Hyundai
86
176,834
JLG Vertical Lift RT2669 RT3369 ERT2669 ERT3369 Operation Safety Manual 3122566500
Brand: JLG
Type of Machine: Vertical Lift
Type of Manual: Operation Safety Manual
Model: JLG RT2669 RT3369 ERT2669 ERT3369 Vertical Lift
Part Number: 3122566500
Publication Date: 2025
Number of Pages: 142 Pages
31225665 Cover Page
Foreword
Revision Log
Other Available Publications​
Serial Number Location​
Safety Precautions
General​
Pre-Operation​
1.2.1 Operator Training and Knowledge​
1.2.2 Workplace Inspection​
1.2.3 Machine Inspection​
Operation​
1.3.1 General​
1.3.2 Trip and Fall Hazards​
1.3.3 Electrocution Hazards​
1.3.4 Tipping Hazards​
1.3.5 Crushing and Collision Hazards​
Towing, Lifting, and Hauling​
Maintenance​
1.5.1 Maintenance Hazards​
1.5.2 Battery Hazards​
Long-Term Storage​
User Responsibilities, Machine Preparation, and Inspection
Personnel Training​
2.1.1 Operator Training​
2.1.2 Training Supervision​
2.1.3 Operator Responsibility​
2.1.4 Machine Familiarization​
Preparation, Inspection and Maintenance​
RT, ERT Series Pre-Start Inspection​
RT2669, RT3369, ERT2669, ERT3369 Walk-Around Inspection​
RT2669, RT3369, ERT2669, ERT3369 Function Check​
Oscillating Axle - Lockout Cylinder Test (If Equipped) (CE M​
2.6.1 Left Side Wheel Test​
2.6.2 Right Side Wheel Test​
Oscillating Axle - Lockout Cylinder Test (If Equipped) (All​
2.7.1 Left Side Wheel Test​
2.7.2 Right Side Wheel Test​
QuikLevel Advanced Test (If Equipped)​
Machine Controls, Indicators, and Operation
General​
Description​
Operating Characteristics and Limitations​
3.3.1 Placards​
3.3.2 Capacities​
3.3.3 Stability​
Platform Loading​
Battery Charging (ERT Machines)​
Midsize RT Scissor Ground Control Station​
3.6.1 Ground Control Station Functions​
Platform Control Station​
3.7.1 Platform Control Station Functions​
Indicator Display​
3.8.1 Indicator Display Functions​
Navigating the Indicator Display​
Engine Operation​
3.10.1 Starting Procedure​
Dual Fuel System (If Equipped)​
3.11.1 Changing from Gasoline to Liquid Propane Gas (LPG)​
3.11.2 Changing from LPG to Gasoline​
Traveling (Driving)​
3.12.1 Steering​
3.12.2 Traveling Forward​
3.12.3 Traveling in Reverse​
Traveling (Grade/Side Slope)​
Platform​
3.14.1 Raising​
3.14.2 Lowering​
3.14.3 Arm Guards (If Equipped)​
3.14.4 Platform Extension​
Leveling Jacks (If Equipped)​
3.15.1 Auto-Leveling​
3.15.2 Manual Level Adjustment (Trim)​
QuikLevel Advanced (Dual Oscillating Axles) (If Equipped)​
3.16.1 Auto-Leveling​
3.16.2 Manual Level Adjustment (Trim)​
Parking and Stowing​
Platform Rails Fold-Down Procedure​
Machine Lifting and Tie Down​
3.19.1 Lifting​
3.19.2 Tie Down​
RT/ERT 26/33 Lifting and Tie Down Chart​
Towing​
Beacons​
3.22.1 ClearSky® LED Motion / Amber Beacon (CS550)​
3.22.2 Amber Beacon​
ClearSky Smart Fleet​
Access Control (Scissor)​
Safety Decal Locations - RT2669, RT3369​
Safety Decal Locations - ERT2669, ERT3369​
Emergency Procedures
General​
Incident Notification - Scissor​
Emergency Operation​
4.3.1 Use of Ground Controls​
4.3.2 Operator Unable to Control Machine​
4.3.3 Platform Caught Overhead​
4.3.4 Righting of Tipped Machine​
Platform Manual Descent Control​
Emergency Towing Procedures​
4.5.1 RT Machines​
4.5.2 ERT Machines​
ClearSky Smart Fleet - Locked Out State​
Available Accessories - RT2669, ERT2669, RT3369, ERT3369​
Footswitch​
5.2.1 Operation​
Generator (2500W)​
Generator (3500W)​
5.4.1 Generator Specifications​
5.4.2 Safety Precautions​
5.4.3 Preparation and Inspection​
5.4.4 Operation​
Panel Carrier​
5.5.1 Safety Precautions​
5.5.2 Preparation and Inspection​
5.5.3 Operation​
Pipe Racks​
5.6.1 Safety Precautions​
5.6.2 Preparation and Inspection​
5.6.3 Operation​
Platform Extension Handle​
Platform Rail Padding​
Platform Work Lights​
SkySense®​
5.10.1 General Information​
5.10.2 Preparation and Inspection​
5.10.3 Operation​
5.10.4 Notification Assembly​
5.10.5 LED Indicator​
5.10.6 SkySense Alarm​
5.10.7 Override Button​
5.10.8 SkySense Coverage Areas​
Work Station​
5.11.1 Safety Precautions​
5.11.2 Preparation and Inspection​
5.11.3 Operation​
Machine Specifications and Operator Maintenance
General​
RT2669, RT3369, ERT2669, ERT3369 Machine Specifications​
6.2.1 Operating Specifications​
6.2.2 Dimensions​
6.2.3 Maximum Allowable Operating Slope​
6.2.4 Platform Capacity​
6.2.5 Fluid Capacities​
6.2.6 Batteries (ERT Machine)​
6.2.7 Tires​
6.2.8 Battery Charger (ERT Machines)​
Engine Specifications​
Engine Oil Operating Temp Spec - RT and ERT Machines​
Lubrication​
Safety Prop​
Battery Maintenance and Charging (Lead Acid/AGM)​
6.7.1 Battery Charging (Daily)​
6.7.2 Battery Maintenance (Quarterly)​
Battery Disconnect (ERT Machines)​
Operator Maintenance​
6.9.1 Fuel Tank​
6.9.2 Hydraulic Oil Tank​
6.9.3 Drive Hub​
6.9.4 Scissor Arm Wear Pads​
6.9.5 Engine Coolant​
6.9.6 Air Filter​
6.9.7 Oil Change with Filter​
6.9.8 Fuel/Water Separator Filter (Diesel)​
6.9.9 Fuel Strainer (Diesel)​
6.9.10 Fuel Filter (Gas)​
ERT Genset (If Equipped)​
6.10.1 Engine Specifications​
6.10.2 Fluid Capacities​
6.10.3 Operator Maintenance​
Propane Fuel System​
6.11.1 Pressure Relief​
6.11.2 Leak Test​
Tires and Wheels​
6.12.1 Tire Damage​
6.12.2 Tire Replacement​
6.12.3 Wheel Replacement​
6.12.4 Wheel Installation​
Radio Frequency (RF) Information​
6.13.1 Federal Communications Commission (FCC)​
6.13.2 Innovation, Science and Economic Development (ISED)​
6.13.3 European Union Conformity (CE)​
Supplemental Information Only Applicable to CE/UKCA Machines​
EC Declaration of Conformity - RT2669, RT3369, ERT2669, ERT3​
UKCA Declaration of Conformity - RT2669, RT3369, ERT2669, ER​
