JLG Telehandler 919 Parts Manual 3122243500
Brand: JLG
Type of Machine: Telehandler
Model: JLG 919 Telehandler
Part Number: 3122243500
Publication Date: 2025
Number of Pages: 584 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME COMPONENTS INSTALLATION
FIGURE 1-2. FRAME COVERS ASSEMBLY
FIGURE 1-3. ENCLOSURE INSTALLATION
FIGURE 1-4. FUEL TANK INSTALLATION
FIGURE 1-5. HOOD INSTALLATION
FIGURE 1-6. HYDRAULIC TANK INSTALLATION
FIGURE 1-7. TANK ASSEMBLY - FUEL
FIGURE 1-8. TANK ASSEMBLY - HYDRAULIC
SECTION 2 - BOOMFIGURE 2-1. BOOM INSTALLATION
FIGURE 2-2. BOOM ASSEMBLY
FIGURE 2-3. BOOM BASE ASSEMBLY
FIGURE 2-4. BOOM FLY ASSEMBLY
FIGURE 2-5. BOOM ANGLE INDICATOR INSTALLATION
FIGURE 2-6. BOOM PROP INSTALLATION
FIGURE 2-7. COUPLER INSTALLATION (HYDRAULIC)
FIGURE 2-8. COUPLER INSTALLATION - UNIVERSAL (HYDRAULIC)
FIGURE 2-9. COUPLER ASSEMBLY - UNIVERSAL
FIGURE 2-10. COUPLER INSTALLATION (MANUAL)
FIGURE 2-11. COUPLER INSTALLATION, UNIVERSAL (MANUAL)
FIGURE 2-12. FORK LOCKING CYLINDER KIT
FIGURE 2-13. TELESCOPE CYLINDER INSTALLATION
SECTION 3 - ATTACHMENTSFIGURE 3-1. BASKET, PERSONNEL (1.2MX2.4M) (DOMESTIC)
FIGURE 3-2. BASKET, PERSONNEL (1.2MX2.4M) (ISO)
FIGURE 3-3. BASKET, PERSONNEL (1.2MX2.4M) (FRENCH)
FIGURE 3-4. BOLT-ON EDGE ASSEMBLY, 72"
FIGURE 3-5. CARRIAGE, SIDE TILT, (48IN)
FIGURE 3-6. CARRIAGE, SIDE TILT, UNIVERSAL QUICK ATTACH, (48IN)
FIGURE 3-7. CARRIAGE, SIDE SHIFT (48IN)
FIGURE 3-8. CARRIAGE, SIDE SHIFT, UNIVERSAL QUICK ATTACH, (48IN)
FIGURE 3-9. CARRIAGE ASSEMBLY - 48IN STANDARD
FIGURE 3-10. CARRIAGE ASSEMBLY - 48IN UNIVERSAL
FIGURE 3-11. CARRIAGE ASSEMBLY - FORK POSITIONING STANDARD (48IN)
FIGURE 3-12. CARRIAGE ASSEMBLY - FORK POSITIONING UNIVERSAL (48IN)
FIGURE 3-13. FORK MOUNTED HOOK (4 TON)
FIGURE 3-14. FORK MOUNTED PLATFORM
FIGURE 3-15. FORK 2.00X4X48 / 3800# CAPACITY
FIGURE 3-16. FORK 2.00X5X60 / 6850# CAPACITY (SN 0160140396 to Present)
FIGURE 3-17. FORK 2.36 X5X72 / 6850# CAPACITY (SN 0160140396 to Present)
FIGURE 3-18. LIFTING HOOK ASSEMBLY, STANDARD
FIGURE 3-19. LIFTING HOOK ASSEMBLY, UNIVERSAL
FIGURE 3-20. LIGHT MATERIAL BUCKET, (72INCH) (1.7 YD³/1.29 M³)
FIGURE 3-21. LIGHT MATERIAL BUCKET, (72INCH) (1.0 YD³/0.76 M³)
FIGURE 3-22. MULTI-PURPOSE GRAPPLE BUCKET (1850MM)
FIGURE 3-23. UNIVERSAL HITCH ATTACHMENT
FIGURE 3-24. QUICK SWITCH ASSEMBLY
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE ASSEMBLY (HRC)
FIGURE 4-2. ENGINE ASSEMBLY (LRC)
FIGURE 4-3. ENGINE MOUNTS INSTALLATION
FIGURE 4-4. ENGINE WIRING INSTALLATION
FIGURE 4-5. ENGINE AIR INTAKE INSTALLATION
FIGURE 4-6. ENGINE FUEL LINES INSTALLATION
FIGURE 4-7. ENGINE PUMP ADAPTOR INSTALLATION
FIGURE 4-8. ENGINE PUMP INSTALLATION
FIGURE 4-9. ENGINE MODULE INSTALLATION
FIGURE 4-10. ENGINE COOLING INSTALLATION
FIGURE 4-11. ENGINE EXHAUST INSTALLATION
FIGURE 4-12. ENGINE HEATER INSTALLATION
FIGURE 4-13. AIR CLEANER ASSEMBLY
FIGURE 4-14. AC LINES INSTALLATION
FIGURE 4-15. AC PUMP INSTALLATION
FIGURE 4-16. COOLANT EXPANSION TANK INSTALLATION
FIGURE 4-17. COOLANT LINES INSTALLATION
FIGURE 4-18. FAN GUARD INSTALLATION
FIGURE 4-19. FAN INSTALLATION - COOLING
FIGURE 4-20. HEATER HOSE INSTALLATION
FIGURE 4-21. RADIATOR ASSEMBLY
FIGURE 4-22. QUICKFIT OIL CHANGE ASSEMBLY
SECTION 5 - DRIVE TRAINFIGURE 5-1. FRONT AXLE ASSEMBLY
FIGURE 5-2. FRONT AXLE ASSEMBLY - CENTER HOUSING
FIGURE 5-3. FRONT AXLE ASSEMBLY - DIFFERENTIAL
FIGURE 5-4. FRONT AXLE ASSEMBLY - HUB REDUCTION (LH)
FIGURE 5-5. FRONT AXLE ASSEMBLY - HUB REDUCTION (RH)
FIGURE 5-6. FRONT AXLE ASSEMBLY - BRAKES
FIGURE 5-7. FRONT AXLE ASSEMBLY - STEERING
FIGURE 5-8. AXLE ASSEMBLY - REAR
FIGURE 5-9. REAR AXLE ASSEMBLY - CENTER HOUSING
FIGURE 5-10. REAR AXLE ASSEMBLY - DIFFERENTIAL
FIGURE 5-11. REAR AXLE ASSEMBLY - HUB REDUCTION (LH)
FIGURE 5-12. REAR AXLE ASSEMBLY - HUB REDUCTION (RH)
FIGURE 5-13. REAR AXLE ASSEMBLY - STEERING
FIGURE 5-14. REAR AXLE ASSEMBLY - TRUNION
FIGURE 5-15. DRIVE TRAIN INSTALLATION
FIGURE 5-16. DRIVE MOTER INSTALLATION
FIGURE 5-17. FENDER INSTALLATION
FIGURE 5-18. FENDER INSTALLATION (CAB)
FIGURE 5-19. FENDER ASSEMBLY (Prior to SN 0160141665)
FIGURE 5-20. FENDER ASSEMBLY (SN 0160141666 to Present)
FIGURE 5-21. TIRE SET - 12 X 16.5 PHUEMATIC
FIGURE 5-22. TIRE SET - 12 X 16.5 FOAM-FILLED
FIGURE 5-23. TIRE SET - 33 X 12-20 NON MARKING
FIGURE 5-24. TIRE SET - 33 X 16 TURF
FIGURE 5-25. TIRE SET - 33 X 16 AG
FIGURE 5-26. RIGHT TIRE/WHEEL ASSEMBLY, CAMSO (AIR 12-16.5 - 12 PLY)
FIGURE 5-27. LEFT TIRE/WHEEL ASSEMBLY, CAMSO (AIR 12-16.5 - 12 PLY)
SECTION 6 - CABFIGURE 6-1. CAB TRIM INSTALLATION - OPEN CAB (Prior to SN 0160139500)
FIGURE 6-2. CAB TRIM INSTALLATION - OPEN CAB (SN 0160139501 to Present)
FIGURE 6-3. CAB TRIM INSTALLATION - CLOSED CAB (Prior to SN 0160139500)
FIGURE 6-4. CAB TRIM INSTALLATION - CLOSED CAB (SN 0160139501 to Present)
FIGURE 6-5. CAB ASSEMBLY - OPEN CAB
FIGURE 6-6. CAB ASSEMBLY - CLOSED CAB (Prior to SN 0160145681)
FIGURE 6-7. CAB ASSEMBLY - CLOSED CAB (SN 0160145682 to Present)
FIGURE 6-8. CAB NO HEAT INSTALLATION
FIGURE 6-9. CAB HEATER INSTALLATION
FIGURE 6-10. CAB HEATER/AC INSTALLATION
FIGURE 6-11. CAB MAT INSTALLATION
FIGURE 6-12. CAB MOUNTS INSTALLATION
FIGURE 6-13. CAB DUCT INSTALLATION
FIGURE 6-14. CAB GUARD INSTALLATION (TOP)
FIGURE 6-15. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-16. AC CONDENSER INSTALLATION
FIGURE 6-17. A/C RECEIVER DRIER
FIGURE 6-18. ARMREST/CONSOLE INSTALLATION
FIGURE 6-19. COLUMN SHIFT INSTALLATION
FIGURE 6-20. CONDENSER
FIGURE 6-21. DECAL INSTALLATION - EMERGENCY EXIT
FIGURE 6-22. DOOR ASSEMBLY - CAB
FIGURE 6-23. FIRE EXTINGUISHER INSTALLATION
FIGURE 6-24. HEADLINER INSTALLATION (Prior to SN 0160142888)
FIGURE 6-25. HEADLINER INSTALLATION (SN 0160142889 to Present)
FIGURE 6-26. HEATER INSTALLATION - HEAT/AC
FIGURE 6-27. HEATER INSTALLATION - HEAT ONLY
FIGURE 6-28. HEATER ASSEMBLY - HEAT ONLY
FIGURE 6-29. HEATER ASSEMBLY - HEAT/AC
FIGURE 6-30. LEVEL INDICATOR INSTALLATION
FIGURE 6-31. MIRROR INSTALLATION
FIGURE 6-32. MIRRORS INSTALLATION
FIGURE 6-33. MOTOR ASSEMBLY - WIPER
FIGURE 6-34. NO ENGINE SPEED SET SWITCH INSTALLATION
FIGURE 6-35. SEAT INSTALLATION - STANDARD
FIGURE 6-36. SEAT INSTALLATION - SEAOP
FIGURE 6-37. SEAT ASSEMBLY - STANDARD
FIGURE 6-38. SEAT ASSEMBLY - VINYL
FIGURE 6-39. SEAT BELT INSTALLATION (2IN) (Prior to SN 0160146763)
FIGURE 6-40. SEAT BELT INSTALLATION (3IN)
FIGURE 6-41. SECONDARY EXIT INSTALLATION (CA SPECS)
FIGURE 6-42. SECONDARY EXIT INSTALLATION (ANSI SPECS)
FIGURE 6-43. SECONDARY EXIT INSTALLATION (ISO SPECS)
FIGURE 6-44. SECONDARY EXIT INSTALLATION (ENGLISH/SPANISH LANGUAGES)
FIGURE 6-45. STEERING COLUMN INSTALLATION - FIXED
FIGURE 6-46. STEERING COLUMN ASSEMBLY - FIXED
FIGURE 6-47. STEERING COLUMN INSTALLATION - TILT
FIGURE 6-48. STEERING COLUMN ASSEMBLY - TILT
FIGURE 6-49. STEERING WHEEL INSTALLATION
FIGURE 6-50. WASHER HOSE PASS THROUGH INSTALLATION
FIGURE 6-51. WINDOW WASHER INSTALLATION
FIGURE 6-52. WINDOW ASSEMBLY - REAR
FIGURE 6-53. WIPER INSTALLATION - FRONT
FIGURE 6-54. WIPER INSTALLATION - REAR WINDOW
FIGURE 6-55. WIPER INSTALLATION - ROOF
SECTION 7 - CONTROLSFIGURE 7-1. JOYSTICK INSTALLATION
FIGURE 7-2. PEDAL INSTALLATION - ACCELERATOR
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL ASSEMBLY
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. BOOM HYDRAULIC INSTALLATION
FIGURE 8-2. HOSE INSTALLATION - BOOM
FIGURE 8-3. HOSE INSTALLATION - CAB
FIGURE 8-4. HOSE INSTALLATION - ENGINE BAY
FIGURE 8-5. HOSE INSTALLATION - FRAME
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. BOOM AUX HYDRAULIC INSTALLATION (MANUAL - SINGLE)
FIGURE 9-2. BOOM AUX HYDRAULIC INSTALLATION (HYDRAULIC - TWIN)
FIGURE 9-3. BOOM AUX HYDRAULIC INSTALLATION (FLAT FACE)
FIGURE 9-4. BOOM AUX HYDRAULIC INSTALLATION (UNIVERSAL COUPLER)
FIGURE 9-5. BOOM AUXILIARY HYDRAULIC VALVE INSTALLATION
FIGURE 9-6. CYLINDERS INSTALLATION (Prior to SN 0160142888)
FIGURE 9-7. CYLINDERS INSTALLATION (SN 0160142889 to Present)
FIGURE 9-8. CYLINDER ASSEMBLY - COMP (Prior to SN 0160142888)
FIGURE 9-9. CYLINDER ASSEMBLY - COMP (SN 0160142889 to Present)
FIGURE 9-10. CYLINDER ASSEMBLY - EXTEND/RETRACT
FIGURE 9-11. CYLINDER ASSEMBLY - FORK LOCKING
FIGURE 9-12. CYLINDER ASSEMBLY - FORK POSITIONING
FIGURE 9-13. CYLINDER ASSEMBLY - LIFT (Prior to SN 0160142888)
FIGURE 9-14. CYLINDER ASSEMBLY - LIFT (SN 0160142889 to Present)
FIGURE 9-15. CYLINDER ASSEMBLY - SIDE TILT CARRIAGE
FIGURE 9-16. CYLINDER ASSEMBLY - TILT
FIGURE 9-17. CYLINDER ASSEMBLY - UNIVERSAL SIDE SHIFT
FIGURE 9-18. DIVERTOR VALVE
FIGURE 9-19. DRIVE MOTOR ASSEMBLY
FIGURE 9-20. MAIN CONTROL VALVE INSTALLATION
FIGURE 9-21. MAIN CONTROL VALVE ASSEMBLY (Prior to SN 0160141920)
FIGURE 9-22. MAIN CONTROL VALVE ASSEMBLY (SN 0160141921 to Present)
FIGURE 9-23. PRIORITY VALVE INSTALLATION
FIGURE 9-24. PRIORITY VALVE ASSEMBLY
FIGURE 9-25. PUMP ASSEMBLY
FIGURE 9-26. PUMP ASSEMBLY
FIGURE 9-27. REMOTE GREASE INSTALLATION
FIGURE 9-28. SAHR BRAKE VALVE INSTALLATION
FIGURE 9-29. SAHR VALVE INSTALLATION
FIGURE 9-30. SAHR BRAKE VALVE AND FITTING ASSEMBLY
FIGURE 9-31. STEERING SELECT VALVE INSTALLATION
FIGURE 9-32. STEERING SELECT VALVE ASSEMBLY
FIGURE 9-33. STEER VALVE ASSEMBLY
FIGURE 9-34. WATCH DOG VALVE INSTALLATION
FIGURE 9-35. WATCH DOG VALVE AND FITTING ASSEMBLY
FIGURE 9-36. VALVE AUX HYDRAULIC INSTALLATION
FIGURE 9-37. VALVE ASSEMBLY - MAIN CONTROL VALVE (Prior to SN 0160141920)
FIGURE 9-38. MAIN CONTROL VALVE ASSEMBLY (SN 0160141921 to Present)
FIGURE 9-39. VALVE ASSEMBLY - STEERING SELECT
FIGURE 9-40. VALVE ASSEMBLY - WATCHDOG
FIGURE 9-41. VALVE ASSEMBLY, - BLOCK
SECTION 10 - ELECTRICALFIGURE 10-1. A/C OPTION HARNESS
FIGURE 10-2. ALARM INSTALLATION - BACK UP
FIGURE 10-3. ALARM INSTALLATION - WHITE NOISE
FIGURE 10-4. BATTERY INSTALLATION
FIGURE 10-5. BATTERY DISCONNECT INSTALLATION
FIGURE 10-6. BATTERY DISCONNECT INSTALLATION (SWITCH NONE)
FIGURE 10-7. CLEARSKY CS550 BEACON INSTALLATION (WITHOUT A/C)
FIGURE 10-8. CLEARSKY CS550 BEACON INSTALLATION (WITH A/C)
FIGURE 10-9. CLEARSKY HARNESS - CS550 BEACON
FIGURE 10-10. BEACON WORKLIGHT HARNESS
FIGURE 10-11. BOOM WORKLIGHT JUMPER HARNESS
FIGURE 10-12. BOOM AUX HARNESS
FIGURE 10-13. CAB ELECTRICAL INSTALLATION
FIGURE 10-14. CAB HARNESS
FIGURE 10-15. CAB HARNESS (ENCLOSED CAB)
FIGURE 10-16. CAB HARNESS - OPTION
FIGURE 10-17. CAMERA INSTALLATION - REVERSE
FIGURE 10-18. DASH SWITCHES INSTALLATION
FIGURE 10-19. ENGINE HARNESS
FIGURE 10-20. FRAME ELECTRICAL COMPONENTS INSTALLATION
FIGURE 10-21. FRAME HARNESS INSTALLATION
FIGURE 10-22. FRAME HARNESS
FIGURE 10-23. FRAME HARNESS
FIGURE 10-24. FUSEBOX ASSEMBLY - FRAME
FIGURE 10-25. HEADLIGHTS HARNESS
FIGURE 10-26. HEADLIGHT/WORKLIGHT OPTIONAL HARNESS
FIGURE 10-27. LIGHTS - ROADLIGHTS INSTALLATION
FIGURE 10-28. LIGHTS - WORKLIGHTS INSTALLATION
FIGURE 10-29. LSI INSTALLATION - OPEN CAB
FIGURE 10-30. LSI INSTALLATION - ENCLOSED CAB
FIGURE 10-31. LSI SENSOR INSTALLATION
FIGURE 10-32. LSI OVERRIDE HARNESS (SN 0160146255 to Present)
FIGURE 10-33. LSI PIGTAIL HARNESS
FIGURE 10-34. REVERSE SENSING INSTALLATION
FIGURE 10-35. REVERSE SENSOR HARNESS
FIGURE 10-36. SEAT BELT ALARM HARNESS
FIGURE 10-37. TAILLIGHTS HARNESS
FIGURE 10-38. VALVE JUMPER HARNESS
SECTION 11 - DECALSFIGURE 11-1. DECALS INSTALLATION - INFO (ANSI SPECS)
FIGURE 11-2. DECALS INSTALLATION - INFO (ISO SPECS)
FIGURE 11-3. DECALS INSTALLATION - INFO (ENGLISH/FRENCH LANGUAGES)
FIGURE 11-4. DECALS INSTALLATION - INFO (ENGLISH/SPANISH LANGUAGES)
FIGURE 11-5. DECALS INSTALLATION - BRAND (OPEN CAB)
FIGURE 11-6. DECALS INSTALLATION - BRAND (CLOSED CAB)
FIGURE 11-7. DECAL INSTALLATION - CLEARSKY CS550 BEACON
FIGURE 11-8. LOAD CHART (ANSI SPECS)
FIGURE 11-9. LOAD CHART (METRIC SPECS)
FIGURE 11-10. REVERSE SENSOR SYSTEM DECAL (ENGLISH)
FIGURE 11-11. REVERSE SENSOR SYSTEM DECAL (ISO)
FIGURE 11-12. REVERSE SENSING SYSTEM DECAL, (ENGLISH/FRENCH)
FIGURE 11-13. REVERSE SENSOR SYSTEM DECAL (ENGLISH/SPANISH)
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
