JLG Telehandler 8042 10042 10054 12054 Service Manual 31222465 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 8042, 10042, 10054, 12054 Telehandler
Part Number: 31222465
Publication Date: 2025
Number of Pages: 522 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information & SpecificationsSpecifications
2.1.1 Travel Speeds
2.1.2 Hydraulic Cylinder Performance
2.1.3 Cylinder Drift
2.1.4 Electrical System
2.1.5 Engine Performance Specifications
2.1.6 Tires
Machine Temperature Chart
Serial Number Location
Fluids and Lubrications
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedules
ClearSky Smart Fleet
2.5.1 General
2.5.2 ClearSky Smart Fleet™ – Access Control
Maintenance & Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Every 10 Hours
3.3.2 First 50 Hours
3.3.3 Every 50 Hours
3.3.4 First 250 Hours
3.3.5 Every 250 Hours
3.3.6 First 500 Hours
3.3.7 Every 500 Hours
3.3.8 Every 750 Hours
3.3.9 Every 1000 Hours
3.3.10 Every 1500 Hours
3.3.11 Every 2000 Hours or 2 Year
3.3.12 Every 4000 Hours or 3 Years
3.3.13 Every 5000 Hours or 4 Years
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Service Brake Bleeding
DEF Tank Inspection
Boom Inspection and Maintenance
3.8.1 Boom Wear Pads
Hydraulic Filter Replacement
Specification and Maintenance Information
3.10.1 Axle
3.10.2 Axle Maintenance
3.10.3 Transmission
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Thread Locking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
Calibration Procedures
4.3.1 JLG Analyzer
Special Procedures
4.4.1 Towing A Disabled Machine
4.4.2 Hydraulic Reservoir
4.4.3 Fuel Tank Cleaning and Drying
4.4.4 Pressure Checks and Adjustments
4.4.5 Cylinder Checking Procedure
4.4.6 Cylinder Drift Test
4.4.7 Hydraulic Circuits
4.4.8 Pressure Specifications
4.4.9 Boom Extend and Retract Chains
4.4.10 Boom Chain Tension Adjustment (8042 & 10042)
4.4.11 Boom Chain Tension Adjustment (10054 & 12054)
4.4.12 Extend Chains Removal and Replacement (8042 & 10042)
4.4.13 Retract Chain Removal and Replacement ( 8042 & 10042)
4.4.14 Extend Chains Removal and Replacement (10054 & 12054)
4.4.15 Retract Chain Removal and Replacement (10054 & 12054)
STABIL-TRAK™ and Boom Interlock System
4.5.1 Stabil-Trak™ System Component Terminology
4.5.2 Boom Extend Interlock System Component Terminology (10054 & 12054 Only)
4.5.3 Stabil-Trak™ Description
4.5.4 Stabil-Trak™ Operation
4.5.5 Boom Extend Interlock System Description
4.5.6 Boom Extend Interlock System Operation (10054 & 12054 Only)
4.5.7 Stabil-Trak™ System Test
4.5.8 Stabil-Trak™ Electrical Circuit Operation And Troubleshooting (8042/10042)
4.5.9 Stabil-Trak™ And Boom Interlock Electrical Circuit Operation And Troubleshooting (10054 & 12054)
4.5.10 Boom/Outrigger Interlock System Test
4.5.11 Boom Extend System Hydraulic Circuit Operation And Troubleshooting
4.5.12 Stabil-Trak™ Hydraulic Circuit Operation And Troubleshooting
System SoftwareAnalyzer
5.1.1 Machine Data Access
5.1.2 Hand Held Analyzer
5.1.3 Mobile Analyzer
5.1.4 Analyzer Software Version P4.0
Analyzer Software Accessibility
5.2.1 Access Level
5.2.2 Diagnostics
5.2.3 Machine Set-Up
5.2.4 Personalities
5.2.5 Calibrations
ClearSky (CS550) Configuration and Troubleshooting
5.3.1 ClearSky Smart FleetTM CS550 Configuration
5.3.2 Troubleshooting
Fault CodesIntroduction
6.1.1 Gauge Fault Code Display
6.1.2 Offboard Diagnostics
Engine Fault Codes
Machine Fault Codes
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Component
Torque Values
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
8.5.1 Engine Compartment Fuse and Relays
8.5.2 Cab Harness Fuses and Relays
Telematics Gateway (if equipped)
8.6.1 Telematics-Ready (TCU) Plug
8.6.2 Component Locations
8.6.3 Telematics Gateway Harness Breakdown
Removal and InstallationWheels
9.1.1 Removing Wheel and Tire Assembly from Machine
9.1.2 Installing Wheel and Tire Assembly onto Machine
Drive Assembly
9.2.1 Axle Assembly And Drive Shaft Troubleshooting
9.2.2 Axle Serial Number
9.2.3 Axle Replacement (8042, 10042, 10054 & 12054)
9.2.4 Drive Shafts
9.2.5 Outrigger Replacement (10042, 10054 & 12054 only)
9.2.6 Transmission Components
Boom
9.3.1 Boom System Component Terminology
9.3.2 Troubleshooting
9.3.3 Boom System ( 8042 & 10042)
9.3.4 Boom System (10054 & 12054)
9.3.5 Manual Coupler
9.3.6 Boom Prop (If Equipped)
9.3.7 Isolation Coupler
9.3.8 Forks
9.3.9 Boom Angle Sensor
9.3.10 Boom Extend Interlock Sensor (10054 & 12054 only)
9.4.1 Serial Number Plate
9.4.2 Cab Removal/Installation
9.4.3 Steering Wheel
9.4.4 Service Brake Switch
9.4.5 Service Brake Pedal
9.4.6 Throttle Pedal
9.4.7 Joystick Assembly
9.4.8 Ignition Key Switch
9.4.9 Dash Switches
9.4.10 Outrigger Pressure Switches (10054 & 12054 Only)
9.4.11 Windshield Wiper Motor
9.4.12 Skylight Wiper Motor
9.4.13 Windshield Washer Reservoir
9.4.14 Heater System (if equipped)
9.4.15 Heater and A/C System (if equipped)
9.4.16 Cab Heater And Fan
9.4.17 Display Monitor
9.4.18 Steering Column and Steering Valve
9.4.19 Auxiliary/Frame Level Lever Assemblies
9.5.1 Component Terminology
9.5.2 Diesel Fuel
9.5.3 Engine Serial Number
9.5.4 Engine Replacement
9.5.5 Engine Electrical System
9.5.6 Coolant System Pressure Cap
9.5.7 Coolant Level Sensor
9.5.8 Thermostat Replacement
9.5.9 Radiator/Oil Cooler and Replacement
9.5.10 Fuel/Hydraulic Oil Tank
9.5.11 Diesel Exhaust Fluid (DEF) Tank - if equipped with 110 hp (82 kW) ULS engine
9.5.12 Diesel Exhaust Fluid (DEF) Header - if equipped with 110 hp (82 kW) ULS engine
9.5.13 Diesel Exhaust Fluid (DEF) Pump Filter - if equipped with 110 hp (82 kW) ULS engine
9.5.14 Diesel Exhaust Fluid (DEF) System Cleaning - if equipped with 110 hp (82 kW) ULS engine
9.5.15 Exhaust System - if equipped with 110 hp (82 kW) ULS engine
9.5.16 Exhaust System - if equipped with 74 hp (55 kW) ULS engine
9.5.17 Exhaust System - if equipped with 110 hp (82 kW) LS engine
9.5.18 Air Cleaner Assembly
9.5.19 Starter
9.5.20 Alternator
9.6.1 Transmission Components
9.6.2 Transmission Serial Number
9.6.3 Transmission Replacement
9.6.4 Transmission Temperature Sender
9.6.5 Reverse Alarm
9.6.6 Transmission Troubleshooting
Hydraulic Cylinders
9.7.1 General Cylinder Instructions
9.7.2 Steering Cylinders
Hydraulic Valves
9.8.1 Main Control Valve
9.8.2 Service Brake Valve
9.8.3 Steering Orbital Valve
9.8.4 Steer Select Valve
9.8.5 Secondary Function Manifold
9.8.6 Outrigger Valve (10042, 10054 & 12054 only)
9.8.7 Extend Lockout Valve (10054 & 12054 only)
9.8.8 Transmission Solenoid Valves
9.9.1 Hydraulic System Pump
Electrical Components
9.10.1 Battery
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Axle Assembly
10.1.2 Transmission Assembly
Boom
10.2.1 Boom System - Three Boom Section (8042 & 10042)
10.2.2 Boom System - Four Boom Section (10054 &12054)
Engine Components
10.4.1 Fuel/Hydraulic Oil Tank
10.5.1 Piston Pump
Hydraulic Cylinders
10.6.1 General Cylinder Disassembly
10.6.2 Cylinder Cleaning Instructions
10.6.3 Cylinder Inspection
10.6.4 Cylinder Assembly Instructions
10.6.5 Hydraulic Cylinder Repair Information
Hydraulic Valves
10.7.1 Main Control Valve
10.7.2 Secondary Function Manifold
10.7.3 Steer Select Valve
10.7.4 Outrigger Valve (10042, 10054 & 12054 only)
10.7.5 Extend Lockout Valve (10054 & 12054 only)
Hydraulic Components
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
Electrical Schematics
12.2.1 Electrical Schematic — T4F HRC
12.2.2 Electrical Schematic — T4F LRC
12.2.3 Electrical Schematic — T4F 55kW
- SuperPac Parts Manual
- StratoLift Parts Manual
