Hyundai
86
176,684
JLG Telehandler 519 Service Manual 3122243400 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 519 Telehandler
Part Number: 3122243400
Publication Date: 2025
Number of Pages: 624 Pages
Cover Page
Effectivity Page
Read This First
Modifications​
Machine Configuration​
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Travel Speed​
2.1.2 Boom Performance Specifications​
2.1.3 Battery​
2.1.4 Engine Specifications​
2.1.5 Operating Specifications​
2.1.6 Dimensions​
2.1.7 Transmission​
2.1.8 Tires​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedules​
ClearSky Smart Fleet​
2.5.1 General​
2.5.2 ClearSky Smart Fleet™ – Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Every 10 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 First 250 Hours​
3.3.5 Every 250 Hours​
3.3.6 Every 500 Hours​
3.3.7 Every 1000 Hours​
3.3.8 Every 1500 Hours​
3.3.9 Every 6000 Hours or 4 Years​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires & Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Spring Applied Hydraulically Released (SAHR) Parking Brake Bleeding​
3.6.2 Service Brake Bleeding​
Boom Inspection and Maintenance​
3.7.1 Boom Wear Pads​
Hydraulic Filter Replacement​
Engine General Inspection​
3.9.1 General Maintenance​
3.9.2 Glow Plugs​
3.9.3 Replacing Engine Oil​
3.9.4 Replacing the Oil Filter​
3.9.5 Replacing the Fuel Filters​
3.9.6 Replacing the Fuel Pre-Filter​
3.9.7 Checking Belt Tension​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Thread Locking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 Fuel Level Indicator and Fuel Level Sender​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 LSI System Calibration​
4.3.3 Reversing Camera Calibration​
4.3.4 Park Brake Calibration/Maximum Drive Traction Test​
Special Procedures​
4.4.1 Emergency Boom Lowering Procedure​
4.4.2 Towing A Disabled Machine​
4.4.3 Hydraulic Oil Tank​
4.4.4 Fuel Tank Cleaning and Drying​
4.4.5 Hydraulic Pressure Settings and Adjustments​
4.4.6 Cylinder Checking Procedure​
4.4.7 Cylinder Drift Test​
4.4.8 Hydraulic Pressure Check​
4.4.9 Bleed Steering System​
4.4.10 Hydraulic Circuit Bleeding​
4.4.11 Evacuating and Recharging Air Conditioning (AC) System​
System Software
Load Stability Indicator (LSI) (If Equipped)​
5.1.1 Load Stability Indicator​
5.1.2 LSI Sensor​
Analyzer​
5.2.1 Machine Data Access​
5.2.2 JLG Hand Held Analyzer​
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer​
5.2.4 PC Analyzer/Loglifter​
5.2.5 Analyzer Software (Version P27.0)​
Access Level​
Diagnostics (Software Version P27.0)​
Machine Setup (Software Version P27.0)​
Personalities (Software Version P27.0)​
Operator Tools (Software Version P27.0)​
Calibrations (Software Version P27.0)​
Premium Display (If Equipped)​
5.9.1 Home Screen and Touch Screen Soft Buttons​
5.9.2 Main Menu​
5.9.3 Reprogramming Menu​
Reprogramming the Premium Display​
5.10.1 Software Installation​
5.10.2 Load Charts Programming​
5.11.1 ClearSky Smart FleetTM CS550 Configuration​
5.11.2 Troubleshooting​
Fault Codes
Introduction​
6.1.1 Fault Code Display​
Engine Fault Codes​
Fault Codes - Help Comment (00x)​
Fault Codes - Power-Up (21x)​
Fault Codes - Ground Inputs (23x)​
Fault Codes - Other Inputs (24x)​
Fault Codes - Function Prevented (25x)​
Fault Codes - Line Contactor, Open-Circuit (31x)​
Fault Codes - Line Contactor, Short-Circuit (32x)​
Fault Codes - Output Drivers (33x)​
Fault Codes - Engine (43x)​
Fault Codes - Battery Supply (44x)​
Fault Codes - Transmission and Drive System (46x)​
Fault Codes - Communications (66x)​
Fault Codes - Telematics (68x)​
Fault Codes - Tilt Sensor (81x)​
Fault Codes - Envelope Control (84x)​
Fault Codes - Load Moment (85x)​
Fault Codes - Steering (86x)​
Fault Codes - Service Required (87x)​
Fault Codes - Hardware (99x)​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Engine Compartment Relays and Fuses​
8.5.2 Power Distribution Module​
8.5.3 Cab Relays and Fuses​
Telematics Gateway​
8.6.1 Telematics Gateway (TCU) Plug​
8.6.2 Telematics Gateway Harness Breakdown​
Wheels​
9.1.1 Wheel and Tire Assembly​
Drive Assembly​
9.2.1 General Information​
9.2.2 Axle Serial Number​
9.2.3 Axle Maintenance​
9.2.4 Axle Assembly and Drive Shaft Troubleshooting​
9.2.5 Axle​
9.2.6 Drive Shaft​
Boom​
9.3.1 Boom System Component Terminology​
9.3.2 Boom System​
9.3.3 Quick Coupler​
9.3.4 Fork​
9.3.5 Boom Prop (If Equipped)​
9.3.6 Boom Wear Pad​
Cab​
9.4.1 Cab Serial Number Plate​
9.4.2 Cab Removal/Installation​
9.4.3 Steering Wheel​
9.4.4 Brake System​
9.4.5 Throttle Pedal​
9.4.6 Joystick Assembly​
9.4.7 Ignition Key Switch​
9.4.8 Dash Switches​
9.4.9 Front Wiper Assembly (If Equipped)​
9.4.10 Rear Wiper Assembly (If Equipped)​
9.4.11 Roof Wiper Assembly (If Equipped)​
9.4.12 Windshield Washer Reservoir (If Equipped)​
9.4.13 Heater System (If Equipped)​
9.4.14 Heater and Air Conditioning System (If Equipped)​
9.4.15 Reversing Camera (If Equipped)​
Engine​
9.5.1 Component Terminology​
9.5.2 Diesel Fuel​
9.5.3 Engine Serial Number​
9.5.4 Specifications and Maintenance Information​
9.5.5 Engine Replacement​
9.5.6 Surge Tank​
9.5.7 Radiator Assembly​
9.5.8 Starter​
9.5.9 Alternator​
9.5.10 Thermostat​
9.5.11 Air Intake/Air Cleaner​
9.5.12 Pump Coupling Kit​
9.5.13 Fuel Tank​
9.5.14 Hydraulic Oil Tank​
9.5.15 Pre-Fuel Filter and Fuel Pump​
9.5.16 Engine Exhaust System​
9.5.17 Air Conditioner (AC) Compressor (If Equipped)​
Hydraulic Valves​
9.6.1 Main Control Valve​
9.6.2 SAHR Valve​
9.6.3 Steer Select Valve​
9.6.4 Priority Valve​
9.6.5 Watchdog Valve​
Hydraulic Cylinders​
9.7.1 Lift Cylinder​
9.7.2 Compensation Cylinder​
9.7.3 Tilt Cylinder​
Hydraulic Pumps​
9.8.1 Hydraulic Pumps​
Electrical Components​
9.9.1 Battery​
Counterweight​
Disassembly and Assembly
Drive Assembly​
10.1.1 Axle Assembly​
10.1.2 Transmission Assembly​
Boom​
10.2.1 Disassembly​
10.2.2 Assembly​
Cab​
Engine Components​
10.4.1 Engine Components​
Transmission​
10.5.1 Drive Motor​
10.5.2 Hystat Pump​
10.5.3 Implement Pump​
10.6.1 General Cylinder Disassembly​
10.6.2 Hydraulic Cylinder Repair Information​
Hydraulic Valves​
10.7.1 Main Control Valve​
10.7.2 Watchdog Valve​
10.7.3 Steer Select and Sahr Brake Valve​
10.7.4 Priority Valve​
Hydraulic Components​
10.8.1 Hydraulic Oil Tank​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
Electrical Schematics​
