JLG Telehandler 742 943 1043 1055 1255 Service Manual 3122552100 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 742, 943, 1043, 1055, 1255 Telehandler
Part Number: 3122552100
Publication Date: 2025
Number of Pages: 688 Pages
Cover Page
Effectivity Page
Read This First
Brand: JLG
Cover Page
Effectivity Page
Read This First
Modifications
Machine Configuration
SafetyGeneral (concept)
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Maximum Travel Speed
2.1.2 Boom Performance
2.1.3 Cylinder Drift
2.1.4 Steering Angle Specifications
2.1.5 Battery
2.1.6 Engine Performance Specifications
2.1.7 Tires
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedules
ClearSky Smart Fleet
2.5.1 General
2.5.2 ClearSky Smart Fleet™ – Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Assembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Maintenance Schedule
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires & Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Park Brake Bleeding (Front Axle Only)
3.6.2 Service Brake Bleeding
3.6.3 Brake System Check
3.6.4 Service Brake Test
3.6.5 Brake Inspection
3.6.6 Steering Angle Adjustment
DEF Tank Inspection
Boom Inspection and Maintenance
3.8.1 Boom Wear Pads
Hydraulic Filter Replacement
3.9.1 Hydraulic Filter Removal and Installation
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Thread Locking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 Alternator
4.2.3 Fuel Level Sender
Calibration Procedures
4.3.1 Analyzer
4.3.2 Boom Angle Sensor Calibration
4.3.3 LSI System Calibration
Special Procedures
4.4.1 Emergency Boom Lowering Procedure
4.4.2 Precision Gravity Lower System (PGLS)
4.4.3 Towing a disabled machine
4.4.4 Hydraulic Oil Tank
4.4.5 Diesel Exhaust Fluid (DEF) System Cleaning (if equipped for ULS)
4.4.6 Accumulators
4.4.7 Hydraulic Pressure Settings and Adjustments
4.4.8 Cylinder Pressure Checking
4.4.9 Cylinder Drift Test
4.4.10 Hydraulic Circuits
4.4.11 Hydraulic Pressures
4.4.12 Pressure Specification
4.4.13 Boom Chain Adjustment - 742, 943, 1043
4.4.14 Boom Chain Adjustment - 1055, 1255
4.4.15 Boom Extend and Retract Chains
4.4.16 Rear Axle Stabilization (RAS) System Test
System SoftwareLoad Stability Indicator (LSI)
5.1.1 Load Stability Indicator
5.1.2 LSI Sensor
JLG Analyzer
5.2.1 Machine Data Access
5.2.2 JLG Hand Held Analyzer
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer
5.2.4 PC Analyzer/Loglifter
5.2.5 Analyzer Software (Version P26.0)
Analyzer Software Accessibility
5.3.1 Access Level
5.3.2 Diagnostics
5.3.3 Machine Set-Up (Software Version P26.0)
5.3.4 Personalities (Software Version P26.0)
5.3.5 Operator Tools (Software Version P26.0)
5.3.6 Calibrations (Software version P26.0)
Premium Display (If Equipped)
5.4.1 Home Screen and Touch Screen Soft Buttons
5.4.2 Main Menu
5.4.3 Reprogramming Menu
Reprogramming the Premium Display
5.5.1 Software Installation
5.5.2 Load Charts Programming
ClearSky (CS550) Configuration and Troubleshooting
5.6.1 ClearSky Smart FleetTM CS550 Configuration
5.6.2 Troubleshooting
Fault CodesIntroduction
6.1.1 Fault Code Display
Engine Diagnostics
Machine Fault Codes
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
Torque Values
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
8.3.1 General Overview
Harness Layouts
Board Layouts
8.5.1 Cab Harness Fuses and Relays
8.5.2 Power Distribution Board
Telematics Gateway
8.6.1 Telematics-Ready (TCU) Plug
8.6.2 Component Locations
8.6.3 Telematics Gateway Harness Breakdown
Removal and InstallationWheels
9.1.1 Wheel and Tire Assembly
Outrigger Assembly
Drive Assembly
9.3.1 Axle, Drive Shaft and Wheel Component Terminology
9.3.2 Axle Assembly and Drive Shaft Troubleshooting
9.3.3 Axle Serial Number
9.3.4 Axle Specifications and Maintenance Information
9.3.5 Axle Removal/Installation
9.3.6 Drive Shafts
Boom
9.4.1 Boom Components Terminology
9.4.2 Troubleshooting
9.4.3 Boom System
9.4.4 Boom Removal/Installation
9.4.5 Manual Coupler
9.4.6 Hydraulic Coupler
9.4.7 Forks
9.4.8 Boom Angle Sensor
9.4.9 Boom Wear Pad Installation, Lubrication
9.4.10 General Accumulator Information (Boom Ride Control)
9.4.11 Boom Prop (If Equipped) (742, 943, 1043)
9.4.12 Boom Prop (If Equipped) (1055, 1255)
9.5.1 Cab Components
9.5.2 Serial Number Plate
9.5.3 Cab Removal/Installation
9.5.4 Steering Wheel
9.5.5 Electronic Throttle Pedal
9.5.6 Brake System
9.5.7 Joystick Assembly
9.5.8 Ignition Switch
9.5.9 Dash Switches
9.5.10 Front Wiper Assembly
9.5.11 Rear Wiper Assembly
9.5.12 Roof Wiper Assembly
9.5.13 Washer Fluid Tank
9.5.14 Heater and A/C System (if equipped)
9.6.1 Component Terminology
9.6.2 Diesel Fuel
9.6.3 Engine Serial Number
9.6.4 Engine Replacement
9.6.5 Engine Electrical System
9.6.6 Surge Tank Cap
9.6.7 Surge Tank
9.6.8 Thermostat
9.6.9 Engine Coolant Temperature Sensor
9.6.10 Radiator Assembly
9.6.11 Air Filter Assembly
9.6.12 Alternator
9.6.13 Starter
9.6.14 Fuel Tank
9.6.15 Pre-Fuel Filter and Fuel Pump
9.6.16 Engine Exhaust System
9.6.17 Air Conditioner (AC) Compressor (If equipped)
9.6.18 Diesel Exhaust Fluid (DEF) Tank (if equipped for ULS)
9.7.1 Component Terminology
9.7.2 Transmission Serial Number
9.7.3 Specifications and Maintenance Information
9.7.4 Transmission Replacement
9.7.5 Transmission Fluid/Filter Replacement
9.7.6 Transmission Fluid Level Check
9.7.7 Transmission Cooler Thermal Bypass Valve
9.7.8 Transmission Temperature Sensor
9.7.9 Transmission Solenoid Valves
9.7.10 Torque Converter Diaphragm
9.7.11 Reverse Alarm
Hydraulic Cylinders
9.8.1 General Cylinder Instructions
9.8.2 Cylinder Pressure Checking
9.8.3 Steering Cylinders
Hydraulic Valves
9.9.1 Steer Select Valve
9.9.2 Main Control Valve
9.9.3 Frame Sway Control Valve/Outrigger Valve (1043, 1055, 1255)
9.9.4 Sway Valve (only 742, 943 without outriggers)
9.9.5 Park Brake/Sahr Valve
9.9.6 RAS Valve
Implement Pump
Electrical Components
9.11.1 Battery
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.12.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Axle Assembly
10.1.2 Transmission Assembly
Boom
10.2.1 Boom Assembly Maintenance - 742, 943, 1043
10.2.2 Third Boom Section Removal/ Installation Only - 742, 943, 1043
10.2.3 Boom Assembly Maintenance - 1055, 1255
10.2.4 Fourth Boom Section Removal/Installation Only - 1055, 1255
10.2.5 Hose Carrier Assembly - 1055, 1255
Engine Components
10.3.1 Engine Disassembly, Inspection and Service
10.3.2 Fuel Tank
DEF System
10.4.1 DEF Tank
Hydraulic Cylinders
10.5.1 General Cylinder Disassembly
10.5.2 General Cylinder Assembly Instructions
10.5.3 Cylinder Cleaning Instructions
10.5.4 Cylinder Inspection
Hydraulic Valves
10.6.1 Main Control Valve
10.6.2 Steer Select Valve and Park Brake Valve
10.6.3 Sway Valve (742, 943)
10.6.4 Sway/Outrigger Valve (1043, 1055, 1255)
10.6.5 RAS Valve
10.6.6 Pressure Reducing Valve
10.7.1 Hydraulic Oil Reservoir
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
12.1.1 742
12.1.2 943, 1043
12.1.3 1055, 1255
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
