JLG Telehandler G5-18A Parts Manual 31211871
Brand: JLG
Type of Machine: Telehandler
Model: JLG G5-18A Telehandler
Part Number: 31211871
Publication Date: 2024
Number of Pages: 728 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. HOODS INSTALLATION
FIGURE 1-2. HOOD ASSEMBLY
FIGURE 1-3. PAD LOCK
FIGURE 1-4. TANK INSTALLATION
FIGURE 1-5. OIL TANK
FIGURE 1-6. FUEL TANK ASSEMBLY
FIGURE 1-7. FUEL CAP INSTALLATION
FIGURE 1-8. MIRROR INSTALLATION
FIGURE 1-9. REAR CONVEX MIRROR INSTALLATION
FIGURE 1-10. MIRROR ASSEMBLY (CONVEX)
FIGURE 1-11. BATTERY COVER INSTALLATION
FIGURE 1-12. REAR COVER PLATE INSTALLATION, (NO HITCH)
FIGURE 1-13. HITCH INSTALLATION
FIGURE 1-14. HITCH ASSEMBLY (FIXED)
FIGURE 1-15. HITCH INSTALLATION - CUNA-C
FIGURE 1-16. HITCH ASSEMBLY (CUNA-C)
FIGURE 1-17. LICENSE HOLDER INSTALLATION, LARGE
FIGURE 1-18. LIFT CYLINDER PROP SUPPORT
SECTION 2 - BOOMFIGURE 2-1. BOOM ASSEMBLY INSTALLATION, STD W/AUX
FIGURE 2-2. BOOM ASSEMBLY INSTALLATION, W/AUX FOR QS
FIGURE 2-3. BOOM INSTALLATION, W/O AUXILIARY HYDRAULICS
FIGURE 2-4. BOOM W/O AUXILIARY HYDRAULIC INSTALLATION
FIGURE 2-5. FORK LOCKING CYLINDER KIT
FIGURE 2-6. QUICK COUPLER INSTALLATION - MANUAL
FIGURE 2-7. COUPLER INSTALLATION, UNIVERSAL (MANUAL)
FIGURE 2-8. UNIVERSAL QUICK COUPLER ASSEMBLY
FIGURE 2-9. BOOM SIDE COVER INSTALLATION
SECTION 3 - ATTACHMENTSFIGURE 3-1. AUGER BIT (6INX4IN)
FIGURE 3-2. AUGER BIT (9INX4IN)
FIGURE 3-3. AUGER BIT (12INX4IN)
FIGURE 3-4. AUGER BIT (15INX4IN)
FIGURE 3-5. AUGER BIT (18INX4IN)
FIGURE 3-6. AUGER DRIVE ASSEMBLY, STANDARD
FIGURE 3-7. AUGER DRIVE ASSEMBLY, UNIVERSAL
FIGURE 3-8. BALE SPEAR ASSEMBLY, STANDARD
FIGURE 3-9. BALE SPEAR ASSEMBLY, UNIVERSAL
FIGURE 3-10. CARRIAGE ASSEMBLY, (50INCH/1270MM)
FIGURE 3-11. CARRIAGE ASSEMBLY, UNIVERSAL QUICK ATTACH, (48IN/1219.2MM)
FIGURE 3-12. CARRIAGE, SIDE TILT, (48IN)
FIGURE 3-13. CARRIAGE, SIDE TILT, UNIVERSAL QUICK ATTACH, (48IN)
FIGURE 3-14. CARRIAGE, SIDE SHIFT (48IN)
FIGURE 3-15. CARRIAGE, SIDE SHIFT, UNIVERSAL QUICK ATTACH, (48IN)
FIGURE 3-16. CARRIAGE ASSEMBLY - FORK POSITIONING STANDARD (48IN)
FIGURE 3-17. CARRIAGE ASSEMBLY - FORK POSITIONING UNIVERSAL (48IN)
FIGURE 3-18. LIGHT MATERIAL BUCKET, (72INCH) (1.0 YD³/0.76 M³)
FIGURE 3-19. LIGHT MATERIAL BUCKET, (72INCH) (1.7 YD³/1.29 M³)
FIGURE 3-20. MULTI-PURPOSE GRAPPLE BUCKET (1850MM) (ANSI - JLG)
FIGURE 3-21. UNIVERSAL HITCH ATTACHMENT
FIGURE 3-22. FORK 2.00X4X48 / 3800# CAPACITY
FIGURE 3-23. FORK MOUNTED HOOK (4 TON)
FIGURE 3-24. LIFTING HOOK ASSEMBLY, STANDARD
FIGURE 3-25. LIFTING HOOK ASSEMBLY, UNIVERSAL
FIGURE 3-26. BOLT-ON EDGE ASSEMBLY, 72"
FIGURE 3-27. HYDRAULIC QUICK SWITCH INSTALLATION
FIGURE 3-28. QUICK SWITCH ASSEMBLY
FIGURE 3-29. BLOCK VALVE ASSEMBLY
FIGURE 3-30. BASKET, PERSONNEL (1.2MX2.4M) (DOMESTIC)
FIGURE 3-31. BASKET, PERSONNEL (1.2MX2.4M) (ISO)
FIGURE 3-32. BASKET, PERSONNEL (1.2MX2.4M) (FRENCH)
FIGURE 3-33. FORK MOUNTED PLATFORM
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION
FIGURE 4-2. ENGINE INSTALLATION (Prior to SN 0160118026)
FIGURE 4-3. ENGINE INSTALLATION (SN 0160118026 to Present)
FIGURE 4-4. FLEX COUPLING ASSEMBLY
FIGURE 4-5. ENGINE MOUNT INSTALLATION
FIGURE 4-6. ENGINE MOUNT INSTALLATION, (HEATER)
FIGURE 4-7. ENGINE MOUNT INSTALLATION, (HEATER & A/C)
FIGURE 4-8. ENGINE (55.4KW - ULS)
FIGURE 4-9. ENGINE (55.4KW - LS)
FIGURE 4-10. FAN INSTALLATION
FIGURE 4-11. FAN INSTALLATION, REVERSING
FIGURE 4-12. RADIATOR INSTALLATION (Prior to SN 0160118026)
FIGURE 4-13. RADIATOR INSTALLATION (SN 0160118026 to Present)
FIGURE 4-14. RADIATOR LOWER HOSE ASSEMBLY
FIGURE 4-15. AIR CLEANER INSTALLATION
FIGURE 4-16. AIR CLEANER ASSEMBLY
FIGURE 4-17. AIR SHUT OFF VALVE INSTALLATION
FIGURE 4-18. RAIN CAP
FIGURE 4-19. PRECLEANER
FIGURE 4-20. EXHAUST INSTALLATION (ULS)
FIGURE 4-21. EXHAUST INSTALLATION (LS)
FIGURE 4-22. HYDROSTATIC DRIVE PUMP ASSEMBLY (Prior to SN 0160118026)
FIGURE 4-23. HYDROSTATIC DRIVE PUMP ASSEMBLY (SN 0160118026 to Present)
FIGURE 4-24. HEATER LINES INSTALLATION
FIGURE 4-25. LUBRICITY DOSER INSTALLATION (MIRROR)
FIGURE 4-26. LUBRICITY DOSER INSTALLATION (LIGHT & MIRROR)
FIGURE 4-27. QUICKFIT OIL CHANGE ASSEMBLY
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVETRAIN INSTALLATION
FIGURE 5-2. FRONT AXLE ASSEMBLY
FIGURE 5-3. FRONT AXLE
FIGURE 5-4. FRONT AXLE, CENTRAL HOUSING
FIGURE 5-5. FRONT AXLE, DIFFERENTIAL
FIGURE 5-6. FRONT AXLE, HUB REDUCTION
FIGURE 5-7. FRONT AXLE, BRAKES
FIGURE 5-8. FRONT AXLE, STEERING
FIGURE 5-9. REAR AXLE ASSEMBLY
FIGURE 5-10. REAR AXLE
FIGURE 5-11. REAR AXLE, CENTRAL HOUSING
FIGURE 5-12. REAR AXLE, DIFFERENTIAL
FIGURE 5-13. REAR AXLE, HUB REDUCTION
FIGURE 5-14. REAR AXLE, STEERING
FIGURE 5-15. REAR AXLE, TRUNION
FIGURE 5-16. DIFFERENTIAL KIT
FIGURE 5-17. STEERING CASE KIT (LF/RR)
FIGURE 5-18. STEERING CASE KIT (RF/LR)
FIGURE 5-19. RING GEAR SUPPORT KIT
FIGURE 5-20. PLANET GEAR CARRIER KIT
FIGURE 5-21. TIRE/WHEEL SET, CAMSO (AIR 12-16.5 - 12 PLY)
FIGURE 5-22. RIGHT TIRE/WHEEL ASSEMBLY, CAMSO (AIR 12-16.5 - 12 PLY)
FIGURE 5-23. LEFT TIRE/WHEEL ASSEMBLY, CAMSO (AIR 12-16.5 - 12 PLY)
FIGURE 5-24. TIRE/WHEEL SET (AIR 14-17.5 - 12 PLY)
FIGURE 5-25. RIGHT TIRE/WHEEL ASSEMBLY (AIR 14-17.5 - 12 PLY)
FIGURE 5-26. LEFT TIRE/WHEEL ASSEMBLY (AIR 14-17.5 - 12 PLY)
FIGURE 5-27. TIRE/WHEEL SET, CAMSO (FOAM 12-16.5 - 12 PLY)
FIGURE 5-28. TIRE/WHEEL SET (FOAM 12-16.5 - 14 PLY)
FIGURE 5-29. TIRE/WHEEL SET (SOLID 33X12-20 - NM)
FIGURE 5-30. TIRE/WHEEL SET, AG (AIR 10.5-18 - 16 PR)
FIGURE 5-31. RIGHT TIRE/WHEEL ASSEMBLY, AG (AIR 10.5-18 - 16 PR)
FIGURE 5-32. LEFT TIRE/WHEEL ASSEMBLY, AG (AIR 10.5-18 - 16 PR)
FIGURE 5-33. FENDER INSTALLATION
FIGURE 5-34. FENDER ASSEMBLY
FIGURE 5-35. TIRE/WHEEL SET 33X16LL19.5 TURF/SAND
FIGURE 5-36. ASSEMBLY, TIRE/WHEEL 33X16LL19.5 TURF/SAND
SECTION 6 - CABFIGURE 6-1. CAB INSTALLATION
FIGURE 6-2. OPEN CAB INSTALLATION (ANSI - FIXED STEERING)
FIGURE 6-3. OPEN CAB INSTALLATION (ANSI - TILT STEERING)
FIGURE 6-4. ENCLOSED CAB INSTALLATION (ANSI - TILT STEERING) (HEAT)
FIGURE 6-5. ENCLOSED CAB INSTALLATION (ANSI - TILT STEERING) (HEAT & A/C)
FIGURE 6-6. ENCLOSED CAB INSTALLATION (LSI - TILT STEERING) (HEAT)
FIGURE 6-7. ENCLOSED CAB INSTALLATION (LSI - TILT STEERING) (HEAT & A/C)
FIGURE 6-8. COMMON CAB INSTALLATION
FIGURE 6-9. CAB COMMON COMPONENTS, ENCLOSED
FIGURE 6-10. CAB GLASS INSTALLATION, OPEN
FIGURE 6-11. CAB GLASS INSTALLATION, ENCLOSED
FIGURE 6-12. REAR WINDOW ASSEMBLY
FIGURE 6-13. DOOR ASSEMBLY INSTALLATION
FIGURE 6-14. JLG COMMON INSTALLATION
FIGURE 6-15. SEAT RISER COVER INSTALLATION
FIGURE 6-16. SEAT RISER COVER INSTALLATION, HVAC
FIGURE 6-17. OPEN CAB COMMON COMPONENTS INSTALLATION
FIGURE 6-18. DASH INSTALLATION, OPEN CAB
FIGURE 6-19. DASH INSTALLATION, ENCLOSED CAB
FIGURE 6-20. RIGHT SIDE CONSOLE
FIGURE 6-21. NA COMMON INSTALLATION
FIGURE 6-22. NA COMMON COMPONENTS INSTALLATION (LSI)
FIGURE 6-23. FRONT WIPER ASSSEMBLY
FIGURE 6-24. WASHER TANK W/PUMP INSTALLATION
FIGURE 6-25. ROOF/REAR WIPER INSTALLATION
FIGURE 6-26. AUX WIPER ASSEMBLY
FIGURE 6-27. SEAT ASSEMBLY - CLOTH (BLACK SEAT BELT)
FIGURE 6-28. SEAT ASSEMBLY - CLOTH (ORANGE SEAT BELT)
FIGURE 6-29. SEAT, LSI
FIGURE 6-30. SEAT BELT INSTALLATION (3 INCH)
FIGURE 6-31. SEAT BELT INSTALLATION, LSI (3 INCH)
FIGURE 6-32. CONTROL COVER INSTALLATION
FIGURE 6-33. HEATER INSTALLATION (CAB PARTS)
FIGURE 6-34. HEATER AND A/C INSTALLATION (CAB PARTS)
FIGURE 6-35. HEATER ASSEMBLY, 3 SPEED
FIGURE 6-36. HEATER AND A/C ASSEMBLY, 3 SPEED
FIGURE 6-37. HEATER
FIGURE 6-38. HEATER AND A/C
FIGURE 6-39. A/C KIT
FIGURE 6-40. A/C CONDENSER INSTALLATION
FIGURE 6-41. CONDENSER
FIGURE 6-42. OVERHEAD CONSOLE INSTALLATION
FIGURE 6-43. OVERHEAD CONSOLE INSTALLATION (OPEN)
FIGURE 6-44. FRONT FOPS INSTALLATION
FIGURE 6-45. OVERHEAD CONSOLE INSTALLATION (LSI)
FIGURE 6-46. CAB FENDER INSTALLATION
FIGURE 6-47. CAB GUARD INSTALLATION (TOP)
FIGURE 6-48. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-49. REAR WINDOW ENTRY KIT INSTALLATION (ANSI)
FIGURE 6-50. REAR WINDOW ENTRY KIT INSTALLATION (ENGLISH/FRENCH)
FIGURE 6-51. REAR WINDOW ENTRY KIT INSTALLATION (ISO)
FIGURE 6-52. FIRE EXTINQUISHER INSTALLATION
FIGURE 6-53. WASHER FLUID TANK ASSEMBLY
FIGURE 6-54. EMERGENCY ENTRY/EXIT WINDOW
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL ASSEMBLY
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL ASSEMBLY
FIGURE 7-4. MASTER CYLINDER VALVE ASSEMBLY
FIGURE 7-5. PARK BRAKE VALVE INSTALLATION
FIGURE 7-6. PARK BRAKE VALVE INSTALLATION (EURO)
FIGURE 7-7. PARK BRAKE VALVE ASSEMBLY (EURO)
FIGURE 7-8. FIXED STEERING COLUMN INSTALLATION
FIGURE 7-9. FIXED STEERING COLUMN
FIGURE 7-10. TILT STEERING COLUMN INSTALLATION
FIGURE 7-11. TILT STEERING COLUMN
FIGURE 7-12. HYDRAULIC CONTROLLER ASSEMBLY
FIGURE 7-13. HEATER CONTROL SWITCH
FIGURE 7-14. HVAC CONTROL SWITCH
FIGURE 7-15. BOOM JOYSTICK
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. HOSE INSTALLATION (ANSI)
FIGURE 8-2. HOSE INSTALLATION (CE)
FIGURE 8-3. HOSE INSTALLATION - BOOM
FIGURE 8-4. HOSE INSTALLATION - BOOM WITH QS
FIGURE 8-5. HOSE INSTALLATION - BOOM AUXILIARY
FIGURE 8-6. HOSE INSTALLATION - CAB (ANSI) (Prior to SN 0160118026)
FIGURE 8-7. HOSE INSTALLATION - CAB (ANSI) (SN 0160118026 to Present)
FIGURE 8-8. CAB HYDRAULICS INSTALLATION (LSI) (Prior to SN 0160118026)
FIGURE 8-9. HOSE INSTALLATION - CAB (CE) (SN 0160118026 to Present)
FIGURE 8-10. FRAME HYDRAULIC HOSE INSTALLATION (Prior to SN 0160118026)
FIGURE 8-11. HOSE INSTALLATION - FRAME (SN 0160118026 to Present)
FIGURE 8-12. HOSE INSTALLATION - REAR OUTLET
FIGURE 8-13. BREATHER INSTALLATION - HYDRAULIC TANK
FIGURE 8-14. BREATHER INSTALLATION - HYDRAULIC TANK (A/C)
FIGURE 8-15. FILTER ASSEMBLY - HYDRAULIC
FIGURE 8-16. FILTER ASSEMBLY - IMPLEMENT PUMP
FIGURE 8-17. REMOTE GREASE INSTALLATION
FIGURE 8-18. VALVE INSTALLATION (ANSI)
FIGURE 8-19. VALVE INSTALLATION (CE)
FIGURE 8-20. VALVES INSTALLATION (Prior to SN 0160118026)
FIGURE 8-21. VALVES INSTALLATION (SN 0160118026 to Present)
FIGURE 8-22. VALVE & FITTINGS ASSEMBLY - BRAKE
FIGURE 8-23. VALVE & FITTINGS ASSEMBLY - DIVERTER (REAR)
FIGURE 8-24. VALVE ASSEMBLY - DIVERTER
FIGURE 8-25. VALVE & FITTINGS ASSEMBLY - MAIN CONTROL
FIGURE 8-26. VALVE & FITTINGS ASSEMBLY - PARK BRAKE
FIGURE 8-27. VALVE & FITTINGS ASSEMBLY - PILOT (ANSI)
FIGURE 8-28. VALVE & FITTINGS ASSEMBLY - PILOT (CE)
FIGURE 8-29. VALVE ASSEMBLY - PILOT (ANSI)
FIGURE 8-30. VALVE ASSEMBLY - PILOT (CE)
FIGURE 8-31. VALVE & FITTINGS ASSEMBLY - PRIORITY
FIGURE 8-32. VALVE & FITTINGS ASSEMBLY - STEERING
FIGURE 8-33. VALVE & FITTINGS ASSEMBLY - STEERING SELECT
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. CYLINDER INSTALLATION - BOOM (ANSI)
FIGURE 9-2. CYLINDER INSTALLATION - BOOM (CE)
FIGURE 9-3. CYLINDER ASSEMBLY - BOOM EXTEND/RETRACT
FIGURE 9-4. CYLINDER ASSEMBLY - BOOM LIFT (ANSI)
FIGURE 9-5. CYLINDER ASSEMBLY - BOOM LIFT (CE)
FIGURE 9-6. CYLINDER ASSEMBLY - BOOM LIFT (CE)
FIGURE 9-7. CYLINDER ASSEMBLY - CARRIAGE TILT
FIGURE 9-8. CYLINDER ASSEMBLY - COMPENSATION
FIGURE 9-9. CYLINDER ASSEMBLY - FORK LOCKING
FIGURE 9-10. CYLINDER ASSEMBLY - FORK LOCKING
FIGURE 9-11. CYLINDER ASSEMBLY - FORK POSITIONING
FIGURE 9-12. CYLINDER ASSEMBLY - SIDE SHIFT
FIGURE 9-13. CYLINDER ASSEMBLY - SIDE SHIFT
FIGURE 9-14. CYLINDER ASSEMBLY - TILT
FIGURE 9-15. MOTOR ASSEMBLY - FAN
FIGURE 9-16. MOTOR ASSEMBLY - FAN REVERSING
FIGURE 9-17. MOTOR ASSEMBLY - HYDROSTATIC
FIGURE 9-18. PUMP ASSEMBLY
FIGURE 9-19. PUMP ASSEMBLY HTDROSTATIC (Prior to SN 0160118026)
FIGURE 9-20. PUMP ASSEMBLY HTDROSTATIC (SN 0160118026 to Present)
FIGURE 9-21. VALVE ASSEMBLY - AIR SHUT-OFF VALVE
FIGURE 9-22. VALVE ASSEMBLY - BRAKE MASTER CYLINDER
FIGURE 9-23. VALVE ASSEMBLY - MAIN CONTROL
FIGURE 9-24. VALVE ASSEMBLY - PARK BRAKE RELEASE
FIGURE 9-25. VALVE ASSEMBLY - PARK BRAKE RELEASE (HYDRAULIC)
FIGURE 9-26. VALVE ASSEMBLY - STEERING SELECT
SECTION 10 - ELECTRICALFIGURE 10-1. MAIN ELECTRICAL INSTALLATION (Prior to SN 0160118026)
FIGURE 10-2. MAIN ELECTRICAL INSTALLATION (SN 0160118026 to Present)
FIGURE 10-3. ASOV HARNESS (CAB)
FIGURE 10-4. ASOV HARNESS (FRAME)
FIGURE 10-5. ATTACHMENT HYDRAULIC QUICK SWITCH JUMPER SWITCH HARNESS
FIGURE 10-6. BATTERY INSTALLATION
FIGURE 10-7. BATTERY DISCONNECT SHIELD INSTALLATION
FIGURE 10-8. BOOM AUXILIARY HARNESS
FIGURE 10-9. BOOM SENSOR INSTALLATION
FIGURE 10-10. BOOM SENSOR ASSEMBLY
FIGURE 10-11. BOOM SENSOR HARNESS
FIGURE 10-12. CAB HARNESS
FIGURE 10-13. CAB A/C CONDENSER HANRESS
FIGURE 10-14. CAB JUMPER HARNESS
FIGURE 10-15. CAB MODE SELECT HARNESS
FIGURE 10-16. CAB ROOF HARNESS
FIGURE 10-17. CAMERA INSTALLATION - BACK-UP
FIGURE 10-18. CAMERA HARNESS - BACK-UP
FIGURE 10-19. ELECTRICAL HARNESS CAPS INSTALLATION
FIGURE 10-20. ENGINE HARNESS
FIGURE 10-21. ENGINE ALTERNATOR CHARGING HARNESS
FIGURE 10-22. ENGINE BLOCK HEATER INSTALLATION (ANSI)
FIGURE 10-23. ENGINE BLOCK HEATER INSTALLATION (CE)
FIGURE 10-24. ENGINE BLOCK HEATER INSTALLATION (LS)
FIGURE 10-25. ENGINE START SWITCH JUMPER HARNESS
FIGURE 10-26. FRAME HARNESS
FIGURE 10-27. FRAME OPTIONS HARNESS INSTALLATION
FIGURE 10-28. FRAME OPTIONS BASE JUMPER HARNESS
FIGURE 10-29. FRAME OPTIONS FUNCTION JUMPER HARNESS
FIGURE 10-30. FRAME OPTIONS HARNESS INSTALLATION (ANSI)
FIGURE 10-31. FRAME OPTIONS HARNESS INSTALLATION (CE)
FIGURE 10-32. FRAME OPTION HARNESS
FIGURE 10-33. LIGHTS - DRIVE LIGHTS INSTALLATION
FIGURE 10-34. LIGHTS - ROADLIGHTS INSTALLATION (ANSI)
FIGURE 10-35. LIGHTS - ROADLIGHTS INSTALLATION (LSI)
FIGURE 10-36. LIGHTS - ROADLIGHTS INSTALLATION (LH DIP)
FIGURE 10-37. LIGHTS - ROADLIGHTS JUMPER HARNESS
FIGURE 10-38. LIGHTS - TAILLIGHTS INSTALLATION (LH)
FIGURE 10-39. LIGHTS - TAILLIGHTS INSTALLATION (RH)
FIGURE 10-40. LIGHTS - WORKLIGHTS INSTALLATION (BOOM)
FIGURE 10-41. LIGHTS - WORKLIGHTS INSTALLATION (BOOM) (LED)
FIGURE 10-42. LIGHTS - WORKLIGHTS HARNESS (BOOM)
FIGURE 10-43. LIGHTS - WORKLIGHTS HARNESS (ENCLOSED CAB)
FIGURE 10-44. LIGHTS - WORKLIGHTS HARNESS (OPEN CAB)
FIGURE 10-45. LIGHTS - WORKLIGHTS JUMPER HARNESS (BOOM)
FIGURE 10-46. LIGHTS - WORKLIGHTS JUMPER HARNESS (BOOM)
FIGURE 10-47. LIGHTS - WORKLIGHTS PROXIMITY SENSOR HARNESS
FIGURE 10-48. REVERSE SENSING SYSTEM INSTALLATION
FIGURE 10-49. REVERSE SENSOR HARNESS
FIGURE 10-50. SPEED SENSOR JUMPER HARNESS
FIGURE 10-51. TELEMATICS/CLEARSKY HARNESS - 3-WIRE
FIGURE 10-52. TELEMATICS/CLEARSKY HARNESS - 4G CANBUS
FIGURE 10-53. TELEMATICS/CLEARSKY READY HARNESS
FIGURE 10-54. TELEMATICS/CLEARSKY INSTALLATION - SMART FLEET
FIGURE 10-55. WORKLIGHTS INSTALLATION
FIGURE 10-56. WORKLIGHTS INSTALLATION
SECTION 11 - DECALSFIGURE 11-1. DECAL INSTALLATION
FIGURE 11-2. DECAL INSTALLATION, (ANSI)
FIGURE 11-3. DECAL INSTALLATION, (ISO)
FIGURE 11-4. DECAL INSTALLATION (ENGLISH/FRENCH)
FIGURE 11-5. LOAD CHART MOUNT
FIGURE 11-6. CAPACITY CHART
FIGURE 11-7. CAPACITY CHART (UNIVERSAL QUICK SWITCH)
FIGURE 11-8. CAPACITY CHART - METRIC
FIGURE 11-9. CAPACITY CHART (UNIVERSAL QUICK SWITCH - METRIC)
FIGURE 11-10. MACHINE DECAL (ULS - ANSI)
FIGURE 11-11. MACHINE DECAL (ULS - ISO)
FIGURE 11-12. MACHINE DECAL (ULS - ENGLISH/FRENCH)
FIGURE 11-13. MACHINE DECAL (LS)
FIGURE 11-14. REVERSE SENSOR SYSTEM DECAL (ENGLISH)
FIGURE 11-15. REVERSE SENSING SYSTEM DECAL, (ENGLISH/FRENCH)
FIGURE 11-16. REVERSE SENSING SYSTEM DECAL (ISO)
FIGURE 11-17. DECAL INSTALLATION - CLEARSKY CS550 BEACON
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
