JLG Telehandler 8042 10042 10054 Parts Manual 31200732
Brand: JLG
Type of Machine: Telehandler
Model: JLG 8042 10042 10054 Telehandler
Part Number: 31200732
Publication Date: 2024
Number of Pages: 506 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME AND ATTACHING PARTS
FIGURE 1-2. COVERS (Prior to SN 0160053075, Excluding 0160050807, 0160050814 and 0160050815)
FIGURE 1-3. COVERS (SN 0160053075 to Present, Including 0160050807, 0160050814 and 0160050815)
FIGURE 1-4. OUTRIGGER INSTALLATION (10042,10054)
SECTION 2 - BOOMFIGURE 2-1. BOOM INSTALLATION
FIGURE 2-2. FIRST BOOM SECTION
FIGURE 2-3. SECOND BOOM SECTION (10042,8042)
FIGURE 2-4. THIRD BOOM SECTION (10042,8042)
FIGURE 2-5. SECOND BOOM SECTION (10054)
FIGURE 2-6. THIRD BOOM SECTION (10054)
FIGURE 2-7. FOURTH BOOM SECTION (10054)
FIGURE 2-8. EXTEND CHAINS (10042,8042)
FIGURE 2-9. EXTEND CHAINS (10054)
FIGURE 2-10. RETRACT CHAINS (10042,8042)
FIGURE 2-11. RETRACT CHAINS (10054)
FIGURE 2-12. QUICK ATTACH
SECTION 3 - ATTACHMENTSFIGURE 3-1. TILT CARRIAGE (Prior to SN 0160051822)
FIGURE 3-2. TILT CARRIAGE (SN 0160051822 to Present)
FIGURE 3-3. SIDE TILT CARRIAGE
FIGURE 3-4. 50IN SIDE SHIFT CARRIAGE
FIGURE 3-5. 50IN DUAL FORK CARRIAGE
FIGURE 3-6. 90 SWING CARRIAGE
FIGURE 3-7. SHEET MATERIAL HANDLER
FIGURE 3-8. FORKS
FIGURE 3-9. FORK MOUNTED PLATFORM
FIGURE 3-10. LIFTING HOOK
FIGURE 3-11. FORK PIN LOCK INSTALLATION
FIGURE 3-12. BUCKETS
FIGURE 3-13. GRAPPLE BUCKET
FIGURE 3-14. TRUSS BOOM
FIGURE 3-15. 12FT TRUSS BOOM WITH WINCH
FIGURE 3-16. 8FT MAST
FIGURE 3-17. ADJUSTABLE TRUSS BOOM
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION IF EQUIPPED FOR ULS
FIGURE 4-2. ENGINE INSTALLATION IF EQUIPPED FOR LS
FIGURE 4-3. CUMMINS ENGINE IF EQUIPPED FOR ULS (Prior to SN 0160068606)
FIGURE 4-4. CUMMINS ENGINE IF EQUIPPED FOR ULS (SN 0160068606 to Present)
FIGURE 4-5. CUMMINS ENGINE IF EQUIPPED FOR LS
FIGURE 4-6. FUEL TANK AND LINES IF EQUIPPED FOR ULS
FIGURE 4-7. FUEL TANK AND LINES IF EQUIPPED FOR ULS
FIGURE 4-8. FUEL TANK AND LINES IF EQUIPPED FOR LS
FIGURE 4-9. RADIATOR AND COOLING INSTALLATION IF EQUIPPED FOR ULS
FIGURE 4-10. RADIATOR AND COOLING INSTALLATION IF EQUIPPED FOR LS
FIGURE 4-11. AIR CLEANER INSTALLATION IF EQUIPPED FOR ULS
FIGURE 4-12. AIR CLEANER INSTALLATION IF EQUIPPED FOR LS
FIGURE 4-13. EXHAUST INSTALLATION IF EQUIPPED FOR ULS
FIGURE 4-14. EXHAUST INSTALLATION IF EQUIPPED FOR LS
FIGURE 4-15. ISOLATION COUPLER
FIGURE 4-16. ISOLATION COUPLER IF EQUIPPED FOR LS
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVE TRAIN COMPONENTS
FIGURE 5-2. AXLE INSTALLATION 110HP (ULS) (8042)
FIGURE 5-3. AXLE INSTALLATION 74HP (LS) (8042)
FIGURE 5-4. FRONT AXLE
FIGURE 5-5. FRONT AXLE - INPUT
FIGURE 5-6. FRONT AXLE - LIMITED SLIP DIFFERENTIAL
FIGURE 5-7. FRONT AXLE - AXLE CASING
FIGURE 5-8. FRONT AXLE - M-DISC BRAKE
FIGURE 5-9. FRONT AXLE - BRAKE
FIGURE 5-10. FRONT AXLE - JOINT HOUSING
FIGURE 5-11. FRONT AXLE - PLANETARY DRIVE
FIGURE 5-12. FRONT AXLE (110HP) (ULS) (8042)
FIGURE 5-13. CENTRAL HOUSING, FRONT AXLE (110HP) (ULS) (8042)
FIGURE 5-14. DIFFERENTIAL, FRONT AXLE (110HP) (ULS) (8042)
FIGURE 5-15. HUB REDUCTION, FRONT AXLE (110HP) (ULS) (8042)
FIGURE 5-16. BRAKES, FRONT AXLE (110HP) (ULS) (8042)
FIGURE 5-17. STEERING, FRONT AXLE (110HP) (8042)
FIGURE 5-18. FRONT AXLE, DIFFERENTIAL KIT 74HP (8042)
FIGURE 5-19. FRONT AXLE, STEERING ADJUSTING BOLT KIT 74HP (8042)
FIGURE 5-20. FRONT AXLE INSTALLATION, 74HP (8042)
FIGURE 5-21. FRONT AXLE, CENTRAL HOUSING 74HP (8042)
FIGURE 5-22. FRONT AXLE, DIFFERENTIAL 74HP (8042)
FIGURE 5-23. FRONT AXLE, HUB REDUCTION 74HP (8042)
FIGURE 5-24. FRONT AXLE, BRAKES 74HP (8042)
FIGURE 5-25. FRONT AXLE, STEERING 74HP (8042)
FIGURE 5-26. REAR AXLE INSTALLATION 74HP (8042)
FIGURE 5-27. REAR AXLE, CENTRAL HOUSING 74HP (8042)
FIGURE 5-28. REAR AXLE, DIFFERENTIAL 74HP (8042)
FIGURE 5-29. REAR AXLE, HUB REDUCTION 74HP (8042)
FIGURE 5-30. REAR AXLE, BRAKES 74HP (8042)
FIGURE 5-31. REAR AXLE, STEERING 74HP (8042)
FIGURE 5-32. REAR AXLE, REDUCTION BUSHING 74HP (8042)
FIGURE 5-33. REAR AXLE, PLANET GEAR CARRIER 74HP (8042)
FIGURE 5-34. REAR AXLE, RING GEAR SUPPORT 74HP (8042)
FIGURE 5-35. REAR AXLE, DIFFERENTIAL KIT 74HP (8042)
FIGURE 5-36. REAR AXLE
FIGURE 5-37. REAR AXLE - INPUT
FIGURE 5-38. REAR AXLE - DIFFERENTIAL
FIGURE 5-39. REAR AXLE - AXLE CASING
FIGURE 5-40. REAR AXLE - M-DISC BRAKE
FIGURE 5-41. REAR AXLE - JOINT HOUSING
FIGURE 5-42. REAR AXLE - PLANETARY DRIVE
FIGURE 5-43. REAR AXLE(110HP) (ULS) (8042)
FIGURE 5-44. CENTRAL HOUSING, REAR AXLE (110HP) (ULS) (8042)
FIGURE 5-45. DIFFERENTIAL, REAR AXLE (110HP) (ULS) (8042)
FIGURE 5-46. HUB REDUCTION, REAR AXLE (110HP) (ULS) (8042)
FIGURE 5-47. BRAKES, REAR AXLE (110HP) (ULS) (8042)
FIGURE 5-48. STEERING, REAR AXLE (110HP) (ULS) (8042)
FIGURE 5-49. TRANSMISSION
FIGURE 5-50. TRANSMISSION, ENGINE CONNECTION AND CONVERTER
FIGURE 5-51. TRANSMISSION, INPUT SHAFTS
FIGURE 5-52. TRANSMISSION, GEARBOX HOUSING
FIGURE 5-53. TRANSMISSION, COUPLING GROUP 1
FIGURE 5-54. TRANSMISSION, COUPLING GROUP 2
FIGURE 5-55. TRANSMISSION, COUPLING GROUP 3
FIGURE 5-56. TRANSMISSION, COUPLING GROUP 4
FIGURE 5-57. TRANSMISSION, REVERSING GEAR GROUP 1
FIGURE 5-58. TRANSMISSION, REVERSING GEAR GROUP 2
FIGURE 5-59. TRANSMISSION, OUTPUT
FIGURE 5-60. TRANSMISSION, CONTROL UNIT
FIGURE 5-61. TRANSMISSION, VALVE HOUSING ASSEMBLY
FIGURE 5-62. TRANSMISSION, VALVE BLOCK ASSEMBLY
FIGURE 5-63. TRANSMISSION, OIL PUMP AND FILTER
FIGURE 5-64. FENDER INSTALLATION
FIGURE 5-65. WHEEL ASSEMBLY (8042)
FIGURE 5-66. WHEEL ASSEMBLY (10042,10054)
SECTION 6 - CABFIGURE 6-1. CAB INSTALLATION
FIGURE 6-2. CAB ASSEMBLY
FIGURE 6-3. CAB DOOR ASSEMBLY (Prior to SN 0160050422, Excluding 0160050419)
FIGURE 6-4. CAB DOOR ASSEMBLY (SN 0160050422 to Present, Including 0160050419)
FIGURE 6-5. SOFT CAB ENCLOSURE
FIGURE 6-6. WIPERS
FIGURE 6-7. OPERATORS SEAT
FIGURE 6-8. CAB HEATER
FIGURE 6-9. REAR DROPOUT WINDOW INSTALLATION
SECTION 7 - CONTROLSFIGURE 7-1. BRAKE
FIGURE 7-2. ACCELERATOR
FIGURE 7-3. STEERING COLUMN
FIGURE 7-4. BOOM CONTROL
FIGURE 7-5. FRAME LEVEL AND ATTACHMENT TILT CONTROL
FIGURE 7-6. AUXILIARY CONTROL
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. SUPPLY CIRCUIT
FIGURE 8-2. DUMP CIRCUIT IF EQUIPPED FOR ULS
FIGURE 8-3. STEER SELECT CIRCUIT
FIGURE 8-4. SERVICE BRAKE CIRCUIT
FIGURE 8-5. LIFT CYLINDER CIRCUIT
FIGURE 8-6. EXTEND/RETRACT CYLINDER CIRCUIT
FIGURE 8-7. ATTACHMENT TILT AND TILT COMPENSATION CYLINDER CIRCUIT
FIGURE 8-8. AUXILIARY HYDRAULIC CIRCUIT
FIGURE 8-9. FRAME LEVEL AND STABIL-TRAK CYLINDER CIRCUIT
FIGURE 8-10. OUTRIGGER CIRCUIT (10042,10054)
FIGURE 8-11. TRANSMISSION COOLER
FIGURE 8-12. MAIN CONTROL VALVE INSTALLATION
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. LIFT CYLINDER
FIGURE 9-2. EXTEND/RETRACT CYLINDER (10054,8042)
FIGURE 9-3. EXTEND/RETRACT CYLINDER (10042)
FIGURE 9-4. ATTACHMENT TILT CYLINDER
FIGURE 9-5. TILT COMPENSATION CYLINDER
FIGURE 9-6. FRAME LEVEL CYLINDER (Prior to SN 0160076614, Including 0160076627 and 0160076629)
FIGURE 9-7. FRAME LEVEL CYLINDER (SN 0160076614 through 0160076626, SN 0160076630 to Present, Including 0160076628, Excluding 0160076627 and 0160076629)
FIGURE 9-8. STABIL-TRAK CYLINDER
FIGURE 9-9. OUTRIGGER CYLINDER
FIGURE 9-10. 50IN SIDE SHIFT CARRIAGE CYLINDER
FIGURE 9-11. MAIN CONTROL VALVE
FIGURE 9-12. PISTON PUMP
FIGURE 9-13. PISTON PUMP
FIGURE 9-14. PISTON PUMP (Prior to SN 0160059878)
FIGURE 9-15. PISTON PUMP (SN 0160059878 to Present)
FIGURE 9-16. FUEL/HYDRAULIC TANK ASSEMBLY
FIGURE 9-17. DIRECTIONAL CONTROL VALVE
FIGURE 9-18. BRAKE VALVE
FIGURE 9-19. SIDE TILT CARRIAGE CYLINDER (Prior to SN 0160066474)
FIGURE 9-20. SIDE TILT CARRIAGE CYLINDER (SN 0160066474 to Present)
FIGURE 9-21. 72 INCH 90 SWING CARRIAGE CYLINDER
FIGURE 9-22. GRAPPLE BUCKET CYLINDER
FIGURE 9-23. VALVE SECONDARY FUNCTION
SECTION 10 - ELECTRICALFIGURE 10-1. ENGINE COMPARTMENT ELECTRICAL INSTALLATION
FIGURE 10-2. CAB ELECTRICAL INSTALLATION
FIGURE 10-3. CAB SWITCHES
FIGURE 10-4. WORK LIGHTING INSTALLATION
FIGURE 10-5. ROAD LIGHTING INSTALLATION
FIGURE 10-6. ROTATING BEACON INSTALLATION
FIGURE 10-7. ENGINE HARNESS IF EQUIPPED FOR ULS
FIGURE 10-8. ENGINE HARNESS IF EQUIPPED FOR LS
FIGURE 10-9. CAB POWER DISTRIBUTION HARNESS (Prior to SN 0160065987)
FIGURE 10-10. CAB POWER DISTRIBUTION HARNESS (SN 0160065987 to Present)
FIGURE 10-11. DASH/THROTTLE HARNESS
FIGURE 10-12. MAF/WATER IN FUEL HARNESS
FIGURE 10-13. OUTRIGGERS HARNESS (10042) (Prior to SN 0160065987)
FIGURE 10-14. OUTRIGGERS HARNESS (10042) (SN 0160065987 to Present)
FIGURE 10-15. GPS JUMPER HARNESS (10042)
FIGURE 10-16. LOGIC HARNESS (10054) (Prior to SN 0160065987)
FIGURE 10-17. LOGIC HARNESS (10054) (SN 0160065987 to Present)
FIGURE 10-18. BOOM EXTEND HARNESS (10054)
FIGURE 10-19. WORK LIGHTING HARNESS
FIGURE 10-20. ROAD LIGHTING HARNESS
FIGURE 10-21. REVERSE SENSING SYSTEM INSTALLATION
FIGURE 10-22. REVERSE SENSOR HARNESS
FIGURE 10-23. TELEMATICS INSTALLATION, UNITED RENTALS
SECTION 11 - DECALSFIGURE 11-1. CAB AND FRAME DECALS
FIGURE 11-2. BOOM DECALS
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
