JLG Telehandler 925 Parts Manual 31211565
Brand: JLG
Type of Machine: Telehandler
Model: JLG 925 Telehandler
Part Number: 31211565
Publication Date: 2024
Number of Pages: 912 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME INSTALLATION
FIGURE 1-2. ENGINE ENCLOSURE INSTALLATION (NO RHOC)
FIGURE 1-3. ENGINE ENCLOSURE COVER INSTALLATION
FIGURE 1-4. HOOD INSTALLATION (NO RHOC)
FIGURE 1-5. COVER PLATES INSTALLATION (NO OUTRIGGERS - ULS)
FIGURE 1-6. COVER PLATES INSTALLATION (NO OUTRIGGERS - LS)
FIGURE 1-7. COVER PLATE INSTALLATION (NO TRAILER BRAKES)
FIGURE 1-8. COVER PLATE INSTALLATION (TRAILER BRAKES)
FIGURE 1-9. COVER PLATE INSTALLATION (NO REAR AUX)
FIGURE 1-10. COVER PLATE INSTALLATION (REAR AUX)
FIGURE 1-11. COVER PLATE INSTALLATION (HYDRAULIC HITCH AND REAR AUX)
FIGURE 1-12. REAR COVER PLATE INSTALLATION (NO HYDRAULIC HITCH)
FIGURE 1-13. TANKS INSTALLATION
FIGURE 1-14. FUEL TANK INSTALLATION
FIGURE 1-15. FUEL TANK ASSEMBLY
FIGURE 1-16. HYDRAULIC TANK INSTALLATION
FIGURE 1-17. HYDRAULIC TANK ASSEMBLY
FIGURE 1-18. FUEL AND HYDRAULIC CAP INSTALLATION
FIGURE 1-19. HITCH RETRIEVAL INSTALLATION
FIGURE 1-20. HITCH INSTALLATION (EEC AUTO)
FIGURE 1-21. HITCH INSTALLATION (PITON)
FIGURE 1-22. HITCH ASSEMBLY (EEC AUTO)
FIGURE 1-23. SLIDING HITCH ASSEMBLY (PITON)
FIGURE 1-24. HITCH INSTALLATION (EEC MANUAL)
FIGURE 1-25. HITCH ASSEMBLY (EEC MANUAL)
FIGURE 1-26. HITCH INSTALLATION (FIXED)
FIGURE 1-27. HITCH ASSEMBLY (FIXED)
FIGURE 1-28. HITCH INSTALLATION (HYDRAULIC)
FIGURE 1-29. CAB PLUG INSTALLATION (NON HYDRAULIC HITCH)
FIGURE 1-30. MIRROR INSTALLATION
FIGURE 1-31. REAR MIRROR INSTALLATION (FLAT)
FIGURE 1-32. REAR MIRROR INSTALLATION (CONVEX)
FIGURE 1-33. MIRROR ASSEMBLY (CONVEX)
FIGURE 1-34. TOOLBOX INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM ASSEMBLY
FIGURE 2-2. FIRST BOOM SECTION
FIGURE 2-3. SECOND BOOM SECTION ASSEMBLY
FIGURE 2-4. LINK ASSEMBLY
FIGURE 2-5. LEVER ASSEMBLY
FIGURE 2-6. RETRACT SENSOR INSTALLATION
FIGURE 2-7. BOOM PINNING INSTALLATION
FIGURE 2-8. LIFT CYLINDER PINNING INSTALLATION
FIGURE 2-9. COMPENSATION CYLINDER PINNING INSTALLATION
FIGURE 2-10. BOOM PIVOT INSTALLATION
FIGURE 2-11. BOOM BRUSHES INSTALLATION
FIGURE 2-12. BOOM PROP INSTALLATION
FIGURE 2-13. HYDRAULIC QUICK COUPLER INSTALLATION
FIGURE 2-14. MANUAL QUICK COUPLER INSTALLATION
SECTION 3 - ATTACHMENTSFIGURE 3-1. AUGER COUPLING
FIGURE 3-2. AUGER BIT (6INX4IN)
FIGURE 3-3. AUGER BIT (9INX4IN)
FIGURE 3-4. AUGER BIT (12INX4IN)
FIGURE 3-5. AUGER BIT (15INX4IN)
FIGURE 3-6. AUGER BIT (18INX4IN)
FIGURE 3-7. AUGER BIT (24INX4IN)
FIGURE 3-8. AUGER BIT (36INX4IN)
FIGURE 3-9. BALE HANDLER (TUBE CLAMP)
FIGURE 3-10. BALE HANDLER KIT (TUBE CLAMP)
FIGURE 3-11. BALE HANDLER (SPIKE CLAMP)
FIGURE 3-12. BALE HANDLER KIT (SPIKE CLAMP)
FIGURE 3-13. BASKET PERSONNEL (1.2MX2.4M) (DOMESTIC)
FIGURE 3-14. BASKET PERSONNEL (1.2MX2.4M) (ISO)
FIGURE 3-15. BASKET PERSONNEL (1.2MX2.4M) (FRENCH LANGUAGE)
FIGURE 3-16. BASKET PERSONNEL (FORK MOUNTED)
FIGURE 3-17. BUCKET (CONCRETE)
FIGURE 3-18. BUCKET (DIRT)
FIGURE 3-19. BUCKET (GRAPPLE MULTI-PURPOSE)
FIGURE 3-20. BUCKET (MANURE GRAPPLE)
FIGURE 3-21. BUCKET(0.6 M³) (MULTI-PURPOSE 4 IN 1)
FIGURE 3-22. BUCKET(1 M³) (GENERAL PURPOSE)
FIGURE 3-23. BUCKET(1 M³) (MULTI-PURPOSE 4 IN 1)
FIGURE 3-24. BUCKET (1.5 M³) (GENERAL PURPOSE)
FIGURE 3-25. BUCKET (2 M³) (GENERAL PURPOSE)
FIGURE 3-26. BUCKET (2.5 M³) (GENERAL PURPOSE)
FIGURE 3-27. BUCKET (3 M³) (GENERAL PURPOSE)
FIGURE 3-28. BUCKET FRONT GUARD
FIGURE 3-29. BUCKET TEETH KIT
FIGURE 3-30. CARRIAGE ASSEMBLY (1225MM)
FIGURE 3-31. CARRIAGE ASSEMBLY (1524MM)
FIGURE 3-32. CARRIAGE ASSEMBLY (1829MM)
FIGURE 3-33. CARRIAGE ASSEMBLY - SIDE TILTING (4.5 TON - 1225 MM)
FIGURE 3-34. CARRIAGE ASSEMBLY - SIDE TILTING (4.0 TON - 1575 MM)
FIGURE 3-35. CARRIAGE ASSEMBLY - SID TILTING (4.0 TON - 1829 MM)
FIGURE 3-36. CARRIAGE ASSEMBLY - SIDE SHIFT (4.0 TON - 1225 MM)
FIGURE 3-37. CARRIAGE ASSEMBLY - FORK POSITIONING (4.0 TON
FIGURE 3-38. CARRIAGE ASSEMBLY - FEM CARRIAGE AND FORKS
FIGURE 3-39. FORK - LUMBER (45X150X1540)
FIGURE 3-40. FORK - LUMBER (50X150X1830)
FIGURE 3-41. FORK - PALLET (50X100X1200)
FIGURE 3-42. FORK - PALLET (50X100X1200) (CE & AUS WITH SIDE SHIFT CARRIAAGE) (4.0 TON - 1225MM)
FIGURE 3-43. FORK - PALLET (50X120X1200)
FIGURE 3-44. FORK - PALLET (60X125X1220)
FIGURE 3-45. FORK - MUCK WITH GRAB
FIGURE 3-46. FORK - DUAL TINE BAILING WITH CARRIAGE
FIGURE 3-47. FORK _ EXTENSIONS (62X163X2286) (ANSI)
FIGURE 3-48. HOOK_CRANE (FORK MOUNTED)
FIGURE 3-49. TRASH HOPPER INSTALLATION
FIGURE 3-50. TRUSS BOOM (0.9 TON - 12 FT WITH WINCH)
FIGURE 3-51. TRUSS BOOM (1 TON - 3.4M)
FIGURE 3-52. TRUSS BOOM (1.8 TON - 3 FT WITH WINCH)
FIGURE 3-53. TRUSS BOOM (4 TON - 2.1M)
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION (90KW - ULS - PISTON PUMP)
FIGURE 4-2. ENGINE INSTALLATION (100KW - ULS - PISTON PUMP)
FIGURE 4-3. ENGINE MOUNTING INSTALLATION (90KW/100KW)
FIGURE 4-4. 3.6L ENGINE (90KW - ULS - PISTON PUMP)
FIGURE 4-5. 3.6L ENGINE (100KW - ULS - PISTON PUMP)
FIGURE 4-6. ENGINE ECU INSTALLATION (ULS)
FIGURE 4-7. BRACKET GUARD INSTALLATION
FIGURE 4-8. FUEL LINES INSTALLATION (ULS - RHOC)
FIGURE 4-9. EXHAUST INSTALLATION (ULS)
FIGURE 4-10. EXHAUST INSTALLATION (LS)
FIGURE 4-11. COOLING PACKAGE INSTALLATION (90KW - ULS)
FIGURE 4-12. COOLING FAN INSTALLATION
FIGURE 4-13. FAN LINES INSTALLATION (90KW)
FIGURE 4-14. FAN DRIVE MOTOR (NO RHOC)
FIGURE 4-15. FUEL FILTER INSTALLATION (90/100KW - ULS)
FIGURE 4-16. AIR CLEANER INSTALLATION (90/100KW)
FIGURE 4-17. AIR CLEANER ASSEMBLY (90/100KW)
FIGURE 4-18. PRE-AIR CLEANER ACCESSORY
FIGURE 4-19. AIR INTAKE RAIN CAP ACCESSORY
FIGURE 4-20. AIR INTAKE LINES INSTALLATION (90/100KW - ULS)
FIGURE 4-21. COOLER INSTALLATION (90KW)
FIGURE 4-22. RADIATOR COOLING PACKAGE (90KW)
FIGURE 4-23. REMOTE HOC INSTALLATION
FIGURE 4-24. FAN DRIVE MOTOR (RHOC)
FIGURE 4-25. COOLANT LINES INSTALLATION (ULS)
FIGURE 4-26. COOLER LINES INSTALLATION (90KW)
FIGURE 4-27. CAC LINES INSTALLATION (ULS)
FIGURE 4-28. SURGE TANK INSTALLATION
FIGURE 4-29. TANK EXPANSION
FIGURE 4-30. BULKHEAD INSTALLATION
FIGURE 4-31. DEF CONTROL MODULE INSTALLATION (ULS)
FIGURE 4-32. DEF TANK INSTALLATION (ULS)
FIGURE 4-33. DEF TANK ASSEMBLY (ULS)
FIGURE 4-34. DEF LINES INSTALLATION (ULS)
FIGURE 4-35. REMOTE FUEL PUMP INSTALLATION (74.4KW)
FIGURE 4-36. HYDRAULIC PUMP INSTALLATION (90KW)
FIGURE 4-37. HEATER LINES INSTALLATION (ULS)
FIGURE 4-38. HEATER LINES INSTALLATION (LS)
FIGURE 4-39. HEATER LINES WITH BLOCK HEATER INSTALLATION (ULS)
FIGURE 4-40. BLOCK HEATER INSTALLATION (120V - LS)
FIGURE 4-41. BLOCK HEATER (LS)
FIGURE 4-42. A/C PUMP INSTALLATION
FIGURE 4-43. A/C LINES INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVETRAIN INSTALLATION
FIGURE 5-2. FRONT AXLE INSTALLATION
FIGURE 5-3. FRONT AXLE ASSEMBLY
FIGURE 5-4. REAR AXLE INSTALLATION
FIGURE 5-5. REAR AXLE ASSEMBLY
FIGURE 5-6. DIFFERENTIAL KIT (REAR AXLE)
FIGURE 5-7. REDUCTION BUSHING KIT (FRONT & REAR AXLES)
FIGURE 5-8. PLANET GEAR CARRIER KIT (FRONT & REAR AXLES)
FIGURE 5-9. STEERING CASE KIT, (LF, RR)
FIGURE 5-10. STEERING CASE KIT, (RF, LR)
FIGURE 5-11. STEERING ADJUST BOLT KIT
FIGURE 5-12. RING GEAR SUPPORT KIT (REAR AXLE)
FIGURE 5-13. PISTON KIT (LH)
FIGURE 5-14. PISTON KIT (RH)
FIGURE 5-15. PISTON KIT
FIGURE 5-16. TRUNION KIT
FIGURE 5-17. DRIVE SHAFTS INSTALLATION
FIGURE 5-18. REMOTE GREASE SYSTEM INSTALLATION
FIGURE 5-19. AXLE SHIM INSTALLATION
FIGURE 5-20. TRANSMISSION INSTALLATION (6 SPD - 90KW)
FIGURE 5-21. TRANSMISSION INSTALLATION (6 SPD - 97KW)
FIGURE 5-22. TRANSMISSION (6 SPD - 90KW)
FIGURE 5-23. TRANSMISSION (6 SPD - HHP - 97KW)
FIGURE 5-24. PLANETARY CASE AND PARTS GROUP
FIGURE 5-25. TORQUE CONVERTER GROUP
FIGURE 5-26. TORQUE CONVERTER GROUP
FIGURE 5-27. TRANSFER GEAR AND CASE GROUP
FIGURE 5-28. TRANSMISSION HYDRAULIC CONTROL GROUP
FIGURE 5-29. INPUT SHAFT GROUP
FIGURE 5-30. TRANSMISSION CLUTCH GROUP
FIGURE 5-31. CLUTCH AND GEAR GROUP
FIGURE 5-32. TRANSMISSION PUMP GROUP
FIGURE 5-33. OUTPUT SHAFT GROUP
FIGURE 5-34. SPEED SENSOR
FIGURE 5-35. IDLER GEAR
FIGURE 5-36. REAR TRANSMISSION CASE
FIGURE 5-37. PLANETARY CASE
FIGURE 5-38. FRONT TRANSFER CASE
FIGURE 5-39. REAR TRANSFER CASE
FIGURE 5-40. RELIEF VALVE
FIGURE 5-41. SOLENOID VALVE
FIGURE 5-42. SOLENOID VALVE
FIGURE 5-43. FRONT TRANSMISSION CASE ASSEMBLY
FIGURE 5-44. REAR TRANSMISSION CASE ASSEMBLY
FIGURE 5-45. TIRE/WHEEL SET (AIR - 460/70 R24 XMCL)
FIGURE 5-46. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 460/70 R24)
FIGURE 5-47. LEFT TIRE/WHEEL ASSEMBLY (AIR - 460/70 R24)
FIGURE 5-48. TIRE/WHEEL SET (AIR - 500/70 R24 XMCL)
FIGURE 5-49. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 500/70 R24)
FIGURE 5-50. LEFT TIRE/WHEEL ASSEMBLY (AIR - 500/70 R24)
FIGURE 5-51. TIRE/WHEEL ASSEMBLY (AIR - 370/75-28)
FIGURE 5-52. FENDER INSTALLATION
FIGURE 5-53. FENDER ASSEMBLY (RR-RH)
FIGURE 5-54. FENDER ASSEMBLY (RR-LH)
FIGURE 5-55. FENDER ASSEMBLY (FRT-RH)
FIGURE 5-56. FENDER ASSEMBLY (FRT-LH)
SECTION 6 - CABFIGURE 6-1. CAB MOUNTS INSTALLATION
FIGURE 6-2. ENCLOSED CAB INSTALLATION
FIGURE 6-3. ENCLOSED CAB ASSEMBLY
FIGURE 6-4. ENCLOSED CAB GROUP
FIGURE 6-5. ENCLOSED CAB
FIGURE 6-6. DOOR INSTALLATION
FIGURE 6-7. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-8. CAB LATCH ASSEMBLY
FIGURE 6-9. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-10. DOOR ASSEMBLY (AG)
FIGURE 6-11. CAB DOOR
FIGURE 6-12. DOOR STRAP INSTALLATION
FIGURE 6-13. REAR WINDOW INSTALLATION
FIGURE 6-14. REAR WINDOW ASSEMBLY
FIGURE 6-15. ENCLOSED CAB PLUG GROUP
FIGURE 6-16. INTERIOR MIRROR INSTALLATION
FIGURE 6-17. FRONT WIPER INSTALLATION
FIGURE 6-18. LEVEL INDICATOR INSTALLATION
FIGURE 6-19. ENCLOSED CAB TRIM INSTALLATION
FIGURE 6-20. DASH COVER ASSEMBLY
FIGURE 6-21. REAR PANEL COVER ASSEMBLY
FIGURE 6-22. ADJUSTABLE ARMREST INSTALLATION
FIGURE 6-23. ARMREST
FIGURE 6-24. FIXED ARMREST BRACKET
FIGURE 6-25. MOVING ARMREST BRACKET
FIGURE 6-26. BEACON INSTALLATION
FIGURE 6-27. WASHER HOSES INSTALLATION
FIGURE 6-28. HAMMER INSTALLATION
FIGURE 6-29. HAMMER ATTACHMENT ASSEMBLY
FIGURE 6-30. FRONT COVER INSTALLATION
FIGURE 6-31. FILTER TRAY PANEL
FIGURE 6-32. FRONT DUCT COVER
FIGURE 6-33. WASHER TANK INSTALLATION
FIGURE 6-34. WASHER BOTTLE
FIGURE 6-35. SEAT INSTALLATION (AIR SUSPENSION - STANDARD)
FIGURE 6-36. SEAT ASSEMBLY (AIR SUSPENSION - STANDARD)
FIGURE 6-37. UPPER SEAT ASSEMBLY
FIGURE 6-38. SUSPENSION KIT
FIGURE 6-39. SEAT INSTALLATION (PREMIUM)
FIGURE 6-40. SEAT ASSEMBLY (AIR SUSPENSION - PREMIUM)
FIGURE 6-41. SEAT INSTALLATION (MECHANICAL)
FIGURE 6-42. SEAT ASSEMBLY
FIGURE 6-43. SEAT BELT INSTALLATION (2IN)
FIGURE 6-44. SEAT BELT INSTALLATION (3IN)
FIGURE 6-45. HEATER INSTALLATION
FIGURE 6-46. HEATER ASSEMBLY
FIGURE 6-47. HEATER
FIGURE 6-48. HEATER AND A/C INSTALLATION
FIGURE 6-49. CAB CONDENSER ASSEMBLY
FIGURE 6-50. CONDENSER
FIGURE 6-51. A/C RECEIVER DRIER
FIGURE 6-52. HEATER AND A/C ASSEMBLY
FIGURE 6-53. HEATER AND A/C
FIGURE 6-54. ROOF WIPER INSTALLATION
FIGURE 6-55. HEADLINER INSTALLATION
FIGURE 6-56. HEADLINER/ RADIO READY INSTALLATION
FIGURE 6-57. CAB GUARD INSTALLATION (TOP)
FIGURE 6-58. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-59. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-60. COMMON CAB TRIM INSTALLATION
FIGURE 6-61. CAB TRIM INSTALLATION
FIGURE 6-62. ROOF CAP INSTALLATION (A/C)
FIGURE 6-63. ROOF CAP INSTALLATION (NO A/C)
FIGURE 6-64. FRONT NOSE CONE INSTALLATION (SIDELIGHT)
FIGURE 6-65. RETRACTABLE SUNSCREEN INSTALLATION
FIGURE 6-66. CAB STEP INSTALLATION
FIGURE 6-67. FLOOR MAT INSTALLATION
FIGURE 6-68. EXTERNAL WINDOW RELEASE INSTALLATION (ANSI)
FIGURE 6-69. EXTERNAL WINDOW RELEASE INSTALLATION (CAN)
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL
FIGURE 7-5. BRAKE PEDAL PLATE
FIGURE 7-6. BRAKE SENSOR INSTALLATION
FIGURE 7-7. SWITCH PLATE ASSEMBLY
FIGURE 7-8. PARKING BRAKE INSTALLATION (CABLE - STANDARD)
FIGURE 7-9. PARKING BRAKE COVER (MECHANICAL)
FIGURE 7-10. PARKING CABLE ASSEMBLY (MECHANICAL)
FIGURE 7-11. STEERING WHEEL INSTALLATION
FIGURE 7-12. STEERING WHEEL
FIGURE 7-13. STEERING COLUMN INSTALLATION
FIGURE 7-14. TILT STEERING COLUMN
FIGURE 7-15. HORN INSTALLATION
FIGURE 7-16. HORN BUTTON INSTALLATION
FIGURE 7-17. JOYSTICK INSTALLATION
FIGURE 7-18. WIPER-TURN SWITCH (0 SPEED - FNR)
FIGURE 7-19. WIPER-TURN SWITCH (NO SPEED)
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. COMMON HYDRAULICS INSTALLATION
FIGURE 8-2. AUXILIARY HYDRAULICS INSTALLATION - REAR (TWIN)
FIGURE 8-3. AUXILIARY HYDRAULICS INSTALLATION - REAR (SINGLE)
FIGURE 8-4. BOOM HYDRAULIC INSTALLATION
FIGURE 8-5. BOOM LINES INSTALLATION
FIGURE 8-6. BOOM RAISE HOSES INSTALLATION (NO RIDE CONTROL)
FIGURE 8-7. BOOM RAISE HOSES INSTALLATION (WITH RIDE CONTROL)
FIGURE 8-8. BRAKE LINES INSTALLATION
FIGURE 8-9. BRAKE INSTALLATION – TRAILER
FIGURE 8-10. BRAKE ACCUMULATOR LINES INSTALLATION (WITHOUT SAHR)
FIGURE 8-11. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - TWIN)
FIGURE 8-12. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - SINGLE)
FIGURE 8-13. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - TWIN)
FIGURE 8-14. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - SINGLE)
FIGURE 8-15. LIFT CYLINDER INSTALLATION
FIGURE 8-16. MAIN CONTROL VALVE INSTALLATION
FIGURE 8-17. MAIN HYDRAULIC PUMP INSTALLATION
FIGURE 8-18. IMPLEMENT PUMP INSTALLATION
FIGURE 8-19. PRIORITY LINES INSTALLATION
FIGURE 8-20. PRIORITY VALVE INSTALLATION
FIGURE 8-21. RETURN LINES INSTALLATION
FIGURE 8-22. STEERING LINES INSTALLATION
FIGURE 8-23. STEER SELECT VALVE INSTALLATION
FIGURE 8-24. SUCTION LINES INSTALLATION
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. CYLINDER ASSEMBLY - COMPENSATION
FIGURE 9-2. CYLINDER SUB-ASSEMBLY - COUPLER LOCKING
FIGURE 9-3. CYLINDER ASSEMBLY - COUPLER LOCKING
FIGURE 9-4. CYLINDER SUB-ASSEMBLY - EXTEND/RETRACT (TELESCOPE)
FIGURE 9-5. CYLINDER ASSEMBLY - EXTEND/RETRACT (TELESCOPE)
FIGURE 9-6. CYLINDER ASSEMBLY - LIFT
FIGURE 9-7. CYLINDER ASSEMBLY - TIFT
FIGURE 9-8. IMPLEMENT PUMP
FIGURE 9-9. VALVE SUB-ASSEMBLY - DIVERTOR (HI-FLOW)
FIGURE 9-10. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-11. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-12. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-13. VALVE ASSEMBLY - FAN MOTOR CONTROL
FIGURE 9-14. VALVE ASSEMBLY - HYDRAULIC HITCH CONTROL VALVE
FIGURE 9-15. VALVE ASSEMBLY - MAIN CONTROL
FIGURE 9-16. VALVE ASSEMBLY - PRIORITY FLOW MANIFOLD
FIGURE 9-17. VALVE ASSEMBLY - RIDE CONTROL
FIGURE 9-18. VALVE ASSEMBLY - STEERING SELECT VALVE
FIGURE 9-19. VALVE ASSEMBLY - TRAILER BRAKE
SECTION 10 - ELECTRICALFIGURE 10-1. 925 ELECTRICAL LAYOUT
FIGURE 10-2. BATTERY INSTALLATION (STANDARD)
FIGURE 10-3. BATTERY INSTALLATION (DUAL)
FIGURE 10-4. BEACON/STROBE INSTALLATION
FIGURE 10-5. BOOM HARNESS INSTALLATION
FIGURE 10-6. BOOM ANGLE SENSOR INSTALLATION
FIGURE 10-7. BOOM HARNESS
FIGURE 10-8. CAB ELECTRICAL INSTALLATION
FIGURE 10-9. CAB HARNESS
FIGURE 10-10. CAB STANDARD ELECTRICAL BOARD ASSEMBLY
FIGURE 10-11. CAB OPTION 1 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-12. CAB OPTION 2 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-13. CAB OPTION HARNESS
FIGURE 10-14. CAB HEATER HARNESS INSTALLATION
FIGURE 10-15. CAB HEATER HARNESS
FIGURE 10-16. HVAC CAB ACTUATOR
FIGURE 10-17. CAB HVAC ACTUATOR HARNESS
FIGURE 10-18. CAB - MULTIFUNCTION DISPLAY INSTALLATION
FIGURE 10-19. CAB SEAT ADAPTOR HARNESS (PREMIUM SEAT)
FIGURE 10-20. CLEARSKY 4G CANBUS INSTALLATION
FIGURE 10-21. DASH ELECTRICS INSTALLATION (ULS)
FIGURE 10-22. DASH ELECTRICS INSTALLATION (LS)
FIGURE 10-23. DECLUTCH SWITCH INSTALLATION
FIGURE 10-24. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 10-25. ELECTRICAL POWER DISTRIBUTION ELECTRICAL BOX
FIGURE 10-26. ELECTRICAL RELAY INSTALLATION - 200 AMP
FIGURE 10-27. ENGINE WIRING INSTALLATION (ULS)
FIGURE 10-28. ENGINE HARNESS (ULS)
FIGURE 10-29. ENGINE FUEL PUMP HARNESS
FIGURE 10-30. ENGINE GLOW PLUG RELAY HARNESS
FIGURE 10-31. ENGINE SPEED SET SWITCH INSTALLATION
FIGURE 10-32. FRAME MAIN ELECTRICAL INSTALLATION
FIGURE 10-33. FRAME HARNESS - REAR
FIGURE 10-34. FRAME HARNESS - FRONT
FIGURE 10-35. IGNITION SWITCH INSTALLATION
FIGURE 10-36. LIGHTS - DIP LIGHTS INSTALLATION (RH)
FIGURE 10-37. LIGHTS - LICENSE PLATE LAMP INSTALLATION
FIGURE 10-38. LIGHTS - LICENSE PLATE LAMP HARNESS
FIGURE 10-39. LIGHTS - NO ROADLIGHTS INSTALLATION
FIGURE 10-40. LIGHTS - WORKLIGHTS INSTALLATION (BOOM MOUNTED)
FIGURE 10-41. LIGHTS - WORKLIGHTS INSTALLATION - LED (BOOM MOUNTED)
FIGURE 10-42. LIGHTS - WORKLIGHTS HARNESS (BOOM MOUNTED LIGHTS)
FIGURE 10-43. LIGHTS - WORKLIGHTS INSTALLATION (CAB MOUNTED) (NO A/C)
FIGURE 10-44. LIGHTS - WORKLIGHTS INSTALLATION - LED (CAB MOUNTED) (NO A/C)
FIGURE 10-45. LIGHTS - WORKLIGHTS INSTALLATION (CAB MOUNTED) (WITH A/C)
FIGURE 10-46. LIGHTS - WORKLIGHTS INSTALLATION -LED (CAB MOUNTED) (WITH A/C)
FIGURE 10-47. LSI SENSOR INSTALLATION
FIGURE 10-48. LSI DISPLAY INSTALLATION
FIGURE 10-49. LSI SENSOR INSTALLATION
FIGURE 10-50. LSI SWITCH INSTALLATION
FIGURE 10-51. LSI SENSOR COVER INSTALLATION
FIGURE 10-52. REVERSE ALARM INSTALLATION
FIGURE 10-53. REVERSE CAMERA INSTALLATION
FIGURE 10-54. REVERSE SENSING INSTALLATION
FIGURE 10-55. REVERSE SENSING HARNESS
FIGURE 10-56. TELEMATICS CLEARSKY CAN 4WARD HARNESS
FIGURE 10-57. TELEMATICS ADAPTER HARNESS
FIGURE 10-58. TELEMATICS READY INSTALLATION
FIGURE 10-59. TELEMATICS READY HARNESS
FIGURE 10-60. TRAILER ELECTRICS INSTALLATION
FIGURE 10-61. TRAILER CONNECTOR HARNESS
SECTION 11 - DECALSFIGURE 11-1. DECALS INSTALLATION (ANSI)
FIGURE 11-2. DECALS INSTALLATION (LATIN AMERICA)
FIGURE 11-3. DECALS INSTALLATION - JLG - (LATIN AMERICA SPECS)
FIGURE 11-4. DECALS INSTALLATION - JLG (ANSI & CSA SPECS)
FIGURE 11-5. CAPACITY CHART (ANSI)
FIGURE 11-6. CAPACITY CHART HOLDER INSTALLATION
FIGURE 11-7. CLEARSKY DECAL INSTALLATION
FIGURE 11-8. TRIANGLE INSTALLATION - SLOW MOVING VEHICLE
SECTION 12 - RECOMMENDED SPARE PARTSFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONSFIGURE 13-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
