JLG Telehandler 742 Parts Catalog 31221592
Brand: JLG
Type of Machine: Telehandler
Model: JLG 742 Telehandler
Part Number: 31221592
Publication Date: 2025
Number of Pages: 1196 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. ENGINE ENCLOSURE INSTALLATION
FIGURE 1-2. ENGINE ENCLOSURE COVER INSTALLATION
FIGURE 1-3. HOOD ASSEMBLY
FIGURE 1-4. COVER INSTALLATION (NO OUTRIGGERS) (ULS)
FIGURE 1-5. COVER INSTALLATION (NO OUTRIGGERS) (LS)
FIGURE 1-6. TANK INSTALLATION
FIGURE 1-7. FUEL TANK INSTALLATION
FIGURE 1-8. HYDRAULIC TANK INSTALLATION
FIGURE 1-9. FUEL CAP ASSEMBLY
FIGURE 1-10. MIRROR INSTALLATION
FIGURE 1-11. BOOM PROP INSTALLATION (ANSI)
FIGURE 1-12. BOOM PROP INSTALLATION (CANADA)
FIGURE 1-13. BOOM PROP BRACKET
FIGURE 1-14. COUNTERWEIGHT INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM ASSEMBLY
FIGURE 2-2. FIRST BOOM SECTION ASSEMBLY
FIGURE 2-3. SECOND BOOM SECTION ASSEMBLY
FIGURE 2-4. THIRD BOOM SECTION ASSEMBLY
FIGURE 2-5. RETRACT CHAIN INSTALLATION
FIGURE 2-6. EXTEND CHAIN INSTALLATION
FIGURE 2-7. PINS INSTALLATION
FIGURE 2-8. RETRACT CHAIN SHEAVE
FIGURE 2-9. CHAIN SHEAVE ASSEMBLY
FIGURE 2-10. HOSE BRACKET INSTALLATION
FIGURE 2-11. BOOM PINNING INSTALLATION
FIGURE 2-12. LIFT CYLINDER PINS INSTALLATION
FIGURE 2-13. COMPENSATION CYLINDER PINS INSTALLATION
FIGURE 2-14. BOOM PIVOT PIN INSTALLATION
FIGURE 2-15. MANUAL QUICK COUPLER INSTALLATION
FIGURE 2-16. HYDRAULIC QUICK COUPLER INSTALLATION
FIGURE 2-17. BOOM PIN INSTALLATION
FIGURE 2-18. TILT CYLINDER PIN INSTALLATION
FIGURE 2-19. BOOM ANGLE INDICATOR INSTALLATION
FIGURE 2-20. BOOM BRUSHES INSTALLATION
FIGURE 2-21. QUICK COUPLER ASSEMBLY
SECTION 3 - ATTACHMENTSFIGURE 3-1. BASKET, PERSONNEL - 4FT X 8FT (ASME)
FIGURE 3-2. BASKET, PERSONNEL - 4FT X 8FT (DOMESTIC)
FIGURE 3-3. BASKET, PERSONNEL - 4FT X 8FT (ISO)
FIGURE 3-4. BASKET, FORK MOUNTED
FIGURE 3-5. BOOM - ADJUSTABLE (CARRIAGE MOUNTED)
FIGURE 3-6. BOOM - ADJUSTABLE (FORK MOUNTED)
FIGURE 3-7. BOOM - 3FT WITH WINCH
FIGURE 3-8. BOOM - 12FT WITH WINCH
FIGURE 3-9. BOOM - 12FT WITHOUT WINCH
FIGURE 3-10. BOOM - 15FT WITHOUT WINCH
FIGURE 3-11. BUCKET - 60IN (1.3 CU YD) (FORK MOUNTED)
FIGURE 3-12. BUCKET - 72IN (1.0 CU YD)
FIGURE 3-13. BUCKET - 96IN (1.5 CU YD)
FIGURE 3-14. BUCKET - 96IN GRAPPLE
FIGURE 3-15. BUCKET - 102IN (2.0 CU YD)
FIGURE 3-16. CARRIAGE ASSEMBLY - 48IN/12000# CAPACITY SIDE SHIFT
FIGURE 3-17. CARRIAGE ASSEMBLY - 50IN/1270MM
FIGURE 3-18. FORK POSITIONING CARRIAGE WITH FORKS (4.5 TON)
FIGURE 3-19. CARRIAGE ASSEMBLY - 50IN/12000# CAPACITY SIDE TILT
FIGURE 3-20. CARRIAGE ASSEMBLY - 60IN/1524MM
FIGURE 3-21. CARRIAGE ASSEMBLY - 60IN/12000# CAPACITY SIDE TILT
FIGURE 3-22. CARRIAGE ASSEMBLY - 72IN/1829MM
FIGURE 3-23. CARRIAGE ASSEMBLY - 72IN - 90 DEGREE SWING
FIGURE 3-24. CARRIAGE ASSEMBLY - 72IN/12000# CAPACITY SIDE TILT
FIGURE 3-25. CARRIAGE ASSEMBLY - DRYWALL (SWING)
FIGURE 3-26. CARRIAGE ASSEMBLY - DRYWALL SWING CARRIAGE
FIGURE 3-27. CARRIAGE ASSEMBLY - DRYWALL BOARD HANDLER
FIGURE 3-28. CARRIAGE ASSEMBLY - DRYWALL PIVOT FRAME
FIGURE 3-29. CARRIAGE ASSEMBLY - DRYWALL CYLINDER
FIGURE 3-30. CARRIAGE ASSEMBLY - DRYWALL HYDRAULICS
FIGURE 3-31. CARRIAGE ASSEMBLY - DRYWALL VALVE ASSEMBLY
FIGURE 3-32. CARRIAGE ASSEMBLY - DRYWALL CYLINDER
FIGURE 3-33. CARRIAGE ASSEMBLY - DRYWALL FORKS
FIGURE 3-34. FORK 2X2X48 / 1940# CAPACITY
FIGURE 3-35. FORK 2.36X4X48 / 5000# CAPACITY
FIGURE 3-36. FORK 2.36X4X48 / 5475# CAPACITY
FIGURE 3-37. FORK 2.00X6X48 / 6005# CAPACITY
FIGURE 3-38. FORK 2.36X5X48 / 6850# CAPACITY
FIGURE 3-39. FORK 2.36X4X60 / 5000# CAPACITY
FIGURE 3-40. FORK 2.36X5X60 / 6850# CAPACITY
FIGURE 3-41. FORK 2.36X6X60 / 8150# CAPACITY
FIGURE 3-42. FORK 2.00X6X72 / 6610# CAPACITY
FIGURE 3-43. FORK 2.36X5X72 / 6850# CAPACITY
FIGURE 3-44. FORK 40X150X1540
FIGURE 3-45. FORK 50X180X1540
FIGURE 3-46. FORK EXTENSION - 90IN
FIGURE 3-47. FORK CLAMPS INSTALLATION
FIGURE 3-48. HOOK, COUPLING
FIGURE 3-49. HOOK, CRANE
FIGURE 3-50. MAST, VERTICAL - 8FT (STANDARD)
FIGURE 3-51. MAST, VERTICAL - 8FT (SIDE TILT ELECTRIC MAST)
FIGURE 3-52. MAST, VERTICAL - DECAL KIT
FIGURE 3-53. MAST, VERTICAL - CYLINDER
FIGURE 3-54. SWEEPER ASSEMBLY
FIGURE 3-55. SWEEPER ASSEMBLY - BODY
FIGURE 3-56. SWEEPER ASSEMBLY - CORE
FIGURE 3-57. SWEEPER ASSEMBLY - HYDRAULIC SINGLE MOTOR ASSEMBLY
FIGURE 3-58. SWEEPER ASSEMBLY - HOPPER
FIGURE 3-59. SWEEPER ASSEMBLY - IDLER
FIGURE 3-60. SWEEPER ASSEMBLY - MOTOR
FIGURE 3-61. TRASH HOPPER
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION, 74HP (ULS)
FIGURE 4-2. ENGINE COMPONENTS, 74HP (ULS)
FIGURE 4-3. ENGINE INSTALLATION, 110HP (ULS)
FIGURE 4-4. ENGINE COMPONENTS, 110HP (ULS)
FIGURE 4-5. ENGINE INSTALLATION, 110HP (LS)
FIGURE 4-6. ENGINE COMPONENTS, 110HP (LS)
FIGURE 4-7. ENGINE MOUNTING INSTALLATION
FIGURE 4-8. ENGINE PARTS INSTALLATION (NO HEATER)
FIGURE 4-9. ENGINE PARTS INSTALLATION (HEATER)
FIGURE 4-10. AIR CLEANER INSTALLATION (ULS)
FIGURE 4-11. AIR CLEANER INSTALLATION (LS)
FIGURE 4-12. AIR CLEANER ASSEMBLY, 74HP
FIGURE 4-13. AIR CLEANER ASSEMBLY, 110HP
FIGURE 4-14. AIR INTAKE DUCT INSTALLATION
FIGURE 4-15. AIR CLEANER LINES INSTALLATION (ULS)
FIGURE 4-16. AIR CLEANER LINES INSTALLATION (LS)
FIGURE 4-17. AIR INTAKE SHUT OFF VALVE INSTALLATION
FIGURE 4-18. HEATER BREATHER - 74 HP
FIGURE 4-19. EXHAUST INSTALLATION, 74HP (ULS)
FIGURE 4-20. EXHAUST INSTALLATION, 110HP (ULS)
FIGURE 4-21. EXHAUST INSTALLATION, 110HP (LS)
FIGURE 4-22. MUFFLER INSTALLATION (LS)
FIGURE 4-23. DEF TANK INSTALLATION
FIGURE 4-24. DEF TANK ASSEMBLY
FIGURE 4-25. DEF BREATHER VALVE
FIGURE 4-26. DEF PUMP AND CONTROL INSTALLATION
FIGURE 4-27. UREA PUMP
FIGURE 4-28. DEF PUMP LINES INSTALLATION
FIGURE 4-29. DEF TANK LINES INSTALLATION
FIGURE 4-30. FUEL LINES INSTALLATION (ULS)
FIGURE 4-31. FUEL LINES INSTALLATION (LS)
FIGURE 4-32. PRIMARY FUEL FILTER INSTALLATION (ULS)
FIGURE 4-33. PRIMARY FUEL FILTER INSTALLATION (LS)
FIGURE 4-34. FUEL TANK ASSEMBLY
FIGURE 4-35. FAN INSTALLATION, 74HP
FIGURE 4-36. FAN INSTALLATION, 110HP
FIGURE 4-37. FAN GUARD INSTALLATION
FIGURE 4-38. COOLING PACKAGE INSTALLATION (ULS)
FIGURE 4-39. COOLING PACKAGE INSTALLATION (LS)
FIGURE 4-40. COOLANT LINES INSTALLATION (ULS)
FIGURE 4-41. COOLANT LINES INSTALLATION (LS)
FIGURE 4-42. RADIATOR COOLING PACKAGE
FIGURE 4-43. SURGE TANK INSTALLATION
FIGURE 4-44. A/C PUMP INSTALLATION (ULS)
FIGURE 4-45. A/C PUMP INSTALLATION (LS)
FIGURE 4-46. A/C LINES INSTALLATION
FIGURE 4-47. ENGINE OIL QUICK DRAIN INSTALLATION
FIGURE 4-48. CAC LINES INSTALLATION (ULS)
FIGURE 4-49. CAC LINES INSTALLATION (LS)
FIGURE 4-50. HOC LINES INSTALLATION
FIGURE 4-51. TOC LINES INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. TRANSMISSION INSTALLATION, 74 HP
FIGURE 5-2. TRANSMISSION INSTALLATION, 110 HP
FIGURE 5-3. POWERSHIFT TRANSMISSION
FIGURE 5-4. TRANSMISION, ENGINE CONNECTION
FIGURE 5-5. TRANSMISSION, CONVERTER
FIGURE 5-6. TRANSMISSION, INPUT
FIGURE 5-7. TRANSMISSION, HOUSING GROUP 1
FIGURE 5-8. TRANSMISSION, HOUSING GROUP 2
FIGURE 5-9. TRANSMISSION, CLUTCH GROUP 1
FIGURE 5-10. TRANSMISSION, CLUTCH GROUP 2
FIGURE 5-11. TRANSMISSION, COUPLING GROUP 1
FIGURE 5-12. TRANSMISSION, COUPLING GROUP 2
FIGURE 5-13. TRANSMISSION, COUPLING GROUP 3
FIGURE 5-14. TRANSMISSION, COUPLING GROUP 4
FIGURE 5-15. TRANSMISSION, OUTPUT
FIGURE 5-16. TRANSMISSION, POWER TAKE-OFF
FIGURE 5-17. TRANSMISSION, CONTROL UNIT
FIGURE 5-18. TRANSMISSION, SHIFT SYSTEM
FIGURE 5-19. TRANSMISSION, PRESSURE REGULATOR
FIGURE 5-20. TRANSMISSION, PRESSURE OIL PUMP
FIGURE 5-21. TRANSMISSION, INDUCTIVE TRANSMITTER
FIGURE 5-22. TRANSMISSION, FILTER
FIGURE 5-23. TRANSMISSION, OIL DIPSTICK
FIGURE 5-24. TRANSMISSION, ACCESSORIES
FIGURE 5-25. TRANSMISSION, TRANSFER BOX HOUSING 1
FIGURE 5-26. TRANSMISSION, TRANSFER BOX HOUSING 2
FIGURE 5-27. TRANSMISSION, TRANSFER BOX HOUSING INPUT
FIGURE 5-28. TRANSMISSION, TRANSFER BOX HOUSING OUTPUT 1
FIGURE 5-29. TRANSMISSION, TRANSFER BOX HOUSING OUTPUT 2
FIGURE 5-30. DRIVE SHAFTS INSTALLATION
FIGURE 5-31. FRONT DRIVE SHAFT INSTALLATION
FIGURE 5-32. REAR DRIVE SHAFT INSTALLATION
FIGURE 5-33. DRIVETRAIN INSTALLATION, 74HP
FIGURE 5-34. DRIVETRAIN INSTALLATION, 110HP
FIGURE 5-35. FRONT AXLE INSTALLATION, 74HP
FIGURE 5-36. FRONT AXLE INSTALLATION, 110HP
FIGURE 5-37. FONT AXLE LINES INSTALLATION
FIGURE 5-38. FRONT AXLE MOUNTING INSTALLATION, 74HP
FIGURE 5-39. FRONT AXLE MOUNTING INSTALLATION, 110HP
FIGURE 5-40. FRONT AXLE, 74HP
FIGURE 5-41. FRONT AXLE, 74HP - CENTRAL HOUSING
FIGURE 5-42. FRONT AXLE, 74HP - DIFFERENTIAL
FIGURE 5-43. FRONT AXLE, 74HP - HUB REDUCTION
FIGURE 5-44. FRONT AXLE, 74HP - BRAKES
FIGURE 5-45. FRONT AXLE, 74HP - STEERING
FIGURE 5-46. FRONT AXLE, 74HP - TRUNION
FIGURE 5-47. FRONT AXLE, 74HP - PLANET GEAR CARRIER
FIGURE 5-48. FRONT AXLE, 110HP
FIGURE 5-49. FRONT AXLE, 110HP - CENTRAL HOUSING
FIGURE 5-50. FRONT AXLE, 110HP - DIFFERENTIAL
FIGURE 5-51. FRONT AXLE, 110HP - HUB REDUCTION
FIGURE 5-52. FRONT AXLE, 110HP - BRAKES
FIGURE 5-53. FRONT AXLE, 110HP -STEERING
FIGURE 5-54. FRONT AXLE, 110HP - TRUNION
FIGURE 5-55. FRONT AXLE, 110HP - DIFFERENTIAL
FIGURE 5-56. FRONT AXLE, 110HP - REDUCTION BUSHING
FIGURE 5-57. FRONT AXLE, 110HP - PLANET GEAR CARRIER
FIGURE 5-58. FRONT AXLE, 110HP - RING GEAR SUPPORT
FIGURE 5-59. FRONT AXLE, 110HP - PLANET GEAR
FIGURE 5-60. FRONT AXLE, 110HP - TRUNION KIT
FIGURE 5-61. REAR AXLE INSTALLATION, 74HP
FIGURE 5-62. REAR AXLE INSTALLATION, 110HP
FIGURE 5-63. REAR AXLE LINES INSTALLATION
FIGURE 5-64. REAR AXLE MOUNTING INSTALLATION, 74HP
FIGURE 5-65. REAR AXLE MOUNTING INSTALLATION, 110HP
FIGURE 5-66. REAR AXLE, 74HP
FIGURE 5-67. REAR AXLE, 74HP - CENTRAL HOUSING
FIGURE 5-68. REAR AXLE, 74HP - DIFFERENTIAL
FIGURE 5-69. REAR AXLE, 74HP - HUB REDUCTION
FIGURE 5-70. REAR AXLE, 74HP - BRAKES
FIGURE 5-71. REAR AXLE, 74HP - STEERING
FIGURE 5-72. REAR AXLE, 74HP- TRUNION
FIGURE 5-73. REAR AXLE, 110HP
FIGURE 5-74. REAR AXLE, LSI SENSOR INSTALLATION
FIGURE 5-75. TIRE/WHEEL SET 315/95-28 SOLID CONTINENTAL
FIGURE 5-76. TIRE/WHEEL SET 370/75-28 PNEUMATIC
FIGURE 5-77. TIRE/WHEEL SET 370/75-28 PNEUMATIC NON-MARKING
FIGURE 5-78. TIRE/WHEEL SET 370/75-28 FOAM-FILLED
FIGURE 5-79. TIRE/WHEEL SET 370/75-28 FOAM-FILLED NON-MARKING
FIGURE 5-80. TIRE/WHEEL SET 13-24/16PR PNEUMATIC
FIGURE 5-81. TIRE/WHEEL SET 13-24/16PR FOAM-FILLED
FIGURE 5-82. TIRE/WHEEL SET 13-24 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-83. TIRE/WHEEL SET 13-24 SOLIDEAL (DIRECTIONAL)
FIGURE 5-84. TIRE/WHEEL SET 13-28 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-85. TIRE/WHEEL SET 13-28 SOLIDBOSS (NON-DIRECTIONAL)
FIGURE 5-86. TIRE/WHEEL SET 18 X 625 (PNEUMATIC TURF)
FIGURE 5-87. FENDER INSTALLATION
FIGURE 5-88. CAB FENDER INSTALLATION
FIGURE 5-89. CAB FENDER INSTALLATION REAR (LH)
FIGURE 5-90. WHEEL CHOCK INSTALLATION
FIGURE 5-91. TOOLBOX INSTALLATION
SECTION 6 - CABFIGURE 6-1. CAB MOUNTING
FIGURE 6-2. CAB MOUNTS INSTALLATION
FIGURE 6-3. FRONT CAB OUTRIGGER INSTALLATION
FIGURE 6-4. OROPS CAB INSTALLATION
FIGURE 6-5. EROPS CAB INSTALLATION
FIGURE 6-6. CAB, TRIM KIT
FIGURE 6-7. CAB, TRIM KIT
FIGURE 6-8. OPEN CAB ASSEMBLY
FIGURE 6-9. OPEN CAB, LSI INSTALLATION
FIGURE 6-10. OPEN CAB PLUG GROUP
FIGURE 6-11. LSI DISPLAY INSTALLATION (OPEN CAB)
FIGURE 6-12. CAB, EPD CAULK
FIGURE 6-13. ENCLOSED CAB ASSEMBLY
FIGURE 6-14. ENCLOSED CAB, LSI INSTALLATION
FIGURE 6-15. REAR WINDOW INSTALLATION
FIGURE 6-16. REAR WINDOW INSTALLATION (WO/WIPER) (ANSI)
FIGURE 6-17. REAR WINDOW INSTALLATION (WO/WIPER) (ISO)
FIGURE 6-18. REAR WINDOW INSTALLATION (WO/WIPER) (ENG/SPAN)
FIGURE 6-19. REAR WINDOW ASSEMBLY
FIGURE 6-20. DOOR INSTALLATION
FIGURE 6-21. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-22. CAB LATCH ASSEMBLY
FIGURE 6-23. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-24. DOOR ASSEMBLY
FIGURE 6-25. CAB DOOR
FIGURE 6-26. DOOR STRAP INSTALLATION
FIGURE 6-27. ENCLOSED CAB PLUG GROUP
FIGURE 6-28. ENCLOSED CAB, LSI DISPLAY INSTALLATION
FIGURE 6-29. BASIC MIRROR INSTALLATION
FIGURE 6-30. FRONT COVER INSTALLATION
FIGURE 6-31. FIRE EXTINGUISHER INSTALLATION
FIGURE 6-32. FILTER TRAY PANEL
FIGURE 6-33. FRONT DUCT COVER
FIGURE 6-34. LEVEL INDICATOR INSTALLATION
FIGURE 6-35. SEAT INSTALLATION - CLOTH (ORANGE SEAT BELT)
FIGURE 6-36. SEAT INSTALLATION - VINYL
FIGURE 6-37. SEAT ASSEMBLY - CLOTH (ORANGE SEAT BELT)
FIGURE 6-38. SEAT ASSEMBLY - VINYL
FIGURE 6-39. SEAT BELT INSTALLATION (3 INCH)
FIGURE 6-40. HEATER INSTALLATION
FIGURE 6-41. HEATER AND A/C INSTALLATION
FIGURE 6-42. HEATER ASSEMBLY
FIGURE 6-43. HEATER
FIGURE 6-44. HEATER AND A/C ASSEMBLY
FIGURE 6-45. HEATER AND A/C
FIGURE 6-46. CAB CONDENSER ASSEMBLY
FIGURE 6-47. A/C RECEIVER DRIER
FIGURE 6-48. CONDENSER
FIGURE 6-49. FRONT WIPER INSTALLATION
FIGURE 6-50. REAR WIPER INSTALLATION
FIGURE 6-51. ROOF WIPER INSTALLATION
FIGURE 6-52. HEADLINER INSTALLATION
FIGURE 6-53. TRIM INSTALLATION - OPEN CAB
FIGURE 6-54. TRIM INSTALLATION - ENCLOSED CAB
FIGURE 6-55. DASH COVER ASSEMBLY - ENCLOSED CAB
FIGURE 6-56. ARMREST
FIGURE 6-57. OPEN CAB FRONT COVER
FIGURE 6-58. ENCLOSED CAB FRONT COVER
FIGURE 6-59. ROOF CAP INSTALLATION (A/C)
FIGURE 6-60. ROOF CAP INSTALLATION (NO A/C)
FIGURE 6-61. NON SKID TAPE INSTALLATION
FIGURE 6-62. EXTERNAL WINDOW RELEASE INSTALLATION (CAN & ISO)
FIGURE 6-63. WASHER TANK INSTALLATION
FIGURE 6-64. WASHER BOTTLE
FIGURE 6-65. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-66. CAB GUARD INSTALLATION (TOP)
FIGURE 6-67. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-68. ROOF PIGTAIL CAP INSTALLATION
FIGURE 6-69. ROOF PIGTAIL INSTALLATION
FIGURE 6-70. NO SUNSCREEN INSTALLATION
FIGURE 6-71. RETRACTABLE SUNSCREEN INSTALLATION
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL
FIGURE 7-5. BRAKE PEDAL PLATE
FIGURE 7-6. COLUMN CLAMP INSTALLATION
FIGURE 7-7. HORN BUTTON INSTALLATION
FIGURE 7-8. JOYSTICK INSTALLATION (ELOBAU BRAND)
FIGURE 7-9. JOYSTICK ASSEMBLY (ELOBAU BRAND)
FIGURE 7-10. JOYSTICK INSTALLATION (BOSCH/REXROTH BRAND)
FIGURE 7-11. JOYSTICK ASSEMBLY (BOSCH BRAND)
FIGURE 7-12. STEERING COLUMN INSTALLATION
FIGURE 7-13. STEERING COLUMN INSTALLATION (EMERGENCY STEERING)
FIGURE 7-14. STEERING WHEEL INSTALLATION
FIGURE 7-15. STEERING WHEEL
FIGURE 7-16. WIPER-TURN SWITCH INSTALLATION
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. MAIN HYDRAULIC INSTALLATION - 74HP
FIGURE 8-2. MAIN HYDRAULIC INSTALLATION - 74HP (EMERGENCY STEERING)
FIGURE 8-3. MAIN HYDRAULIC INSTALLATION - 110HP
FIGURE 8-4. MAIN HYDRAULIC INSTALLATION - 110HP (EMERGENCY STEERING)
FIGURE 8-5. BOOM HYDRAULICS INSTALLATION - 74HP
FIGURE 8-6. BOOM HYDRAULICS INSTALLATION - 110HP
FIGURE 8-7. BOOM AUXILIARY HYDRAULICS INSTALLATION
FIGURE 8-8. BOOM AUXILIARY HYDRAULICS INSTALLATION (SIDE MOUNTED)
FIGURE 8-9. BOOM AUXILIARY HYDRAULICS INSTALLATION (HYDRAULIC COUPLER)
FIGURE 8-10. BOOM AUXILIARY VALVE & FITTINGS ASSEMBLY (HYDRAULIC COUPLER)
FIGURE 8-11. BOOM TUBES INSTALLATION
FIGURE 8-12. CAB HYDRAULICS INSTALLATION - 74HP
FIGURE 8-13. CAB HYDRAULICS INSTALLATION - 74HP (EMERGENCY STEERING)
FIGURE 8-14. CAB HYDRAULICS INSTALLATION - 110HP
FIGURE 8-15. CAB HYDRAULICS INSTALLATION - 110HP (EMERGENCY STEERING)
FIGURE 8-16. COUNTERBALANCE VALVE INSTALLATION (LIFT - NO RIDE CONTROL) (74HP)
FIGURE 8-17. COUNTERBALANCE VALVE INSTALLATION (LIFT - NO RIDE CONTROL) (110HP)
FIGURE 8-18. COUNTERBALANCE VALVE HYDRAULIC LINES (LIFT - RIDE CONTROL) (74HP)
FIGURE 8-19. COUNTERBALANCE VALVE HYDRAULIC LINES (LIFT - RIDE CONTROL) (110HP)
FIGURE 8-20. EMERGENCY STEERING MANIFOLD & FITTINGS ASSEMBLY
FIGURE 8-21. FRAME HYDRAULICS INSTALLATION - 74HP
FIGURE 8-22. FRAME HYDRAULICS INSTALLATION 110HP
FIGURE 8-23. FRAME LEVEL INSTALLATION
FIGURE 8-24. FRAME LEVEL HYDRAULICS INSTALLATION (NO OUTRIGGERS)
FIGURE 8-25. FRAME LEVEL HYDRAULICS INSTALLATION (NO OUTRIGGERS) (EMERGENCY STEERING)
FIGURE 8-26. PISTON PUMP INSTALLATION - 74HP
FIGURE 8-27. PISTON PUMP INSTALLATION - 110HP
FIGURE 8-28. PISTON PUMP ASSEMBLY - 74HP
FIGURE 8-29. PISTON PUMP ASSEMBLY - 110HP
FIGURE 8-30. REAR AXLE STABILIZER INSTALLATION
FIGURE 8-31. VALVES INSTALLATION - 74HP
FIGURE 8-32. VALVES INSTALLATION - 110HP
FIGURE 8-33. VALVES INSTALLATION - FRAME LEVEL
FIGURE 8-34. VALVE & FITTINGS ASSEMBLY- FRAME LEVEL
FIGURE 8-35. VALVES INSTALLATION - MAIN & PRIORITY- 74HP
FIGURE 8-36. VALVES INSTALLATION - MAIN & PRIORITY- 110HP
FIGURE 8-37. VALVE INSTALLATION - MAIN - 74HP
FIGURE 8-38. VALVE INSTALLATION - MAIN - 110HP
FIGURE 8-39. VALVE & FITTINGS ASSEMBLY- MAIN - 74HP
FIGURE 8-40. VALVE INSTALLATION - PRIORITY - 74HP
FIGURE 8-41. VALVE ASSEMBLY - PRIORITY FUNCTION MANIFOLD
FIGURE 8-42. VALVE INSTALLATION - PARKING BRAKE - 110HP
FIGURE 8-43. VALVES INSTALLATION - PARKING BRAKE - 110HP
FIGURE 8-44. VALVE INSTALLATION - SAHR BRAKE
FIGURE 8-45. VALVE ASSEMBLY - SAHR BRAKE
FIGURE 8-46. VALVES INSTALLATION - STEER SELECT
FIGURE 8-47. VALVE MOUNTING INSTALLATION - STEER SELECT
FIGURE 8-48. VALVE INSTALLATION - STEER SELECT
FIGURE 8-49. VALVE & FITTINGS ASSEMBLY- STEER SELECT
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. COUPLER - HYDRAULIC COUPLER
FIGURE 9-2. CYLINDER GROUP INSTALLATION (74HP)
FIGURE 9-3. CYLINDER GROUP INSTALLATION (110HP)
FIGURE 9-4. CYLINDER - CARRIAGE SIDE TILT
FIGURE 9-5. CYLINDER - CARRIAGE SWING
FIGURE 9-6. CYLINDER - COMPENSATION (74HP)
FIGURE 9-7. CYLINDER - COMPENSATION (110HP)
FIGURE 9-8. CYLINDER & VALVE SUB-ASSEMBLY - EXTEND/RETRACT (74HP)
FIGURE 9-9. CYLINDER & VALVE SUB-ASSEMBLY - EXTEND/RETRACT (110HP)
FIGURE 9-10. CYLINDER ASSEMBLY - EXTEND/RETRACT
FIGURE 9-11. CYLINDER - FORK POSITIONING
FIGURE 9-12. CYLINDER - FORK POSITIONING
FIGURE 9-13. CYLINDER INSTALLATION - FRAME LEVEL
FIGURE 9-14. CYLINDER - FRAME LEVEL
FIGURE 9-15. CYLINDER ASSEMBLY - GRAPPLE BUCKET
FIGURE 9-16. CYLINDER ASSEMBLY - LIFT
FIGURE 9-17. CYLINDER SUB-ASSEMBLY - QUICK COUPLER
FIGURE 9-18. CYLINDER - QUICK COUPLER
FIGURE 9-19. CYLINDER & VALVE INSTALLATION - STABILIZER (REAR AXLE) (Prior to SN 0160126697)
FIGURE 9-20. CYLINDER & VALVE INSTALLATION - STABILIZER (REAR AXLE) (SN 0160126698 to Present)
FIGURE 9-21. CYLINDER - STABILIZER (REAR AXLE)
FIGURE 9-22. CYLINDER & FITTINGS SUB-ASSEMBLY - TILT
FIGURE 9-23. CYLINDER ASSEMBLY - TILT
FIGURE 9-24. PUMP - GEAR
FIGURE 9-25. PUMP - PISTON
FIGURE 9-26. TANK - HYDRAULIC
FIGURE 9-27. TANK - HYDRAULIC FILTER ASSEMBLY
FIGURE 9-28. VALVE - AIR SHUT OFF
FIGURE 9-29. VALVE & FITTINGS - CARRIAGE (DUAL FORK)
FIGURE 9-30. VALVE - CARRIAGE DUAL FORK FLOW DIVIDER
FIGURE 9-31. VALVE ASSEMBLY - FRAME LEVEL
FIGURE 9-32. VALVE ASSEMBLY - MAIN CONTROL (74HP)
FIGURE 9-33. VALVE ASSEMBLY - MAIN CONTROL (110HP)
FIGURE 9-34. VALVE - PARKING BRAKE
FIGURE 9-35. VALVE ASSEMBLY - PRIORITY
FIGURE 9-36. VALVE ASSEMBLY - PRIORITY
FIGURE 9-37. VALVE - QUICK COUPLER
FIGURE 9-38. VALVE ASSEMBLY - SAHR BRAKE
FIGURE 9-39. VALVE ASSEMBLY - STABILIZER (REAR AXLE) (Prior to SN 0160126697)
FIGURE 9-40. VALVE ASSEMBLY - STABILIZER (REAR AXLE) (SN 0160126698 to Present)
FIGURE 9-41. VALVE ASSEMBLY - STEERING ORBITAL
FIGURE 9-42. VALVE ASSEMBLY - STEERING SELECT
SECTION 10 - ELECTRICALFIGURE 10-1. MAIN ELECTRICAL INSTALLATION - 74HP (ULS)
FIGURE 10-2. MAIN ELECTRICAL INSTALLATION - 110HP (ULS)
FIGURE 10-3. MAIN ELECTRICAL INSTALLATION - 110HP (LS)
FIGURE 10-4. A/C OPTION HARNESS
FIGURE 10-5. AIR SHUT OFF VALVE HARNESS - CAB
FIGURE 10-6. AIR SHUT OFF VALVE HARNESS - ENGINE
FIGURE 10-7. ALARM INSTALLATION - BACK UP (97DB)
FIGURE 10-8. ALARM INSTALLATION - BACK UP (120DB)
FIGURE 10-9. ALARM INSTALLATION - BACK UP (WHITE NOISE)
FIGURE 10-10. ARCTIC COLD WEATHER PACKAGE INSTALLATION (74HP) (ULS)
FIGURE 10-11. ARCTIC COLD WEATHER PACKAGE INSTALLATION (110HP) (ULS)
FIGURE 10-12. ARCTIC COLD WEATHER PACKAGE INSTALLATION (110HP) (LS)
FIGURE 10-13. BATTERY INSTALLATION
FIGURE 10-14. BATTERY INSTALLATION
FIGURE 10-15. BATTERY INSTALLATION - ARCTIC PACKAGE
FIGURE 10-16. BOOM ANGLE SENSOR INSTALLATION (LSI)
FIGURE 10-17. BOOM ELECTRIC HARNESS INSTALLATION
FIGURE 10-18. BOOM ELECTRIC HARNESS
FIGURE 10-19. BOOM AUXILIARY ELECTRIC INSTALLATION
FIGURE 10-20. BOOM AUXILIARY ELECTRIC HARNESS INSTALLATION
FIGURE 10-21. CAB DASH ELECTRICAL (ULS)
FIGURE 10-22. CAB DASH ELECTRICAL (LS)
FIGURE 10-23. CAB ELECTRICAL INSTALLATION
FIGURE 10-24. CAB ELECTRICAL BOARD ASSEMBLY
FIGURE 10-25. CAB ELECTRICAL COMMUNICATION CABLE
FIGURE 10-26. CAB HARNESS
FIGURE 10-27. CAB ELECTRICAL INSTALLATION - ENCLOSED
FIGURE 10-28. CAB ELECTRICAL INSTALLATION - OPEN
FIGURE 10-29. CAB OPTION 1 ELECTRICAL BOARD
FIGURE 10-30. CAB OPTION 2 ELECTRICAL BOARD
FIGURE 10-31. CAB OPTION HARNESS
FIGURE 10-32. CAB OPTION 1 HARNESS
FIGURE 10-33. CAB OPTION 2 HARNESS
FIGURE 10-34. CAB - KEY HARNESS
FIGURE 10-35. CAB MULTIFUNCTION DISPLAY INSTALLATION
FIGURE 10-36. CAB SEAT BELT ALARM HARNESS
FIGURE 10-37. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 10-38. CLEARSKY HARNESS - CS550 BEACON
FIGURE 10-39. DEF PURGE LIGHT HARNESS (110HP) (ULS)
FIGURE 10-40. ENGINE - WIRING INSTALLATION (74HP) (ULS)
FIGURE 10-41. ENGINE - WIRING INSTALLATION (110HP) (ULS)
FIGURE 10-42. ENGINE - WIRING INSTALLATION (110HP) (LS)
FIGURE 10-43. ENGINE HARNESS (74HP) (ULS)
FIGURE 10-44. ENGINE HARNESS (110HP) (ULS)
FIGURE 10-45. ENGINE HARNESS (110HP) (LS)
FIGURE 10-46. ENGINE BAY - ELECTRICAL INSTALLATION (74HP) (ULS)
FIGURE 10-47. ENGINE BAY - ELECTRICAL INSTALLATION (110HP) (ULS)
FIGURE 10-48. ENGINE BAY - ELECTRICAL INSTALLATION (110HP) (LS)
FIGURE 10-49. ENGINE BAY - WIRING INSTALLATION (74HP) (ULS)
FIGURE 10-50. ENGINE BAY - WIRING INSTALLATION (110HP) (ULS)
FIGURE 10-51. ENGINE BAY - WIRING INSTALLATION (110HP) (LS)
FIGURE 10-52. ENGINE/CHASSIS HARNESS (110HP) (ULS)
FIGURE 10-53. ENGINE - ECU INSTALLATION (ULS)
FIGURE 10-54. ENGINE - ECU INSTALLATION (LS)
FIGURE 10-55. ENGINE TBAP HARNESS
FIGURE 10-56. FRAME - ELECTRICAL INSTALLATION
FIGURE 10-57. FRAME - POWER DISTRIBUTION BOX
FIGURE 10-58. FRAME - WIRING INSTALLATION (74HP) (ULS)
FIGURE 10-59. FRAME - WIRING INSTALLATION (110HP) (ULS)
FIGURE 10-60. FRAME - WIRING INSTALLATION (110HP) (LS)
FIGURE 10-61. FRAME HARNESS - FRONT
FIGURE 10-62. FRAME HARNESS - REAR (74HP)
FIGURE 10-63. FRAME HARNESS - REAR (110HP)
FIGURE 10-64. HEATER HARNESS - CUMMINS BREATHER (74HP) (ULS)
FIGURE 10-65. HEATER HARNESS - CUMMINS BREATHER (110HP) (ULS)
FIGURE 10-66. HEATER HARNESS - FUEL FILTER
FIGURE 10-67. HEATER HARNESS - HYDRAULIC TANK
FIGURE 10-68. HVAC ACTUATOR HARNESS
FIGURE 10-69. JOYSTICK HARNESS
FIGURE 10-70. LIGHTS - BOOM WORK LIGHTS SWITCH/HARNESS INSTALLATION (LED)
FIGURE 10-71. LIGHTS - BOOM WORK LIGHTS INSTALLATION (LED)
FIGURE 10-72. LIGHTS - BOOM WORK LIGHTS HARNESS
FIGURE 10-73. LIGHTS - CAB WORK LIGHTS INSTALLATION (NO A/C) (LED)
FIGURE 10-74. LIGHTS - CAB WORK LIGHTS INSTALLATION (A/C) (LED)
FIGURE 10-75. LIGHTS - ROADLIGHTS INSTALLATION
FIGURE 10-76. LIGHTS - ROADLIGHTS HEADLIGHT HARNESS
FIGURE 10-77. LIGHTS - ROADLIGHTS TAILLIGHTS HARNESS
FIGURE 10-78. LIGHTS - SWITCH INSTALLATION
FIGURE 10-79. LSI HARNESS - BOOM RETRACT
FIGURE 10-80. PLATFORM HARNESS
FIGURE 10-81. REVERSE CAMERA INSTALLATION
FIGURE 10-82. MULTI VIEW CAMERA INSTALLATION (SN 0160122578 to Present)
FIGURE 10-83. REVERSE SENSOR INSTALLATION
FIGURE 10-84. REVERSE SENSOR HARNESS
FIGURE 10-85. RIDE CONTROL VALVE HARNESS INSTALLATION
FIGURE 10-86. RIDE CONTROL VALVE HARNESS
FIGURE 10-87. ROOF PIGTAIL HARNESS
FIGURE 10-88. TELEMATICS READY INSTALLATION
FIGURE 10-89. TELEMATICS READY HARNESS
FIGURE 10-90. USB CHARGER INSTALLATION
SECTION 11 - DECALSFIGURE 11-1. DECAL INSTALLATION (ANSI) (74 HP)
FIGURE 11-2. DECAL INSTALLATION (ANSI) (110 HP)
FIGURE 11-3. DECAL INSTALLATION (CSA ENGLISH/FRENCH) (74 HP)
FIGURE 11-4. DECAL INSTALLATION (CSA ENGLISH/FRENCH) (110 HP)
FIGURE 11-5. DECAL INSTALLATION (ISO) (74 HP)
FIGURE 11-6. DECAL INSTALLATION (ISO) (110 HP)
FIGURE 11-7. DECAL INSTALLATION (HRC)(110HP)
FIGURE 11-8. DECAL INSTALLATION (HRC)(110HP)
FIGURE 11-9. DECAL INSTALLATION (HRC)(74HP)
FIGURE 11-10. DECAL INSTALLATION (HRC)(74HP)
FIGURE 11-11. DECAL INSTALLATION (LATIN AMERICAN ENGLISH/SPANISH) (74HP)
FIGURE 11-12. DECAL INSTALLATION (LATIN AMERICAN ENGLISH/SPANISH) (110HP)
FIGURE 11-13. BRAND AND MODEL DECAL INSTALLATION
FIGURE 11-14. CAPACITY CHART BOOKLET (ANSI)
FIGURE 11-15. CAPACITY CHART BOOKLET (ISO)
FIGURE 11-16. CAPACITY CHART HOLDER INSTALLATION
FIGURE 11-17. DECAL INSTALLATION - CLEARSKY CS550 BEACON
FIGURE 11-18. REVERSE SENSING SYSTEM DECAL (ANSI)
FIGURE 11-19. REVERSE SENSING SYSTEM DECAL (CSA)
FIGURE 11-20. REVERSE SENSOR SYSTEM DECAL (ENGLISH/SPANISH)
FIGURE 11-21. REVERSE SENSING SYSTEM DECAL (ISO)
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
