Hyundai
86
176,834
JLG Telehandler AG823 AG832 AG925 Service Manual 3122311600 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG AG823, AG832, AG925 Telehandler
Part Number: 3122311600
Publication Date: 2025
Number of Pages: 638 Pages
Coverpage
Effectivity Page
Read This First
Modifications​
Machine Configuration​
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Travel Speed​
2.1.2 Hydraulic Cylinder Performance​
2.1.3 Cylinder Drift​
2.1.4 Steering Angle Specification​
2.1.5 Electrical System​
2.1.6 Engine Performance Specifications​
2.1.7 Tires​
2.1.8 Transmission Performance Specifications​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
After Treatment System​
ClearSky Smart Fleet​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ – Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Every 10 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 First 250 Hours​
3.3.5 Every 250 Hours​
3.3.6 Every 500 Hours​
3.3.7 Every 750 Hours​
3.3.8 Every 1000 Hours​
3.3.9 Every 1500 Hours​
3.3.10 Every 3000 Hours​
3.3.11 Every 3000 Hours or 2 Years​
3.3.12 Every 6000 Hours or 4 Years​
3.3.13 Every 10000 Hours​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Service Brake Bleeding​
DEF Tank Inspection​
Boom Inspection and Maintenance​
3.8.1 Boom Wear Pads​
Hydraulic Filter Replacement​
3.9.1 Hydraulic Filter Removal​
3.9.2 Hydraulic Filter Installation​
Transmission Fluid/Filter Replacement​
Transmission Fluid Level Check​
Brake Inspection​
Specification and Maintenance Information​
3.13.1 Axle​
3.13.2 Transmission​
3.13.3 Engine​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Thread Locking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 Charging Circuit​
Calibration Procedures​
4.3.1 Analyzer​
4.3.2 Boom Angle Sensor Calibration​
4.3.3 Load Stability Indicator (LSI) System Calibration​
4.3.4 LMIS (Load Moment Indicator System) Calibration​
4.3.5 Brake Pedal Calibration​
4.3.6 Reversing Camera Calibration​
Special Procedures​
4.4.1 Emergency Boom Lowering Procedure​
4.4.2 Towing a Disabled Machine​
4.4.3 Charge Air Cooler (CAC) Hose Draining​
4.4.4 Hydraulic Oil Reservoir​
4.4.5 Diesel Exhaust Fluid (DEF) System Cleaning​
4.4.6 Fuel Tank Cleaning and Drying​
4.4.7 Accumulators​
4.4.8 Hydraulic Pressure Settings and Adjustments​
4.4.9 Cylinder Checking Procedure​
4.4.10 Cylinder Drift Test​
4.4.11 Hydraulic Circuits​
4.4.12 Hydraulic Pressures​
4.4.13 Pressure Specifications​
4.4.14 Steering Angle Adjustment​
4.4.15 Steering Cylinders​
4.4.16 Extend/Retract Cylinder Bleeding Procedure - AG832​
System Software
Load Stability Indicator (LSI) (If Equipped)​
5.1.1 Load Stability Indicator​
5.1.2 LSI Sensor​
Analyzer​
5.2.1 Machine Data Access​
5.2.2 JLG Hand Held Analyzer​
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer​
5.2.4 PC Analyzer/Loglifter​
5.2.5 Analyzer Software (Version P26.0)​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostics​
5.3.3 Machine Set-up​
5.3.4 Personalities (Software Version P26.0)​
5.3.5 Operator Tools​
5.3.6 Calibrations​
Multifunction display (If Equipped)​
5.4.1 Technical Specification​
5.4.2 Multifunction Display and Control Buttons​
5.4.3 Main Menu​
5.4.4 Calibrations​
5.4.5 Setup and Maintenance​
5.4.6 Troubleshooting​
Premium Display (If Equipped)​
5.5.1 Home Screen and Touch Screen Soft Buttons​
5.5.2 Main Menu​
5.5.3 Reprogramming Menu​
Reprogramming the Premium Display​
5.6.1 Software Installation​
5.6.2 Load Charts Programming​
5.7.1 ClearSky Smart FleetTM CS550 Configuration​
5.7.2 Troubleshooting​
Fault Codes
Introduction​
Engine Diagnostic​
6.2.1 EMR5 Diagnosis and Error codes​
Machine Fault Codes​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
7.3.1 AG823​
7.3.2 AG832​
7.3.3 AG925​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
General Information (reference)​
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
8.3.1 General Overview​
Harness Layouts​
Board Layouts​
8.5.1 Cab Power Distribution Board​
8.5.2 Frame Power Distribution Board​
8.5.3 Option 1 Distribution Board​
8.5.4 Option 2 Distribution Board​
8.5.5 Engine Harness Fuses and Relays​
Solenoids and Sensors and Senders​
8.6.1 Transmission Solenoid Valves​
8.6.2 Fuel Level Sender​
Wheels​
9.1.1 Removing Wheel and Tire Assembly from Machine​
9.1.2 Installing Wheel and Tire Assembly onto Machine​
Drive Assembly​
9.2.1 Axle Assembly and Drive Shaft Troubleshooting​
9.2.2 Axle​
9.2.3 Drive Shafts​
9.2.4 Transmission Components​
Boom​
9.3.1 Boom System Component Terminology​
9.3.2 Troubleshooting​
9.3.3 Boom System​
9.3.4 Accumulator​
9.3.5 Manual Quick Coupler​
9.3.6 Hydraulic Quick Coupler​
9.3.7 Forks​
9.3.8 Boom Prop (If Equipped)​
9.3.9 Boom Wear Pad Installation, Lubrication​
9.3.10 Boom Angle Sensor​
9.3.11 Boom Retract Sensor​
Cab​
9.4.1 Serial Number Plate​
9.4.2 Cab Removal/Installation​
9.4.3 Steering Wheel​
9.4.4 Service Brake​
9.4.5 Brake Accumulator​
9.4.6 Electronic Throttle Pedal​
9.4.7 Joystick Assembly​
9.4.8 Ignition Key Switch​
9.4.9 Dash Switches​
9.4.10 Front Windshield Wiper Motor​
9.4.11 Rear Window Wiper Motor​
9.4.12 Roof Window Wiper Motor​
9.4.13 Washer Fluid Reservoir​
9.4.14 Cab Heater and A/C (If Equipped)​
9.4.15 Heater System (If equipped)​
9.4.16 Heater/Air Conditioning System (If equipped)​
9.4.17 Multifunction Display (If Equipped)​
9.4.18 Premium Display (If Equipped)​
9.4.19 Reversing Camera​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Diesel Fuel​
9.5.4 Engine Replacement​
9.5.5 Surge Tank Cap​
9.5.6 Thermostat Replacement​
9.5.7 Engine Coolant Temperature Sensor​
9.5.8 Radiator Assembly Replacement​
9.5.9 Hydraulic Oil Reservoir Removal/ Installation​
9.5.10 Diesel Exhaust Fluid (DEF) Tank​
9.5.11 Diesel Exhaust Fluid (DEF) Filter​
9.5.12 Diesel Exhaust Fluid (DEF) Pump Filter​
9.5.13 Fuel Tank​
9.5.14 Engine Exhaust System (ULS)​
9.5.15 Engine Exhaust System (LS)​
9.5.16 Air Cleaner Assembly​
9.5.17 Starter​
9.5.18 Alternator​
9.5.19 Air Conditioner (AC) Compressor (If Equipped)​
Transmission​
9.6.1 Component Terminology​
9.6.2 Transmission Serial Number​
9.6.3 Transmission Removal/Installation​
9.6.4 Reverse Alarm​
9.6.5 Torque Converter Diaphragm​
9.6.6 Transmission Oil Temperature Sensor​
9.6.7 Transmission Mounted Speed Sensor​
Hydraulic Cylinders​
9.7.1 General Cylinder Instructions​
9.7.2 Steering Cylinders​
Hydraulic Valves​
9.8.1 Main Control Valve​
9.8.2 Priority Valve​
9.8.3 Steering Column/Orbital Valve​
9.8.4 Steering Orbital Valve​
9.8.5 Steer Select Valve​
Hydraulic Pumps​
9.9.1 Implement Pump​
Electrical Components​
9.10.1 Battery​
9.10.2 Electrical Master Switch​
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Boom​
10.1.1 Boom Assembly Maintenance - AG823/AG925​
10.1.2 Boom Assembly Maintenance - AG832​
10.1.3 Third Boom Section Removal/Installation Only - AG832​
Drive Assembly​
10.2.1 Axle Assembly​
10.2.2 Transmission Assembly​
Cab​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
10.4.3 Diesel Exhaust Fluid (DEF) Tank Header Element Cleaning​
10.4.4 Diesel Exhaust Fluid (DEF) Tank​
Transmission​
10.5.1 Implement Pump​
10.6.1 General Cylinder Instruction​
10.6.2 Hydraulic Cylinder Repair Information​
Hydraulic Valves​
10.7.1 Main Control Valve​
10.7.2 Priority Valve​
10.7.3 Steer Select Valve​
Hydraulic Components​
10.8.1 Hydraulic Oil Reservoir​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
Electrical Schematics​
