JLG Telehandler 6034 Parts Catalog 3122327600
Brand: JLG
Type of Machine: Telehandler
Model: JLG 6034 Telehandler
Part Number: 3122327600
Publication Date: 2025
Number of Pages: 566 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME BEARING AND TRIM INSTALLATION
FIGURE 1-2. FRAME COVERS ASSEMBLY
FIGURE 1-3. FUEL TANK ASSEMBLY (Prior to SN 0160134485)
FIGURE 1-4. FUEL TANK ASSEMBLY (SN 0160134486 to Present)
FIGURE 1-5. FUEL TANK MOUNTING INSTALLATION
FIGURE 1-6. HYDRAULIC TANK ASSEMBLY
FIGURE 1-7. HYDRAULIC TANK MOUNTING INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM INSTALLATION
FIGURE 2-2. BOOM ASSEMBLY
FIGURE 2-3. BOOM BASE ASSEMBLY
FIGURE 2-4. BOOM MID ASSEMBLY
FIGURE 2-5. HOSE PULLEY ASSEMBLY
FIGURE 2-6. BOOM FLY ASSEMBLY
FIGURE 2-7. BOOM ANGLE INDICATOR
FIGURE 2-8. BOOM PROP INSTALLATION
FIGURE 2-9. COUPLER ASSEMBLY
FIGURE 2-10. LOCK PIN ASSEMBLY
SECTION 3 - ATTACHMENTSFIGURE 3-1. BASKET, PERSONNEL (1.2MX2.4M) (DOMESTIC)
FIGURE 3-2. BASKET, PERSONNEL (1.2MX2.4M) (ISO)
FIGURE 3-3. BASKET, PERSONNEL (1.2MX2.4M) (FRENCH LANGUAGE)
FIGURE 3-4. PLATFORM (FORK MOUNTED) (4X9.8)
FIGURE 3-5. PLATFORM (FORK MOUNTED) (4X8 WITH DOORS)
FIGURE 3-6. BASKET, PERSONNEL ASSEMBLY
FIGURE 3-7. BOOM - 3 FOOT WITH WINCH
FIGURE 3-8. BOOM - 12 FOOT WITH WINCH
FIGURE 3-9. BOOM - 12FT WITHOUT WINCH
FIGURE 3-10. BOOM - 15FT WITHOUT WINCH
FIGURE 3-11. BOOM - ADJUSTABLE (FORK MOUNTED)
FIGURE 3-12. BUCKET (72 INCH)
FIGURE 3-13. BUCKET (96 INCH)
FIGURE 3-14. BUCKET (102 INCH)
FIGURE 3-15. CARRIAGE ASSEMBLY - 48IN SIDE SHIFT
FIGURE 3-16. CARRIAGE ASSEMBLY - 50IN
FIGURE 3-17. CARRIAGE ASSEMBLY - 50IN DUAL FORK POSITIONING
FIGURE 3-18. CARRIAGE ASSEMBLY - 50IN/12000# CAPICITY SIDE TILT
FIGURE 3-19. CARRIAGE ASSEMBLY - 60IN
FIGURE 3-20. CARRIAGE ASSEMBLY - 60IN/12000# CAPACITY SIDE TILT
FIGURE 3-21. CARRIAGE ASSEMBLY - 72IN
FIGURE 3-22. CARRIAGE ASSEMBLY - 72IN/12000# CAPACITY SIDE TILT
FIGURE 3-23. CARRIAGE ASSEMBLY - 72IN/10000# CAPACITY 90 DEGREE SWING
FIGURE 3-24. FORK 2.36X4X48 PALLET
FIGURE 3-25. FORK 2.36X5X48 PALLET
FIGURE 3-26. FORK 2.4X4X48 PALLET
FIGURE 3-27. FORK 2.4X4X60 PALLET
FIGURE 3-28. FORK 2.36X5X72 PALLET
FIGURE 3-29. FORK 2.36X5X60 PALLET
FIGURE 3-30. FORK 2.36X6X60 PALLET
FIGURE 3-31. FORK 1.75X7X60 LUMBER
FIGURE 3-32. FORK 2X6X72 LUMBER
FIGURE 3-33. FORK 2X2X48 BLOCK
FIGURE 3-34. HOOK - COUPLER MOUNTED
FIGURE 3-35. HOOK - 4TON (FORK MOUNTED)
FIGURE 3-36. LIFTING HOOK (6K)
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION - HRC
FIGURE 4-2. ENGINE INSTALLATION - LRC
FIGURE 4-3. ENGINE ASSEMBLY - HRC
FIGURE 4-4. ENGINE ASSEMBLY - LRC
FIGURE 4-5. ENGINE MOUNTS INSTALLATION
FIGURE 4-6. ENGINE ELECTRICAL INSTALLATION
FIGURE 4-7. ENGINE AIR INTAKE INSTALLATION
FIGURE 4-8. ENGINE FUEL SYSTEM INSTALLATION (HRC ENGINES)
FIGURE 4-9. ENGINE FUEL SYSTEM INSTALLATION (LRC ENGINES)
FIGURE 4-10. ENGINE PUMPS INSTALLATION
FIGURE 4-11. ENGINE COOLING SYSTEM INSTALLATION
FIGURE 4-12. ENGINE EXHAUST INSTALLATION
FIGURE 4-13. ENGINE OIL QUICK DRAIN INSTALLATION
FIGURE 4-14. AC PUMP INSTALLATION
FIGURE 4-15. AIR SHUT-OFF VALVE (ASOV) INSTALLATION
FIGURE 4-16. BLOCK HEATER INSTALLATION (ANSI)
FIGURE 4-17. BREATHER HEATER INSTALLATION
FIGURE 4-18. COOLING LINES INSTALLATION
FIGURE 4-19. RADIATOR HOSES INSTALLATION
FIGURE 4-20. SURGE TANK INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. AXLES INSTALLATION
FIGURE 5-2. FRONT AXLE ASSEMBLY - CENTRAL HOUSING
FIGURE 5-3. FRONT AXLE ASSEMBLY - DIFFERENTIAL
FIGURE 5-4. FRONT AXLE ASSEMBLY - HUB REDUCTION
FIGURE 5-5. FRONT AXLE ASSEMBLY - BRAKES
FIGURE 5-6. FRONT AXLE ASSEMBLY - STEERING
FIGURE 5-7. FRONT AXLE ASSEMBLY - TRUNION
FIGURE 5-8. REAR AXLE ASSEMBLY - CENTRAL HOUSING
FIGURE 5-9. REAR AXLE ASSEMBLY - DIFFERENTIAL
FIGURE 5-10. REAR AXLE ASSEMBLY - HUB REDUCTION
FIGURE 5-11. REAR AXLE ASSEMBLY - STEERING
FIGURE 5-12. REAR AXLE ASSEMBLY - TRUNION
FIGURE 5-13. DRIVE MOTOR INSTALLATION
FIGURE 5-14. DRIVE MOTOR AND FITTINGS ASSEMBLY
FIGURE 5-15. DRIVE MOTOR ASSEMBLY
FIGURE 5-16. DRIVESHAFT INSTALLATION
FIGURE 5-17. DRIVESHAFT ASSEMBLY
FIGURE 5-18. FENDER INSTALLATION
FIGURE 5-19. FENDER INSTALLATION (CLOSED CAB)
FIGURE 5-20. GEARBOX INSTALLATION
FIGURE 5-21. GEARBOX ASSEMBLY
FIGURE 5-22. LUGNUT INSTALLATION
FIGURE 5-23. TIRE SET - 15-19.5 PNUEMATIC
FIGURE 5-24. TIRE SET - 15-19.5 FOAM-FILLED
FIGURE 5-25. TIRE SET - 315/8-20/8.5 SOLID
FIGURE 5-26. TIRE SET - 15-19.5 PNUEMATIC NON-MARKING
FIGURE 5-27. TIRE SET - 15-19.5 FOAM-FILLED NON-MARKING
FIGURE 5-28. TIRE SET - 18 X 625 PNUEMATIC TURF
SECTION 6 - CABFIGURE 6-1. CAB INSTALLATION - OPEN
FIGURE 6-2. CAB INSTALLATION - ENCLOSED WITH HEAT ONLY
FIGURE 6-3. CAB INSTALLATION - ENCLOSED WITH HEAT/AC
FIGURE 6-4. CAB INTERIOR INSTALLATION
FIGURE 6-5. CAB SUB-ASSEMBLY (HEAT ONLY)
FIGURE 6-6. CAB SUB-ASSEMBLY (HEAT AND AC)
FIGURE 6-7. CAB ASSEMBLY
FIGURE 6-8. DOOR ASSEMBLY (Prior to SN 0160136441)
FIGURE 6-9. DOOR ASSEMBLY (SN 0160136442 to Present)
FIGURE 6-10. WINDOW ASSEMBLY (REAR)
FIGURE 6-11. HEATER ASSEMBLY
FIGURE 6-12. HVAC ASSEMBLY
FIGURE 6-13. CAB MOUNTING INSTALLATION
FIGURE 6-14. CAB HEATER INSTALLATION
FIGURE 6-15. CAB HEATER CONTROLS INSTALLATION
FIGURE 6-16. CAB HEATER LINES INSTALLATION (Prior to SN 0160136441)
FIGURE 6-17. CAB HEATER LINES INSTALLATION (SN 0160136442 to Present)
FIGURE 6-18. CAB HVAC CONTROLS INSTALLATION
FIGURE 6-19. CAB HVAC LINES INSTALLATION (Prior to SN 0160136441)
FIGURE 6-20. CAB HVAC LINES INSTALLATION (SN 0160136442 to Present)
FIGURE 6-21. FIRE EXTINGUISHER INSTALLATION
FIGURE 6-22. FORWARD/NEUTRAL/REVERSE CONTROL INSTALLATION
FIGURE 6-23. FORWARD/NEUTRAL/REVERSE AND WIPER/LIGHTS CONTROL
FIGURE 6-24. FLOOR HEATER
FIGURE 6-25. HEATER VALVE
FIGURE 6-26. LOADCHART HOLDER INSTALLATION
FIGURE 6-27. MIRRORS INSTALLATION
FIGURE 6-28. SEAT INSTALLATION - STANDARD
FIGURE 6-29. SEAT INSTALLATION - SEAOP
FIGURE 6-30. SEAT ASSEMBLY - STANDARD
FIGURE 6-31. SEAT ASSEMBLY - VINYL
FIGURE 6-32. SEAT BELT INSTALLATION (3IN WIDTH)
FIGURE 6-33. STEERING SYSTEM INSTALLATION
FIGURE 6-34. WINDOW EXIT INSTALLATION (ANSI SPECS)
FIGURE 6-35. WINDOW EXIT INSTALLATION (ENGLISH/FRENCH LANGUAGES)
FIGURE 6-36. WINDOW EXIT INSTALLATION (ISO SPECS)
FIGURE 6-37. WINDOW EXIT INSTALLATION (ENGLISH/SPANISH LANGUAGES)
SECTION 7 - CONTROLSFIGURE 7-1. BRAKE SYSTEM INSTALLATION (Prior to SN 10160136124)
FIGURE 7-2. BRAKE SYSTEM INSTALLATION (SN 0160136125 to Present)
FIGURE 7-3. JOYSTICK INSTALLATION (Prior to SN 0160132681)
FIGURE 7-4. JOYSTICK INSTALLATION (SN 0160132682 to Present)
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. HOSE INSTALLATION - AXLE
FIGURE 8-2. HOSE INSTALLATION - AXLE (FRONT)
FIGURE 8-3. HOSE INSTALLATION - AXLE (REAR)
FIGURE 8-4. HOSE INSTALLATION - BOOM
FIGURE 8-5. HOSE INSTALLATION - BRAKE
FIGURE 8-6. HOSE INSTALLATION - HYDRASTATIC DRIVE (PVC 2311)
FIGURE 8-7. HOSE INSTALLATION - MAIN CONTROL VALVE (PVC 2311)
FIGURE 8-8. HOSE INSTALLATION - OIL COOLER
FIGURE 8-9. HOSE INSTALLATION - STABILIZER/SWAY
FIGURE 8-10. HOSE INSTALLATION - PUMP/TANK
FIGURE 8-11. HOSE INSTALLATION - STEER
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. BRAKE AND FITTINGS SUB-ASSEMBLY
FIGURE 9-2. BRAKE ASSEMBLY
FIGURE 9-3. BRAKE AND STEER VALVES INSTALLATION
FIGURE 9-4. BRAKE VALVE AND FITTINGS SUB-ASSEMBLY
FIGURE 9-5. BRAKE VALVE ASSEMBLY
FIGURE 9-6. CYLINDERS INSTALLATION
FIGURE 9-7. CYLINDER - LIFT
FIGURE 9-8. CYLINDER - SWAY
FIGURE 9-9. CYLINDER - STABLIZER
FIGURE 9-10. CYLINDER - COMP
FIGURE 9-11. CYLINDER - TILT
FIGURE 9-12. CYLINDER - EXTEND/RETRACT
FIGURE 9-13. CYLINDER ASSEMBLY, SIDE SHIFT CARRIAGE
FIGURE 9-14. CYLINDER - FORK POSITIONING
FIGURE 9-15. CYLINDER - SIDE TILT
FIGURE 9-16. CYLINDER - SWING CARRIAGE
FIGURE 9-17. DUAL FORK CARRIAGE VALVE ASSEMBLY
FIGURE 9-18. FLOW DIVIDER VALVE
FIGURE 9-19. MAIN CONTROL VALVE AND FITTINGS SUB-ASSEMBLY
FIGURE 9-20. MAIN CONTROL VALVE ASSEMBLY
FIGURE 9-21. PUMP MOUNTING KIT
FIGURE 9-22. PUMP AND FITTINGS ASSEMBLY
FIGURE 9-23. PUMP ASSEMBLY
FIGURE 9-24. PUMP AND FITTINGS ASSEMBLY - GEAR PUMP
FIGURE 9-25. STABILIZER VALVE AND FITTINGS SUBASSEMBLY
FIGURE 9-26. STABILIZER VALVE ASSEMBLY
FIGURE 9-27. STEER SELECT VALVE AND FITTINGS SUB-ASSEMBLY
FIGURE 9-28. STEERING SELECT VALVE
FIGURE 9-29. STEER VALVE AND FITTINGS SUB-ASSEMBLY
FIGURE 9-30. VALVE INSTALLATION - WATCHDOG
FIGURE 9-31. VALVE ASSEMBLY - WATCHDOG
FIGURE 9-32. VALVE, AIR SHUT OFF
SECTION 10 - ELECTRICALFIGURE 10-1. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 10-2. 6034 ELECTRICAL LAYOUT
FIGURE 10-3. AIR SHUT-OFF VALVE HARNESS - POSI
FIGURE 10-4. AIR SHUT-OFF VALVE HARNESS - ENGINE
FIGURE 10-5. ALARM INSTALLATION - BACK UP
FIGURE 10-6. ALARM INSTALLATION - BACK UP (WHITE NOISE)
FIGURE 10-7. BATTERY INSTALLATION
FIGURE 10-8. BEACON INSTALLATION (WITHOUT CLEARSKY BEACON)
FIGURE 10-9. BEACON HARNESS (WITHOUT CLEARSKY BEACON)
FIGURE 10-10. BOOM SENSOR INSTALLATION (WITHOUT LSI)
FIGURE 10-11. BOOM SENSOR INSTALLATION (WITH LSI)
FIGURE 10-12. CAB ELECTRICAL INSTALLATION (Prior to SN 0160134485)
FIGURE 10-13. CAB ELECTRICAL INSTALLATION (SN 0160134486 to Present)
FIGURE 10-14. CAB ELECTRICAL INSTALLATION - ENCLOSED CAB
FIGURE 10-15. CAB DIAGNOSTIC PLUG INSTALLATION
FIGURE 10-16. CAB HARNESS
FIGURE 10-17. CAB AC JUMPER HARNESS
FIGURE 10-18. CAB HVAC/WIPER HARNESS
FIGURE 10-19. CAMERA INSTALLATION - BACK UP (WITHOUT LIGHTS) (Prior to SN 0160135732)
FIGURE 10-20. CAMERA INSTALLATION - BACK UP (WITHOUT LIGHTS) (SN 0160135733 to Present)
FIGURE 10-21. CAMERA INSTALLATION - BACK UP (WITH LIGHTS)
FIGURE 10-22. CAMERA HARNESS - BACK UP CAMERA
FIGURE 10-23. ENGINE HARNESS
FIGURE 10-24. FRAME HARNESS INSTALLATION (PVC 2311)
FIGURE 10-25. FRAME HARNESS
FIGURE 10-26. FRAME ELECTRICAL COMPONENTS INSTALLATION
FIGURE 10-27. FRAME FUSEBOX ASSEMBLY
FIGURE 10-28. HEADLIGHT HARNESS
FIGURE 10-29. HEATER INSTALLATION - HYDRAULIC TANK
FIGURE 10-30. HEATER INSTALLATION - BATTERY
FIGURE 10-31. HEATER INSTALLATION - ENGINE OIL PAN
FIGURE 10-32. LIGHTS - ROADLIGHTS INSTALLATION
FIGURE 10-33. LIGHTS - WORKLIGHTS INSTALLATION
FIGURE 10-34. LIGHTS - BOOM HARNESS
FIGURE 10-35. LIGHTS – HEADLIGHTS HARNESS
FIGURE 10-36. LIGHTS – TAILLIGHTS HARNESS
FIGURE 10-37. LOAD SENSE INDICATOR (LSI) SYSTEM INSTALLATION - CAB
FIGURE 10-38. LOAD SENSE INDICATOR (LSI) SYSTEM INSTALLATION - AXLE
FIGURE 10-39. LOAD SENSE INDICATOR (LSI) HARNESS
FIGURE 10-40. REVERSE SENSOR SYSTEM INSTALLATION (WITHOUT CAMERA)
FIGURE 10-41. REVERSE SENSOR SYSTEM INSTALLATION (WITH CAMERA)
FIGURE 10-42. REVERSE SENSOR HARNESS
FIGURE 10-43. SEAT HARNESS - SEAOP SEAT
FIGURE 10-44. TELEMATICS INSTALLATION - GATEWAY (CUSTOMER SUPPLIED)
FIGURE 10-45. TELEMATICS INSTALLATION - GATEWAY PLUS (CUSTOMER SUPPLIED)
FIGURE 10-46. TELEMATICS READY INSTALLATION
SECTION 11 - DECALSFIGURE 11-1. DECALS INSTALLATION (ANSI SPECS)
FIGURE 11-2. DECALS INSTALLATION (ISO SPECS)
FIGURE 11-3. DECALS INSTALLATION (ENGLISH/FRENCH LANGUAGES)
FIGURE 11-4. DECALS INSTALLATION (ENGLISH/SPANISH LANGUAGES)
FIGURE 11-5. DECALS INSTALLSTION (ISO) (HRC)
FIGURE 11-6. DECALS INSTALLATION - BRAND
FIGURE 11-7. DECAL INSTALLATION - CLEARSKY CS550 BEACON
FIGURE 11-8. DECALS INSTALLATION - SKYTRAK
FIGURE 11-9. LOAD CHART (ANSI SPECS)
FIGURE 11-10. LOAD CHART (METRIC SPECS)
FIGURE 11-11. REVERSE SENSOR SYSTEM DECAL (ENGLISH)
FIGURE 11-12. REVERSE SENSOR SYSTEM DECAL (ISO)
FIGURE 11-13. REVERSE SENSING SYSTEM DECAL, (ENGLISH/FRENCH)
FIGURE 11-14. REVERSE SENSOR SYSTEM DECAL (ENGLISH/SPANISH)
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
