Hyundai
86
176,834
JLG Telehandler 925 Parts Manual 31211474
Brand: JLG
Type of Machine: Telehandler
Model: JLG 925 Telehandler
Part Number: 31211474
Publication Date: 2024
Number of Pages: 1066 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
FIGURE 1-1. FRAME INSTALLATION​
FIGURE 1-2. ENGINE ENCLOSURE INSTALLATION (NO RHOC)​
FIGURE 1-3. ENGINE ENCLOSURE INSTALLATION (RHOC)​
FIGURE 1-4. ENGINE ENCLOSURE COVER INSTALLATION​
FIGURE 1-5. HOOD INSTALLATION (NO RHOC)​
FIGURE 1-6. HOOD INSTALLATION (RHOC)​
FIGURE 1-7. COVER PLATES INSTALLATION (NO OUTRIGGERS - ULS)​
FIGURE 1-8. COVER PLATES INSTALLATION (NO OUTRIGGERS - LS)​
FIGURE 1-9. COVER PLATE INSTALLATION (NO TRAILER BRAKES)​
FIGURE 1-10. COVER PLATE INSTALLATION (TRAILER BRAKES)​
FIGURE 1-11. COVER PLATE INSTALLATION (NO REAR AUX)​
FIGURE 1-12. COVER PLATE INSTALLATION (REAR AUX)​
FIGURE 1-13. COVER PLATE INSTALLATION (HYDRAULIC HITCH AND REAR AUX)​
FIGURE 1-14. REAR COVER PLATE INSTALLATION (NO HYDRAULIC HITCH)​
FIGURE 1-15. TANKS INSTALLATION​
FIGURE 1-16. FUEL TANK INSTALLATION​
FIGURE 1-17. FUEL TANK ASSEMBLY​
FIGURE 1-18. HYDRAULIC TANK INSTALLATION​
FIGURE 1-19. HYDRAULIC TANK ASSEMBLY​
FIGURE 1-20. FUEL AND HYDRAULIC CAP INSTALLATION​
FIGURE 1-21. HITCH RETRIEVAL INSTALLATION​
FIGURE 1-22. HITCH INSTALLATION (EEC AUTO)​
FIGURE 1-23. HITCH INSTALLATION (PITON)​
FIGURE 1-24. HITCH ASSEMBLY (EEC AUTO)​
FIGURE 1-25. SLIDING HITCH ASSEMBLY (PITON)​
FIGURE 1-26. HITCH INSTALLATION (EEC MANUAL)​
FIGURE 1-27. HITCH ASSEMBLY (EEC MANUAL)​
FIGURE 1-28. HITCH INSTALLATION (FIXED)​
FIGURE 1-29. HITCH ASSEMBLY (FIXED)​
FIGURE 1-30. HITCH INSTALLATION (HYDRAULIC)​
FIGURE 1-31. CAB PLUG INSTALLATION (NON HYDRAULIC HITCH)​
FIGURE 1-32. REAR MIRROR INSTALLATION (FLAT)​
FIGURE 1-33. REAR MIRROR INSTALLATION (CONVEX)​
FIGURE 1-34. 9. MIRROR ASSEMBLY (CONVEX)​
FIGURE 1-35. TOOLBOX INSTALLATION​
SECTION 2 - BOOM
FIGURE 2-1. BOOM ASSEMBLY​
FIGURE 2-2. FIRST BOOM SECTION​
FIGURE 2-3. SECOND BOOM SECTION ASSEMBLY​
FIGURE 2-4. LINK ASSEMBLY​
FIGURE 2-5. LEVER ASSEMBLY​
FIGURE 2-6. RETRACT SENSOR INSTALLATION​
FIGURE 2-7. BOOM PINNING INSTALLATION​
FIGURE 2-8. LIFT CYLINDER PINNING INSTALLATION​
FIGURE 2-9. COMPENSATION CYLINDER PINNING INSTALLATION​
FIGURE 2-10. BOOM PIVOT INSTALLATION​
FIGURE 2-11. BOOM ANGLE INDICATOR INSTALLATION​
FIGURE 2-12. BOOM BRUSHES INSTALLATION​
FIGURE 2-13. BOOM PROP INSTALLATION​
FIGURE 2-14. HYDRAULIC QUICK COUPLER INSTALLATION​
FIGURE 2-15. MANUAL QUICK COUPLER INSTALLATION​
SECTION 3 - ATTACHMENTS
FIGURE 3-1. AUGER COUPLING​
FIGURE 3-2. AUGER BIT (6INX4IN)​
FIGURE 3-3. AUGER BIT (9INX4IN)​
FIGURE 3-4. AUGER BIT (12INX4IN)​
FIGURE 3-5. AUGER BIT (15INX4IN)​
FIGURE 3-6. AUGER BIT (18INX4IN)​
FIGURE 3-7. AUGER BIT (24INX4IN)​
FIGURE 3-8. AUGER BIT (36INX4IN)​
FIGURE 3-9. BALE HANDLER (TUBE CLAMP)​
FIGURE 3-10. BALE HANDLER KIT (TUBE CLAMP)​
FIGURE 3-11. BALE HANDLER (SPIKE CLAMP)​
FIGURE 3-12. BALE HANDLER KIT (SPIKE CLAMP)​
FIGURE 3-13. BASKET PERSONNEL (1.2MX2.4M) (DOMESTIC)​
FIGURE 3-14. BASKET PERSONNEL (1.2MX2.4M) (ISO)​
FIGURE 3-15. BASKET PERSONNEL (1.2MX2.4M) (FRENCH LANGUAGE)​
FIGURE 3-16. BASKET PERSONNEL (FORK MOUNTED)​
FIGURE 3-17. BUCKET (CONCRETE)​
FIGURE 3-18. BUCKET (DIRT)​
FIGURE 3-19. BUCKET (GRAPPLE MULTI-PURPOSE)​
FIGURE 3-20. BUCKET (MANURE GRAPPLE)​
FIGURE 3-21. BUCKET(0.6 M³) (MULTI-PURPOSE 4I N 1)​
FIGURE 3-22. BUCKET(1 M³) (GENERAL PURPOSE)​
FIGURE 3-23. BUCKET(1 M³) (MULTI-PURPOSE 4I N 1)​
FIGURE 3-24. BUCKET (1.5 M³) (GENERAL PURPOSE)​
FIGURE 3-25. BUCKET (2 M³) (GENERAL PURPOSE)​
FIGURE 3-26. BUCKET (2.5 M³) (GENERAL PURPOSE)​
FIGURE 3-27. BUCKET (3 M³) (GENERAL PURPOSE)​
FIGURE 3-28. BUCKET FRONT GUARD​
FIGURE 3-29. BUCKET TEETH KIT​
FIGURE 3-30. CARRIAGE ASSEMBLY (1225MM)​
FIGURE 3-31. CARRIAGE ASSEMBLY (1524MM) (PVC 1911)​
FIGURE 3-32. CARRIAGE ASSEMBLY (1524MM) (PVC 2005)​
FIGURE 3-33. CARRIAGE ASSEMBLY (1829MM) (PVC 1911)​
FIGURE 3-34. CARRIAGE ASSEMBLY (1829MM) (PVC 2005)​
FIGURE 3-35. CARRIAGE ASSEMBLY - SIDE TILTING (4.5 TON - 1225 MM)​
FIGURE 3-36. CARRIAGE ASSEMBLY - SIDE TILTING (4.0 TON - 1575 MM)​
FIGURE 3-37. CARRIAGE ASSEMBLY - SID TILTING (4.0 TON - 1829 MM)​
FIGURE 3-38. CARRIAGE ASSEMBLY - SIDE SHIFT (4.0 TON - 1225 MM)​
FIGURE 3-39. CARRIAGE ASSEMBLY - FORK POSITIONING (4.0 TON​
FIGURE 3-40. CARRIAGE ASSEMBLY (JOHN DEERE FIT)​
FIGURE 3-41. CARRIAGE ASSEMBLY (MANITOU FIT)​
FIGURE 3-42. CARRIAGE ASSEMBLY (JCB FIT)​
FIGURE 3-43. CARRIAGE ASSEMBLY - FEM CARRIAGE AND FORKS​
FIGURE 3-44. FORK - LUMBER (45X150X1540)​
FIGURE 3-45. FORK - LUMBER (50X150X1830)​
FIGURE 3-46. FORK - PALLET (50X50X1220)​
FIGURE 3-47. FORK - PALLET (50X100X1070)​
FIGURE 3-48. FORK - PALLET (50X100X1200)​
FIGURE 3-49. FORK - PALLET (50X100X1200) (CE & AUS WITH SIDE SHIFT CARRIAAGE) (4.0 TON - 1225MM)​
FIGURE 3-50. FORK - PALLET (50X120X1200)​
FIGURE 3-51. FORK - PALLET (60X125X1220)​
FIGURE 3-52. FORK - MUCK WITH GRAB​
FIGURE 3-53. FORK - DUAL TINE BAILING WITH CARRIAGE​
FIGURE 3-54. FORK _EXTENSIONS (62X163X2286) (ANSI)​
FIGURE 3-55. HOOK_CRANE (FORK MOUNTED)​
FIGURE 3-56. TRASH HOPPER INSTALLATION​
FIGURE 3-57. TRUSS BOOM (0.9 TON - 12 FT WITH WINCH)​
FIGURE 3-58. TRUSS BOOM (1 TON - 3.4M)​
FIGURE 3-59. TRUSS BOOM (1.8 TON - 3 FT WITH WINCH)​
FIGURE 3-60. TRUSS BOOM (4 TON - 2.1M)​
SECTION 4 - ENGINE AND ATTACHING PARTS
FIGURE 4-1. ENGINE INSTALLATION (90KW - ULS - PISTON PUMP)​
FIGURE 4-2. ENGINE INSTALLATION (100KW - ULS - PISTON PUMP)​
FIGURE 4-3. ENGINE INSTALLATION (90KW - LS - PISTON PUMP) (ANSI SPEC)​
FIGURE 4-4. ENGINE MOUNTING INSTALLATION (90KW/100KW)​
FIGURE 4-5. 3.6L ENGINE (90KW - ULS - PISTON PUMP)​
FIGURE 4-6. 3.6L ENGINE (100KW - ULS - PISTON PUMP)​
FIGURE 4-7. 3.6L ENGINE (90KW - LS - PISTON PUMP)​
FIGURE 4-8. ENGINE ECU INSTALLATION (ULS)​
FIGURE 4-9. ENGINE ECU INSTALLATION (LS)​
FIGURE 4-10. BRACKET GUARD INSTALLATION​
FIGURE 4-11. FUEL LINES INSTALLATION (ULS - RHOC)​
FIGURE 4-12. FUEL LINES INSTALLATION (LS - RHOC)​
FIGURE 4-13. EXHAUST INSTALLATION (ULS)​
FIGURE 4-14. EXHAUST INSTALLATION (LS)​
FIGURE 4-15. EXHAUST INSTALLATION (LS)​
FIGURE 4-16. COOLING PACKAGE INSTALLATION (90KW - ULS)​
FIGURE 4-17. COOLING PACKAGE INSTALLATION (90KW - LS)​
FIGURE 4-18. COOLING FAN INSTALLATION​
FIGURE 4-19. FAN LINES INSTALLATION (90KW) (PVC 1911)​
FIGURE 4-20. FAN LINES INSTALLATION (90KW) (PVC 2005)​
FIGURE 4-21. FAN DRIVE MOTOR (NO RHOC)​
FIGURE 4-22. FUEL FILTER INSTALLATION (90/100KW - ULS)​
FIGURE 4-23. PRIMARY FUEL FILTER INSTALLATION (90KW - LS)​
FIGURE 4-24. AIR CLEANER INSTALLATION (90/100KW) (PVC 1911)​
FIGURE 4-25. AIR CLEANER INSTALLATION (90/100KW) (PVC 2005)​
FIGURE 4-26. AIR CLEANER ASSEMBLY (90/100KW)​
FIGURE 4-27. PRE-AIR CLEANER ACCESSORY​
FIGURE 4-28. AIR INTAKE RAIN CAP ACCESSORY​
FIGURE 4-29. AIR INTAKE LINES INSTALLATION (90/100KW - ULS)​
FIGURE 4-30. AIR INTAKE LINES INSTALLATION (90KW - LS)​
FIGURE 4-31. COOLER INSTALLATION (90KW)​
FIGURE 4-32. RADIATOR COOLING PACKAGE (90KW)​
FIGURE 4-33. REMOTE HOC INSTALLATION​
FIGURE 4-34. FAN DRIVE MOTOR (RHOC)​
FIGURE 4-35. COOLANT LINES INSTALLATION (ULS)​
FIGURE 4-36. COOLANT LINES INSTALLATION (LS)​
FIGURE 4-37. COOLER LINES INSTALLATION (90KW)​
FIGURE 4-38. CAC LINES INSTALLATION (ULS)​
FIGURE 4-39. CAC LINES INSTALLATION (LS)​
FIGURE 4-40. SURGE TANK INSTALLATION​
FIGURE 4-41. TANK EXPANSION​
FIGURE 4-42. BULKHEAD INSTALLATION​
FIGURE 4-43. DEF CONTROL MODULE INSTALLATION (ULS)​
FIGURE 4-44. DEF TANK INSTALLATION (ULS)​
FIGURE 4-45. DEF TANK ASSEMBLY (ULS)​
FIGURE 4-46. DEF LINES INSTALLATION (ULS)​
FIGURE 4-47. REMOTE FUEL PUMP INSTALLATION (74.4KW)​
FIGURE 4-48. HYDRAULIC PUMP INSTALLATION (90KW)​
FIGURE 4-49. HEATER LINES INSTALLATION (ULS)​
FIGURE 4-50. HEATER LINES INSTALLATION (LS)​
FIGURE 4-51. HEATER LINES WITH BLOCK HEATER INSTALLATION (ULS)​
FIGURE 4-52. HEATER LINES INSTALLATION (LS)​
FIGURE 4-53. BLOCK HEATER INSTALLATION (230V - LS)​
FIGURE 4-54. BLOCK HEATER INSTALLATION (120V - LS) (PVC 1911)​
FIGURE 4-55. BLOCK HEATER INSTALLATION (120V - LS) (PVC 2005)​
FIGURE 4-56. BLOCK HEATER (ULS)​
FIGURE 4-57. BLOCK HEATER (LS)​
FIGURE 4-58. A/C PUMP INSTALLATION​
FIGURE 4-59. A/C LINES INSTALLATION​
SECTION 5 - DRIVE TRAIN
FIGURE 5-1. DRIVETRAIN INSTALLATION​
FIGURE 5-2. FRONT AXLE INSTALLATION - DANA AXLE PN212/A82​
FIGURE 5-3. FRONT AXLE INSTALLATION - DANA AXLE PN10168157​
FIGURE 5-4. FRONT AXLE ASSEMBLY - DANA AXLE PN212/A82​
FIGURE 5-5. FRONT AXLE - CENTRAL​
FIGURE 5-6. FRONT AXLE- DIFFERENTIAL​
FIGURE 5-7. FRONT AXLE - HUB REDUCTION​
FIGURE 5-8. FRONT AXLE - BRAKES​
FIGURE 5-9. FRONT AXLE - STEERING​
FIGURE 5-10. FRONT AXLE ASSEMBLY - DANA AXLE PN10168157​
FIGURE 5-11. DIFFERENTIAL KIT (FRONT AXLE)​
FIGURE 5-12. REAR AXLE INSTALLATION - DANA AXLE PN212/A60​
FIGURE 5-13. REAR AXLE INSTALLATION - DANA AXLE PN10168439​
FIGURE 5-14. REAR AXLE ASSEMBLY​
FIGURE 5-15. REAR AXLE - CENTRAL HOUSING​
FIGURE 5-16. REAR AXLE - DIFFERENTIAL​
FIGURE 5-17. REAR AXLE - HUB REDUCTION​
FIGURE 5-18. REAR AXLE - BRAKES​
FIGURE 5-19. REAR AXLE - STEERING​
FIGURE 5-20. REAR AXLE ASSEMBLY - DANA AXLE PN 10168439​
FIGURE 5-21. DIFFERENTIAL KIT (REAR AXLE)​
FIGURE 5-22. REDUCTION BUSHING KIT (FRONT & REAR AXLES)​
FIGURE 5-23. PLANET GEAR CARRIER KIT (FRONT & REAR AXLES)​
FIGURE 5-24. STEERING CASE KIT, (LF, RR)​
FIGURE 5-25. STEERING CASE KIT, (RF, LR)​
FIGURE 5-26. STEERING ADJUST BOLT KIT​
FIGURE 5-27. RING GEAR SUPPORT KIT (REAR AXLE)​
FIGURE 5-28. PISTON KIT (LH)​
FIGURE 5-29. PISTON KIT (RH)​
FIGURE 5-30. PISTON KIT​
FIGURE 5-31. TRUNION KIT​
FIGURE 5-32. DRIVE SHAFTS INSTALLATION​
FIGURE 5-33. REMOTE GREASE SYSTEM INSTALLATION​
FIGURE 5-34. AXLE SHIM INSTALLATION​
FIGURE 5-35. TRANSMISSION INSTALLATION (6 SPD - 90KW)​
FIGURE 5-36. TRANSMISSION INSTALLATION (6 SPD - 97KW)​
FIGURE 5-37. TRANSMISSION (6 SPD - 90KW)​
FIGURE 5-38. TRANSMISSION (6 SPD - HHP - 97KW)​
FIGURE 5-39. PLANETARY CASE AND PARTS GROUP​
FIGURE 5-40. TORQUE CONVERTER GROUP​
FIGURE 5-41. TORQUE CONVERTER GROUP​
FIGURE 5-42. TRANSFER GEAR AND CASE GROUP​
FIGURE 5-43. TRANSMISSION HYDRAULIC CONTROL GROUP​
FIGURE 5-44. INPUT SHAFT GROUP​
FIGURE 5-45. TRANSMISSION CLUTCH GROUP​
FIGURE 5-46. CLUTCH AND GEAR GROUP​
FIGURE 5-47. TRANSMISSION PUMP GROUP​
FIGURE 5-48. OUTPUT SHAFT GROUP​
FIGURE 5-49. SPEED SENSOR​
FIGURE 5-50. IDLER GEAR​
FIGURE 5-51. REAR TRANSMISSION CASE​
FIGURE 5-52. PLANETARY CASE​
FIGURE 5-53. FRONT TRANSFER CASE​
FIGURE 5-54. REAR TRANSFER CASE​
FIGURE 5-55. RELIEF VALVE​
FIGURE 5-56. SOLENOID VALVE​
FIGURE 5-57. SOLENOID VALVE​
FIGURE 5-58. FRONT TRANSMISSION CASE ASSEMBLY​
FIGURE 5-59. REAR TRANSMISSION CASE ASSEMBLY​
FIGURE 5-60. TIRE/WHEEL SET (AIR - 15.5/80-24 - 16PR)​
FIGURE 5-61. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 15.5/80-24 - 16PR)​
FIGURE 5-62. LEFT TIRE/WHEEL ASSEMBLY (AIR - 15.5/80-24 - 16PR)​
FIGURE 5-63. TIRE/WHEEL SET (AIR - 15.5 R25 XHA TL)​
FIGURE 5-64. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 15.5 R25)​
FIGURE 5-65. LEFT TIRE/WHEEL ASSEMBLY (AIR - 15.5 R25)​
FIGURE 5-66. TIRE/WHEEL SET (AIR - 460/70 R24 XMCL)​
FIGURE 5-67. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 460/70 R24)​
FIGURE 5-68. LEFT TIRE/WHEEL ASSEMBLY (AIR - 460/70 R24)​
FIGURE 5-69. TIRE/WHEEL SET (AIR - 500/70 R24 XMCL)​
FIGURE 5-70. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 500/70 R24)​
FIGURE 5-71. LEFT TIRE/WHEEL ASSEMBLY (AIR - 500/70 R24)​
FIGURE 5-72. TIRE/WHEEL SET (AIR - 440/80-24 POWER CL)​
FIGURE 5-73. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 440/80-24)​
FIGURE 5-74. LEFT TIRE/WHEEL ASSEMBLY (AIR - 440/80-24)​
FIGURE 5-75. TIRE/WHEEL SET (AIR - 400/80-24 POWER CL)​
FIGURE 5-76. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 400/80-24)​
FIGURE 5-77. LEFT TIRE/WHEEL ASSEMBLY (AIR - 400/80-24)​
FIGURE 5-78. TIRE/WHEEL SET (AIR - 370/75-28)​
FIGURE 5-79. TIRE/WHEEL ASSEMBLY (AIR - 370/75-28)​
FIGURE 5-80. TIRE/WHEEL SET (FOAM - 13X24)​
FIGURE 5-81. TIRE/WHEEL SET (AIR - 460/70 R24 - BIBLOAD)​
FIGURE 5-82. RIGHT TIRE/WHEEL ASSEMBLY (AIR - 460/70 R24 - BIBLOAD)​
FIGURE 5-83. LEFT TIRE/WHEEL ASSEMBLY (AIR - 460/70 R24 - BIBLOAD)​
FIGURE 5-84. FENDER INSTALLATION​
FIGURE 5-85. FENDER ASSEMBLY (RR-RH)​
FIGURE 5-86. FENDER ASSEMBLY (RR-LH)​
FIGURE 5-87. FENDER ASSEMBLY (FRT-RH)​
FIGURE 5-88. FENDER ASSEMBLY (FRT-LH)​
SECTION 6 - CAB
FIGURE 6-1. CAB MOUNTS INSTALLATION​
FIGURE 6-2. ENCLOSED CAB INSTALLATION​
FIGURE 6-3. ENCLOSED CAB ASSEMBLY​
FIGURE 6-4. ENCLOSED CAB GROUP​
FIGURE 6-5. ENCLOSED CAB​
FIGURE 6-6. DOOR INSTALLATION​
FIGURE 6-7. DOOR UPPER GLASS ASSEMBLY​
FIGURE 6-8. CAB LATCH ASSEMBLY​
FIGURE 6-9. CAB DOOR TRIGGER ASSEMBLY​
FIGURE 6-10. DOOR ASSEMBLY (AG)​
FIGURE 6-11. CAB DOOR​
FIGURE 6-12. DOOR STRAP INSTALLATION​
FIGURE 6-13. REAR WINDOW INSTALLATION​
FIGURE 6-14. REAR WINDOW ASSEMBLY​
FIGURE 6-15. ENCLOSED CAB PLUG GROUP​
FIGURE 6-16. INTERIOR MIRROR INSTALLATION​
FIGURE 6-17. FRONT WIPER INSTALLATION​
FIGURE 6-18. LEVEL INDICATOR INSTALLATION​
FIGURE 6-19. ENCLOSED CAB TRIM INSTALLATION​
FIGURE 6-20. DASH COVER ASSEMBLY​
FIGURE 6-21. REAR PANEL COVER ASSEMBLY​
FIGURE 6-22. ADJUSTABLE ARMREST INSTALLATION​
FIGURE 6-23. ARMREST​
FIGURE 6-24. FIXED ARMREST BRACKET​
FIGURE 6-25. MOVING ARMREST BRACKET​
FIGURE 6-26. BEACON INSTALLATION​
FIGURE 6-27. WASHER HOSES INSTALLATION​
FIGURE 6-28. HAMMER INSTALLATION​
FIGURE 6-29. HAMMER ATTACHMENT ASSEMBLY​
FIGURE 6-30. FRONT COVER INSTALLATION​
FIGURE 6-31. FILTER TRAY PANEL​
FIGURE 6-32. FRONT DUCT COVER​
FIGURE 6-33. WASHER TANK INSTALLATION​
FIGURE 6-34. WASHER BOTTLE​
FIGURE 6-35. SEAT INSTALLATION (AIR SUSPENSION - STANDARD)​
FIGURE 6-36. SEAT ASSEMBLY (AIR SUSPENSION - STANDARD)​
FIGURE 6-37. UPPER SEAT ASSEMBLY​
FIGURE 6-38. SUSPENSION KIT​
FIGURE 6-39. SEAT INSTALLATION (PREMIUM)​
FIGURE 6-40. SEAT ASSEMBLY (AIR SUSPENSION - PREMIUM)​
FIGURE 6-41. SEAT INSTALLATION (MECHANICAL)​
FIGURE 6-42. SEAT ASSEMBLY​
FIGURE 6-43. SEAT BELT INSTALLATION (2IN)​
FIGURE 6-44. SEAT BELT INSTALLATION (3IN)​
FIGURE 6-45. HEATER INSTALLATION​
FIGURE 6-46. HEATER ASSEMBLY​
FIGURE 6-47. HEATER​
FIGURE 6-48. HEATER AND A/C INSTALLATION​
FIGURE 6-49. CAB CONDENSER ASSEMBLY​
FIGURE 6-50. CONDENSER​
FIGURE 6-51. A/C RECEIVER DRIER​
FIGURE 6-52. HEATER AND A/C ASSEMBLY​
FIGURE 6-53. HEATER AND A/C​
FIGURE 6-54. ROOF WIPER INSTALLATION​
FIGURE 6-55. HEADLINER INSTALLATION​
FIGURE 6-56. HEADLINER/ RADIO READY INSTALLATION​
FIGURE 6-57. CAB GUARD INSTALLATION (TOP)​
FIGURE 6-58. CAB GUARD INSTALLATION (FRONT)​
FIGURE 6-59. CAB GUARD INSTALLATION (TOP AND FRONT)​
FIGURE 6-60. COMMON CAB TRIM INSTALLATION​
FIGURE 6-61. CAB TRIM INSTALLATION​
FIGURE 6-62. ROOF CAP INSTALLATION (A/C)​
FIGURE 6-63. ROOF CAP INSTALLATION (NO A/C)​
FIGURE 6-64. FRONT NOSE CONE INSTALLATION (SIDELIGHT)​
FIGURE 6-65. RETRACTABLE SUNSCREEN INSTALLATION​
FIGURE 6-66. CAB STEP INSTALLATION​
FIGURE 6-67. FLOOR MAT INSTALLATION​
FIGURE 6-68. EXTERNAL WINDOW RELEASE INSTALLATION (ANSI)​
FIGURE 6-69. EXTERNAL WINDOW RELEASE INSTALLATION (CAN & ISO)​
SECTION 7 - CONTROLS
FIGURE 7-1. ACCELERATOR PEDAL INSTALLATION​
FIGURE 7-2. ACCELERATOR PEDAL​
FIGURE 7-3. BRAKE PEDAL INSTALLATION​
FIGURE 7-4. BRAKE PEDAL​
FIGURE 7-5. BRAKE PEDAL PLATE​
FIGURE 7-6. BRAKE SENSOR INSTALLATION​
FIGURE 7-7. SWITCH PLATE ASSEMBLY​
FIGURE 7-8. PARKING BRAKE INSTALLATION (CABLE - STANDARD)​
FIGURE 7-9. PARKING BRAKE COVER (MECHANICAL)​
FIGURE 7-10. PARKING CABLE ASSEMBLY (MECHANICAL)​
FIGURE 7-11. PARKING BRAKE INSTALLATION (SAHR - OPTIONAL)​
FIGURE 7-12. STEERING WHEEL INSTALLATION​
FIGURE 7-13. STEERING WHEEL​
FIGURE 7-14. STEERING COLUMN INSTALLATION​
FIGURE 7-15. TILT STEERING COLUMN​
FIGURE 7-16. HORN INSTALLATION​
FIGURE 7-17. HORN BUTTON INSTALLATION​
FIGURE 7-18. JOYSTICK INSTALLATION​
FIGURE 7-19. WIPER-TURN SWITCH (0 SPEED - FNR)​
FIGURE 7-20. WIPER-TURN SWITCH (NO SPEED)​
SECTION 8 - HYDRAULIC CIRCUITS
FIGURE 8-1. COMMON HYDRAULICS INSTALLATION (PVC 1911)​
FIGURE 8-2. COMMON HYDRAULICS INSTALLATION (PVC 2005)​
FIGURE 8-3. ACOUSTIC DAMPENER INSTALLATION​
FIGURE 8-4. AUXILIARY HYDRAULICS INSTALLATION - REAR (TWIN)​
FIGURE 8-5. AUXILIARY HYDRAULICS INSTALLATION - REAR (SINGLE)​
FIGURE 8-6. BOOM HYDRAULIC INSTALLATION​
FIGURE 8-7. BOOM LINES INSTALLATION​
FIGURE 8-8. BOOM RAISE HOSES INSTALLATION (NO RIDE CONTROL) (PVC 1911)​
FIGURE 8-9. BOOM RAISE HOSES INSTALLATION (NO RIDE CONTROL) (PVC 2005)​
FIGURE 8-10. BOOM RAISE HOSES INSTALLATION (WITH RIDE CONTROL)​
FIGURE 8-11. BRAKE LINES INSTALLATION​
FIGURE 8-12. BRAKE LINES INSTALLATION​
FIGURE 8-13. BRAKE INSTALLATION - TRAILER​
FIGURE 8-14. BRAKE ACCUMULATOR INSTALLATION​
FIGURE 8-15. BRAKE ACCUMULATOR LINES INSTALLATION (WITHOUT SAHR)​
FIGURE 8-16. BRAKE ACCUMULATOR LINES INSTALLATION (WITH SAHR)​
FIGURE 8-17. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - TWIN)​
FIGURE 8-18. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - SINGLE)​
FIGURE 8-19. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - TWIN)​
FIGURE 8-20. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - SINGLE)​
FIGURE 8-21. LIFT CYLINDER INSTALLATION (Prior to SN E160000638)​
FIGURE 8-22. LIFT CYLINDER INSTALLATION (SN E160000638 to Present)​
FIGURE 8-23. MAIN CONTROL VALVE INSTALLATION​
FIGURE 8-24. MAIN HYDRAULIC PUMP INSTALLATION​
FIGURE 8-25. IMPLEMENT PUMP INSTALLATION​
FIGURE 8-26. PRIORITY LINES INSTALLATION (PVC 1911)​
FIGURE 8-27. PRIORITY LINES INSTALLATION (PVC 2005)​
FIGURE 8-28. PRIORITY VALVE INSTALLATION​
FIGURE 8-29. RETURN LINES INSTALLATION​
FIGURE 8-30. RETURN LINES INSTALLATION (SAHR)​
FIGURE 8-31. STEERING LINES INSTALLATION​
FIGURE 8-32. STEER SELECT VALVE INSTALLATION​
FIGURE 8-33. SUCTION LINES INSTALLATION (PVC 1911)​
FIGURE 8-34. SUCTION LINES INSTALLATION (PVC 2005)​
SECTION 9 - HYDRAULIC COMPONENTS
FIGURE 9-1. CYLINDER ASSEMBLY - COMPENSATION (Prior to SN E160000638)​
FIGURE 9-2. CYLINDER ASSEMBLY - COMPENSATION (SN E160000638 to Present)​
FIGURE 9-3. CYLINDER SUB-ASSEMBLY - COUPLER LOCKING​
FIGURE 9-4. CYLINDER ASSEMBLY - COUPLER LOCKING​
FIGURE 9-5. CYLINDER SUB-ASSEMBLY - EXTEND/RETRACT (TELESCOPE)​
FIGURE 9-6. CYLINDER ASSEMBLY - EXTEND/RETRACT (TELESCOPE)​
FIGURE 9-7. CYLINDER ASSEMBLY - LIFT​
FIGURE 9-8. CYLINDER ASSEMBLY - TIFT​
FIGURE 9-9. IMPLEMENT PUMP​
FIGURE 9-10. VALVE SUB-ASSEMBLY - DIVERTOR (HI-FLOW)​
FIGURE 9-11. VALVE ASSEMBLY - DIVERTOR​
FIGURE 9-12. VALVE ASSEMBLY - DIVERTOR​
FIGURE 9-13. VALVE ASSEMBLY - DIVERTOR​
FIGURE 9-14. VALVE ASSEMBLY - FAN MOTOR CONTROL​
FIGURE 9-15. VALVE ASSEMBLY - HYDRAULIC HITCH CONTROL VALVE​
FIGURE 9-16. VALVE ASSEMBLY - MAIN CONTROL​
FIGURE 9-17. VALVE ASSEMBLY - PRIORITY FLOW MANIFOLD​
FIGURE 9-18. VALVE ASSEMBLY - RIDE CONTROL​
FIGURE 9-19. VALVE ASSEMBLY - STEERING SELECT VALVE​
FIGURE 9-20. VALVE ASSEMBLY - TRAILER BRAKE​
SECTION 10 - ELECTRICAL
FIGURE 10-1. BATTERY INSTALLATION (STANDARD) (PVC 1911)​
FIGURE 10-2. BATTERY INSTALLATION (STANDARD) (PVC 2005)​
FIGURE 10-3. BATTERY INSTALLATION (DUAL)​
FIGURE 10-4. BEACON/STROBE INSTALLATION​
FIGURE 10-5. BOOM HARNESS INSTALLATION​
FIGURE 10-6. BOOM HARNESS​
FIGURE 10-7. BOOM ANGLE SENSOR INSTALLATION​
FIGURE 10-8. CAB ELECTRICAL INSTALLATION​
FIGURE 10-9. CAB HARNESS​
FIGURE 10-10. CAB STANDARD ELECTRICAL BOARD ASSEMBLY​
FIGURE 10-11. CAB OPTION 1 ELECTRICAL BOARD ASSEMBLY​
FIGURE 10-12. CAB OPTION 2 ELECTRICAL BOARD ASSEMBLY​
FIGURE 10-13. CAB OPTION HARNESS​
FIGURE 10-14. CAB HEATER HARNESS INSTALLATION​
FIGURE 10-15. CAB HEATER HARNESS​
FIGURE 10-16. HVAC CAB ACTUATOR​
FIGURE 10-17. CAB HVAC ACTUATOR HARNESS​
FIGURE 10-18. CAB - MULTIFUNCTION DISPLAY INSTALLATION​
FIGURE 10-19. CAB SEAT ADAPTOR HARNESS (PREMIUM SEAT)​
FIGURE 10-20. CLEARSKY INSTALLATION (NO A/C - LONG ROOF CAP)​
FIGURE 10-21. CLEARSKY INSTALLATION (NO A/C - SHORT ROOF CAP)​
FIGURE 10-22. CLEARSKY HARNESS​
FIGURE 10-23. DASH ELECTRICS INSTALLATION (ULS) (PVC 1911)​
FIGURE 10-24. DASH ELECTRICS INSTALLATION (ULS) (PVC 2005)​
FIGURE 10-25. CAB DASH ELECTRICAL INSTALLATION (LS)​
FIGURE 10-26. DECLUTCH SWITCH INSTALLATION​
FIGURE 10-27. EARTH STRAP INSTALLATION​
FIGURE 10-28. ELECTRICAL COMPONENTS INSTALLATION​
FIGURE 10-29. ELECTRICAL POWER DISTRIBUTION ELECTRICAL BOX​
FIGURE 10-30. ELECTRICAL RELAY INSTALLATION - 200 AMP​
FIGURE 10-31. ENGINE WIRING INSTALLATION (ULS)​
FIGURE 10-32. ENGINE WIRING INSTALLATION (LS)​
FIGURE 10-33. ENGINE HARNESS (ULS) (PVC 1911)​
FIGURE 10-34. ENGINE HARNESS (ULS) (PVC 2005)​
FIGURE 10-35. ENGINE HARNESS (LS)​
FIGURE 10-36. ENGINE FUEL PUMP HARNESS​
FIGURE 10-37. ENGINE GLOW PLUG RELAY HARNESS​
FIGURE 10-38. ENGINE SPEED SET SWITCH INSTALLATION​
FIGURE 10-39. FRAME MAIN ELECTRICAL INSTALLATION​
FIGURE 10-40. FRAME HARNESS - REAR​
FIGURE 10-41. FRAME HARNESS - FRONT​
FIGURE 10-42. IGNITION SWITCH INSTALLATION​
FIGURE 10-43. LIGHTS - DIP LIGHTS INSTALLATION (LH)​
FIGURE 10-44. LIGHTS - DIP LIGHTS INSTALLATION (RH)​
FIGURE 10-45. LIGHTS - LICENSE PLATE LAMP INSTALLATION​
FIGURE 10-46. LIGHTS - LICENSE PLATE LAMP HARNESS​
FIGURE 10-47. LIGHTS - NO ROADLIGHTS INSTALLATION​
FIGURE 10-48. LIGHTS - WORKLIGHTS INSTALLATION (BOOM MOUNTED)​
FIGURE 10-49. LIGHTS - WORKLIGHTS INSTALLATION - LED (BOOM MOUNTED)​
FIGURE 10-50. LIGHTS - WORKLIGHTS HARNESS (BOOM MOUNTED LIGHTS)​
FIGURE 10-51. LIGHTS - WORKLIGHTS INSTALLATION (CAB MOUNTED) (NO A/C)​
FIGURE 10-52. LIGHTS - WORKLIGHTS INSTALLATION - LED (CAB MOUNTED) (NO A/C)​
FIGURE 10-53. LIGHTS - WORKLIGHTS INSTALLATION (CAB MOUNTED) (WITH A/C)​
FIGURE 10-54. LIGHTS - WORKLIGHTS INSTALLATION -LED (CAB MOUNTED) (WITH A/C)​
FIGURE 10-55. LSI SENSOR INSTALLATION​
FIGURE 10-56. LSI DISPLAY INSTALLATION​
FIGURE 10-57. LSI SENSOR INSTALLATION​
FIGURE 10-58. LSI SWITCH INSTALLATION​
FIGURE 10-59. LSI SENSOR COVER INSTALLATION​
FIGURE 10-60. REVERSE ALARM INSTALLATION​
FIGURE 10-61. REVERSE CAMERA INSTALLATION​
FIGURE 10-62. REVERSE SENSING INSTALLATION​
FIGURE 10-63. REVERSE SENSING HARNESS​
FIGURE 10-64. TRAILER ELECTRICS INSTALLATION​
FIGURE 10-65. TRAILER CONNECTOR HARNESS​
SECTION 11 - DECALS
FIGURE 11-1. DECALS INSTALLATION (ANSI) (PVC 1911)​
FIGURE 11-2. DECALS INSTALLATION (ANSI) (PVC 2005)​
FIGURE 11-3. DECALS INSTALLATION (AUS & LATIN AMERICA)​
FIGURE 11-4. DECALS INSTALLATION - JLG - (LATIN AMERICA SPECS)​
FIGURE 11-5. DECALS INSTALLATION - JLG (ANSI & CSA SPECS)​
FIGURE 11-6. CAPACITY CHART (ANSI) (PVC 1911)​
FIGURE 11-7. CAPACITY CHART (ANSI) (PVC 2005)​
FIGURE 11-8. CAPACITY CHART HOLDER INSTALLATION​
SECTION 12 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK​
SECTION 13 - SPECIAL OPTIONS
FIGURE 13-1. SPECIAL OPTIONS​
PART NUMBER INDEX
