Hyundai
86
176,834
JLG Telehandler 6036 6042 8042 10042 10054 12054 Service Manual 31211953 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 6036, 6042, 8042, 10042, 10054, 12054 Telehandler
Part Number: 31211953
Publication Date: 2025
Number of Pages: 500 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
General Machine Information & Specifications
Specifications​
2.1.1 Travel Speeds​
2.1.2 Hydraulic Cylinder Performance​
2.1.3 Cylinder Drift​
2.1.4 Electrical System​
2.1.5 Engine Performance Specifications​
2.1.6 Tires​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedules​
Maintenance & Inspection Schedules
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Every 10 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 First 250 Hours​
3.3.5 Every 250 Hours​
3.3.6 First 500 Hours​
3.3.7 Every 500 Hours​
3.3.8 Every 750 Hours​
3.3.9 Every 1000 Hours​
3.3.10 Every 1500 Hours​
3.3.11 Every 2000 Hours or 2 Year​
3.3.12 Every 4000 Hours or 3 Years​
3.3.13 Every 5000 Hours or 4 Years​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Service Brake Bleeding​
DEF Tank Inspection​
Boom Inspection and Maintenance​
3.8.1 Boom Wear Pads​
Hydraulic Filter Replacement​
Specification and Maintenance Information​
3.10.1 Axle​
3.10.2 Axle Maintenance​
3.10.3 Transmission​
Testing, Calibrations, & Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Thread Locking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
Calibration Procedures​
4.3.1 JLG Analyzer​
Special Procedures​
4.4.1 Towing A Disabled Machine​
4.4.2 Hydraulic Reservoir​
4.4.3 Fuel Tank Cleaning and Drying​
4.4.4 Pressure Checks and Adjustments​
4.4.5 Cylinder Checking Procedure​
4.4.6 Cylinder Drift Test​
4.4.7 Hydraulic Circuits​
4.4.8 Pressure Specifications​
4.4.9 Boom Extend and Retract Chains​
4.4.10 Boom Chain Tension Adjustment (6036, 6042, 8042 & 10042)​
4.4.11 Boom Chain Tension Adjustment (10054 & 12054)​
4.4.12 Extend Chains Removal and Replacement (6036, 6042, 8042 & 10042)​
4.4.13 Retract Chain Removal and Replacement (6036, 6042, 8042 & 10042)​
4.4.14 Extend Chains Removal and Replacement (10054 & 12054)​
4.4.15 Retract Chain Removal and Replacement (10054 & 12054)​
STABIL-TRAK™ and Boom Interlock System​
4.5.1 Stabil-Trak™ System Component Terminology​
4.5.2 Boom Extend Interlock System Component Terminology (10054 & 12054 Only)​
4.5.3 Stabil-Trak™ Description​
4.5.4 Stabil-Trak™ Operation​
4.5.5 Boom Extend Interlock System Description​
4.5.6 Boom Extend Interlock System Operation (10054 & 12054 Only)​
4.5.7 Stabil-Trak™ System Test​
4.5.8 Stabil-Trak™ Electrical Circuit Operation And Troubleshooting (6042/8042/10042)​
4.5.9 Stabil-Trak™ And Boom Interlock Electrical Circuit Operation And Troubleshooting (10054 & 12054)​
4.5.10 Boom/Outrigger Interlock System Test​
4.5.11 Boom Extend System Hydraulic Circuit Operation And Troubleshooting​
4.5.12 Stabil-Trak™ Hydraulic Circuit Operation And Troubleshooting​
System Software
Analyzer​
5.1.1 Machine Data Access​
5.1.2 Hand Held Analyzer​
5.1.3 Mobile Analyzer​
5.1.4 Analyzer Software Version P4.0​
Analyzer Software Accessibility​
5.2.1 Access Level​
5.2.2 Diagnostics​
5.2.3 Machine Set-Up​
5.2.4 Personalities​
5.2.5 Calibrations​
Fault Codes
Introduction​
6.1.1 Gauge Fault Code Display​
6.1.2 Offboard Diagnostics​
Engine Fault Codes​
Machine Fault Codes​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Engine Compartment Fuse and Relays​
8.5.2 Cab Harness Fuses and Relays​
Telematics Gateway (if equipped)​
8.6.1 Telematics-Ready (TCU) Plug​
8.6.2 Component Locations​
8.6.3 Telematics Gateway Harness Breakdown​
Wheels​
9.1.1 Removing Wheel and Tire Assembly from Machine​
9.1.2 Installing Wheel and Tire Assembly onto Machine​
Drive Assembly​
9.2.1 Axle Assembly And Drive Shaft Troubleshooting​
9.2.2 Axle Serial Number​
9.2.3 Axle Replacement (6036 & 6042)​
9.2.4 Axle Replacement (8042, 10042, 10054 & 12054)​
9.2.5 Drive Shafts​
9.2.6 Outrigger Replacement (10042, 10054 & 12054 only)​
9.2.7 Transmission Components​
Boom​
9.3.1 Boom System Component Terminology​
9.3.2 Troubleshooting​
9.3.3 Boom System (6036, 6042, 8042 & 10042)​
9.3.4 Boom System (10054 & 12054)​
9.3.5 Manual Coupler​
9.3.6 Boom Prop (If Equipped)​
9.3.7 Isolation Coupler​
9.3.8 Forks​
9.3.9 Boom Angle Sensor​
9.3.10 Boom Extend Interlock Sensor (10054 & 12054 only)​
Cab​
9.4.1 Serial Number Plate​
9.4.2 Cab Removal/Installation​
9.4.3 Steering Wheel​
9.4.4 Service Brake Switch​
9.4.5 Service Brake Pedal​
9.4.6 Throttle Pedal​
9.4.7 Joystick Assembly​
9.4.8 Ignition Key Switch​
9.4.9 Dash Switches​
9.4.10 Outrigger Pressure Switches (10054 & 12054 Only)​
9.4.11 Windshield Wiper Motor​
9.4.12 Skylight Wiper Motor​
9.4.13 Windshield Washer Reservoir​
9.4.14 Heater System (if equipped)​
9.4.15 Heater and A/C System (if equipped)​
9.4.16 Cab Heater And Fan​
9.4.17 Display Monitor​
9.4.18 Steering Column and Steering Valve​
9.4.19 Auxiliary/Frame Level Lever Assemblies​
Engine​
9.5.1 Component Terminology​
9.5.2 Diesel Fuel​
9.5.3 Engine Serial Number​
9.5.4 Engine Replacement​
9.5.5 Engine Electrical System​
9.5.6 Coolant System Pressure Cap​
9.5.7 Coolant Level Sensor​
9.5.8 Thermostat Replacement​
9.5.9 Radiator/Oil Cooler and Replacement​
9.5.10 Fuel/Hydraulic Oil Tank​
9.5.11 Diesel Exhaust Fluid (DEF) Tank - if equipped with 110 hp (82 kW) ULS engine​
9.5.12 Diesel Exhaust Fluid (DEF) Header - if equipped with 110 hp (82 kW) ULS engine​
9.5.13 Diesel Exhaust Fluid (DEF) Pump Filter - if equipped with 110 hp (82 kW) ULS engine​
9.5.14 Diesel Exhaust Fluid (DEF) System Cleaning - if equipped with 110 hp (82 kW) ULS engine​
9.5.15 Exhaust System - if equipped with 110 hp (82 kW) ULS engine​
9.5.16 Exhaust System - if equipped with 74 hp (55 kW) ULS engine​
9.5.17 Exhaust System - if equipped with 110 hp (82 kW) LS engine​
9.5.18 Air Cleaner Assembly​
9.5.19 Starter​
9.5.20 Alternator​
Transmission​
9.6.1 Transmission Components​
9.6.2 Transmission Serial Number​
9.6.3 Transmission Replacement​
9.6.4 Transmission Temperature Sender​
9.6.5 Reverse Alarm​
9.6.6 Transmission Troubleshooting​
Hydraulic Cylinders​
9.7.1 General Cylinder Instructions​
9.7.2 Steering Cylinders​
Hydraulic Valves​
9.8.1 Main Control Valve​
9.8.2 Service Brake Valve​
9.8.3 Steering Orbital Valve​
9.8.4 Steer Select Valve​
9.8.5 Secondary Function Manifold​
9.8.6 Outrigger Valve (10042, 10054 & 12054 only)​
9.8.7 Extend Lockout Valve (10054 & 12054 only)​
9.8.8 Transmission Solenoid Valves​
Hydraulic Pump​
9.9.1 Hydraulic System Pump​
Electrical Components​
9.10.1 Battery​
Disassembly and Assembly
Drive Assembly​
10.1.1 Axle Assembly​
10.1.2 Transmission Assembly​
Boom​
10.2.1 Boom System - Three Boom Section (6036, 6042, 8042 & 10042)​
10.2.2 Boom System - Four Boom Section (10054 &12054)​
Cab​
Engine Components​
10.4.1 Fuel/Hydraulic Oil Tank​
Transmission​
10.5.1 Piston Pump​
10.6.1 General Cylinder Disassembly​
10.6.2 Cylinder Cleaning Instructions​
10.6.3 Cylinder Inspection​
10.6.4 Cylinder Assembly Instructions​
10.6.5 Hydraulic Cylinder Repair Information​
Hydraulic Valves​
10.7.1 Main Control Valve​
10.7.2 Secondary Function Manifold​
10.7.3 Steer Select Valve​
10.7.4 Outrigger Valve (10042, 10054 & 12054 only)​
10.7.5 Extend Lockout Valve (10054 & 12054 only)​
Hydraulic Components​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
Electrical Schematics​
12.2.1 Electrical Schematic — T4F HRC​
12.2.2 Electrical Schematic — T4F LRC​
12.2.3 Electrical Schematic — T4F 55KW​
