JLG Telehandler 832 Parts Manual 31211882
Brand: JLG
Type of Machine: Telehandler
Model: JLG 832 Telehandler
Part Number: 31211882
Publication Date: 2024
Number of Pages: 876 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME INSTALLATION
FIGURE 1-2. ENGINE ENCLOSURE INSTALLATION
FIGURE 1-3. ENGINE ENCLOSURE COVER INSTALLATION
FIGURE 1-4. HOOD INSTALLATION
FIGURE 1-5. COVER PLATES INSTALLATION (NO OUTRIGGERS - ULS)
FIGURE 1-6. COVER PLATE INSTALLATION (NO TRAILER BRAKES)
FIGURE 1-7. COVER PLATE INSTALLATION (TRAILER BRAKES)
FIGURE 1-8. COVER PLATE INSTALLATION (NO REAR AUX)
FIGURE 1-9. COVER PLATE INSTALLATION (REAR AUX)
FIGURE 1-10. COVER PLATE INSTALLATION (HYDRAULIC HITCH AND REAR AUX)
FIGURE 1-11. REAR COVER PLATE INSTALLATION (NO HYDRAULIC HITCH)
FIGURE 1-12. TANKS INSTALLATION
FIGURE 1-13. FUEL TANK INSTALLATION
FIGURE 1-14. FUEL TANK ASSEMBLY
FIGURE 1-15. HYDRAULIC TANK INSTALLATION
FIGURE 1-16. HYDRAULIC TANK ASSEMBLY
FIGURE 1-17. FUEL AND HYDRAULIC CAP INSTALLATION
FIGURE 1-18. HITCH RETRIEVAL INSTALLATION
FIGURE 1-19. HITCH INSTALLATION (EEC AUTO)
FIGURE 1-20. HITCH INSTALLATION (PITON)
FIGURE 1-21. HITCH ASSEMBLY (EEC AUTO)
FIGURE 1-22. SLIDING HITCH ASSEMBLY (PITON)
FIGURE 1-23. HITCH INSTALLATION (EEC MANUAL)
FIGURE 1-24. HITCH ASSEMBLY (EEC MANUAL)
FIGURE 1-25. HITCH INSTALLATION (FIXED)
FIGURE 1-26. HITCH ASSEMBLY (FIXED)
FIGURE 1-27. HITCH INSTALLATION (HYDRAULIC)
FIGURE 1-28. CAB PLUG INSTALLATION (NON HYDRAULIC HITCH)
FIGURE 1-29. MIRROR INSTALLATION
FIGURE 1-30. REAR MIRROR INSTALLATION (FLAT)
FIGURE 1-31. REAR MIRROR INSTALLATION (CONVEX)
FIGURE 1-32. MIRROR ASSEMBLY (CONVEX)
FIGURE 1-33. TOOLBOX INSTALLATION
FIGURE 1-34. GROUND STRAP INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM PINNING INSTALLATION
FIGURE 2-2. LIFT CYLINDER PINNING INSTALLATION
FIGURE 2-3. COMPENSATION CYLINDER PINNING INSTALLATION
FIGURE 2-4. BOOM PIVOT INSTALLATION
FIGURE 2-5. BOOM ASSEMBLY
FIGURE 2-6. FIRST BOOM SECTION ASSEMBLY
FIGURE 2-7. SECOND BOOM SECTION ASSEMBLY
FIGURE 2-8. THIRD BOOM SECTION ASSEMBLY
FIGURE 2-9. LINK ASSEMBLY
FIGURE 2-10. LEVER ASSEMBLY
FIGURE 2-11. MANUAL QUICK COUPLER INSTALLATION
FIGURE 2-12. HYDRAULIC QUICK COUPLER INSTALLATION
FIGURE 2-13. BOOM PROP INSTALLATION
FIGURE 2-14. BOOM BRUSHES INSTALLATION
SECTION 3 - ATTACHMENTSFIGURE 3-1. AUGER COUPLING
FIGURE 3-2. AUGER BIT (6INX4IN)
FIGURE 3-3. AUGER BIT (9INX4IN)
FIGURE 3-4. AUGER BIT (12INX4IN)
FIGURE 3-5. AUGER BIT (15INX4IN)
FIGURE 3-6. AUGER BIT (18INX4IN)
FIGURE 3-7. AUGER BIT (24INX4IN)
FIGURE 3-8. AUGER BIT (36INX4IN)
FIGURE 3-9. BALE HANDLER (TUBE CLAMP)
FIGURE 3-10. BALE HANDLER KIT (TUBE CLAMP)
FIGURE 3-11. BALE HANDLER (SPIKE CLAMP)
FIGURE 3-12. BALE HANDLER KIT (SPIKE CLAMP)
FIGURE 3-13. BASKET PERSONNEL (1.2MX2.4M) (DOMESTIC)
FIGURE 3-14. BASKET PERSONNEL (1.2MX2.4M) (FRENCH LANGUAGE)
FIGURE 3-15. BASKET PERSONNEL (1.2MX2.4M) (ISO)
FIGURE 3-16. BASKET PERSONNEL (FORK MOUNTED)
FIGURE 3-17. BUCKET (CONCRETE)
FIGURE 3-18. BUCKET (DIRT)
FIGURE 3-19. BUCKET (GRAPPLE MULTI-PURPOSE)
FIGURE 3-20. BUCKET (MANURE GRAPPLE)
FIGURE 3-21. BUCKET(0.6 M³) (MULTI-PURPOSE 4 IN 1)
FIGURE 3-22. BUCKET(1 M³) (GENERAL PURPOSE)
FIGURE 3-23. BUCKET(1 M³) (MULTI-PURPOSE 4 IN 1)
FIGURE 3-24. BUCKET (1.5 M³) (GENERAL PURPOSE)
FIGURE 3-25. BUCKET (2 M³) (GENERAL PURPOSE)
FIGURE 3-26. BUCKET (2.5 M³) (GENERAL PURPOSE)
FIGURE 3-27. BUCKET (3 M³) (GENERAL PURPOSE)
FIGURE 3-28. BUCKET FRONT GUARD
FIGURE 3-29. BUCKET TEETH KIT
FIGURE 3-30. CARRIAGE ASSEMBLY (1225MM)
FIGURE 3-31. CARRIAGE ASSEMBLY (1524MM)
FIGURE 3-32. CARRIAGE ASSEMBLY (1829MM)
FIGURE 3-33. CARRIAGE ASSEMBLY - SIDE TILTING (4.5 TON - 1225 MM)
FIGURE 3-34. CARRIAGE ASSEMBLY - SIDE TILTING (4.0 TON - 1575 MM)
FIGURE 3-35. CARRIAGE ASSEMBLY - SID TILTING (4.0 TON - 1829 MM)
FIGURE 3-36. CARRIAGE ASSEMBLY - SIDE SHIFT (4.0 TON - 1225 MM)
FIGURE 3-37. CARRIAGE ASSEMBLY - FORK POSITIONING (4.0 TON
FIGURE 3-38. CARRIAGE ASSEMBLY - FEM CARRIAGE AND FORKS
FIGURE 3-39. FORK - LUMBER (45X150X1540)
FIGURE 3-40. FORK - LUMBER (50X150X1830)
FIGURE 3-41. FORK - PALLET (50X100X1200)
FIGURE 3-42. FORK - PALLET (50X100X1200) (CE & AUS WITH SIDE SHIFT CARRIAAGE) (4.0 TON - 1225MM)
FIGURE 3-43. FORK - PALLET (50X120X1200)
FIGURE 3-44. FORK - PALLET (60X125X1220)
FIGURE 3-45. FORK - MUCK WITH GRAB
FIGURE 3-46. FORK - DUAL TINE BAILING WITH CARRIAGE
FIGURE 3-47. FORK _ EXTENSIONS (62X163X2286) (ANSI)
FIGURE 3-48. HOOK_CRANE (FORK MOUNTED)
FIGURE 3-49. TRASH HOPPER INSTALLATION
FIGURE 3-50. TRUSS BOOM (0.9 TON - 12 FT WITH WINCH)
FIGURE 3-51. TRUSS BOOM (1 TON - 3.4M)
FIGURE 3-52. TRUSS BOOM (1.8 TON - 3 FT WITH WINCH)
FIGURE 3-53. TRUSS BOOM (4 TON - 2.1M)
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION (90KW - ULS - PISTON PUMP)
FIGURE 4-2. ENGINE INSTALLATION (100KW - ULS - PISTON PUMP)
FIGURE 4-3. ENGINE MOUNTING INSTALLATION (90KW/100KW)
FIGURE 4-4. 3.6L ENGINE (90KW - ULS - PISTON PUMP)
FIGURE 4-5. 3.6L ENGINE (100KW - ULS - PISTON PUMP)
FIGURE 4-6. ENGINE ECU INSTALLATION (ULS)
FIGURE 4-7. BRACKET GUARD INSTALLATION
FIGURE 4-8. FUEL LINES INSTALLATION (ULS - RHOC)
FIGURE 4-9. EXHAUST INSTALLATION (ULS)
FIGURE 4-10. DEF TANK INSTALLATION (ULS)
FIGURE 4-11. DEF TANK ASSEMBLY (ULS)
FIGURE 4-12. DEF LINES INSTALLATION (ULS)
FIGURE 4-13. DEF CONTROL MODULE INSTALLATION (ULS)
FIGURE 4-14. AIR CLEANER INSTALLATION (90/100KW)
FIGURE 4-15. AIR CLEANER ASSEMBLY (90/100KW)
FIGURE 4-16. PRE-AIR CLEANER ACCESSORY
FIGURE 4-17. AIR INTAKE RAIN CAP ACCESSORY
FIGURE 4-18. AIR INTAKE LINES INSTALLATION (90/100KW - ULS)
FIGURE 4-19. COOLING PACKAGE INSTALLATION (90KW - ULS)
FIGURE 4-20. COOLING FAN INSTALLATION
FIGURE 4-21. FAN LINES INSTALLATION (90KW)
FIGURE 4-22. FAN DRIVE MOTOR (NO RHOC)
FIGURE 4-23. FUEL FILTER & PUMP INSTALLATION
FIGURE 4-24. REMOTE FUEL PUMP INSTALLATION (74.4KW)
FIGURE 4-25. COOLER INSTALLATION (90KW)
FIGURE 4-26. RADIATOR COOLING PACKAGE (90KW)
FIGURE 4-27. REMOTE HOC INSTALLATION
FIGURE 4-28. FAN DRIVE MOTOR (RHOC)
FIGURE 4-29. COOLANT LINES INSTALLATION (ULS)
FIGURE 4-30. COOLER LINES INSTALLATION (90KW)
FIGURE 4-31. CAC LINES INSTALLATION (ULS)
FIGURE 4-32. SURGE TANK INSTALLATION
FIGURE 4-33. TANK EXPANSION
FIGURE 4-34. BULKHEAD INSTALLATION
FIGURE 4-35. HYDRAULIC PUMP INSTALLATION (90KW)
FIGURE 4-36. HEATER LINES INSTALLATION (ULS)
FIGURE 4-37. HEATER LINES WITH BLOCK HEATER INSTALLATION (ULS)
FIGURE 4-38. BLOCK HEATER INSTALLATION (120V - LS)
FIGURE 4-39. BLOCK HEATER (LS)
FIGURE 4-40. A/C PUMP INSTALLATION
FIGURE 4-41. A/C LINES INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVETRAIN INSTALLATION
FIGURE 5-2. FRONT AXLE INSTALLATION
FIGURE 5-3. FRONT AXLE ASSEMBLY
FIGURE 5-4. REAR AXLE INSTALLATION
FIGURE 5-5. REAR AXLE ASSEMBLY
FIGURE 5-6. DRIVE SHAFTS INSTALLATION
FIGURE 5-7. REMOTE GREASE SYSTEM INSTALLATION
FIGURE 5-8. AXLE SHIM INSTALLATION
FIGURE 5-9. TRANSMISSION INSTALLATION (6 SPD - 90KW)
FIGURE 5-10. TRANSMISSION INSTALLATION (6 SPD - 97KW)
FIGURE 5-11. TRANSMISSION (6 SPD - 90KW)
FIGURE 5-12. TRANSMISSION (6 SPD - HHP - 97KW)
FIGURE 5-13. PLANETARY CASE AND PARTS GROUP
FIGURE 5-14. TORQUE CONVERTER GROUP
FIGURE 5-15. TORQUE CONVERTER GROUP
FIGURE 5-16. TRANSFER GEAR AND CASE GROUP
FIGURE 5-17. TRANSMISSION HYDRAULIC CONTROL GROUP
FIGURE 5-18. INPUT SHAFT GROUP
FIGURE 5-19. TRANSMISSION CLUTCH GROUP
FIGURE 5-20. CLUTCH AND GEAR GROUP
FIGURE 5-21. TRANSMISSION PUMP GROUP
FIGURE 5-22. OUTPUT SHAFT GROUP
FIGURE 5-23. SPEED SENSOR
FIGURE 5-24. IDLER GEAR
FIGURE 5-25. REAR TRANSMISSION CASE
FIGURE 5-26. PLANETARY CASE
FIGURE 5-27. FRONT TRANSFER CASE
FIGURE 5-28. REAR TRANSFER CASE
FIGURE 5-29. RELIEF VALVE
FIGURE 5-30. SOLENOID VALVE
FIGURE 5-31. SOLENOID VALVE
FIGURE 5-32. FRONT TRANSMISSION CASE ASSEMBLY
FIGURE 5-33. REAR TRANSMISSION CASE ASSEMBLY
FIGURE 5-34. TIRE/WHEEL SET (AIR - 460/70 R24 XMCL)
FIGURE 5-35. TIRE/WHEEL SET (AIR - 500/70 R24 XMCL)
FIGURE 5-36. FENDER INSTALLATION
FIGURE 5-37. FENDER ASSEMBLY (RR-RH)
FIGURE 5-38. FENDER ASSEMBLY (RR-LH)
FIGURE 5-39. FENDER ASSEMBLY (FRT-RH)
FIGURE 5-40. FENDER ASSEMBLY (FRT-LH)
SECTION 6 - CABFIGURE 6-1. CAB MOUNTS INSTALLATION
FIGURE 6-2. ENCLOSED CAB INSTALLATION
FIGURE 6-3. ENCLOSED CAB ASSEMBLY
FIGURE 6-4. ENCLOSED CAB GROUP
FIGURE 6-5. ENCLOSED CAB
FIGURE 6-6. DOOR INSTALLATION
FIGURE 6-7. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-8. CAB LATCH ASSEMBLY
FIGURE 6-9. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-10. DOOR ASSEMBLY (AG)
FIGURE 6-11. CAB DOOR
FIGURE 6-12. DOOR STRAP INSTALLATION
FIGURE 6-13. REAR WINDOW INSTALLATION
FIGURE 6-14. REAR WINDOW ASSEMBLY
FIGURE 6-15. ENCLOSED CAB PLUG GROUP
FIGURE 6-16. INTERIOR MIRROR INSTALLATION
FIGURE 6-17. FRONT WIPER INSTALLATION
FIGURE 6-18. LEVEL INDICATOR INSTALLATION
FIGURE 6-19. ENCLOSED CAB TRIM INSTALLATION
FIGURE 6-20. DASH COVER ASSEMBLY
FIGURE 6-21. REAR PANEL COVER ASSEMBLY
FIGURE 6-22. ADJUSTABLE ARMREST INSTALLTION (Prior to SN 0160112883)
FIGURE 6-23. ADJUSTABLE ARMREST INSTALLTION (SN 0160112883 to Present)
FIGURE 6-24. ARMREST
FIGURE 6-25. FIXED ARMREST BRACKET
FIGURE 6-26. MOVING ARMREST BRACKET
FIGURE 6-27. BEACON TERMINAL INSTALLATION
FIGURE 6-28. WASHER HOSES INSTALLATION
FIGURE 6-29. HAMMER INSTALLATION
FIGURE 6-30. HAMMER ATTACHMENT ASSEMBLY
FIGURE 6-31. FRONT COVER INSTALLATION
FIGURE 6-32. FILTER TRAY PANEL
FIGURE 6-33. FRONT DUCT COVER
FIGURE 6-34. WASHER TANK INSTALLATION
FIGURE 6-35. WASHER BOTTLE
FIGURE 6-36. SEAT INSTALLATION (AIR SUSPENSION - STANDARD) (Prior to SN 0160112883)
FIGURE 6-37. SEAT INSTALLATION (AIR SUSPENSION - STANDARD) (SN 0160112883 to Present)
FIGURE 6-38. SEAT ASSEMBLY (AIR SUSPENSION - STANDARD) (Prior to SN 0160112883)
FIGURE 6-39. SEAT ASSEMBLY (AIR SUSPENSION - STANDARD) (SN 0160112883 to Present)
FIGURE 6-40. UPPER SEAT ASSEMBLY
FIGURE 6-41. SUSPENSION KIT
FIGURE 6-42. SEAT INSTALLATION (PREMIUM)
FIGURE 6-43. SEAT ASSEMBLY (AIR SUSPENSION - PREMIUM)
FIGURE 6-44. SEAT INSTALLATION (MECHANICAL)
FIGURE 6-45. SEAT ASSEMBLY
FIGURE 6-46. SEAT BELT INSTALLATION (2IN)
FIGURE 6-47. SEAT BELT INSTALLATION (3IN)
FIGURE 6-48. HEATER INSTALLATION
FIGURE 6-49. HEATER ASSEMBLY
FIGURE 6-50. HEATER AND A/C INSTALLATION
FIGURE 6-51. CAB CONDENSER ASSEMBLY
FIGURE 6-52. CONDENSER
FIGURE 6-53. A/C RECEIVER DRIER
FIGURE 6-54. HEATER AND A/C ASSEMBLY
FIGURE 6-55. ROOF WIPER INSTALLATION
FIGURE 6-56. HEADLINER INSTALLATION
FIGURE 6-57. HEADLINER/ RADIO READY INSTALLATION
FIGURE 6-58. CAB GUARD INSTALLATION (TOP)
FIGURE 6-59. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-60. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-61. COMMON CAB TRIM INSTALLATION
FIGURE 6-62. CAB TRIM INSTALLATION
FIGURE 6-63. ROOF CAP INSTALLATION (A/C)
FIGURE 6-64. ROOF CAP INSTALLATION (NO A/C)
FIGURE 6-65. FRONT NOSE CONE INSTALLATION (SIDELIGHT)
FIGURE 6-66. RETRACTABLE SUNSCREEN INSTALLATION
FIGURE 6-67. CAB STEP INSTALLATION
FIGURE 6-68. FLOOR MAT INSTALLATION
FIGURE 6-69. EXTERNAL WINDOW RELEASE INSTALLATION (ANSI)
FIGURE 6-70. EXTERNAL WINDOW RELEASE INSTALLATION (CAN)
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL
FIGURE 7-5. BRAKE PEDAL PLATE
FIGURE 7-6. BRAKE SENSOR INSTALLATION
FIGURE 7-7. SWITCH PLATE ASSEMBLY
FIGURE 7-8. PARKING BRAKE INSTALLATION (CABLE - STANDARD)
FIGURE 7-9. PARKING BRAKE COVER (MECHANICAL)
FIGURE 7-10. PARKING CABLE ASSEMBLY (MECHANICAL)
FIGURE 7-11. STEERING WHEEL INSTALLATION
FIGURE 7-12. STEERING WHEEL
FIGURE 7-13. STEERING COLUMN INSTALLATION
FIGURE 7-14. HORN INSTALLATION
FIGURE 7-15. HORN BUTTON INSTALLATION
FIGURE 7-16. JOYSTICK INSTALLATION
FIGURE 7-17. WIPER-TURN SWITCH (0 SPEED - FNR)
FIGURE 7-18. WIPER-TURN SWITCH (NO SPEED)
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. COMMON HYDRAULICS INSTALLATION
FIGURE 8-2. AUXILIARY HYDRAULICS INSTALLATION - REAR (TWIN)
FIGURE 8-3. AUXILIARY HYDRAULICS INSTALLATION - REAR (SINGLE)
FIGURE 8-4. BOOM HYDRAULIC INSTALLATION
FIGURE 8-5. BOOM LINES INSTALLATION
FIGURE 8-6. BOOM RAISE HOSES INSTALLATION (NO RIDE CONTROL)
FIGURE 8-7. BOOM RAISE HOSES INSTALLATION (WITH RIDE CONTROL)
FIGURE 8-8. BRAKE LINES INSTALLATION
FIGURE 8-9. BRAKE INSTALLATION – TRAILER
FIGURE 8-10. BRAKE ACCUMULATOR LINES INSTALLATION (WITHOUT SAHR)
FIGURE 8-11. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - TWIN)
FIGURE 8-12. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - SINGLE)
FIGURE 8-13. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - TWIN)
FIGURE 8-14. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - SINGLE)
FIGURE 8-15. LIFT CYLINDER INSTALLATION
FIGURE 8-16. MAIN CONTROL VALVE INSTALLATION
FIGURE 8-17. MAIN HYDRAULIC PUMP INSTALLATION
FIGURE 8-18. IMPLEMENT PUMP INSTALLATION
FIGURE 8-19. PRIORITY LINES INSTALLATION
FIGURE 8-20. PRIORITY VALVE INSTALLATION
FIGURE 8-21. RETURN LINES INSTALLATION
FIGURE 8-22. STEERING LINES INSTALLATION
FIGURE 8-23. STEER SELECT VALVE INSTALLATION
FIGURE 8-24. SUCTION LINES INSTALLATION
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. BOOM HOSE AND HARNESS ASSEMBLY
FIGURE 9-2. CYLINDER ASSEMBLY - COMPENSATION
FIGURE 9-3. CYLINDER SUB-ASSEMBLY - COUPLER LOCKING
FIGURE 9-4. CYLINDER ASSEMBLY - COUPLER LOCKING
FIGURE 9-5. CYLINDER ASSEMBLY - EXTEND/RETRACT (TELESCOPE) (INNER)
FIGURE 9-6. CYLINDER SUB-ASSEMBLY - EXTEND/RETRACT (TELESCOPE) (OUTER)
FIGURE 9-7. CYLINDER ASSEMBLY - EXTEND/RETRACT (TELESCOPE) (OUTER)
FIGURE 9-8. CYLINDER ASSEMBLY - LIFT
FIGURE 9-9. CYLINDER ASSEMBLY - TILT
FIGURE 9-10. IMPLEMENT PUMP
FIGURE 9-11. VALVE SUB-ASSEMBLY - DIVERTOR (HI-FLOW)
FIGURE 9-12. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-13. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-14. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-15. VALVE ASSEMBLY - FAN MOTOR CONTROL
FIGURE 9-16. VALVE ASSEMBLY - HYDRAULIC HITCH CONTROL VALVE
FIGURE 9-17. VALVE ASSEMBLY - MAIN CONTROL
FIGURE 9-18. VALVE ASSEMBLY - PRIORITY FLOW MANIFOLD
FIGURE 9-19. VALVE ASSEMBLY - RIDE CONTROL
FIGURE 9-20. VALVE ASSEMBLY - STEERING SELECT VALVE
FIGURE 9-21. VALVE ASSEMBLY - TRAILER BRAKE
SECTION 10 - ELECTRICALFIGURE 10-1. 832 ELECTRICAL LAYOUT
FIGURE 10-2. BATTERY INSTALLATION (STANDARD)
FIGURE 10-3. BATTERY INSTALLATION (DUAL)
FIGURE 10-4. BEACON/STROBE INSTALLATION
FIGURE 10-5. BOOM HARNESS INSTALLATION
FIGURE 10-6. BOOM HARNESS
FIGURE 10-7. BOOM RETRACT SENSOR INSTALLATION
FIGURE 10-8. BOOM ANGLE SENSOR INSTALLATION
FIGURE 10-9. CAB ELECTRICAL INSTALLATION
FIGURE 10-10. CAB ELECTRICAL INSTALLATION
FIGURE 10-11. CAB HARNESS
FIGURE 10-12. CAB HARNESS
FIGURE 10-13. CAB STANDARD ELECTRICAL BOARD ASSEMBLY
FIGURE 10-14. CAB OPTION 1 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-15. CAB OPTION 2 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-16. CAB OPTION HARNESS
FIGURE 10-17. DASH ELECTRICS INSTALLATION (ULS)
FIGURE 10-18. CAB HEATER HARNESS INSTALLATION
FIGURE 10-19. CAB HEATER HARNESS
FIGURE 10-20. CAB HVAC ACTUATOR HARNESS
FIGURE 10-21. CAB HVAC ACTUATOR HARNESS
FIGURE 10-22. CAB - MULTIFUNCTION DISPLAY INSTALLATION
FIGURE 10-23. CAB SEAT ADAPTOR HARNESS (PREMIUM SEAT)
FIGURE 10-24. CLEARSKY 4G CANBUS INSTALLATION
FIGURE 10-25. DECLUTCH SWITCH INSTALLATION
FIGURE 10-26. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 10-27. ELECTRICAL POWER DISTRIBUTION ELECTRICAL BOX
FIGURE 10-28. ELECTRICAL RELAY INSTALLATION - 200 AMP
FIGURE 10-29. ENGINE WIRING INSTALLATION (ULS)
FIGURE 10-30. ENGINE HARNESS (ULS)
FIGURE 10-31. ENGINE FUEL PUMP HARNESS
FIGURE 10-32. ENGINE GLOW PLUG RELAY HARNESS
FIGURE 10-33. ENGINE SPEED SET SWITCH INSTALLATION
FIGURE 10-34. FRAME MAIN ELECTRICAL INSTALLATION
FIGURE 10-35. FRAME HARNESS - REAR
FIGURE 10-36. FRAME HARNESS - FRONT
FIGURE 10-37. IGNITION SWITCH INSTALLATION
FIGURE 10-38. LIGHTS - DIP LIGHTS INSTALLATION (RH)
FIGURE 10-39. LIGHTS - LICENSE PLATE LAMP INSTALLATION
FIGURE 10-40. LIGHTS - LICENSE PLATE LAMP HARNESS
FIGURE 10-41. LIGHTS - NO ROADLIGHTS INSTALLATION
FIGURE 10-42. LIGHTS - WORKLIGHTS INSTALLATION (BOOM MOUNTED)
FIGURE 10-43. LIGHTS - WORKLIGHTS INSTALLATION - LED (BOOM MOUNTED)
FIGURE 10-44. LIGHTS - WORKLIGHTS HARNESS (BOOM MOUNTED LIGHTS)
FIGURE 10-45. LIGHTS - WORKLIGHTS INSTALLATION (CAB MOUNTED) (NO A/C)
FIGURE 10-46. LIGHTS - WORKLIGHTS INSTALLATION - LED (CAB MOUNTED) (NO A/C)
FIGURE 10-47. LIGHTS - WORKLIGHTS INSTALLATION (CAB MOUNTED) (WITH A/C)
FIGURE 10-48. LIGHTS - WORKLIGHTS INSTALLATION -LED (CAB MOUNTED) (WITH A/C)
FIGURE 10-49. LSI SENSOR INSTALLATION
FIGURE 10-50. LSI DISPLAY INSTALLATION
FIGURE 10-51. LSI SENSOR INSTALLATION
FIGURE 10-52. LSI SWITCH INSTALLATION
FIGURE 10-53. LSI SENSOR COVER INSTALLATION
FIGURE 10-54. REVERSE ALARM INSTALLATION
FIGURE 10-55. REVERSE CAMERA INSTALLATION
FIGURE 10-56. REVERSE SENSING INSTALLATION
FIGURE 10-57. REVERSE SENSING HARNESS
FIGURE 10-58. TELEMATICS CLEARSKY CAN 4WARD HARNESS
FIGURE 10-59. TELEMATICS ADAPTER HARNESS
FIGURE 10-60. TELEMATICS READY INSTALLATION
FIGURE 10-61. TELEMATICS READY HARNESS
FIGURE 10-62. TRAILER ELECTRICS INSTALLATION
FIGURE 10-63. TRAILER CONNECTOR HARNESS
SECTION 11 - DECALSFIGURE 11-1. DECALS INSTALLATION (ANSI)
FIGURE 11-2. DECALS INSTALLATION - JLG
FIGURE 11-3. DECALS INSTALLATION - JLG AG
FIGURE 11-4. CAPACITY CHART (ANSI)
FIGURE 11-5. CAPACITY CHART HOLDER INSTALLATION
FIGURE 11-6. CLEARSKY DECAL INSTALLATION
FIGURE 11-7. TRIANGLE INSTALLATION - SLOW MOVING VEHICLE
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
