JLG Telehandler 6036 Parts Catalog 31211954
Brand: JLG
Type of Machine: Telehandler
Model: JLG 6036 Telehandler
Part Number: 31211954
Publication Date: 2025
Number of Pages: 702 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME COMPONENTS INSTALLATION - 74HP (ULS)
FIGURE 1-2. FRAME COMPONENTS INSTALLATION - 85HP (LS)
FIGURE 1-3. FRAME COVERS INSTALLATION - 74HP (AIR SHUT OFF VALVE)
FIGURE 1-4. FRAME COVERS INSTALLATION - 74HP (ULS)
FIGURE 1-5. FRAME COVERS INSTALLATION - 85HP (LS)
FIGURE 1-6. HYDRAULIC/FUEL/DEF TANK ASSEMBLY (LS)
FIGURE 1-7. HYDRAULIC/FUEL TANK ASSEMBLY (ULS)
SECTION 2 - BOOMFIGURE 2-1. BOOM INSTALLATION
FIGURE 2-2. BOOM PROP INSTALLATION
FIGURE 2-3. BOOM PROP BRACKET INSTALLATION
FIGURE 2-4. EXTEND CHAIN ASSEMBLY
FIGURE 2-5. HOSE PULLEY ASSEMBLY
FIGURE 2-6. LOCK PIN ASSEMBLY
FIGURE 2-7. QUICK COUPLER ASSEMBLY
FIGURE 2-8. RETRACT CHAIN ASSEMBLY (6036)
SECTION 3 - ATTACHMENTSFIGURE 3-1. BASKET, PERSONNEL (1.2MX2.4M) (DOMESTIC)
FIGURE 3-2. BASKET, PERSONNEL (1.2MX2.4M) (ISO)
FIGURE 3-3. BASKET, PERSONNEL (1.2MX2.4M) (FRENCH LANGUAGE)
FIGURE 3-4. BASKET, PERSONNEL ASSEMBLY
FIGURE 3-5. BOOM - ADJUSTABLE
FIGURE 3-6. BOOM - ADJUSTABLE (FORK MOUNTED)
FIGURE 3-7. BOOM - 3 FOOT WITH WINCH
FIGURE 3-8. BOOM - 12 FOOT WITH WINCH
FIGURE 3-9. BOOM - 12FT WITHOUT WINCH
FIGURE 3-10. BOOM - 15FT WITHOUT WINCH
FIGURE 3-11. BUCKET (60 INCH)
FIGURE 3-12. BUCKET (72 INCH)
FIGURE 3-13. BUCKET (96 INCH)
FIGURE 3-14. BUCKET - GRAPPLE (96 INCH)
FIGURE 3-15. BUCKET (102 INCH)
FIGURE 3-16. CARRIAGE ASSEMBLY - 48IN SIDE SHIFT
FIGURE 3-17. CARRIAGE ASSEMBLY - 50IN
FIGURE 3-18. CARRIAGE ASSEMBLY - 50IN DUAL FORK POSITIONING
FIGURE 3-19. CARRIAGE ASSEMBLY - 50IN/12000# CAPICITY SIDE TILT
FIGURE 3-20. CARRIAGE ASSEMBLY - 60IN
FIGURE 3-21. CARRIAGE ASSEMBLY - 60IN/12000# CAPACITY SIDE TILT
FIGURE 3-22. CARRIAGE ASSEMBLY - 72IN
FIGURE 3-23. CARRIAGE ASSEMBLY - 72IN/12000# CAPACITY SIDE TILT
FIGURE 3-24. CARRIAGE ASSEMBLY - 72IN SWING
FIGURE 3-25. FORK 1.75X7X60 - DUAL TAPERED 5400#
FIGURE 3-26. FORK 2X2X48 - CUBING/BLOCKING 1940#
FIGURE 3-27. FORK 2X6X72 - DUAL TAPERED 6613#
FIGURE 3-28. FORK 2.36X4X48 PALLET 5000#
FIGURE 3-29. FORK 2.36X4X48 PALLET 5475#
FIGURE 3-30. FORK 2.36X4X60 PALLET 5000#
FIGURE 3-31. FORK 2.36X5X48 PALLET 6850#
FIGURE 3-32. FORK 2.36X5X60 PALLET 6850#
FIGURE 3-33. FORK 2.36X5X72 PALLET 6850#
FIGURE 3-34. FORK 2.36X6X60 PALLET 8150#
FIGURE 3-35. FORK EXTENSION (90 INCH)
FIGURE 3-36. FORK PIN LOCK INSTALLATION
FIGURE 3-37. HOOK - COUPLER MOUNTED
FIGURE 3-38. HOOK - FORK MOUNTED
FIGURE 3-39. MAST (8 FOOT)
FIGURE 3-40. SHEET MATERIAL HANDLER INSTALLATION
FIGURE 3-41. SHEET MATERIAL HANDLE FORK SUPPORT ASSEMBLY (LH)
FIGURE 3-42. SHEET MATERIAL HANDLE FORK SUPPORT ASSEMBLY (RH)
FIGURE 3-43. SWEEPER ASSEMBLY
FIGURE 3-44. SWEEPER - BODY ASSEMBLY
FIGURE 3-45. SWEEPER - CORE ASSEMBLY
FIGURE 3-46. SWEEPER - HOPPER ASSEMBLY
FIGURE 3-47. SWEEPER - HYDRAULIC SINGLE MOTOR ASSEMBLY
FIGURE 3-48. SWEEPER - IDLER ASSEMBLY
FIGURE 3-49. SWEEPER - MOTOR ASSEMBLY
FIGURE 3-50. TRASH HOPPER - FORK MOUNTED
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE COMPONENT INSTALLATION - 74HP (ULS)
FIGURE 4-2. ENGINE COMPONENT INSTALLATION - 85HP (ULS)
FIGURE 4-3. ENGINE INSTALLATION - 74HP (ULS)
FIGURE 4-4. ENGINE INSTALLATION - 85HP (LS)
FIGURE 4-5. ENGINE - 74HP (ULS)
FIGURE 4-6. ENGINE - 85HP (LS)
FIGURE 4-7. A/C COMPONENTS INSTALLATION, 74HP
FIGURE 4-8. A/C COMPONENTS INSTALLATION, 85HP
FIGURE 4-9. AIR CLEANER INSTALLATION (LS)
FIGURE 4-10. AIR CLEANER INSTALLATION (ULS)
FIGURE 4-11. AIR CLEANER ASSEMBLY (LS)
FIGURE 4-12. AIR CLEANER ASSEMBLY (ULS)
FIGURE 4-13. AIR INTAKE SHUT OFF VALVE INSTALLATION
FIGURE 4-14. COOLING INSTALLATION, 74HP
FIGURE 4-15. COOLING INSTALLATION, 85HP
FIGURE 4-16. DEAERATION TANK ASSEMBLY
FIGURE 4-17. EXHAUST INSTALLATION - 74HP (ULS)
FIGURE 4-18. EXHAUST INSTALLATION - 85HP (LS)
FIGURE 4-19. EXHAUST INSTALLATION - 85HP (ULS)
FIGURE 4-20. MUFFLER ASSEMBLY - AFTER TREATMENT
FIGURE 4-21. MUFFLER ASSEMBLY - DECOMPOSITION REACTOR
FIGURE 4-22. FAN INSTALLATION - 74HP
FIGURE 4-23. FAN INSTALLATION - 85HP
FIGURE 4-24. FUEL PLUMBING INSTALLATION (LS)
FIGURE 4-25. FUEL PLUMBING INSTALLATION (ULS)
FIGURE 4-26. HEATER BREATHER
FIGURE 4-27. ISOLATION COUPLER INSTALLATION
FIGURE 4-28. PLUMBING COOLING INSTALLATION (LS)
FIGURE 4-29. PLUMBING COOLING INSTALLATION (ULS)
FIGURE 4-30. RADIATOR ASSEMBLY, 74HP
FIGURE 4-31. RADIATOR ASSEMBLY, 85HP
SECTION 5 - DRIVE TRAINFIGURE 5-1. TRANSMISSION INSTALLATION
FIGURE 5-2. TRANSMISSION ASSEMBLY
FIGURE 5-3. TRANSMISSION, ENGINE CONNECTION AND CONVERTER
FIGURE 5-4. TRANSMISSION, CONTROL UNIT
FIGURE 5-5. TRANSMISSION, COUPLING GROUP 1
FIGURE 5-6. TRANSMISSION, COUPLING GROUP 2
FIGURE 5-7. TRANSMISSION, COUPLING GROUP 3
FIGURE 5-8. TRANSMISSION, COUPLING GROUP 4
FIGURE 5-9. TRANSMISSION, GEARBOX HOUSING
FIGURE 5-10. TRANSMISSION, INPUT SHAFTS
FIGURE 5-11. TRANSMISSION, OIL PUMP AND FILTER
FIGURE 5-12. TRANSMISSION, OUTPUT
FIGURE 5-13. TRANSMISSION, REVERSING GEAR GROUP 1
FIGURE 5-14. TRANSMISSION, REVERSING GEAR GROUP 2
FIGURE 5-15. TRANSMISSION, VALVE BLOCK ASSEMBLY
FIGURE 5-16. TRANSMISSION, VALVE HOUSING ASSEMBLY
FIGURE 5-17. DRIVE SHAFT INSTALLATION
FIGURE 5-18. FRONT DRIVE SHAFT ASSEMBLY
FIGURE 5-19. REAR DRIVE SHAFT ASSEMBLY
FIGURE 5-20. DRIVE SHAFT INPUT
FIGURE 5-21. AXLES INSTALLATION (6036)
FIGURE 5-22. FRONT AXLE SUB-ASSEMBLY
FIGURE 5-23. FRONT AXLE ASSEMBLY
FIGURE 5-24. FRONT AXLE, BRAKES
FIGURE 5-25. FRONT AXLE, CENTRAL HOUSING
FIGURE 5-26. FRONT AXLE, DIFFERENTIAL
FIGURE 5-27. FRONT AXLE, HUB REDUCTION
FIGURE 5-28. FRONT AXLE, STEERING
FIGURE 5-29. FRONT AXLE, TRUNNION
FIGURE 5-30. REAR AXLE ASSEMLBLY
FIGURE 5-31. REAR AXLE, BRAKES
FIGURE 5-32. REAR AXLE, CENTRAL HOUSING
FIGURE 5-33. REAR AXLE, DIFFERENTIAL
FIGURE 5-34. REAR AXLE, HUB REDUCTION
FIGURE 5-35. REAR AXLE, STEERING
FIGURE 5-36. REAR AXLE, TRUNNION
FIGURE 5-37. FENDER INSTALLATION
FIGURE 5-38. TIRE SET, 13.00-24 PNEUMATIC
FIGURE 5-39. TIRE SET, 13.00-24 FOAM FILLED
FIGURE 5-40. TIRE SET, 370/75-28 PNEUMATIC
FIGURE 5-41. TIRE SET, 370/75-28 FOAM FILLED
FIGURE 5-42. TIRE SET, 315/95-28/8.5 SOLID
FIGURE 5-43. TIRE SET, 370/75-28 PNEUMATIC NON-MARKING
FIGURE 5-44. TIRE SET, 370/75-28 FOAM FILLED NON-MARKING
FIGURE 5-45. TIRE SET 18 X 625 PNUEMATIC TURF/SAND
FIGURE 5-46. TIRE SET, 13.00-24 FOAM FILLED (E-3) (SUNSTATE ONLY)
FIGURE 5-47. TIRE SET, 13-24 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-48. TIRE SET, 13-28 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-49. TIRE SET, 13-28 SOLIDBOSS (NON-DIRECTIONAL)
FIGURE 5-50. TIRE SET, 13-24 SOLID
SECTION 6 - CABFIGURE 6-1. CAB INSTALLATION
FIGURE 6-2. CAB INSTALLATION - OPEN CAB (ORANGE SEAT BELT)
FIGURE 6-3. CAB INSTALLATION - OPEN CAB (ORANGE SEAT BELT)
FIGURE 6-4. OPEN CAB SEAT BELT ENG INSTALLATION
FIGURE 6-5. OPEN CAB SEAT BELT ENG INSTALLATION
FIGURE 6-6. CAB ASSEMBLY - OPEN CAB
FIGURE 6-7. OPEN CAB INSTALLATION WITH RED LED LIGHT ON DASHBOARD
FIGURE 6-8. CAB INSTALLATION - ENCLOSED CAB WITH HEATER (ORANGE SEAT BELT)
FIGURE 6-9. CAB INSTALLATION - ENCLOSED CAB WITH HEATER (ORANGE SEAT BELT)
FIGURE 6-10. CAB INSTALLATION - CLOSED CAB WITH HEATER
FIGURE 6-11. CAB INSTALLATION - CLOSED CAB WITH HEATER
FIGURE 6-12. CAB ASSEMBLY - ENCLOSED CAB WITH HEATER
FIGURE 6-13. CAB ASSEMBLY - ENCLOSED WITH HEATER
FIGURE 6-14. CAB INSTALLATION - ENCLOSED CAB WITH HEATER/AC (ORANGE SEAT BELT)
FIGURE 6-15. CAB INSTALLATION - ENCLOSED CAB WITH HEATER/AC (ORANGE SEAT BELT)
FIGURE 6-16. CLOSED CAB WITH HVAC INSTALLATION
FIGURE 6-17. CLOSED CAB WITH HVAC INSTALLATION
FIGURE 6-18. CAB ASSEMBLY - ENCLOSED CAB WITH HEATER/AC
FIGURE 6-19. CAB ASSEMBLY - ENCLOSED WITH HEATER & AC
FIGURE 6-20. CAB DOOR
FIGURE 6-21. CAB ENCLOSURE INSTALLATION
FIGURE 6-22. CAB ENCLOSURE INSTALLATION - WITH HVAC
FIGURE 6-23. CAB HEATER LINES INSTALLATION
FIGURE 6-24. CAB HEATER/AC LINES INSTALLATION
FIGURE 6-25. CAB SEAT (ORANGE SEAT BELT)
FIGURE 6-26. FIRE EXTINGUISHER INSTALLATION
FIGURE 6-27. FLOOR HEATER
FIGURE 6-28. FRONT WIPER ASSEMBLY
FIGURE 6-29. HEATER VALVE
FIGURE 6-30. INSTALLTION, REAR WINDOW EXIT (ENG/SP)
FIGURE 6-31. REAR DROPOUT WINDOW INSTALLATION (ANSI)
FIGURE 6-32. REAR DROPOUT WINDOW INSTALLATION (ENGLISH/FRENCH)
FIGURE 6-33. REAR DROPOUT WINDOW INSTALLATION (ISO)
FIGURE 6-34. RH SLIDER WINDOW
FIGURE 6-35. ROOF BOX HVAC
FIGURE 6-36. ROOF HEATER BOX
FIGURE 6-37. SEAT BELT INSTALLATION (3IN WIDTH)
FIGURE 6-38. SKYLIGHT WIPER ASSEMBLY
SECTION 7 - CONTROLSFIGURE 7-1. BRAKE ASSEMBLY
FIGURE 7-2. PILOT JOYSTICK CONTROL
FIGURE 7-3. SECONDARY CONTROLS INSTALLATION
FIGURE 7-4. SECONDARY SHORT CONTROL
FIGURE 7-5. SECONDARY TALL CONTROL
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. HYDRAULIC INSTALLATION
FIGURE 8-2. AXLE (FRONT) HYDRAULICS INSTALLATION
FIGURE 8-3. AXLE (FRONT) HYDRAULICS ASSEMBLY
FIGURE 8-4. AXLE (REAR) HYDRAULICS INSTALLATION
FIGURE 8-5. AXLE (REAR) HYDRAULICS ASSEMBLY
FIGURE 8-6. BOOM AUXILIARY HYDRAULICS
FIGURE 8-7. BOOM EXTEND/RETRACT HYDRAULICS (MAIN VALVE TO BOOM)
FIGURE 8-8. BRAKE & FITTINGS ASSEMBLY
FIGURE 8-9. BRAKE HYDRAULICS
FIGURE 8-10. CAB HYDRAULICS INSTALLATION
FIGURE 8-11. FRAME AUXILIARY HYDRAULICS
FIGURE 8-12. FRAME TILT HYDRAULICS
FIGURE 8-13. FORK HYDRAULICS (MAIN VALVE TO BOOM)
FIGURE 8-14. HYDRAULIC OIL COOLER HYDRAULICS
FIGURE 8-15. HYDRAULIC PUMP INSTALLATION
FIGURE 8-16. LIFT CYLINDER HYDRAULICS
FIGURE 8-17. MAIN CONTROL VALVE INSTALLATION
FIGURE 8-18. MAIN CONTROL VALVE & FITTINGS ASSEMBLY
FIGURE 8-19. PILOT CONTROL VALVE AND FITTINGS ASSEMBLY
FIGURE 8-20. PILOT CONTROL VALVE HYDRAULICS
FIGURE 8-21. PISTON PUMP AND FITTINGS ASSEMBLY
FIGURE 8-22. REAR BULKHEAD TO COMPENSATION CYLINDERS HYDRAULICS
FIGURE 8-23. SECONDARY VALVE & FITTINGS ASSEMBLY
FIGURE 8-24. STEER VALVE & FITTINGS ASSEMBLY
FIGURE 8-25. STEER/SECONDARY VALVES HYDRAULICS
FIGURE 8-26. STEERING HYDRAULICS
FIGURE 8-27. STEERING VALVE AND FITTINGS ASSEMBLY
FIGURE 8-28. TRANSMISSION COOLER HYDRAULICS
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. CYLINDER - CARRIAGE SIDE SHIFT
FIGURE 9-2. CYLINDER - CARRIAGE SIDE TILT
FIGURE 9-3. CYLINDER - CARRIAGE SWING
FIGURE 9-4. CYLINDER - COMPENSATION
FIGURE 9-5. CYLINDER - EXTEND/RETRACT
FIGURE 9-6. CYLINDER - FORK POSITIONING
FIGURE 9-7. CYLINDER - FORK TILT
FIGURE 9-8. CYLINDER - FRAME LEVEL
FIGURE 9-9. CYLINDER - GRAPPLE BUCKET
FIGURE 9-10. CYLINDER - LIFT
FIGURE 9-11. FLOW DIVIDER VALVE
FIGURE 9-12. PUMP - PISTON
FIGURE 9-13. VALVE - AIR SHUT OFF
FIGURE 9-14. VALVE - BRAKE
FIGURE 9-15. VALVE - CARRIAGE
FIGURE 9-16. VALVE - MAIN CONTROL
FIGURE 9-17. VALVE - SECONDARY CONTROL
FIGURE 9-18. VALVE - STEERING SELECT
SECTION 10 - ELECTRICALFIGURE 10-1. ELECTRICAL INSTALLATION - 74HP
FIGURE 10-2. ELECTRICAL INSTALLATION - 85HP
FIGURE 10-3. AIR SHUT OFF VALVE HARNESS - CAB
FIGURE 10-4. AIR SHUT OFF VALVE HARNESS - T4F
FIGURE 10-5. ALARM INSTALLATION - BACK UP
FIGURE 10-6. ALARM INSTALLATION - WHITE NOSE
FIGURE 10-7. BATTERY INSTALLATION
FIGURE 10-8. BATTERY BLANKET INSTALLATION
FIGURE 10-9. BEACON INSTALLATION (OPEN CAB)
FIGURE 10-10. BEACON INSTALLATION (ENCLOSED CAB)
FIGURE 10-11. BEACON OPTION HARNESS
FIGURE 10-12. CAB POWER DISTRIBUTION HARNESS
FIGURE 10-13. CAMERA INSTALLATION - REVERSE MULTI-VIEW
FIGURE 10-14. CAMERA OPTION HARNESS - REVERSE
FIGURE 10-15. CLEARSKY INSTALLATION 3-WIRE (ANSI)
FIGURE 10-16. CLEARSKY INSTALLATION CANBUS (ANSI)
FIGURE 10-17. CLEARSKY INSTALLATION CANBUS (CE)
FIGURE 10-18. CLEARSKY TELEMATICS HARNESS (3-WIRE)
FIGURE 10-19. CLEARSKY TELEMATICS HARNESS (CANBUS)
FIGURE 10-20. CLEARSKY TELEMATICS 3-WIRE INSTALLATION
FIGURE 10-21. CLEARSKY TELEMATICS 3-WIRE HARNESS
FIGURE 10-22. COLD WEATHER PACKAGE INSTALLATION
FIGURE 10-23. COLD WEATHER PACKAGE INSTALLATION
FIGURE 10-24. CONTROLLER
FIGURE 10-25. ENGINE HARNESS - 74HP (ULS)
FIGURE 10-26. ENGINE HARNESS - 85HP (ULS)
FIGURE 10-27. HVAC HARNESS
FIGURE 10-28. LED ROADLIGHT INSTALLATION
FIGURE 10-29. LED WORKLIGHT PACKAGE INSTALLATION
FIGURE 10-30. LIGHTS - ROADLIGHT PACKAGE INSTALLATION
FIGURE 10-31. LIGHTS - ROADLIGHT ASSEMBLY (LH)
FIGURE 10-32. LIGHTS - ROADLIGHT ASSEMBLY (RH)
FIGURE 10-33. LIGHTS - ROADLIGHT BRACKET ASSEMBLY (LH)
FIGURE 10-34. LIGHTS - ROADLIGHT BRACKET ASSEMBLY (RH)
FIGURE 10-35. LIGHTS - ROADLIGHT OPTION HARNESS
FIGURE 10-36. LIGHTS - ROADLIGHT/WORKLIGHT OPTION HARNESS
FIGURE 10-37. LIGHTS - WORKLIGHT OPTION HARNESS (BOOM)
FIGURE 10-38. LIGHTS - WORKLIGHT PACKAGE INSTALLATION
FIGURE 10-39. LIGHTS - WORKLIGHT ASSEMBLY (RH) (LED)
FIGURE 10-40. LIGHTS - WORKLIGHT ASSEMBLY (RH) (LED)
FIGURE 10-41. LIGHTS - WORKLIGHT OPTION HARNESS
FIGURE 10-42. RELAY PANEL INSTALLATION
FIGURE 10-43. RELAY PANEL COVER ASSEMBLY
FIGURE 10-44. REVERSE SENSOR INSTALLATION
FIGURE 10-45. REVERSE SENSOR HARNESS
FIGURE 10-46. SEAT BELT ALARM HARNESS
FIGURE 10-47. TANK (HYDRAULIC) HEATER INSTALLATION
FIGURE 10-48. TBAP HARNESS
FIGURE 10-49. WIPER HARNESS
SECTION 11 - DECALSFIGURE 11-1. DECAL INSTALLATION - 74HP (ANSI)
FIGURE 11-2. DECAL INSTALLATION HRC 74HP (ISO)(HRC)
FIGURE 11-3. DECAL INSTALLATION - 74HP (ENGLISH/FRENCH)
FIGURE 11-4. DECAL INSTALLATION - 74HP (ENGLISH/SPANISH)
FIGURE 11-5. DECAL INSTALLATION (ISO)
FIGURE 11-6. BOOM DECALS INSTALLATION (6036)
FIGURE 11-7. CAPACITY CHART (ANSI)
FIGURE 11-8. CAPACITY CHART - SUPPLEMENTAL (ISO)
FIGURE 11-9. CLEARSKY DECAL INSTALLATION
FIGURE 11-10. REVERSE SENSOR SYSTEM DECAL (ENGLISH)
FIGURE 11-11. REVERSE SENSOR SYSTEM DECAL (ENGLISH/FRENCH)
FIGURE 11-12. REVERSE SENSOR SYSTEM DECAL (ENGLISH/SPANISH)
FIGURE 11-13. REVERSE SENSOR SYSTEM DECAL (ISO)
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
