JLG Telehandler AG823 AG832 AG925 Service Manual 3122554900 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG AG823, AG832, AG925 Telehandler
Part Number: 3122554900
Publication Date: 2025
Number of Pages: 642 Pages
Coverpage
Effectivity Page
Read This First
Brand: JLG
Coverpage
Effectivity Page
Read This First
Modifications
Machine Configuration
SafetyGeneral
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Travel Speed
2.1.2 Hydraulic Cylinder Performance
2.1.3 Cylinder Drift
2.1.4 Steering Angle Specification
2.1.5 Electrical System
2.1.6 Engine Performance Specifications
2.1.7 Tires
2.1.8 Transmission Performance Specifications
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
After Treatment System
ClearSky Smart Fleet
2.6.1 General
2.6.2 ClearSky Smart Fleet™ – Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Every 10 Hours
3.3.2 First 50 Hours
3.3.3 Every 50 Hours
3.3.4 First 250 Hours
3.3.5 Every 250 Hours
3.3.6 Every 500 Hours
3.3.7 Every 750 Hours
3.3.8 Every 1000 Hours
3.3.9 Every 1500 Hours
3.3.10 Every 3000 Hours
3.3.11 Every 3000 Hours or 2 Years
3.3.12 Every 6000 Hours or 4 Years
3.3.13 Every 10000 Hours
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Service Brake Bleeding
DEF Tank Inspection
Boom Inspection and Maintenance
3.8.1 Boom Wear Pads
Hydraulic Filter Replacement
3.9.1 Hydraulic Filter Removal
3.9.2 Hydraulic Filter Installation
Transmission Fluid/Filter Replacement
Transmission Fluid Level Check
Brake Inspection
Specification and Maintenance Information
3.13.1 Axle
3.13.2 Transmission
3.13.3 Engine
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Thread Locking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 Charging Circuit
Calibration Procedures
4.3.1 Analyzer
4.3.2 Boom Angle Sensor Calibration
4.3.3 Load Stability Indicator (LSI) System Calibration
4.3.4 LMIS (Load Moment Indicator System) Calibration
4.3.5 Brake Pedal Calibration
4.3.6 Reversing Camera Calibration
Special Procedures
4.4.1 Emergency Boom Lowering Procedure
4.4.2 Towing a Disabled Machine
4.4.3 Charge Air Cooler (CAC) Hose Draining
4.4.4 Hydraulic Oil Reservoir
4.4.5 Diesel Exhaust Fluid (DEF) System Cleaning
4.4.6 Fuel Tank Cleaning and Drying
4.4.7 Accumulators
4.4.8 Hydraulic Pressure Settings and Adjustments
4.4.9 Cylinder Checking Procedure
4.4.10 Cylinder Drift Test
4.4.11 Hydraulic Circuits
4.4.12 Hydraulic Pressures
4.4.13 Pressure Specifications
4.4.14 Steering Angle Adjustment
4.4.15 Steering Cylinders
4.4.16 Extend/Retract Cylinder Bleeding Procedure - AG832
System SoftwareLoad Stability Indicator (LSI) (If Equipped)
5.1.1 Load Stability Indicator
5.1.2 LSI Sensor
Analyzer
5.2.1 Machine Data Access
5.2.2 JLG Hand Held Analyzer
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer
5.2.4 PC Analyzer/Loglifter
5.2.5 Analyzer Software (Version P27.0)
Access Level
Diagnostics (Software Version P27.0)
Machine Setup (Software Version P27.0)
Personalities (Software Version P27.0)
Operator Tools (Software Version P27.0)
Calibrations (Software Version P27.0)
Premium Display (If Equipped)
5.9.1 Home Screen and Touch Screen Soft Buttons
5.9.2 Main Menu
5.9.3 Reprogramming Menu
Reprogramming the Premium Display
5.10.1 Software Installation
5.10.2 Load Charts Programming
5.10.3 Premium Display Reassembly
ClearSky (CS550) Configuration and Troubleshooting
5.11.1 ClearSky Smart FleetTM CS550 Configuration
5.11.2 Troubleshooting
Fault CodesIntroduction
Engine Diagnostic
6.2.1 EMR5 Diagnosis and Error codes
Fault Codes - Help Comment (00x)
Fault Codes - Power-Up (21x)
Fault Codes - Ground Inputs (23x)
Fault Codes - Other Inputs (24x)
Fault Codes - Function Prevented (25x)
Fault Codes - Line Contactor, Open-Circuit (31x)
Fault Codes - Line Contactor, Short-Circuit (32x)
Fault Codes - Output Drivers (33x)
Fault Codes - Engine (43x)
Fault Codes - Battery Supply (44x)
Fault Codes - Transmission and Drive System (46x)
Fault Codes - Communications (66x)
Fault Codes - Telematics (68x)
Fault Codes - Tilt Sensor (81x)
Fault Codes - Envelope Control (84x)
Fault Codes - Load Moment (85x)
Fault Codes - Steering (86x)
Fault Codes - Service Required (87x)
Fault Codes - Hardware (99x)
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Component
7.3.1 AG823
7.3.2 AG832
7.3.3 AG925
Torque Values
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information (reference)
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
8.3.1 General Overview
Harness Layouts
Board Layouts
8.5.1 Cab Power Distribution Board
8.5.2 Frame Power Distribution Board
8.5.3 Option 1 Distribution Board
8.5.4 Option 2 Distribution Board
8.5.5 Engine Harness Fuses and Relays
Solenoids and Sensors and Senders
8.6.1 Transmission Solenoid Valves
8.6.2 Fuel Level Sender
Removal and InstallationWheels
9.1.1 Removing Wheel and Tire Assembly from Machine
9.1.2 Installing Wheel and Tire Assembly onto Machine
Drive Assembly
9.2.1 Axle Assembly and Drive Shaft Troubleshooting
9.2.2 Axle
9.2.3 Drive Shafts
9.2.4 Transmission Components
Boom
9.3.1 Boom System Component Terminology
9.3.2 Troubleshooting
9.3.3 Boom System
9.3.4 Accumulator
9.3.5 Manual Quick Coupler
9.3.6 Hydraulic Quick Coupler
9.3.7 Forks
9.3.8 Boom Prop (If Equipped)
9.3.9 Boom Wear Pad Installation, Lubrication
9.3.10 Boom Angle Sensor
9.3.11 Boom Retract Sensor
9.4.1 Serial Number Plate
9.4.2 Cab Removal/Installation
9.4.3 Steering Wheel
9.4.4 Service Brake
9.4.5 Brake Accumulator
9.4.6 Electronic Throttle Pedal
9.4.7 Joystick Assembly
9.4.8 Ignition Key Switch
9.4.9 Dash Switches
9.4.10 Front Windshield Wiper Motor
9.4.11 Rear Window Wiper Motor
9.4.12 Roof Window Wiper Motor
9.4.13 Washer Fluid Reservoir
9.4.14 Cab Heater and A/C (If Equipped)
9.4.15 Heater System (If equipped)
9.4.16 Heater/Air Conditioning System (If equipped)
9.4.17 Premium Display (If Equipped)
9.4.18 Reversing Camera
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Diesel Fuel
9.5.4 Engine Replacement
9.5.5 Surge Tank Cap
9.5.6 Thermostat Replacement
9.5.7 Engine Coolant Temperature Sensor
9.5.8 Radiator Assembly Replacement
9.5.9 Hydraulic Oil Reservoir Removal/ Installation
9.5.10 Diesel Exhaust Fluid (DEF) Tank
9.5.11 Diesel Exhaust Fluid (DEF) Filter
9.5.12 Diesel Exhaust Fluid (DEF) Pump Filter
9.5.13 Fuel Tank
9.5.14 Engine Exhaust System (ULS)
9.5.15 Engine Exhaust System (LS)
9.5.16 Air Cleaner Assembly
9.5.17 Starter
9.5.18 Alternator
9.5.19 Air Conditioner (AC) Compressor (If Equipped)
9.6.1 Component Terminology
9.6.2 Transmission Serial Number
9.6.3 Transmission Removal/Installation
9.6.4 Reverse Alarm
9.6.5 Torque Converter Diaphragm
9.6.6 Transmission Oil Temperature Sensor
9.6.7 Transmission Mounted Speed Sensor
Hydraulic Cylinders
9.7.1 General Cylinder Instructions
9.7.2 Steering Cylinders
Hydraulic Valves
9.8.1 Main Control Valve
9.8.2 Priority Valve
9.8.3 Steering Column/Orbital Valve
9.8.4 Steering Orbital Valve
9.8.5 Steer Select Valve
Hydraulic Pumps
9.9.1 Implement Pump
Electrical Components
9.10.1 Battery
9.10.2 Electrical Master Switch
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyBoom
10.1.1 Boom Assembly Maintenance - AG823/AG925
10.1.2 Boom Assembly Maintenance - AG832
10.1.3 Third Boom Section Removal/Installation Only - AG832
Drive Assembly
10.2.1 Axle Assembly
10.2.2 Transmission Assembly
Engine Components
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
10.4.3 Diesel Exhaust Fluid (DEF) Tank Header Element Cleaning
10.4.4 Diesel Exhaust Fluid (DEF) Tank
10.5.1 Implement Pump
Hydraulic Cylinders
10.6.1 General Cylinder Instruction
10.6.2 Hydraulic Cylinder Repair Information
Hydraulic Valves
10.7.1 Main Control Valve
10.7.2 Priority Valve
10.7.3 Steer Select Valve
Hydraulic Components
10.8.1 Hydraulic Oil Tank
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
