JLG Telehandler 6034 6042 Service Manual 3122554600 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 6034, 6042 Telehandler
Part Number: 3122554600
Publication Date: 2025
Number of Pages: 674 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information & SpecificationsSpecifications
2.1.1 Travel Speeds
2.1.2 Boom Performance
2.1.3 Cylinder Drift
2.1.4 Electrical System
2.1.5 Engine Performance Specifications
2.1.6 Tires
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedules
ClearSky Smart Fleet
2.5.1 General
2.5.2 ClearSky Smart Fleet™ – Access Control
Maintenance & Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Every 10 Hours
3.3.2 First 50 Hours
3.3.3 Every 50 Hours
3.3.4 First 250 Hours
3.3.5 Every 250 Hours
3.3.6 First 500 Hours
3.3.7 Every 500 Hours
3.3.8 Every 1000 Hours
3.3.9 Every 1500 Hours
3.3.10 Every 2000 Hours
3.3.11 Every 3000 Hours or 2 Years
3.3.12 Every 6000 Hours or 4 Years
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Parking Brake Bleeding (Manually)
3.6.2 Service Brake Bleeding
DEF Tank Inspection
Boom Inspection and Maintenance
3.8.1 Boom Wear Pads
Hydraulic Filter Replacement
3.9.1 Removal
3.9.2 Installation
Engine General Inspection
3.10.1 General Maintenance
3.10.2 Glow Plugs
3.10.3 Replacing Engine Oil
3.10.4 Replacing the Oil Filter
3.10.5 Replacing the Fuel Filters
3.10.6 Replacing the Fuel Pre-Filter
3.10.7 Checking Belt Tension
Testing, Calibrations & Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Thread Locking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 Charging Circuit
Calibration Procedures
4.3.1 Analyzer
4.3.2 Calibration Preparation
4.3.3 Boom Angle Sensor Calibration
4.3.4 Load Stability Indicator (LSI) System Calibration
4.3.5 Brake Pedal Calibration
4.3.6 Park Brake Calibration/Maximum Drive Traction Test
Special Procedures
4.4.1 Emergency Lowering Procedure
4.4.2 Lowering Procedure
4.4.3 Towing a Disabled Machine
4.4.4 Charge Air Cooler (CAC) Hose Draining
4.4.5 Hydraulic Tank
4.4.6 Fuel Tank Cleaning and Drying
4.4.7 Pressure Checks and Adjustments
4.4.8 Cylinder Checking Procedure
4.4.9 Cylinder Drift Test
4.4.10 Hydraulic Circuits
4.4.11 Pressure Specifications
4.4.12 Boom Extend and Retract Chains
4.4.13 Boom Chain Tension Adjustment
4.4.14 Evacuating and Recharging Air Conditioning (AC) System
Stabil-Trak™ and Boom Interlock System
4.5.1 Stabil-Trak™ System Component Terminology
4.5.2 Stabil-Trak™ Description
4.5.3 Stabil-Trak™ Operation
4.5.4 Stabil-Trak™ System Test
System SoftwareLoad Stability Indicator (LSI) (If Equipped)
5.1.1 Load Stability Indicator
5.1.2 LSI Sensor
Analyzer
5.2.1 Machine Data Access
5.2.2 JLG Hand Held Analyzer
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer
5.2.4 PC Analyzer/Loglifter
5.2.5 Analyzer Software (Version P27.0)
Access Level
Diagnostics (Software Version P27.0)
Machine Setup (Software Version P27.0)
Personalities (Software Version P27.0)
Operator Tools (Software Version P27.0)
Calibrations (Software Version P27.0)
ClearSky (CS550) Configuration and Troubleshooting
5.9.1 ClearSky Smart FleetTM CS550 Configuration
5.9.2 Troubleshooting
Fault CodesIntroduction
6.1.1 Fault Code Display
Engine Fault Codes
6.2.1 TCD 2.9L4 Fault Codes
Fault Codes - Help Comment (00x)
Fault Codes - Power-Up (21x)
Fault Codes - Ground Inputs (23x)
Fault Codes - Other Inputs (24x)
Fault Codes - Function Prevented (25x)
Fault Codes - Line Contactor, Open-Circuit (31x)
Fault Codes - Line Contactor, Short-Circuit (32x)
Fault Codes - Output Drivers (33x)
Fault Codes - Engine (43x)
Fault Codes - Battery Supply (44x)
Fault Codes - Transmission and Drive System (46x)
Fault Codes - Communications (66x)
Fault Codes - Telematics (68x)
Fault Codes - Tilt Sensor (81x)
Fault Codes - Envelope Control (84x)
Fault Codes - Load Moment (85x)
Fault Codes - Steering (86x)
Fault Codes - Service Required (87x)
Fault Codes - Hardware (99x)
Air Shutoff Valve (ASOV) Controller
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Component
Torque Values
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
8.3.1 General Overview
Harness Layouts
8.4.1 Electrical Frame Harness
8.4.2 Component Layout - Frame
8.4.3 Harness Layout- Engine
8.4.4 Component Layout- Cab
8.4.5 Component Layout- Electrical Control
Board Layouts
8.5.1 Cab Harness Fuses and Relays
8.5.2 Power Distribution Board
Telematics Gateway
8.6.1 Telematics-Ready (TCU) Plug
8.6.2 Component Locations
8.6.3 Telematics Gateway Harness Breakdown
Removal and InstallationWheels
9.1.1 Removing Wheel and Tire Assembly from Machine
9.1.2 Installing Wheel and Tire Assembly onto Machine
Drive Assembly
9.2.1 Axle Assembly And Drive Shaft Troubleshooting
9.2.2 Axle
9.2.3 Drive Shafts
9.2.4 Transmission Components
Boom
9.3.1 Boom System Component Terminology
9.3.2 Troubleshooting
9.3.3 Boom System
9.3.4 Quick Coupler
9.3.5 Forks
9.3.6 Boom Prop (If Equipped)
9.3.7 Boom Wear Pad Installation and Lubrication
9.3.8 Boom Angle Sensor
9.4.1 Serial Number Plate
9.4.2 Cab Removal/Installation
9.4.3 Steering Wheel
9.4.4 Brake System
9.4.5 Throttle Pedal
9.4.6 Joystick Assembly
9.4.7 Ignition Key Switch
9.4.8 Dash Switches
9.4.9 Front Wiper Assembly (If Equipped)
9.4.10 Roof Wiper Assembly (If Equipped)
9.4.11 Windshield Washer Reservoir (If Equipped)
9.4.12 Heater System (If Equipped)
9.4.13 Heater and Air Conditioning System (If Equipped)
9.4.14 Rear Camera and Reverse Sensor (If Equipped)
9.5.1 Component Terminology
9.5.2 Diesel Fuel
9.5.3 Engine Serial Number
9.5.4 Engine Replacement
9.5.5 Engine Electrical System
9.5.6 Surge Tank Cap
9.5.7 Surge Tank
9.5.8 Thermostat
9.5.9 Engine Coolant Temperature Sensor
9.5.10 Radiator/Oil Cooler Assembly
9.5.11 Pump Coupling Kit
9.5.12 Air Filter Assembly
9.5.13 Relay Assembly
9.5.14 Alternator
9.5.15 Starter
9.5.16 Fuel Tank
9.5.17 Hydraulic Tank
9.5.18 Pre-Fuel Filter and Fuel Pump
9.5.19 Engine Exhaust System
9.5.20 Air Conditioning (AC) Compressor (If equipped)
9.6.1 Component Terminology
9.6.2 Transmission Replacement
9.6.3 Drive Motor
9.6.4 Gearbox
Hydraulic Cylinders
9.7.1 Sway Cylinder Assembly
9.7.2 Stabilizer Cylinder Assembly
9.7.3 Compensator Cylinder Assembly
9.7.4 Lift Cylinder Assembly
9.7.5 Tilt Cylinder Assembly
9.7.6 Extend/Retract Cylinder Assembly
Hydraulic Valves
9.8.1 Stabil-Trak Valve
9.8.2 Steer Select Valve and Park Brake Valve
9.8.3 Main Control Valve
9.8.4 Watchdog Valve
9.8.5 Priority Valve (6042)
9.8.6 Diverter Valve (6042)
Hydraulic Pumps
9.9.1 Gear Pump
9.9.2 Drive Pump
Electrical Components
9.10.1 Battery
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Axle Assembly
10.1.2 Transmission Assembly
Boom
10.2.1 Disassembly
10.2.2 Assembly
Engine Components
10.4.1 Engine Components
10.5.1 Drive Motor
10.5.2 Gearbox
10.5.3 Gear Pump
10.5.4 Drive Pump
Hydraulic Cylinders
10.6.1 General Cylinder Disassembly
10.6.2 Hydraulic Cylinder Repair Information
Hydraulic Valves
10.7.1 Main Control Valve
10.7.2 Watchdog Valve
10.7.3 Steer Select and Park Brake Valve
10.7.4 Stabil-Trak Valve
10.7.5 Priority Valve (Only for 6042)
10.7.6 Diverter Valve (Only for 6042)
Hydraulic Components
10.8.1 Hydraulic Oil Reservoir
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
