Intermediate Square Baler 110001-140000 Operators Manual OME96012
Format: HTML
Brand: John Deere
Type of Machine: Square Baler
Model: John Deere 100 Intermediate Square Baler
Serial Number: 110001-140000
Parts Number:OME96012
Forward
Dealer's Record
Predelivery
Delivery
After-Sale
Section : 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Operate Baler Safely
Use Handholds and Steps
Keep Riders Off Machine
Prepare for Emergencies
Wear Protective Clothing
Stay Clear of Rotating Drivelines
Use Safety Lights and Devices
Use a Safety Chain
Transport Safely
Tow Loads Safely
Practice Safe Maintenance
Avoid High-Pressure Fluids
Dispose of Waste Properly
Section : 10 - Safety Signs
Safety Signs-Tongue
Safety Signs-Tongue and Hood
Safety Signs-Front
Safety Signs-Side
Safety Signs-Rear
Section : 15 - Preparing the Tractor
Selecting Tractor PTO Diameter
Positioning Tractor Drawbar
Three-Point/Quick Coupler Tractor Hitch Position
Setting Tractor Hydraulic Outlets
Adjusting Tractor Wheels
Checking Ballast, Wheel Spacing, and Tire Inflation
Three-Terminal Convenience Outlet and Wiring Harness
Convenience Outlet Adapters
Power Outlet Strip Connection Harnesses
Installing Monitor on Open-Station Tractor
Installing Monitor in SOUND-GARD® Cab Tractor
Installing Monitor In ComfortGard™ Cab
Installing Monitor and Mounting Brackets
Using Drawbar Shield
Making Drawbar Shield
Using Extended Rear-View Mirror
Section : 20 - Preparing the Baler
Checking Air Compressor Oil Level (if Equipped)
Cleaning Air Compressor Filter (if Equipped)
Draining Water from Air Compressor Tank (if Equipped)
Checking Hydraulic Oil Level
Adjusting Pickup Working Height
Adjusting Pickup Depth Stop
Adjusting Baffle Plate Height
Adjusting Pre-Cutter Knives
Checking Tire Inflation Pressure
Checking Wheel Nut Torque
Checking Baler Tongue Hardware Torque
Adjusting Bale Length
Lowering and Adjusting Bale Chute
Selecting Twine
Twine Loading, Tying and Routing Diagram
Loading Twine Boxes
Back Threading Twine Balls
Routing Twine
Three Position Adjustable Baler Hitch
Section : 25 - Attaching and Detaching
Using Flywheel Brake
Attaching Baler to Tractor Drawbar
Assembling Main PTO Driveline Splined Telescoping Members (If Necessary)
Attaching PTO Driveline
Attaching to Tractor Hydraulic System
Using Tractor Convenience Outlet
Using Tractor Power Outlet Strip
Connecting Baler Wiring Harnesses to Tractor
Connecting Tail/Warning Lights Wiring Harness to Tractor
Storing Jackstand
Checking Monitor
Detaching Baler from Tractor
Section : 30 - Transporting
Preparing Baler for Transport
Follow Safe Transport Procedures
Section : 35 - Electronic Control System
Electronic Control System Components and Function
Identifying Monitor Keys and Switches
Changing Monitor Display Language
Alarm Messages
System Override Switch
Bale Case Release Switch
Section : 40 - Baler Components
Component Location-Right-Hand Side
Component Location-Left-Hand Side
Main Drive
Pickup Drive
Powr-Feed Drive
Knotter Driveline
Pickup
Pre-Cutter Knives
Plungerhead
Last Bale Ejection System (Optional)
Section : 45 - Knotter Components
Knotter Assembly
Billhook
Twine Disk
Wiper Arm
Knotter Cleaning System (Optional)
Section : 50 - Crop Preparation and Storage
Use TY16136 Digital Hay Tester
Crop Quality
Crop Preparation
Preservative Usage
Bale Storage
Additional Reference Information
Section : 55 - Operating the Baler
How the Baler Works
Twine Tying Cycle Operation
Raising and Lowering Pickup
Observing Baling Pressure
Monitor Start-Up Sequence
Switching Pre-Cutter Knives Alarm On/Off
Viewing Strokes Per Bale
Bale Density
Starting to Bale
Adjusting Bale Density
Twine Alarm
Viewing Bale Count
Opening Bale Case
Manually Tripping Twine Tying Cycle
Emptying Bale Case
Resetting Powr-Feed Clutch
Checking Twine Knot Strength
Section : 60 - Attachments
Knotter Cleaner
Field Working Lights
Rear-View Mirror Extension
Monitor Mounting Brackets for 7000 Series Tractors
Monitor Mounting Kit for Open Station 7000 Series Tractors
Fire Extinguisher and Mounting Bracket
Drawbar Shield
Allied Equipment
Side Hay Resistors
Section : 65 - Lubricants and Capacities
Gear Case Oil
Hydraulic Oil
Air Compressor (If Equipped) Oil
Grease
Oil Filters
Mixing of Lubricants
Lubricant Storage
Section : 70 - Lubrication and Maintenance
Lubricating and Maintaining Machine Safely
Perform Lubrication and Maintenance
Break-In Service
Observe Service Intervals
Observe Lubrication Symbols
Chains
Every 4 Hours
Every 8 Hours
Every 50 Hours
Every 100 Hours
Every 500 Hours
Annually
As Required
Section : 75 - Troubleshooting
Electromagnetic Interference (EMI)
General Baler Troubleshooting
Monitor Troubleshooting
Pickup Difficulties
Driveline Difficulties
Knotter Mechanism Troubleshooting Illustrations
Multiluber Difficulties
Bale Quality Troubleshooting
Electrohydraulic Valve Cycle During Normal Operation of Density Control System
Hydraulic Troubleshooting Flowchart
Section : 80 - Service-Drive, Air, Hydraulic & Lighting
Detailed Service Information-Use TM1690
Practice Safe Service Procedures
Keep Service Area Clean
Service Tires Safely
Replacing Operating/Alarm Indicator Light Bulbs
Replacing Warning/Tail Light Bulb
Freeing Main Slip Clutch
Adjusting Main Slip Clutch Torque Setting
Adjusting Flywheel Brake Band
Replacing Flywheel Shear Bolt-Machine (Serial No. 120029- )
Electrohydraulic System Diagram
Checking Control Valves
Bleeding Air From Regulator Valve
Flushing Hydraulic System
Checking Packer-to-Plungerhead Timing
Adjusting Packer-to-Plungerhead Timing
Adjusting Plungerhead
Adjusting Guide Rail Scrapers
Replacing Packer Cam Follower Bearings
Replacing Pre-Cutter Knives Shear Bolt
Adjusting Pickup Flotation
Changing Tire
Checking and Adjusting Air Compressor Drive Belt (If Equipped) Tension
Replacing Air Compressor Drive Belt (If Equipped)
Section : 85 - Service-Twine Delivery and Knotters
Adjusting Needles
Checking Needle Timing Relative to Plungerhead
Adjusting Needle Timing Relative to Plungerhead
Adjusting Needle Arm Brake
Adjusting Knotter Shaft Brake Tension
Adjusting Tucker Fingers
Adjusting Tucker Finger Return Spring
Checking Twine Tension
Adjusting Twine Tension Plates
Replacing Needle Yoke Shear Bolt
Replacing Knotter Drive Shear Bolt
Checking and Adjusting Cam Lobe-to-Wheel Clearance
Checking Trip Pawl
Adjusting Trip Pawl
Checking Wiper Arm Wear
Adjusting Wiper Arm
Adjusting Twine Holder
Replacing Twine Cutoff Knife
Sharpening Twine Cutoff Knife
Adjusting Twine Disk Timing
Adjusting Billhook Tongue Tension
Checking Knotter Frame to Intermittent Gear
Section : 90 - Service-Electronic Control System
Electrical Schematic Symbols
Wire Color Chart
Abbreviations and Explanations-Wiring Schematic
Electronic System Wiring Schematic
Manual Operating Mode
Setting Fixed Relief Valve
Setting Adjustable Relief Valve
Entering Sensor Test Mode
Testing Packer Sensor
Adjusting Packer Sensor Timing
Testing Knotter Sensor
Adjusting Knotter Sensor
Testing Pre-Cutter Knives Sensor
Adjusting Pre-Cutter Knives Sensor
Testing Twine Tension Sensor
Testing Calibration Sensor
Testing Measurement Sensor
Adjusting Calibration and Measurement Sensors
Adjusting Monitor Display Contrast
Replacing On-Board Computer Fuses
Replacing Monitor Fuse
Replacing Amplifier Fuse
Section : 95 - Storage
Storing Baler
Removing Baler from Storage
Section : 100 - Predelivery Instructions
Remove Shipping Wires
Remove Shipping Block
Install Power Harness and Monitor
Install Pickup Gauge Wheels
Install SMV Sign
Check Tire Inflation Pressure
Check Wheel Nut Torque
Checking Baler Tongue Bolt Torque
Install Fire Extinguisher (Optional)
Section : 105 - Specifications
100 Intermediate Square Baler Specifications1
Record Product Identification Number
Record Serial Number
Shear Bolt Specifications
Metric Bolt and Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Section : 110 - Lubrication And Maintenance Records
4 Hours or 200 Bales Service Chart
8 Hours or 400 Bales Service Chart
50 Hour Service Chart
100 Hours Service Chart
500 Hour Service Chart
Annual Service Chart
As Required Service Chart
Section : 115 - Crime Prevention Tips
Help Prevent Crime
Record Identification Numbers
Keep Proof of Ownership
Park Indoors Out of Sight
When Parking Outdoors
Reduce Vandalism
Report Thefts Immediately
Technical Information
John Deere Is At Your Service When You Need It
Format: HTML
Brand: John Deere
Forward
Dealer's Record
Predelivery
Delivery
After-Sale
Use a Safety Chain
Transport Safely
Tow Loads Safely
Safety Signs-Tongue
Safety Signs-Front
Safety Signs-Side
Safety Signs-Rear
Selecting Twine
Loading Twine Boxes
Routing Twine
Storing Jackstand
Checking Monitor
Alarm Messages
Main Drive
Pickup Drive
Powr-Feed Drive
Knotter Driveline
Pickup
Pre-Cutter Knives
Plungerhead
Knotter Assembly
Billhook
Twine Disk
Wiper Arm
Crop Quality
Crop Preparation
Preservative Usage
Bale Storage
How the Baler Works
Bale Density
Starting to Bale
Twine Alarm
Viewing Bale Count
Opening Bale Case
Emptying Bale Case
Knotter Cleaner
Drawbar Shield
Allied Equipment
Side Hay Resistors
Gear Case Oil
Hydraulic Oil
Grease
Oil Filters
Lubricant Storage
Break-In Service
Chains
Every 4 Hours
Every 8 Hours
Every 50 Hours
Every 100 Hours
Every 500 Hours
Annually
As Required
Pickup Difficulties
Changing Tire
Adjusting Needles
Checking Trip Pawl
Adjusting Trip Pawl
Adjusting Wiper Arm
Wire Color Chart
Storing Baler
Install SMV Sign
Help Prevent Crime
Reduce Vandalism
- JOHN DEERE CODE DTC LIST
