Hyundai
86
176,834
JLG Vertical Lift E18MML E18MCL E18MSP Service & Maintenance Manual 3122326800
Brand: JLG
Type of Machine: Vertical Lift
Model: JLG E18MML E18MCL E18MSP Vertical Lift
Part Number: 3122326800
Publication Date: 2024
Number of Pages: 382 Pages
Coverpage
Effectivity Page
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Battery Specifications​
2.1.3 Battery Charger​
2.1.4 Cylinder Specifications​
2.1.5 Platform Data​
2.1.6 Machine Wheel Loads and PSI - Per Wheel​
2.1.7 Machine Component Weights​
2.1.8 Specifications For Various Components​
2.1.9 Torque Requirements​
Serial Number Location​
Fluids and Lubrication​
2.3.1 Hydraulic System​
2.3.2 Hydraulic Oil​
2.3.3 Changing Hydraulic Oil​
2.3.4 Lubrication Specifications​
2.3.5 Fluids​
Machine Characteristics​
2.4.1 Primary Regulatory Standards​
2.4.2 Languages of Markings​
2.4.3 Outdoor Rating​
2.4.4 Tilt System​
2.4.5 Platform Height Monitoring System​
2.4.6 Platform Joystick Trigger​
2.4.7 Platform Footswitch​
2.4.8 Battery Charger System​
2.4.9 Platform Load Sensing System (LSS)​
2.4.10 Universal Telematics​
2.4.11 Battery Charge Indication​
2.4.12 Control System​
2.4.13 Beacon​
2.4.14 Lithium-Ion Batteries (If Equipped)​
2.4.15 FLA or AGM Batteries (If Equipped)​
2.4.16 Ground Control Key Switch​
2.4.17 JLG Mobile Control System​
2.4.18 Drive System​
2.4.19 Brake System​
2.4.20 Gate Alarm (Accessory on Material Tray Platform)​
2.4.21 Lift System​
2.4.22 Steer System​
2.4.23 Pothole Protection System​
2.4.24 Manual Descent System​
2.4.25 Wheels/Tires​
2.4.26 Platform Rail System​
2.4.27 Tow System​
2.4.28 Pothole Protection Alarm​
2.4.29 Low Temperature Cutout​
2.4.30 Indoor/Outdoor Mode​
2.4.31 Slope Descent System​
2.4.32 Driving Above Elevated Position​
Clearsky Smart Fleet (If Equipped)​
2.5.1 General​
2.5.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventative Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication and Servicing​
3.2.13 Batteries​
3.2.14 Mast Chain Inspection Procedure​
3.2.15 Lift Cylinder Component Inspection​
Preventive Maintenance and Inspection Schedule​
Tires and Wheels​
3.4.1 Tire Wear and Damage​
3.4.2 Wheel and Tire Replacement​
Battery System Maintenance/Troubleshooting​
3.5.1 Battery Management System (BMS)​
3.5.2 State of Charge (SOC)​
3.5.3 Battery Status Indicator (LED)​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
4.1.4 Special Pin Extractor Tools For Electrical Connectors​
4.1.5 Hydraulic Line - Disconnect - Special Tool​
Testing Procedures​
4.2.1 LSS Testing and Evaluation​
4.2.2 Battery Condition Testing​
4.2.3 Electrical Switch Testing​
4.2.4 Verify Elevation​
Calibration Procedures​
4.3.1 Load Sensing System (LSS)​
Special Procedure​
4.4.1 Emergency Procedure​
4.4.2 Base Assembly Components​
4.4.3 Joystick Controller​
4.4.4 Mast Chains And Sequencing Cables Adjustment​
4.4.5 Sequence Cable Replacement Kit​
4.4.6 Traction System​
4.4.7 Factory Reset​
4.4.8 Preventative Maintenance - Brush Wear - Dust Removal Procedure​
4.4.9 Lithium-Ion Battery Troubleshooting Notes​
WHEEL DRIVE ASSEMBLY - SERVICING​
4.5.1 Roll And Leak Testing​
4.5.2 Oil Type & Capacity​
System Software
Control Module​
5.1.1 Ground Control Module​
5.1.2 Machine Software​
Ground Control Station - Programming​
5.2.1 General​
5.2.2 Ground Control Station Functions​
Machine Configuration Programming Information​
Machine Model Adjustment​
5.5.1 ClearSky Smart FleetTM CS550 Configuration​
5.5.2 Troubleshooting​
Fault Codes
Introduction​
6.1.1 General​
6.1.2 Troubleshooting Information​
DTC Check Tables​
6.2.1 ClearSky Smart Fleet DTC Fault Codes​
Main Power Circuit Troubleshooting​
6.3.1 Machine Will Not Power Up​
Mast Troubleshooting​
6.4.1 Platform Will Not Lower Manually​
6.4.2 Platform Lift Up And Down - Jerky​
6.4.3 Mast Noisy When Lifting And Lowering​
6.4.4 Platform (Mast) Will Not Stay Elevated​
6.4.5 Platform (Mast) Descends Too Slowly​
Hydraulic Leak Troubleshooting​
6.5.1 Miscellaneous Hydraulic Leak Troubleshooting​
Base Frame Components Troubleshooting​
6.6.1 Caster Wheels Not Operating Freely​
6.6.2 Pot Hole Protection (PHP) Bars will not Lower​
Drive System Troubleshooting​
6.7.1 Will Not Climb Grade​
6.7.2 Machine Drives in Opposite Direction​
6.7.3 Machine will Not Drive Straight​
6.7.4 Noise From Drive Assembly​
Hydraulics
General Information and Safety​
Theory Of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
7.2.3 Pump/Motor​
7.2.4 Hydraulic Circuit Checks​
Pressure Setting pocedures​
7.3.1 Main/Lift Relief​
7.3.2 Steer Reliefs - 18MCL only​
Torque Values​
7.4.1 Manifold Valve Torque Specifications​
Electricals
General Electrical Information​
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors​
8.1.3 Installation​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
8.1.11 Electrical Circuit Checks​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
8.3.1 Component Location​
8.3.2 Controls​
Harness Layouts​
Board Layouts​
8.5.1 Logic Control Module​
8.5.2 Drive Control Module​
AMP Connector​
8.6.1 Assembly​
8.6.2 Disassembly​
8.6.3 Wedge Lock​
8.6.4 Service - Voltage Reading​
Switches​
8.7.1 Basic check​
8.7.2 Limit Switches​
8.7.3 Automatic Switches​
8.7.4 Switch Wiring - Low Side, High Side​
Wiring Harness​
9.1.1 Pothole Protection System Components​
Tires and Wheels​
9.2.1 Removal​
9.2.2 Installation​
Steering, Caster and Ackermann​
9.3.1 Caster Wheel​
9.3.2 Hydraulic Steering​
Battery​
9.4.1 Battery Cover Removal​
9.4.2 Battery Cover Installation​
9.4.3 Battery Replacement​
9.4.4 Battery Quick-Disconnect​
9.4.5 Lead Acid Battery​
9.4.6 Lithium Ion Battery​
Battery Charger​
9.5.1 Battery Charger (Delta-Q 650 W (CAN))​
9.5.2 Battery Charger (Delta-Q 1200 W (CAN))​
9.5.3 Battery Charger (Green Power)​
Tilt Sensor​
9.6.1 Removal​
9.6.2 Installation​
9.7.1 Removal​
9.7.2 Installation​
9.7.3 Alarm Removal​
Hood Assembly​
9.8.1 Removal​
9.8.2 Installation​
Drive Motor System​
9.9.1 Drive Cover Removal​
9.9.2 Installation​
9.9.3 Drive Motor Removal​
9.9.4 Drive Motor Installation​
9.10.1 Removal​
9.10.2 Installation​
9.11.1 Module Access​
9.11.2 Removal​
9.11.3 Installation​
Pump Motor Assembly​
9.12.1 Removal​
9.12.2 Installation​
Platform Control Console​
9.13.1 Removal​
9.13.2 Installation​
9.13.3 Joystick Assembly​
Mast​
9.14.1 Removal​
9.14.2 Installation​
Lift Cylinder​
9.15.1 Removal​
9.15.2 Installation​
Platform​
9.16.1 Platform Removal​
9.16.2 Platform Installation​
9.17.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Torque Hub​
10.1.2 Primary Planet Carrier​
10.1.3 Spindle Carrier​
Platform Control Station​
10.2.1 Control Components Overview​
10.2.2 Disassembly​
Lift Cylinder​
Steer Cylinder​
Pump/Motor​
10.5.1 Hydraulic Pressure Settings and Adjustment​
10.5.2 Hydraulic Pressure Gauge Connection​
10.5.3 After Filter Pressure Check​
10.5.4 Pump/Motor/Tank Installation​
10.5.5 General Assembly and Disassembly​
10.5.6 Inline Hydraulic Filter Installation​
10.5.7 Fenner Brand Pump - Brush Replacement​
10.5.8 Monarch Brand Pump - Brush Replacement​
Mast Assembly and Disassembly​
10.6.1 Mast Components Overview​
10.6.2 Mast Disassembly Procedure - MML/MCL/MSP​
10.6.3 Mast Assembly Procedure - MML/MCL/MSP​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematic​
Electrical Schematic​
