JLG Telehandler AG313 Service Manual 3122327100 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG AG313 Telehandler
Part Number: 3122327100
Publication Date: 2025
Number of Pages: 382 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information & SpecificationsSpecifications
2.1.1 Travel Speeds
2.1.2 Hydraulic Cylinder Performance
2.1.3 Cylinder Drift
2.1.4 Battery
2.1.5 Engine Specifications
2.1.6 Tires
2.1.7 Dimensions
2.1.8 Machine Specifications
Machine Temperature Chart
Serial Number Locations
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedules
Maintenance & Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Every 8 Hours
3.3.2 First 50 Hours
3.3.3 Every 50 Hours
3.3.4 Every 200 Hours
3.3.5 Every 400 Hours
3.3.6 Every 600 Hours
3.3.7 Every 1000 Hours
3.3.8 Every 1500 Hours
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Service Brake Bleeding
3.6.2 Inching Valve Bleeding Procedure
Boom Inspection and Maintenance
3.7.1 Boom Wear Pads
Hydraulic Filter Replacement
3.8.1 Removal
3.8.2 Installation
Engine General Inspection
3.9.1 General Maintenance
3.9.2 Glow Plugs
3.9.3 Replacing Engine Oil
3.9.4 Replacing the Oil Filter
3.9.5 Replacing the Fuel Filters
3.9.6 Replace the Fuel Pump and Fuel In-Line Filter
3.9.7 Checking Belt Tension
Transmission Filter Replacement
Testing, Calibrations, & Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Thread Locking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
Calibration Procedures
4.3.1 Load Stability Indicator (LSI) System Calibration
4.3.2 Boom Sensor Calibration
Special Procedures
4.4.1 Emergency Lowering Procedure
4.4.2 Towing a Disabled Machine
4.4.3 Fuel Tank Cleaning and Drying
4.4.4 Pressure Checks and Adjustments
4.4.5 Cylinder Drift Test
4.4.6 Hydraulic Circuits
4.4.7 Pressure Specification
System SoftwareLoad Stability Indicator (LSI)
5.1.1 LSI Sensor
5.1.2 Boom Sensor
5.1.3 Troubleshooting
Fault CodesIntroduction
Engine Fault Codes
Machine Fault Codes
Transmission Fault Codes
Hydraulic Pump Fault Codes
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Component
Torque Values
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
8.3.1 General Overview
Harness Layouts
Board Layouts
8.5.1 Cab Fuses
8.5.2 Engine Fuses
8.5.3 Relays
Removal and InstallationWheels
9.1.1 Wheel and Tire Assembly
Drive Assembly
9.2.1 Axle Assembly and Drive Shaft Troubleshooting
9.2.2 Axle
9.2.3 Drive Shaft
Boom
9.3.1 Component Terminology
9.3.2 Troubleshooting
9.3.3 Boom Systems
9.3.4 Hydraulic Coupler
9.3.5 Forks
9.3.6 Boom Prop
9.3.7 Boom Wear Pad Installation and Lubrication
9.3.8 Boom Proximity Sensor
9.4.1 Serial Number Plate
9.4.2 Cab
9.4.3 Steering Wheel
9.4.4 Steering Column and Steering Valve
9.4.5 Brake System
9.4.6 Throttle Pedal
9.4.7 Joystick Assembly
9.4.8 Front Wiper Assembly
9.4.9 Windshield Wiper Fluid Reservoir
9.4.10 Heater System
9.4.11 Instrument Panel
9.4.12 Ignition key Switch
9.4.13 Dash Switches
9.5.1 Component Terminology
9.5.2 Diesel Fuel
9.5.3 Engine Serial Number
9.5.4 Engine
9.5.5 Engine Electrical System
9.5.6 Radiator/Cooler Assembly
9.5.7 Pump Coupling Assembly
9.5.8 Air Cleaner Assembly
9.5.9 Alternator
9.5.10 Starter
9.5.11 Fuel Tank Assembly
9.5.12 Hydraulic Tank
9.5.13 Fuel Filter and Pump
9.5.14 Engine Exhaust Assembly
9.6.1 Drive Motor
9.6.2 Gearbox
Hydraulic Cylinders
9.7.1 Lift Cylinder Assembly
9.7.2 Compensation Cylinder
9.7.3 Tilt Cylinder
Hydraulic Valves
9.8.1 Hydraulic Function Manifold
9.8.2 4 Wheel / 2 Wheel Drive Selector Valve and Park Brake Valve
9.8.3 Transmission Filter
Hydraulic Pumps
9.9.1 Transmission and Gear Pump
Electrical Components
9.10.1 Battery
Counterweight
9.11.1 Removal
9.11.2 Installation
Disassembly and AssemblyDrive Assembly
10.1.1 Axle Assembly
10.1.2 Transmission Assembly
Boom
10.2.1 Disassembly
10.2.2 Assembly
Engine Components
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
10.5.1 Drive Motor
10.5.2 Gearbox
10.5.3 Gear Pump
10.5.4 Transmission Pump
Hydraulic Cylinders
10.6.1 General Cylinder Disassembly
10.6.2 Hydraulic Cylinder Repair Information
Hydraulic Valves
10.7.1 Hydraulic Function Manifold
Hydraulic Components
10.8.1 Hydraulic Tank
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
