Hyundai
86
176,834
JLG Telehandler EAG313 Service Manual 3122327300 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG EAG313 Telehandler
Part Number: 3122327300
Publication Date: 2025
Number of Pages: 438 Pages
Coverpage
Effectivity Page
Read This First
Modifications​
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
General Machine Information & Specifications
Specifications​
2.1.1 Travel Speeds​
2.1.2 Hydraulic Cylinder Performance​
2.1.3 Cylinder Drift​
2.1.4 Battery 48 V​
2.1.5 Battery 12 V​
2.1.6 Battery Charger​
2.1.7 Tires​
2.1.8 Dimensions​
2.1.9 Machine Specifications​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Lubrication Schedules​
2.4.6 Fluids​
2.4.7 Capacities​
ClearSky Smart Fleet​
2.5.1 General​
2.5.2 ClearSky Smart Fleet™ – Access Control​
Maintenance & Inspection Schedules
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Every 8 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 Every 200 Hours​
3.3.5 Every 400 Hours​
3.3.6 Every 600 Hours​
3.3.7 Every 1000 Hours​
3.3.8 Every 1500 Hours or 2 Years​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Service Brake Bleeding​
Boom Inspection and Maintenance​
3.7.1 Boom Wear Pads​
Hydraulic Filter Replacement​
3.8.1 Removal​
3.8.2 Installation​
Battery Charger​
3.9.1 General Information​
3.9.2 Input and Output Cables​
3.9.3 Auxiliary Inputs and Outputs Cable​
3.9.4 Alarms​
Testing, Calibrations, & Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Thread Locking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
Calibration Procedures​
4.3.1 Load Stability Indicator (LSI) System Calibration​
4.3.2 Boom Sensor Calibration​
Special Procedures​
4.4.1 Emergency Lowering Procedure​
4.4.2 Towing a Disabled Machine​
4.4.3 Pressure Checks and Adjustments​
4.4.4 Cylinder Drift Test​
4.4.5 Hydraulic Circuits​
4.4.6 Pressure Specification​
System Software
Load Stability Indicator​
5.1.1 LSI Sensor​
5.1.2 Boom Sensor​
5.1.3 Troubleshooting​
Battery Programming​
Diagnostics​
5.3.1 Diagnostic Screens on Multifunction Display​
5.3.2 Battery Diagnostics​
5.3.3 Indicators​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction​
Machine Fault Codes​
Transmission Fault Codes​
Hydraulic Pump Fault Codes​
Battery and Battery Charger Fault Codes​
6.5.1 Battery Fault Codes​
6.5.2 MAST Charger Fault Codes​
6.5.3 SLAV Charger Fault Codes​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
8.3.1 General Overview​
Harness Layouts​
Board Layouts​
8.5.1 Cab Fuses​
8.5.2 Relays​
Wheels​
9.1.1 Wheel and Tire Assembly​
Drive Assembly​
9.2.1 Axle Assembly and Drive Shaft Troubleshooting​
9.2.2 Axle​
9.2.3 Drive Shaft​
Boom​
9.3.1 Component Terminology​
9.3.2 Troubleshooting​
9.3.3 Boom Systems​
9.3.4 Hydraulic Coupler​
9.3.5 Forks​
9.3.6 Boom Prop​
9.3.7 Boom Wear Pad Installation and Lubrication​
9.3.8 Boom Proximity Sensor​
Cab​
9.4.1 Cab​
9.4.2 Steering Wheel​
9.4.3 Steering Column and Steering Valve​
9.4.4 Brake System​
9.4.5 Throttle Pedal​
9.4.6 Joystick Assembly​
9.4.7 Front Wiper Assembly​
9.4.8 Windshield Wiper Fluid Reservoir​
9.4.9 Heater System​
9.4.10 Multifunction Display​
9.4.11 ON-OFF key Switch​
9.4.12 Dash Switches​
9.4.13 Hydraulic Tank​
Transmission​
9.5.1 Electric Drive Motor​
9.5.2 Gearbox​
Hydraulic Valves​
9.6.1 Hydraulic Function Manifold​
9.6.2 4 Wheel / 2 Wheel Drive Selector Valve and Park Brake Valve​
9.6.3 Hydraulic Filter (Spin-On)​
Hydraulic Cylinders​
9.7.1 Lift Cylinder Assembly​
9.7.2 Compensation Cylinder​
9.7.3 Tilt Cylinder​
Hydraulic Pumps​
9.8.1 Function, Steering, 2WD / 4WD Drive and Park Brake Pump​
Electrical Components​
9.9.1 Battery Disconnect/Connect​
9.9.2 Battery 48 V​
9.9.3 Battery 12 V​
Counterweight​
9.10.1 Removal​
9.10.2 Installation​
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Axle Assembly​
10.1.2 Transmission Assembly​
Boom​
10.2.1 Disassembly​
10.2.2 Assembly​
Cab​
Transmission​
10.4.1 Electric Drive Motor​
10.4.2 Gearbox​
10.4.3 Gear Pump​
10.5.1 General Cylinder Disassembly​
10.5.2 Hydraulic Cylinder Repair Information​
Hydraulic Valves​
10.6.1 Hydraulic Function Manifold​
Hydraulic Components​
10.7.1 Hydraulic Oil Reservoir​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
Electrical Schematics​
