JLG Telehandler 8042 10042 10054 Service & Maintenance Manual 8990187
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service & Maintenance Manual, Electric and Hydraulic Diagrams
Model: JLG 8042 10042 10054 Telehandler
Part Number: 8990187
Publication Date: 2024
Number of Pages: 600 Pages
SECTION 1 - MAIN FRAME AND GUARDS
Brand: JLG
FIGURE 1-1. MAIN FRAME
FIGURE 1-2. HOODS AND GUARDS
SECTION 2 - OPERATOR'S CAB AND CONTROLSFIGURE 2-1. OPERATOR'S CAB - OPEN
FIGURE 2-2. OPERATOR'S CAB - CLOSED (OPTIONAL)
FIGURE 2-3. CAB DOOR
FIGURE 2-4. OPERATOR'S SEAT
FIGURE 2-5. CONTROL CONSOLE
FIGURE 2-6. TRANSMISSION SHIFT CONTROLS (Prior to SN 9909)
FIGURE 2-7. TRANSMISSION SHIFT CONTROLS (SN 9909 through 13197)
FIGURE 2-8. BOOM RAISE/LOWER AND EXTEND/RETRACT CONTROL
FIGURE 2-9. FRAME LEVEL AND ATTACHMENT TILT CONTROL
FIGURE 2-10. THROTTLE PEDAL CONTROL
FIGURE 2-11. SERVICE BRAKE PEDAL CONTROL
FIGURE 2-12. FRONT WINDSHIELD WIPER
FIGURE 2-13. CAB HEATER (OPTIONAL)
FIGURE 2-14. AUX. HYDRAULIC CONTROL (OPTIONAL)
FIGURE 2-15. MIRRORS
FIGURE 2-16. SKYLIGHT WINDSHIELD WIPER (OPTIONAL)
FIGURE 2-17. SOFT CAB ENCLOSURE (OPTIONAL)
SECTION 3 - DRIVE TRAINFIGURE 3-1. CONVERTER AND TRANSMISSION HOUSINGS (Prior to SN 9909)
FIGURE 3-2. CONVERTER GROUP (Prior to SN 9909)
FIGURE 3-3. FORWARD, REVERSE, LOW AND 2ND (Prior to SN 9909)
FIGURE 3-4. OUTPUT, IDLER AND THIRD (Prior to SN 9909)
FIGURE 3-5. TRANSMISSION CLUTCH GROUPS (Prior to SN 9909)
FIGURE 3-6. CONTROL VALVE ASSEMBLY (Prior to SN 9909)
FIGURE 3-7. EMERGENCY BRAKE (Prior to SN 9909)
FIGURE 3-8. TRANSMISSION MOUNTING (Prior to SN 9909)
FIGURE 3-9. ENGINE CONNECT (SN 9909 through 13197)
FIGURE 3-10. CONVERTER AND LAYSHAFT (SN 9909 through 13197)
FIGURE 3-11. OIL PRESSURE PUMP (SN 9909 through 13197)
FIGURE 3-12. INPUT SHAFT (SN 9909 through 13197)
FIGURE 3-13. GEARBOX HOUSING (SN 9909 through 13197)
FIGURE 3-14. CLUTCH PACK 1ST GEAR - 1 OF 2 (SN 9909 through 13197)
FIGURE 3-15. CLUTCH PACK 1ST GEAR - 2 OF 2 (SN 9909 through 13197)
FIGURE 3-16. CLUTCH PACK 2ND GEAR - 1 OF 2 (SN 9909 through 13197)
FIGURE 3-17. CLUTCH PACK 2ND GEAR - 2 OF 2 (SN 9909 through 13197)
FIGURE 3-18. CLUTCH PACK 3RD GEAR - 1 OF 2 (SN 9909 through 13197)
FIGURE 3-19. CLUTCH PACK 3RD GEAR - 2 OF 2 (SN 9909 through 13197)
FIGURE 3-20. OUTPUT SHAFT (SN 9909 through 13197)
FIGURE 3-21. PARKING BRAKE (SN 9909 through 13197)
FIGURE 3-22. POWER TAKE-OFF SHAFT (SN 9909 through 13197)
FIGURE 3-23. GEARSHIFT SYSTEM (SN 9909 through 13197)
FIGURE 3-24. CONTROL VALVE (SN 9909 through 13197)
FIGURE 3-25. TRANSMISSION FILTER AND DIPSTICK (SN 9909 through 13197)
FIGURE 3-26. OIL TUBES (SN 9909 through 13197)
FIGURE 3-27. TRANSMISSION MOUNTING (SN 9909 through 13197)
FIGURE 3-28. DRIVE SHAFT - ENGINE TO TRANSMISSION (Prior to SN 9909)
FIGURE 3-29. DRIVE SHAFT - ENGINE TO TRANSMISSION (SN 9909 through 13197)
FIGURE 3-30. DRIVE SHAFT - FRONT AND REAR (Prior to SN 9909)
FIGURE 3-31. DRIVE SHAFT - FRONT AND REAR (SN 9909 through 13197)
FIGURE 3-32. DIFFERENTIAL CARRIER ASSEMBLY
FIGURE 3-33. AXLE STEERING JOINTS
FIGURE 3-34. AXLE WHEEL ENDS (Prior to SN 0461)
FIGURE 3-35. AXLE WHEEL ENDS (SN 0461 through 13197)
FIGURE 3-36. TIE ROD AND STEERING CYLINDER MOUNTING
FIGURE 3-37. WHEELS AND TIRES (8042)
FIGURE 3-38. WHEELS AND TIRES (10042,10054)
SECTION 4 - POWER PLANTFIGURE 4-1. ENGINE, RADIATOR AND OIL COOLER MOUNTING (Prior to SN 0119)
FIGURE 4-2. ENGINE, RADIATOR AND OIL COOLER MOUNTING (SN 0119 through 1598)
FIGURE 4-3. ENGINE, RADIATOR AND OIL COOLER MOUNTING (EPA) (SN 1599 through 13197)
FIGURE 4-4. TORSION COUPLER (SN 9909 through 13197)
FIGURE 4-5. EXHAUST SYSTEM
FIGURE 4-6. AIR CLEANER
FIGURE 4-7. FUEL SYSTEM (Prior to SN 1599)
FIGURE 4-8. FUEL SYSTEM (EPA) (SN 1599 through 13197)
SECTION 5 - HYDRAULIC CIRCUITSFIGURE 5-1. POWER STEERING CIRCUIT (Prior to SN 9909)
FIGURE 5-2. POWER STEERING CIRCUIT (SN 9909 through 13197)
FIGURE 5-3. CONTROL VALVES CIRCUIT (Prior to SN 9909)
FIGURE 5-4. CONTROL VALVES CIRCUIT (SN 9909 through 13197)
FIGURE 5-5. BOOM RAISE/LOWER AND EXTEND/RETRACT CIRCUIT (Prior to SN 9909)
FIGURE 5-6. BOOM RAISE/LOWER AND EXTEND/RETRACT CIRCUIT (SN 9909 through 13197)
FIGURE 5-7. ATTACHMENT TILT AND SLAVE CIRCUIT
FIGURE 5-8. FRAME TILT AND STABILIZER CIRCUIT
FIGURE 5-9. SERVICE BRAKE AND DE-CLUTCH CIRCUIT
FIGURE 5-10. VALVE PLATE ASSEMBLY (WITHOUT OUTRIGGERS) (8042)
FIGURE 5-11. VALVE PLATE ASSEMBLY (WITH OUTRIGGERS) (10042,10054)
FIGURE 5-12. TRANSMISSION COOLING CIRCUIT (Prior to SN 9909)
FIGURE 5-13. TRANSMISSION COOLING CIRCUIT (SN 9909 through 13197)
FIGURE 5-14. AUXILIARY HYDRAULIC CIRCUIT (OPTIONAL)
FIGURE 5-15. OUTRIGGER HYDRAULIC CIRCUIT (10042,10054)
SECTION 6 - HYDRAULIC COMPONENTSFIGURE 6-1. HYDRAULIC RESERVOIR
FIGURE 6-2. MAIN PUMP (Prior to SN 9909)
FIGURE 6-3. MAIN PUMP (SN 9909 through 13197)
FIGURE 6-4. BOOM EXTEND CYLINDER (EARLY PRODUCTION)
FIGURE 6-5. BOOM EXTEND CYLINDER (CURRENT PRODUCTION)
FIGURE 6-6. BOOM HOIST CYLINDER (Prior to SN 5819)
FIGURE 6-7. BOOM HOIST CYLINDER (SN 5819 through 13197)
FIGURE 6-8. FRAME TILT CYLINDER
FIGURE 6-9. STABILIZER CYLINDER
FIGURE 6-10. SLAVE CYLINDER (EARLY PRODUCTION)
FIGURE 6-11. SLAVE CYLINDER (CURRENT PRODUCTION)
FIGURE 6-12. ATTACHMENT TILT CYLINDER
FIGURE 6-13. OUTRIGGER CYLINDER (Prior to SN 10882)
FIGURE 6-14. OUTRIGGER CYLINDER (SN 10882 through 13197)
FIGURE 6-15. SWING CARRIAGE CYLINDER
FIGURE 6-16. SIDE TILT CARRIAGE CYLINDER
FIGURE 6-17. STEERING CYLINDER (Prior to SN 1168)
FIGURE 6-18. STEERING CYLINDER (SN 1168 through 13197)
FIGURE 6-19. MAIN CONTROL VALVE
FIGURE 6-20. SECONDARY CONTROL VALVE
FIGURE 6-21. DIRECTIONAL CONTROL VALVES 1 OF 2
FIGURE 6-22. DIRECTIONAL CONTROL VALVES 2 OF 2
SECTION 7 - ELECTRICALFIGURE 7-1. ELECTRICAL SYSTEM - CAB HARNESS (Prior to SN 0292)
FIGURE 7-2. ELECTRICAL SYSTEM - CAB HARNESS (SN 0292 through 9908)
FIGURE 7-3. ELECTRICAL SYSTEM - CAB HARNESS (SN 9909 through 13197)
FIGURE 7-4. ELECTRICAL SYSTEM - ENGINE HARNESS (10042,8042) (8042 Prior to SN 0207; 10042 Prior to SN 0212)
FIGURE 7-5. ELECTRICAL SYSTEM - ENGINE HARNESS (10042,10054,8042) (8042 SN 0207 through 1598; 10042 SN 0212 through 1598; 10054 Prior to SN 1599)
FIGURE 7-6. ELECTRICAL SYSTEM - ENGINE HARNESS (10042,10054,8042) (8042 SN 1599 through 5234; 10042 SN 1599 through 5250; 10054 SN 1599 through 5274)
FIGURE 7-7. ELECTRICAL SYSTEM - ENGINE HARNESS (EPA) (10042,10054,8042) (8042 Prior to SN 5236; 10042 Prior to SN 5252; 10054 SN 5275 through 9908)
FIGURE 7-8. ELECTRICAL SYSTEM - ENGINE HARNESS (EPA) (SN 9909 through 13197)
FIGURE 7-9. LIGHTING SYSTEM
FIGURE 7-10. OUTRIGGER ELECTRICAL HARNESS (10042,10054)
SECTION 8 - DECALS AND PAINTFIGURE 8-1. DECALS AND PAINT
SECTION 9 - BOOM AND ATTACHMENTSFIGURE 9-1. OUTER BOOM
FIGURE 9-2. INTERMEDIATE BOOM (10042,8042)
FIGURE 9-3. INNER BOOM (10042,8042)
FIGURE 9-4. PRIMARY INTERMEDIATE BOOM (10054)
FIGURE 9-5. SECONDARY INTERMEDIATE BOOM (10054)
FIGURE 9-6. INNER BOOM (10054)
FIGURE 9-7. QUICK ATTACH
FIGURE 9-8. CARRIAGE 48IN
FIGURE 9-9. CARRIAGE 60IN
FIGURE 9-10. CARRIAGE 72IN
FIGURE 9-11. SIDE TILT CARRIAGE - EARLY PRODUCTION (OPTIONAL)
FIGURE 9-12. SIDE TILT CARRIAGE - CURRENT PRODUCTION (OPTIONAL)
FIGURE 9-13. OUTRIGGERS (10042,10054)
FIGURE 9-14. SWING CARRIAGE (OPTIONAL)
FIGURE 9-15. SHEET MATERIAL HANDLER (OPTIONAL)
FIGURE 9-16. UTILITY BUCKET (OPTIONAL)
FIGURE 9-17. BOOM EXTEND CHAINS (10042,8042)
FIGURE 9-18. BOOM RETRACT CHAIN (10042,8042) (Prior to SN 1085)
FIGURE 9-19. BOOM RETRACT CHAIN (10042,8042) (SN 1085 through 13197)
FIGURE 9-20. BOOM EXTEND CHAINS (10054)
FIGURE 9-21. BOOM RETRACT CHAINS (10054) (Prior to SN 0885)
FIGURE 9-22. BOOM RETRACT CHAINS (10054) (SN 0885 through 1084)
FIGURE 9-23. BOOM RETRACT CHAINS (10054) (SN 1085 through 13197)
FIGURE 9-24. TRUSS BOOM 12 & 15 FT (OPTIONAL)
SECTION 10 - GENERAL TROUBLESHOOTINGFIGURE 10-1. HYDRAULIC DIAGNOSTIC TEST EQUIPMENT
FIGURE 10-2. HYDRAULIC DIAGRAM (8042) (Prior to SN 1168)
FIGURE 10-3. HYDRAULIC TESTING (8042) (Prior to SN 1168)
FIGURE 10-4. HYDRAULIC DIAGRAM (8042) (SN 1168 through 2194)
FIGURE 10-5. HYDRAULIC TESTING (8042) (SN 1168 through 2194)
FIGURE 10-6. HYDRAULIC DIAGRAM (8042) (SN 2195 through 9908)
FIGURE 10-7. HYDRAULIC TESTING (8042) (SN 2195 through 9908)
FIGURE 10-8. HYDRAULIC DIAGRAM (8042) (SN 9909 to Present)
FIGURE 10-9. HYDRAULIC TESTING (8042) (SN 9909 to Present)
FIGURE 10-10. HYDRAULIC DIAGRAM (10042) (Prior to SN 1168)
FIGURE 10-11. HYDRAULIC TESTING (10042) (Prior to SN 1168)
FIGURE 10-12. HYDRAULIC DIAGRAM (10042) (SN 1168 through 2194)
FIGURE 10-13. HYDRAULIC TESTING (10042) (SN 1168 through 2194)
FIGURE 10-14. HYDRAULIC DIAGRAM (10042) (SN 2195 through 9908)
FIGURE 10-15. HYDRAULIC TESTING (10042) (SN 2195 through 9908)
FIGURE 10-16. HYDRAULIC DIAGRAM (10042) (SN 9909 to Present)
FIGURE 10-17. HYDRAULIC TESTING (10042) (SN 9909 to Present)
FIGURE 10-18. HYDRAULIC DIAGRAM (10054) (Prior to SN 1168)
FIGURE 10-19. HYDRAULIC TESTING (10054) (Prior to SN 1168)
FIGURE 10-20. HYDRAULIC DIAGRAM (10054) (SN 1168 through 2194)
FIGURE 10-21. HYDRAULIC TESTING (10054) (SN 1168 through 2194)
FIGURE 10-22. HYDRAULIC DIAGRAM (10054) (SN 2195 through 9908)
FIGURE 10-23. HYDRAULIC TESTING (10054) (SN 2195 through 9908)
FIGURE 10-24. HYDRAULIC DIAGRAM (10054) (SN 9909 to Present)
FIGURE 10-25. HYDRAULIC TESTING (10054) (SN 9909 to Present)
FIGURE 10-26. VARIABLE VOLUME LOAD SENSING PUMP FLOW METER DIAGRAM (Prior to SN 9909)
FIGURE 10-27. VARIABLE VOLUME LOAD SENSING PUMP FLOW METER DIAGRAM (SN 9909 to Present)
FIGURE 10-28. HOIST AND EXTEND CIRCUITS (10042,8042) (Prior to SN 8541)
FIGURE 10-29. HOIST AND EXTEND SCHEMATIC (10042,8042) (Prior to SN 8541)
FIGURE 10-30. HOIST AND EXTEND CIRCUITS (10042,8042) (SN 8541 through 9908)
FIGURE 10-31. HOIST AND EXTEND SCHEMATIC (10042,8042) (SN 8541 through 9908)
FIGURE 10-32. HOIST AND EXTEND CIRCUITS (10042,8042) (SN 9909 to Present)
FIGURE 10-33. HOIST AND EXTEND SCHEMATIC (10042,8042) (SN 9909 to Present)
FIGURE 10-34. HOIST AND EXTEND CIRCUITS (10054) (Prior to SN 8541)
FIGURE 10-35. HOIST AND EXTEND SCHEMATIC (10054) (Prior to SN 8541)
FIGURE 10-36. HOIST AND EXTEND CIRCUITS (10054) (SN 8541 through 9908)
FIGURE 10-37. HOIST AND EXTEND SCHEMATIC (10054) (SN 8541 through 9908)
FIGURE 10-38. HOIST AND EXTEND CIRCUITS (10054) (SN 9909 to Present)
FIGURE 10-39. HOIST AND EXTEND SCHEMATIC (10054) (SN 9909 to Present)
FIGURE 10-40. FRAME TILT, ATTACHMENT TILT, SLAVE & AUXILIARY CIRCUITS (Prior to SN 2195)
FIGURE 10-41. FRAME TILT, ATTACHMENT TILT, SLAVE & AUXILIARY SCHEMATIC (Prior to SN 2195)
FIGURE 10-42. FRAME TILT, ATTACHMENT TILT, SLAVE & AUXILIARY CIRCUITS (SN 2195 through 9908)
FIGURE 10-43. FRAME TILT, ATTACHMENT TILT, SLAVE & AUXILIARY SCHEMATIC (SN 2195 through 9908)
FIGURE 10-44. FRAME TILT, ATTACHMENT TILT, SLAVE & AUXILIARY CIRCUITS (SN 9909 to Present)
FIGURE 10-45. FRAME TILT, ATTACHMENT TILT, SLAVE & AUXILIARY SCHEMATIC (SN 9909 to Present)
FIGURE 10-46. STEERING CIRCUIT (Prior to SN 9909)
FIGURE 10-47. STEERING SCHEMATIC (Prior to SN 9909)
FIGURE 10-48. STEERING CIRCUIT (SN 9909 to Present)
FIGURE 10-49. STEERING SCHEMATIC (SN 9909 to Present)
FIGURE 10-50. SERVICE BRAKE & DE-CLUTCH CIRCUITS (Prior to SN 9909)
FIGURE 10-51. SERVICE BRAKE & DE-CLUTCH SCHEMATIC (Prior to SN 9909)
FIGURE 10-52. SERVICE BRAKE CIRCUITS (SN 9909 to Present)
FIGURE 10-53. SERVICE BRAKE SCHEMATIC (SN 9909 to Present)
FIGURE 10-54. OUTRIGGER SCHEMATIC (10042,10054) (Prior to SN 10882)
FIGURE 10-55. OUTRIGGER SCHEMATIC (10042,10054) (SN 10882 to Present)
FIGURE 10-56. ELECTRICAL SCHEMATIC (10042,8042) (Prior to SN 0292)
FIGURE 10-57. ELECTRICAL SCHEMATIC (10042,8042) (SN 0292 through 9908)
FIGURE 10-58. ELECTRICAL SCHEMATIC (10042,8042) (SN 9909 to Present)
FIGURE 10-59. ELECTRICAL SCHEMATIC (10054) (Prior to SN 9909)
FIGURE 10-60. ELECTRICAL SCHEMATIC (10054) (SN 9909 to Present)
FIGURE 10-61. OUTRIGGER LOGIC CIRCUIT (10042)
FIGURE 10-62. OUTRIGGER LOGIC CIRCUIT (10054) (Prior to SN 9909)
FIGURE 10-63. OUTRIGGER LOGIC CIRCUIT (10054) (SN 9909 to Present)
FIGURE 10-64. LIGHTING SYSTEM CIRCUIT (OPTIONAL)
FIGURE 10-65. CHARGING CIRCUIT
FIGURE 10-66. CRANKING CIRCUIT (Prior to SN 9909)
FIGURE 10-67. CRANKING CIRCUIT (SN 9909 to Present)
FIGURE 10-68. STEER SELECT CIRCUIT (10042,8042) (Prior to SN 0292)
FIGURE 10-69. STEER SELECT CIRCUIT (SN 0292 to Present)
FIGURE 10-70. STABILIZER CIRCUIT (10042,8042) (Prior to SN 0292)
FIGURE 10-71. STABILIZER CIRCUIT (10042,8042) (SN 0292 through 9908)
FIGURE 10-72. STABILIZER CIRCUIT (10042,8042) (SN 9909 to Present)
FIGURE 10-73. STABILIZER CIRCUIT (10054) (Prior to SN 9909)
FIGURE 10-74. STABILIZER CIRCUIT (10054) (SN 9909 to Present)
FIGURE 10-75. STABIL-TRAK SYSTEM
FIGURE 10-76. STABIL-TRAK SYSTEM
FIGURE 10-77. STABIL-TRAK SYSTEM
FIGURE 10-78. STABIL-TRAK SYSTEM
FIGURE 10-79. STABIL-TRAK SYSTEM TROUBLESHOOTING (10042,8042) (Prior to SN 9909)
FIGURE 10-80. STABIL-TRAK ELECTRICAL CIRCUIT IGNITION OFF (10042,8042) (Prior to SN 9909)
FIGURE 10-81. STABIL-TRAK ELECTRICAL CIRCUIT FREE PIVOT MODE (10042,8042) (Prior to SN 9909)
FIGURE 10-82. STABIL-TRAK HYDRAULIC CIRCUIT FREE PIVOT MODE (10042,8042) (Prior to SN 9909)
FIGURE 10-83. STABIL-TRAK ELECTRICAL CIRCUIT FINAL POSITIONING MODE (10042,8042) (Prior to SN 9909)
FIGURE 10-84. STABIL-TRAK HYDRAULIC CIRCUIT FINAL POSITIONING MODE (10042,8042) (Prior to SN 9909)
FIGURE 10-85. STABIL-TRAK ELECTRICAL CIRCUIT LOCKED MODE (10042,8042) (Prior to SN 9909)
FIGURE 10-86. STABIL-TRAK HYDRAULIC CIRCUIT LOCKED MODE (10042,8042) (Prior to SN 9909)
FIGURE 10-87. STABIL-TRAK SYSTEM TROUBLESHOOTING (10042,8042) (SN 9909 to Present)
FIGURE 10-88. STABIL-TRAK ELECTRICAL CIRCUIT IGNITION OFF (10042,8042) (SN 9909 to Present)
FIGURE 10-89. STABIL-TRAK ELECTRICAL CIRCUIT FREE PIVOT MODE (10042,8042) (SN 9909 to Present)
FIGURE 10-90. STABIL-TRAK HYDRAULIC CIRCUIT FREE PIVOT MODE (10042,8042) (SN 9909 to Present)
FIGURE 10-91. STABIL-TRAK ELECTRICAL CIRCUIT FINAL POSITIONING MODE (10042,8042) (SN 9909 to Present)
FIGURE 10-92. STABIL-TRAK HYDRAULIC CIRCUIT FINAL POSITIONING MODE (10042,8042) (SN 9909 to Present)
FIGURE 10-93. STABIL-TRAK ELECTRICAL CIRCUIT LOCKED MODE (10042,8042) (SN 9909 to Present)
FIGURE 10-94. STABIL-TRAK HYDRAULIC CIRCUIT LOCKED MODE (10042,8042) (SN 9909 to Present)
FIGURE 10-95. STABIL-TRAK SYSTEM TROUBLESHOOTING (10054) (Prior to SN 9909)
FIGURE 10-96. STABIL-TRAK SYSTEM TROUBLESHOOTING (10054) (Prior to SN 9909)
FIGURE 10-97. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 1 (10054) (Prior to SN 9909)
FIGURE 10-98. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 2 (10054) (Prior to SN 9909)
FIGURE 10-99. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 3 (10054) (Prior to SN 9909)
FIGURE 10-100. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 4 (10054) (Prior to SN 9909)
FIGURE 10-101. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 5 (10054) (Prior to SN 9909)
FIGURE 10-102. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 6 (10054) (Prior to SN 9909)
FIGURE 10-103. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 7 (10054) (Prior to SN 9909)
FIGURE 10-104. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 8 (10054) (Prior to SN 9909)
FIGURE 10-105. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 9 (10054) (Prior to SN 9909)
FIGURE 10-106. STABIL-TRAK SYSTEM TROUBLESHOOTING (10054) (SN 9909 to Present)
FIGURE 10-107. STABIL-TRAK SYSTEM TROUBLESHOOTING (10054) (SN 9909 to Present)
FIGURE 10-108. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 1 (10054) (SN 9909 to Present)
FIGURE 10-109. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 2 (10054) (SN 9909 to Present)
FIGURE 10-110. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 3 (10054) (SN 9909 to Present)
FIGURE 10-111. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 4 (10054) (SN 9909 to Present)
FIGURE 10-112. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 5 (10054) (SN 9909 to Present)
FIGURE 10-113. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 6 (10054) (SN 9909 to Present)
FIGURE 10-114. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 7 (10054) (SN 9909 to Present)
FIGURE 10-115. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 8 (10054) (SN 9909 to Present)
FIGURE 10-116. STABIL-TRAK ELECTRICAL CIRCUIT BOOM EXTEND MODE 9 (10054) (SN 9909 to Present)
SECTION 11 - RECOMMENDED SERVICE PARTS STOCKFIGURE 11-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 12 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 12-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
