JLG Telehandler R11100 Operation Safety Manual 31211947
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Operation Safety Manual
Model: JLG R11100 Telehandler
Part Number: 31211947
Publication Date: 2024
Number of Pages: 344 Pages
cover page R11100
Revision Log
Brand: JLG
cover page R11100
Revision Log
Other Publications Available
Vehicle Identification
Serial Number Plate
Read This FirstOperator Qualifications
Modifications
General IntroductionIntroduction
Recipients
Training
Machine Orientation
General Safety PracticesHazard Classification System
1.1.1 Safety Alert System and Safety Signal Words
General Precautions
Operation Safety
1.3.1 Electrical Hazards
1.3.2 Tip Over Hazard
1.3.3 Travel Hazard
1.3.4 Load Falling Hazard
1.3.5 Lifting Personnel
1.3.6 Driving Hazards on Slopes
1.3.7 Pinch Points and Crush Hazards
1.3.8 Fall Hazard
1.3.9 Chemical Hazards
1.3.10 Windy Conditions
Accessing Rotated Cab
Traveling with a Load
1.5.1 General Warnings for Traveling with a Load
1.5.2 Handling Loads with Rotary Machines
1.5.3 Use of Cables, Ropes, and Slings
Personal Protective Equipment (PPE)
1.6.1 Protective Clothing
1.6.2 Noise Protection
1.6.3 Protection Against Objects falling from Height
1.6.4 Protection from Flying Fragments
Preparing for Accidents
1.7.1 Emergency Call
Pre-Operation and InspectionPreparation, Inspection, and Maintenance
Pre-Operation Check and Inspection
Safety Decals
2.3.1 Safety Decal Descriptions
Warm-Up and Operational Checks
2.4.1 Warm-Up Check
2.4.2 Operational Check
Operator Cab
2.5.1 Cab Components Description
2.5.2 Door Opening — External Handle
2.5.3 Door Opening — Interior Handle
2.5.4 Climbing In and Out of the Cab
Cab Features
2.6.1 Cab Door Window
2.6.2 Heated Mirrors (If Equipped)
2.6.3 Rear Window
2.6.4 Sunshade
2.6.5 Cab Ventilation
2.6.6 Webasto Auxiliary Heating
2.6.7 Air Conditioning (If Equipped)
2.6.8 12 Volt Socket
2.6.9 Storage Compartment
2.6.10 Cab Front Glass Protection (If Equipped)
Controls and IndicatorsGeneral
Controls
3.2.1 Instrument Panel
3.2.2 Display Screen
3.2.3 Indicators
3.2.4 Ignition
3.2.5 Joystick
3.2.6 Anti-Tipping Device
3.2.7 ByPass Key
3.2.8 Attachment Selection Key
3.2.9 Steering Wheel
3.2.10 Transmission Control Lever
3.2.11 Accessory Control Lever
3.2.12 Park Brake
3.2.13 Service Brake Pedal
3.2.14 Inching Pedal
3.2.15 Accelerator Pedal
3.2.16 Outrigger Levers
3.2.17 Transverse Leveling
3.2.18 Bubble Level
3.2.19 Continuous Oil Function
3.2.20 Window Wiper/Washer Controls
3.2.21 Lights
Controller
3.3.1 Drive Mode
3.3.2 Manual Gear Shift
Automatic Swing Axle Lock
Automatic Turret Rotation Lock
Steer Modes
3.6.1 Steering Mode Icons
3.6.2 Steering Status Icon
3.6.3 Manual Steering Selector
3.6.4 Manual Wheel Alignment
Multifunction Display
3.7.1 Initial Check
3.7.2 Home
3.7.3 Digital Level
3.7.4 Bookmarks
3.7.5 Menu
3.7.6 Active Errors
3.7.7 Clock and Clock Settings
3.7.8 Service Icon
3.7.9 Limits
3.7.10 Resolution
3.7.11 Load Capacity Charts
3.7.12 Rear Camera
3.7.13 Documentation
3.7.14 Attachment Automatic Recognition System (ARS)
3.7.15 Boom Suspension (If Equipped)
Operator Seat
3.8.1 Seat Adjustment
3.8.2 Seat Belts
OperationEngine
4.1.1 Starting the Engine in Normal Conditions
4.1.2 After Engine Starting Procedures
4.1.3 Starting Engine in Low Temperatures
4.1.4 Shut-Down Procedure
4.1.5 Engine Start with Auxiliary Batteries
Remote Control
4.2.1 Description
4.2.2 Remote Control Display
4.2.3 Remote Connection Cable
4.2.4 Operation
Operation Check with Anti-Tipping Device Load
Loading and Securing for Transport
4.4.1 Lifting the Machine
4.4.2 Transporting Machine on a Trailer
AttachmentsApproved Attachments
5.1.1 Coupler Mounted Attachments
Unapproved Attachments
Equivalent Load
5.3.1 Load Centers Beyond 24 Inches
Use of the Capacity Chart
5.4.1 Load Charts
5.4.2 Reading the Capacity Charts
5.4.3 Use of the Capacity Charts
5.4.4 Legend for Capacity Load Charts
JLG Supplied Attachments
5.5.1 Attachment Pre-Use Checks
5.5.2 Attachment List
Attachment Installation
5.6.1 Installation Procedure
5.6.2 Hydraulic Sockets and Electrical Contact on Boom Head*
5.6.3 Hydraulic Connections
5.6.4 Electrical Contact on Boom Head (If Equipped)
5.6.5 Electrical Connections
5.6.6 Attachment Quick Coupling
5.6.7 Attachment Removal
Attachment Operation
Forks
5.8.1 Forks Inspection
5.8.2 Forks Usage
5.8.3 Forks Adjustment
5.8.4 Moving Loads with Forks
5.8.5 Use of non-JLG Branded Tools Attached to Forks
Buckets
5.9.1 Bucket Usage
5.9.2 Fixed Tilt Indicator Use
5.9.3 Safe Working Procedures
Personnel Platform Attachments
5.10.1 Platform Identification
5.10.2 Lanyard Anchorage Points
5.10.3 Platform Features
5.10.4 Prior to Use
5.10.5 Platform Movement Controls
5.10.6 Platform Remote Control
5.10.7 Platform Safety Decals
Fixed Winch Attachment
5.11.1 Fixed Winch Identification and Technical Data
5.11.2 Preliminary Checks
5.11.3 Winch Installation
5.11.4 Winch Removal
5.11.5 Operation
5.11.6 Winch Maintenance Schedules
5.11.7 Handling Loads
5.11.8 Winch Safety Devices
5.11.9 Winch Connections
Trellis Winch Attachment
5.12.1 Safety Precautions
5.12.2 Installation
5.12.3 Removal
5.12.4 Operation
5.12.5 Trellis Winch Maintenance Schedules
5.12.6 Safety Devices
5.12.7 Connection Types
Romaster Attachment
5.13.1 Romastor Information and Safety
5.13.2 Specifications
5.13.3 Operating Instructions
5.13.4 Cleaning
5.13.5 Maintenance
Emergency ProceduresEmergency Stop Button
Towing a Disabled Product
6.2.1 Moving Short Distances
6.2.2 Moving Longer Distance
6.2.3 Towing with Electrical Panel On
6.2.4 Towing with Engine Failure
6.2.5 Manually Disengage the Internal Parking Brake
6.2.6 Manually Disable the 2–Gear Hydrostatic Transmission
Emergency Lowering of Boom
Emergency Personnel Platform Recovery - Electric
6.4.1 Boom Retraction
6.4.2 Platform Recovery from Cab
Emergency Exit from Enclosed Cab
6.5.1
Machine Shifted with Turret Rotated
Lubrication and MaintenanceIntroduction
7.1.1 Clothing and Safety Gear
Pre-Maintenance Operations
General Maintenance Instructions
7.3.1 Machine Components
7.3.2 Pressure Gauge
Boom Prop
Batteries
7.5.1 Recharging Batteries
7.6.1 Legend
7.6.2 Safety Checks
7.6.3 As Needed Checks
7.6.4 Every 10 Hours
7.6.5 Every 50 Hours
7.6.6 Every 250 Hours
7.6.7 Every 500 Hours
7.6.8 Every 1000 Hours
7.6.9 Every 2000 Hours
7.6.10 Every 3000 Hours
7.6.11 Every 3600 Hours
7.6.12 Every 4000 Hours
7.6.13 Every 10,000 Hours
7.6.14 Every 2 Years
Lubrication Schedules
7.7.1 Greasing Fifth Wheel Teeth
Operator Maintenance Instructions
7.8.1 Engine Oil
7.8.2 Air Intake System
7.8.3 Tires
7.8.4 Hydraulic Oil
7.8.5 Brake System
7.8.6 Engine Cooling System
7.8.7 Windshield Washer System
7.8.8 Cab Air Filters
AdBlue
7.9.1 Proper Use
7.9.2 Specifications
7.9.3 Tank Filling
7.9.4 After Run Indicator
7.9.5 AdBlue — Urea Quality
7.9.6 AdBlue — Urea Level
7.9.7 AdBlue — Urea Circuit Errors
Additional Checks and InformationGeneral
Troubleshooting
8.2.1 Engine
8.2.2 Hydraulic Transmission System
8.2.3 Brakes
8.2.4 Steering Wheel
8.2.5 Telescopic Boom
8.2.6 Turret Rotation
8.2.7 Warning Codes
Telehandler Storage
8.3.1 Long Period of Inactivity
8.3.2 Extended Period of Inactivity
8.3.3 Restarting the Telehandler
SpecificationsProduct Specifications
9.1.1 Dimensions
9.1.2 Performance
9.1.3 Engine
9.1.4 Weights
9.1.5 Electrical and Hydraulic System
9.1.6 Transmission
9.1.7 Axles
9.1.8 Acoustic Pressure
9.1.9 Acoustic Power
9.1.10 Vibration
9.1.11 Tires
9.1.12 Fluids
9.1.13 Environmental Conditions
9.1.14 Electromagnetic Interference
9.1.15 Radiation
Attachments Specifications
9.2.1 Counter Plate with Forks
9.2.2 Bucket
Definitions
- SuperPac Parts Manual
- StratoLift Parts Manual
