Hyundai
86
176,834
JLG Telehandler 6034 6042 Service Manual 3122331100 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 6034, 6042 Telehandler
Part Number: 3122331100
Publication Date: 2025
Number of Pages: 656 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
General Machine Information & Specifications
Specifications​
2.1.1 Travel Speeds​
2.1.2 Boom Performance​
2.1.3 Cylinder Drift​
2.1.4 Electrical System​
2.1.5 Engine Performance Specifications​
2.1.6 Tires​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedules​
ClearSky Smart Fleet​
2.5.1 General​
2.5.2 ClearSky Smart Fleet™ – Access Control​
Maintenance & Inspection Schedules
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Every 10 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 First 250 Hours​
3.3.5 Every 250 Hours​
3.3.6 First 500 Hours​
3.3.7 Every 500 Hours​
3.3.8 Every 1000 Hours​
3.3.9 Every 1500 Hours​
3.3.10 Every 2000 Hours​
3.3.11 Every 3000 Hours or 2 Years​
3.3.12 Every 6000 Hours or 4 Years​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Parking Brake Bleeding (Manually)​
3.6.2 Service Brake Bleeding​
DEF Tank Inspection​
Boom Inspection and Maintenance​
3.8.1 Boom Wear Pads​
Hydraulic Filter Replacement​
3.9.1 Removal​
3.9.2 Installation​
Engine General Inspection​
3.10.1 General Maintenance​
3.10.2 Glow Plugs​
3.10.3 Replacing Engine Oil​
3.10.4 Replacing the Oil Filter​
3.10.5 Replacing the Fuel Filters​
3.10.6 Replacing the Fuel Pre-Filter​
3.10.7 Checking Belt Tension​
Testing, Calibrations & Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Thread Locking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 Charging Circuit​
Calibration Procedures​
4.3.1 Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Boom Angle Sensor Calibration​
4.3.4 Load Stability Indicator (LSI) System Calibration​
4.3.5 Brake Pedal Calibration​
4.3.6 Park Brake Calibration/Maximum Drive Traction Test​
Special Procedures​
4.4.1 Emergency Lowering Procedure​
4.4.2 Lowering Procedure​
4.4.3 Towing a Disabled Machine​
4.4.4 Charge Air Cooler (CAC) Hose Draining​
4.4.5 Hydraulic Tank​
4.4.6 Fuel Tank Cleaning and Drying​
4.4.7 Pressure Checks and Adjustments​
4.4.8 Cylinder Checking Procedure​
4.4.9 Cylinder Drift Test​
4.4.10 Hydraulic Circuits​
4.4.11 Pressure Specifications​
4.4.12 Boom Extend and Retract Chains​
4.4.13 Boom Chain Tension Adjustment​
4.4.14 Evacuating and Recharging Air Conditioning (AC) System​
STABIL-TRAK™ and Boom Interlock System​
4.5.1 Stabil-Trak™ System Component Terminology​
4.5.2 Stabil-Trak™ Description​
4.5.3 Stabil-Trak™ Operation​
4.5.4 Stabil-Trak™ System Test​
System Software
Load Stability Indicator (LSI) (If Equipped)​
5.1.1 Load Stability Indicator​
5.1.2 LSI Sensor​
Analyzer​
5.2.1 Machine Data Access​
5.2.2 JLG Hand Held Analyzer​
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer​
5.2.4 PC Analyzer/Loglifter​
5.2.5 Analyzer Software (Version P26.2)​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostics​
5.3.3 Machine Set-up (Software version P26.2)​
5.3.4 Personalities (Software Version P26.2)​
5.3.5 Operator Tools (Software version P26.2)​
5.3.6 Calibrations (Software version P26.2)​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction​
6.1.1 Fault Code Display​
Engine Fault Codes​
6.2.1 TCD 2.9L4 Fault Codes​
Machine Fault Codes​
Air Shutoff Valve (ASOV) Controller​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
8.3.1 General Overview​
Harness Layouts​
8.4.1 Electrical Frame Harness​
8.4.2 Component Layout - Frame​
8.4.3 Harness Layout- Engine​
8.4.4 Component Layout- Cab​
8.4.5 Component Layout- Electrical Control​
Board Layouts​
8.5.1 Cab Harness Fuses and Relays​
8.5.2 Power Distribution Board​
Telematics Gateway​
8.6.1 Telematics-Ready (TCU) Plug​
8.6.2 Component Locations​
8.6.3 Telematics Gateway Harness Breakdown​
Wheels​
9.1.1 Removing Wheel and Tire Assembly from Machine​
9.1.2 Installing Wheel and Tire Assembly onto Machine​
Drive Assembly​
9.2.1 Axle Assembly And Drive Shaft Troubleshooting​
9.2.2 Axle​
9.2.3 Drive Shafts​
9.2.4 Transmission Components​
Boom​
9.3.1 Boom System Component Terminology​
9.3.2 Troubleshooting​
9.3.3 Boom System​
9.3.4 Quick Coupler​
9.3.5 Forks​
9.3.6 Boom Prop (If Equipped)​
9.3.7 Boom Wear Pad Installation and Lubrication​
9.3.8 Boom Angle Sensor​
Cab​
9.4.1 Serial Number Plate​
9.4.2 Cab Removal/Installation​
9.4.3 Steering Wheel​
9.4.4 Brake System​
9.4.5 Throttle Pedal​
9.4.6 Joystick Assembly​
9.4.7 Ignition Key Switch​
9.4.8 Dash Switches​
9.4.9 Front Wiper Assembly (If Equipped)​
9.4.10 Roof Wiper Assembly (If Equipped)​
9.4.11 Windshield Washer Reservoir (If Equipped)​
9.4.12 Heater System (If Equipped)​
9.4.13 Heater and Air Conditioning System (If Equipped)​
9.4.14 Rear Camera and Reverse Sensor (If Equipped)​
Engine​
9.5.1 Component Terminology​
9.5.2 Diesel Fuel​
9.5.3 Engine Serial Number​
9.5.4 Engine Replacement​
9.5.5 Engine Electrical System​
9.5.6 Surge Tank Cap​
9.5.7 Surge Tank​
9.5.8 Thermostat​
9.5.9 Engine Coolant Temperature Sensor​
9.5.10 Radiator/Oil Cooler Assembly​
9.5.11 Pump Coupling Kit​
9.5.12 Air Filter Assembly​
9.5.13 Relay Assembly​
9.5.14 Alternator​
9.5.15 Starter​
9.5.16 Fuel Tank​
9.5.17 Hydraulic Tank​
9.5.18 Pre-Fuel Filter and Fuel Pump​
9.5.19 Engine Exhaust System​
9.5.20 Air Conditioning (AC) Compressor (If equipped)​
Transmission​
9.6.1 Component Terminology​
9.6.2 Transmission Replacement​
9.6.3 Drive Motor​
9.6.4 Gearbox​
Hydraulic Cylinders​
9.7.1 Sway Cylinder Assembly​
9.7.2 Stabilizer Cylinder Assembly​
9.7.3 Compensator Cylinder Assembly​
9.7.4 Lift Cylinder Assembly​
9.7.5 Tilt Cylinder Assembly​
9.7.6 Extend/Retract Cylinder Assembly​
Hydraulic Valves​
9.8.1 Stabil-Trak Valve​
9.8.2 Steer Select Valve and Park Brake Valve​
9.8.3 Main Control Valve​
9.8.4 Watchdog Valve​
9.8.5 Priority Valve (6042)​
9.8.6 Diverter Valve (6042)​
Hydraulic Pumps​
9.9.1 Gear Pump​
9.9.2 Drive Pump​
Electrical Components​
9.10.1 Battery​
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Axle Assembly​
10.1.2 Transmission Assembly​
Boom​
10.2.1 Disassembly​
10.2.2 Assembly​
Cab​
Engine Components​
10.4.1 Engine Components​
Transmission​
10.5.1 Drive Motor​
10.5.2 Gearbox​
10.5.3 Gear Pump​
10.5.4 Drive Pump​
10.6.1 General Cylinder Disassembly​
10.6.2 Hydraulic Cylinder Repair Information​
Hydraulic Valves​
10.7.1 Main Control Valve​
10.7.2 Watchdog Valve​
10.7.3 Steer Select and Park Brake Valve​
10.7.4 Stabil-Trak Valve​
10.7.5 Priority Valve (Only for 6042)​
10.7.6 Diverter Valve (Only for 6042)​
Hydraulic Components​
10.8.1 Hydraulic Oil Reservoir​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
Electrical Schematics​
