JLG Telehandler AG519 Service Manual 3122345000 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG AG519 Telehandler
Part Number: 3122345000
Publication Date: 2025
Number of Pages: 626 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Travel Speed
2.1.2 Boom Performance Specifications
2.1.3 Battery
2.1.4 Engine Specifications
2.1.5 Operating Specifications
2.1.6 Dimensions
2.1.7 Transmission
2.1.8 Tires
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedules
ClearSky Smart Fleet
2.5.1 General
2.5.2 ClearSky Smart Fleet™ – Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Every 10 Hours
3.3.2 First 50 Hours
3.3.3 Every 50 Hours
3.3.4 First 250 Hours
3.3.5 Every 250 Hours
3.3.6 Every 500 Hours
3.3.7 Every 1000 Hours
3.3.8 Every 1500 Hours
3.3.9 Every 6000 Hours or 4 Years
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires & Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Spring Applied Hydraulically Released (SAHR) Parking Brake Bleeding
3.6.2 Service Brake Bleeding
Boom Inspection and Maintenance
3.7.1 Boom Wear Pads
Hydraulic Filter Replacement
Engine General Inspection
3.9.1 General Maintenance
3.9.2 Glow Plugs
3.9.3 Replacing Engine Oil
3.9.4 Replacing the Oil Filter
3.9.5 Replacing the Fuel Filters
3.9.6 Replacing the Fuel Pre-Filter
3.9.7 Checking Belt Tension
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Thread Locking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 Fuel Level Indicator and Fuel Level Sender
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 LSI System Calibration
4.3.3 Reversing Camera Calibration
4.3.4 Park Brake Calibration/Maximum Drive Traction Test
Special Procedures
4.4.1 Emergency Boom Lowering Procedure
4.4.2 Towing A Disabled Machine
4.4.3 Hydraulic Oil Tank
4.4.4 Fuel Tank Cleaning and Drying
4.4.5 Hydraulic Pressure Settings and Adjustments
4.4.6 Cylinder Checking Procedure
4.4.7 Cylinder Drift Test
4.4.8 Hydraulic Pressure Check
4.4.9 Bleed Steering System
4.4.10 Hydraulic Circuit Bleeding
System SoftwareLoad Stability Indicator System (LSI)
5.1.1 Load Stability Indicator
5.1.2 LSI Sensor
Analyzer
5.2.1 Machine Data Access
5.2.2 JLG Hand Held Analyzer
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer
5.2.4 PC Analyzer/Loglifter
5.2.5 Analyzer Software (Version P27.0)
Access Level
Diagnostics (Software Version P27.0)
Machine Setup (Software Version P27.0)
Personalities (Software Version P27.0)
Operator Tools (Software Version P27.0)
Calibrations (Software Version P27.0)
Premium Display (If Equipped)
5.9.1 Home Screen and Touch Screen Soft Buttons
5.9.2 Main Menu
5.9.3 Reprogramming Menu
Reprogramming the Premium Display
5.10.1 Software Installation
5.10.2 Load Charts Programming
ClearSky (CS550) Configuration and Troubleshooting
5.11.1 ClearSky Smart FleetTM CS550 Configuration
5.11.2 Troubleshooting
Fault CodesIntroduction
6.1.1 Fault Code Display
Engine Fault Codes
Fault Codes - Help Comment (00x)
Fault Codes - Power-Up (21x)
Fault Codes - Ground Inputs (23x)
Fault Codes - Other Inputs (24x)
Fault Codes - Function Prevented (25x)
Fault Codes - Line Contactor, Open-Circuit (31x)
Fault Codes - Line Contactor, Short-Circuit (32x)
Fault Codes - Output Drivers (33x)
Fault Codes - Engine (43x)
Fault Codes - Battery Supply (44x)
Fault Codes - Transmission and Drive System (46x)
Fault Codes - Communications (66x)
Fault Codes - Telematics (68x)
Fault Codes - Tilt Sensor (81x)
Fault Codes - Envelope Control (84x)
Fault Codes - Load Moment (85x)
Fault Codes - Steering (86x)
Fault Codes - Service Required (87x)
Fault Codes - Hardware (99x)
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Component
Torque Values
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
8.5.1 Engine Compartment Relays and Fuses
8.5.2 Power Distribution Module
8.5.3 Cab Relays and Fuses
Telematics Gateway
8.6.1 Telematics Gateway (TCU) Plug
8.6.2 Telematics Gateway Harness Breakdown
Removal and InstallationWheels
9.1.1 Wheel and Tire Assembly
Drive Assembly
9.2.1 General Information
9.2.2 Axle Serial Number
9.2.3 Axle Maintenance
9.2.4 Axle Assembly and Drive Shaft Troubleshooting
9.2.5 Axle
9.2.6 Drive Shaft
Boom
9.3.1 Boom System Component Terminology
9.3.2 Boom System
9.3.3 Quick Coupler
9.3.4 Fork
9.3.5 Boom Prop (If Equipped)
9.3.6 Boom Wear Pad
9.4.1 Cab Serial Number Plate
9.4.2 Cab Removal/Installation
9.4.3 Steering Wheel
9.4.4 Brake System
9.4.5 Throttle Pedal
9.4.6 Joystick Assembly
9.4.7 Ignition Key Switch
9.4.8 Dash Switches
9.4.9 Front Wiper Assembly
9.4.10 Rear Wiper Assembly
9.4.11 Roof Wiper Assembly
9.4.12 Windshield Washer Reservoir
9.4.13 Heater System
9.4.14 Heater and Air Conditioning System (if equipped)
9.4.15 Reversing Camera (If Equipped)
9.5.1 Component Terminology
9.5.2 Diesel Fuel
9.5.3 Engine Serial Number
9.5.4 Specifications and Maintenance Information
9.5.5 Engine Replacement
9.5.6 Surge Tank
9.5.7 Radiator Assembly
9.5.8 Starter
9.5.9 Alternator
9.5.10 Thermostat
9.5.11 Air Intake/Air Cleaner
9.5.12 Pump Coupling Kit
9.5.13 Fuel Tank
9.5.14 Hydraulic Tank
9.5.15 Pre-Fuel Filter and Fuel Pump
9.5.16 Engine Exhaust System
9.5.17 Air Conditioner (AC) Compressor (If equipped)
Hydraulic Valves
9.6.1 Main Control Valve
9.6.2 SAHR Valve
9.6.3 Steer Select Valve
9.6.4 Priority Valve
9.6.5 Watchdog Valve
Hydraulic Cylinders
9.7.1 Lift Cylinder
9.7.2 Compensation Cylinder
9.7.3 Tilt Cylinder
Hydraulic Pumps
9.8.1 Hydraulic Pumps
Electrical Components
9.9.1 Battery
Counterweight
Disassembly and AssemblyDrive Assembly
10.1.1 Axle Assembly
10.1.2 Transmission Assembly
Boom
10.2.1 Disassembly
10.2.2 Assembly
Engine Components
10.4.1 Engine Components
10.5.1 Drive Motor
10.5.2 Hystat Pump
10.5.3 Implement Pump
Hydraulic Cylinders
10.6.1 General Cylinder Disassembly
10.6.2 Hydraulic Cylinder Repair Information
Hydraulic Valves
10.7.1 Main Control Valve
10.7.2 Watchdog Valve
10.7.3 Steer Select and Sahr Brake Valve
10.7.4 Priority Valve
Hydraulic Components
10.8.1 Hydraulic Oil Tank
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
