JLG Telehandler 3507 Parts Manual 3122551000
Brand: JLG
Type of Machine: Telehandler
Model: JLG 3507 Telehandler
Part Number: 3122551000
Publication Date: 2025
Number of Pages: 764 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME INSTALLATION
FIGURE 1-2. CAB PLUG INSTALLATION (NON HYDRAULIC HITCH)
FIGURE 1-3. COVER PLATE INSTALLATION (NO OUTRIGGERS)
FIGURE 1-4. COVER PLATE INSTALLATION (NO TRAILER BRAKES)
FIGURE 1-5. COVER PLATE INSTALLATION (TRAILER BRAKES)
FIGURE 1-6. COVER PLATE INSTALLATION (NO REAR AUX)
FIGURE 1-7. COVER PLATE INSTALLATION (REAR AUX)
FIGURE 1-8. ENGINE ENCLOSURE INSTALLATION
FIGURE 1-9. ENGINE ENCLOSURE COVER INSTALLATION
FIGURE 1-10. FUEL TANK INSTALLATION
FIGURE 1-11. FUEL TANK ASSEMBLY
FIGURE 1-12. FUEL TANK ASSEMBLY
FIGURE 1-13. FUEL AND HYDRAULIC CAP INSTALLATION
FIGURE 1-14. HOOD INSTALLATION
FIGURE 1-15. HITCH RETRIEVAL INSTALLATION
FIGURE 1-16. HITCH PIN ASSEMBLY (RETRIEVAL HITCH)
FIGURE 1-17. HITCH INSTALLATION (FIXED)
FIGURE 1-18. HITCH ASSEMBLY (FIXED)
FIGURE 1-19. HYDRAULIC TANK INSTALLATION
FIGURE 1-20. HYDRAULIC TANK ASSEMBLY
FIGURE 1-21. MIRROR INSTALLATION
FIGURE 1-22. MIRROR ASSEMBLY (CONVEX)
FIGURE 1-23. REAR MIRROR INSTALLATION (FLAT)
FIGURE 1-24. REAR MIRROR INSTALLATION (CONVEX)
FIGURE 1-25. REAR COVER PLATE INSTALLATION (NO HYDRAULIC HITCH)
FIGURE 1-26. TANKS INSTALLATION
FIGURE 1-27. TOOLBOX INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM ASSEMBLY
FIGURE 2-2. FIRST BOOM SECTION ASSEMBLY
FIGURE 2-3. SECOND BOOM SECTION ASSEMBLY
FIGURE 2-4. BOOM PROP INSTALLATION
FIGURE 2-5. BOOM ANGLE INDICATOR INSTALLATION
FIGURE 2-6. BOOM BRUSHES INSTALLATION
FIGURE 2-7. BOOM PINNING INSTALLATION
FIGURE 2-8. BOOM PIVOT INSTALLATION
FIGURE 2-9. COMPENSATION CYLINDER PINNING INSTALLATION
FIGURE 2-10. COUPLER INSTALLATION - MANUAL (JLG)
FIGURE 2-11. COUPLER INSTALLATION - HYDRAULIC (JLG)
FIGURE 2-12. LEVER ASSEMBLY
FIGURE 2-13. LIFT CYLINDER PINNING INSTALLATION
FIGURE 2-14. REMOTE GREASE SYSTEM INSTALLATION
SECTION 3 - ATTACHMENTSFIGURE 3-1. AUGER BIT (6INX4IN)
FIGURE 3-2. AUGER BIT (12INX4IN)
FIGURE 3-3. AUGER BIT (18INX4IN)
FIGURE 3-4. AUGER BIT (24INX4IN)
FIGURE 3-5. AUGER COUPLING
FIGURE 3-6. BALE HANDLER KIT (SPIKES TO TUBE)
FIGURE 3-7. BALE HANDLER KIT (SPIKES)
FIGURE 3-8. BUCKET(1M³/1.25YD³) (MULTI-PURPOSE 4 IN 1)
FIGURE 3-9. BUCKET (GRAPPLE MULTI-PURPOSE)
FIGURE 3-10. BUCKET ATTACHMENT - GRAPPLE
FIGURE 3-11. BUCKET(0.6M³) (MULTI-PURPOSE 4 IN 1)
FIGURE 3-12. BUCKET BOLT-ON EDGE (ONE PIECE)
FIGURE 3-13. BUCKET BOLT-ON EDGE (TWO PIECE)
FIGURE 3-14. BUCKET BOLT-ON EDGE (THREE PIECE)
FIGURE 3-15. BUCKET(1M³/1.25YD³) (GENERAL PURPOSE - ANGULAR HEEL)
FIGURE 3-16. BUCKET (1.5M³/2YD³) (GENERAL PURPOSE - ANGULAR HEEL)
FIGURE 3-17. BUCKET (2M³/2.6YD³) (GENERAL PURPOSE - ANGULAR HEEL)
FIGURE 3-18. CARRIAGE ASSEMBLY (1524MM)
FIGURE 3-19. CARRIAGE ASSEMBLY (1829MM)
FIGURE 3-20. CARRIAGE ASSEMBLY (SIDE SHIFT)
FIGURE 3-21. FORK - DUAL TINE BAILING WITH CARRIAGE (SN 0160146967 to Present)
FIGURE 3-22. FORK EXTENSIONS (62X163X2286) (ANSI)
FIGURE 3-23. FORK POSITIONING CARRIAGE ASSEMBLY WITH FORK - 48IN
FIGURE 3-24. FORK - PALLET (50X100X1200)
FIGURE 3-25. FORK - PALLET (50X120X1200)
FIGURE 3-26. FORK - PALLET (60X125X1220)
FIGURE 3-27. FORK - LUMBER (45X150X1540)
FIGURE 3-28. FORK - LUMBER (50X150X1830)
FIGURE 3-29. FORK ROTATING CARRIAGE ASSEMBLY
FIGURE 3-30. FORK ROTATING CARRIAGE ASSEMBLY
FIGURE 3-31. LIFTING HOOK ASSEMBLY
FIGURE 3-32. TRUSS BOOM (4.4TON - 2.3M/7.5FT)
FIGURE 3-33. UNIVERSAL HITCH ATTACHMENT (SN 0160146967 to Present)
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION
FIGURE 4-2. ENGINE ASSEMBLY
FIGURE 4-3. ENGIINE MOUNT INSTALLATION
FIGURE 4-4. ENGINE BRACKET GUARD INSTALLATION
FIGURE 4-5. AIR CLEANER INSTALLATION (90/100KW)
FIGURE 4-6. AIR CLEANER ASSEMBLY (90/100KW)
FIGURE 4-7. AIR INTAKE LINES INSTALLATION
FIGURE 4-8. PRE-AIR CLEANER ACCESSORY
FIGURE 4-9. AIR INTAKE RAIN CAP ACCESSORY
FIGURE 4-10. A/C PUMP INSTALLATION
FIGURE 4-11. A/C LINES INSTALLATION
FIGURE 4-12. BULKHEAD INSTALLATION
FIGURE 4-13. CAC LINES INSTALLATION
FIGURE 4-14. COOLANT LINES INSTALLATION
FIGURE 4-15. COOLER LINES INSTALLATION
FIGURE 4-16. COOLER INSTALLATION
FIGURE 4-17. COOLING PACKAGE INSTALLATION
FIGURE 4-18. COOLING FAN INSTALLATION
FIGURE 4-19. COOLNG FAN MOTOR
FIGURE 4-20. DEF TANK INSTALLATION
FIGURE 4-21. DEF TANK ASSEMBLY
FIGURE 4-22. EXPANSION TANK
FIGURE 4-23. EXHAUST INSTALLATION
FIGURE 4-24. FAN LINES INSTALLATION
FIGURE 4-25. FAN DRIVE MOTER
FIGURE 4-26. FUEL LINES INSTALLATION
FIGURE 4-27. FUEL FILTER INSTALLATION
FIGURE 4-28. HEATER LINES INSTALLATION
FIGURE 4-29. HYDRAULIC PUMP INSTALLATION
FIGURE 4-30. RADIATOR COOLING PACKAGE
FIGURE 4-31. REMOTE HOC INSTALLATION
FIGURE 4-32. REMOTE FUEL PUMP INSTALLATION (74.4KW)
FIGURE 4-33. SURGE TANK INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVETRAIN INSTALLATION
FIGURE 5-2. FRONT AXLE INSTALLATION
FIGURE 5-3. FRONT AXLE ASSEMBLY
FIGURE 5-4. REAR AXLE INSTALLATION
FIGURE 5-5. REAR AXLE ASSEMBLY
FIGURE 5-6. DRIVE SHAFT INSTALLATION
FIGURE 5-7. AXLE SHIM INSTALLATION
FIGURE 5-8. TRANSMISSION INSTALLATION
FIGURE 5-9. TRANSMISSION ASSEMBLY
FIGURE 5-10. PLANETARY CASE AND PARTS
FIGURE 5-11. TORQUE CONVERTER
FIGURE 5-12. TRANSFER GEAR AND CASE
FIGURE 5-13. TRANSMISSION HYDRAULIC CONTROL
FIGURE 5-14. INPUT SHAFT
FIGURE 5-15. TRANSMISSION CLUTCH
FIGURE 5-16. CLUTCH AND GEAR
FIGURE 5-17. TRANSMISSION PUMP
FIGURE 5-18. OUTPUT SHAFT
FIGURE 5-19. SPEED SENSOR
FIGURE 5-20. IDLER GEAR
FIGURE 5-21. REAR TRANSMISSION CASE
FIGURE 5-22. PLANETARY CASE
FIGURE 5-23. FRONT TRANSFER CASE
FIGURE 5-24. REAR TRANSFER CASE
FIGURE 5-25. RELIEF VALVE
FIGURE 5-26. SOLENOID VALVE
FIGURE 5-27. SOLENOID VALVE
FIGURE 5-28. FRONT TRANSMISSION CASE ASSEMBLY
FIGURE 5-29. REAR TRANSMISSION CASE ASSEMBLY
FIGURE 5-30. TIRE/WHEEL SET (AIR - 460/70 R24 XMCL)
FIGURE 5-31. TIRE/WHEEL SET (AIR - 500/70 R24 XMCL)
FIGURE 5-32. FENDER INSTALLATION
FIGURE 5-33. FENDER ASSEMBLY (RR-RH)
FIGURE 5-34. FENDER ASSEMBLY (RR-LH)
FIGURE 5-35. FENDER ASSEMBLY (FRT-RH)
FIGURE 5-36. FENDER ASSEMBLY (FRT-LH)
SECTION 6 - CABFIGURE 6-1. CAB MOUNTS INSTALLATION
FIGURE 6-2. ENCLOSED CAB INSTALLATION
FIGURE 6-3. ENCLOSED CAB ASSEMBLY
FIGURE 6-4. ENCLOSED CAB GROUP
FIGURE 6-5. ENCLOSED CAB
FIGURE 6-6. DOOR INSTALLATION
FIGURE 6-7. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-8. CAB LATCH ASSEMBLY
FIGURE 6-9. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-10. DOOR ASSEMBLY (AG)
FIGURE 6-11. CAB DOOR
FIGURE 6-12. DOOR STRAP INSTALLATION
FIGURE 6-13. REAR WINDOW INSTALLATION
FIGURE 6-14. REAR WINDOW ASSEMBLY
FIGURE 6-15. ENCLOSED CAB PLUG GROUP
FIGURE 6-16. INTERIOR MIRROR INSTALLATION
FIGURE 6-17. FRONT WIPER INSTALLATION
FIGURE 6-18. LEVEL INDICATOR INSTALLATION
FIGURE 6-19. ENCLOSED CAB TRIM INSTALLATION
FIGURE 6-20. DASH COVER ASSEMBLY
FIGURE 6-21. REAR PANEL COVER ASSEMBLY
FIGURE 6-22. ADJUSTABLE ARMREST INSTALLTION
FIGURE 6-23. ARMREST
FIGURE 6-24. FIXED ARMREST BRACKET
FIGURE 6-25. MOVING ARMREST BRACKET
FIGURE 6-26. BEACON TERMINAL INSTALLATION
FIGURE 6-27. WASHER HOSES INSTALLATION
FIGURE 6-28. HAMMER INSTALLATION
FIGURE 6-29. HAMMER ATTACHMENT ASSEMBLY
FIGURE 6-30. FRONT COVER INSTALLATION
FIGURE 6-31. FILTER TRAY PANEL
FIGURE 6-32. FRONT DUCT COVER
FIGURE 6-33. WASHER TANK INSTALLATION
FIGURE 6-34. WASHER BOTTLE
FIGURE 6-35. SEAT INSTALLATION (CLOTH) (SEAOP)
FIGURE 6-36. SEAT ASSEMBLY
FIGURE 6-37. HEATER AND A/C INSTALLATION
FIGURE 6-38. CAB CONDENSER ASSEMBLY
FIGURE 6-39. CONDENSER
FIGURE 6-40. A/C RECEIVER DRIER
FIGURE 6-41. HEATER AND A/C ASSEMBLY
FIGURE 6-42. ROOF WIPER INSTALLATION
FIGURE 6-43. HEADLINER INSTALLATION (Prior to SN 0160146966)
FIGURE 6-44. HEADLINER/ RADIO READY INSTALLATION
FIGURE 6-45. CAB GUARD INSTALLATION (TOP)
FIGURE 6-46. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-47. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-48. COMMON CAB TRIM INSTALLATION
FIGURE 6-49. CAB TRIM INSTALLATION
FIGURE 6-50. ROOF CAP INSTALLATION (A/C)
FIGURE 6-51. FRONT NOSE CONE INSTALLATION (SIDELIGHT)
FIGURE 6-52. ENCLOSED CAB FRONT COVER INSTALLATION
FIGURE 6-53. RETRACTABLE SUNSCREEN INSTALLATION
FIGURE 6-54. CAB STEP INSTALLATION
FIGURE 6-55. FLOOR MAT INSTALLATION
FIGURE 6-56. REAR WINDOW INSTALLATION (WO/WIPER) (ISO)
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL ASSEMBLY
FIGURE 7-5. BRAKE PEDAL PLATE
FIGURE 7-6. BRAKE SENSOR INSTALLATION
FIGURE 7-7. SWITCH PLATE ASSEMBLY
FIGURE 7-8. PARKING BRAKE INSTALLATION (CABLE - STANDARD)
FIGURE 7-9. PARKING CABLE COVER
FIGURE 7-10. PARKING CABLE ASSEMBLY
FIGURE 7-11. STEERING WHEEL INSTALLATION
FIGURE 7-12. STEERING WHEEL
FIGURE 7-13. STEERING COLUMN INSTALLATION
FIGURE 7-14. HORN INSTALLATION
FIGURE 7-15. HORN BUTTON INSTALLATION
FIGURE 7-16. JOYSTICK INSTALLATION
FIGURE 7-17. WIPER SWITCH (O SPEED) - FNR
FIGURE 7-18. WIPER SWITCH (NO SPEED)
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. COMMON HYDRAULICS INSTALLATION
FIGURE 8-2. AUXILIARY HYDRAULICS INSTALLATION - REAR (TWIN)
FIGURE 8-3. AUXILIARY HYDRAULICS INSTALLATION - REAR (SINGLE)
FIGURE 8-4. BOOM HYDRAULIC INSTALLATION
FIGURE 8-5. BOOM LINES INSTALLATION
FIGURE 8-6. BOOM RAISE HOSES INSTALLATION (NO RIDE CONTROL)
FIGURE 8-7. BOOM RAISE HOSES INSTALLATION (WITH RIDE CONTROL)
FIGURE 8-8. BRAKE LINES INSTALLATION
FIGURE 8-9. BRAKE INSTALLATION – TRAILER
FIGURE 8-10. BRAKE ACCUMULATOR LINES INSTALLATION (WITHOUT SAHR)
FIGURE 8-11. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - TWIN)
FIGURE 8-12. COUPLER (HYDRAULIC) LINES INSTALLATION (FRONT BOOM - SINGLE)
FIGURE 8-13. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - TWIN)
FIGURE 8-14. COUPLER (MANUAL) LINES INSTALLATION (FRONT BOOM - SINGLE)
FIGURE 8-15. LIFT CYLINDER INSTALLATION
FIGURE 8-16. MAIN CONTROL VALVE INSTALLATION (Prior to SN 0160146966)
FIGURE 8-17. MAIN CONTROL VALVE INSTALLATION (SN 0160146967 to Present)
FIGURE 8-18. MAIN HYDRAULIC PUMP INSTALLATION
FIGURE 8-19. IMPLEMENT PUMP INSTALLATION
FIGURE 8-20. PRIORITY LINES INSTALLATION
FIGURE 8-21. PRIORITY VALVE INSTALLATION
FIGURE 8-22. RETURN LINES INSTALLATION
FIGURE 8-23. STEERING LINES INSTALLATION
FIGURE 8-24. STEER SELECT VALVE INSTALLATION
FIGURE 8-25. SUCTION LINES INSTALLATION
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. CYLINDER ASSEMBLY - COMPENSATION
FIGURE 9-2. CYLINDER SUB-ASSEMBLY - COUPLER LOCKING
FIGURE 9-3. CYLINDER ASSEMBLY - COUPLER LOCKING
FIGURE 9-4. CYLINDER SUB-ASSEMBLY - EXTEND/RETRACT (TELESCOPE)
FIGURE 9-5. CYLINDER ASSEMBLY - EXTEND/RETRACT (TELESCOPE)
FIGURE 9-6. CYLINDER ASSEMBLY - GRAPPLE BUCKET
FIGURE 9-7. CYLINDER ASSEMBLY - LIFT
FIGURE 9-8. CYLINDER ASSEMBLY - TILT
FIGURE 9-9. IMPLEMENT PUMP
FIGURE 9-10. VALVE SUB-ASSEMBLY - DIVERTOR (HI-FLOW)
FIGURE 9-11. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-12. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-13. VALVE ASSEMBLY - DIVERTOR
FIGURE 9-14. VALVE ASSEMBLY - FAN MOTOR CONTROL
FIGURE 9-15. VALVE ASSEMBLY - HYDRAULIC HITCH CONTROL VALVE
FIGURE 9-16. VALVE ASSEMBLY - MAIN CONTROL (Prior to SN 0160146966)
FIGURE 9-17. VALVE ASSEMBLY - MAIN CONTROL (SN 0160146967 to Present)
FIGURE 9-18. VALVE ASSEMBLY - PRIORITY FLOW MANIFOLD
FIGURE 9-19. VALVE ASSEMBLY - RIDE CONTROL
FIGURE 9-20. VALVE ASSEMBLY - STEERING SELECT VALVE
FIGURE 9-21. VALVE ASSEMBLY - TRAILER BRAKE
FIGURE 9-22. UNIVERSAL SIDE SHIFT CYLINDER
SECTION 10 - ELECTRICALFIGURE 10-1. BATTERY INSTALLATION (STANDARD)
FIGURE 10-2. BATTERY INSTALLATION (DUAL)
FIGURE 10-3. BOOM HARNESS INSTALLATION
FIGURE 10-4. BOOM HARNESS
FIGURE 10-5. BOOM ANGLE SENSOR INSTALLATION
FIGURE 10-6. BOOM RETRACT SENSOR INSTALLATION
FIGURE 10-7. BOOM RETRACT SENSOR INSTALLATION
FIGURE 10-8. CAB ELECTRICAL INSTALLATION
FIGURE 10-9. CAB HARNESS
FIGURE 10-10. CAB HARNESS
FIGURE 10-11. CAB STANDARD ELECTRICAL BOARD ASSEMBLY
FIGURE 10-12. CAB OPTION 1 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-13. CAB OPTION 2 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-14. CAB OPTION HARNESS
FIGURE 10-15. CAB HEATER HARNESS INSTALLATION
FIGURE 10-16. CAB HEATER HARNESS
FIGURE 10-17. CAB HVAC ACTUATOR HARNESS
FIGURE 10-18. CAB HVAC ACTUATOR HARNESS
FIGURE 10-19. CAB DISPLAY INSTALLATION
FIGURE 10-20. CAB SEAT ADAPTOR HARNESS (PREMIUM SEAT)
FIGURE 10-21. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 10-22. CLEARSKY HARNESS - CS550 BEACON
FIGURE 10-23. DASH ELECTRICS INSTALLATION
FIGURE 10-24. DECLUTCH SWITCH INSTALLATION
FIGURE 10-25. DISPLAY JUMPER HARNESS
FIGURE 10-26. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 10-27. ELECTRICAL POWER DISTRIBUTION ELECTRICAL BOX
FIGURE 10-28. ELECTRICAL RELAY INSTALLATION - 200 AMP
FIGURE 10-29. ENGINE ECU WIRING INSTALLATION
FIGURE 10-30. ENGINE WIRING INSTALLATION
FIGURE 10-31. ENGINE HARNESS (HRC)
FIGURE 10-32. ENGINE HARNESS (HRC)
FIGURE 10-33. ENGINE FUEL PUMP HARNESS
FIGURE 10-34. ENGINE GLOW PLUG RELAY HARNESS
FIGURE 10-35. ENGINE SPEED SET SWITCH INSTALLATION
FIGURE 10-36. FRAME MAIN ELECTRICAL INSTALLATION
FIGURE 10-37. FRAME HARNESS - REAR
FIGURE 10-38. FRAME HARNESS - FRONT
FIGURE 10-39. IGNITION SWITCH INSTALLATION
FIGURE 10-40. LIGHTS - DIP LIGHTS INSTALLATION (LH)
FIGURE 10-41. LIGHTS - LICENSE PLATE LAMP INSTALLATION
FIGURE 10-42. LIGHTS - LICENSE PLATE LAMP HARNESS
FIGURE 10-43. LIGHTS - WORKLIGHTS INSTALLATION - LED (BOOM MOUNTED)
FIGURE 10-44. LIGHTS - WORKLIGHTS HARNESS (BOOM MOUNTED LIGHTS)
FIGURE 10-45. LIGHTS - WORKLIGHTS INSTALLATION -LED (CAB MOUNTED) (WITH A/C)
FIGURE 10-46. LMIS INSTALLATION (NO RIDE CONTROL)
FIGURE 10-47. LMIS INSTALLATION (RIDE CONTROL)
FIGURE 10-48. LMIS CONTROLLER INSTALLATION
FIGURE 10-49. LMIS CABLE REEL INSTALLATION (NO RIDE CONTROL)
FIGURE 10-50. LMIS WIRING INSTALLATION
FIGURE 10-51. LMIS CABLE REEL INSTALLATION (RIDE CONTROL)
FIGURE 10-52. LMIS BEACON INSTALLATION
FIGURE 10-53. LMIS CHASSIS HARNESS
FIGURE 10-54. LSI SENSOR INSTALLATION
FIGURE 10-55. LSI DISPLAY INSTALLATION
FIGURE 10-56. LSI SENSOR INSTALLATION
FIGURE 10-57. LSI SWITCH INSTALLATION
FIGURE 10-58. LSI SENSOR COVER INSTALLATION
FIGURE 10-59. REVERSE ALARM INSTALLATION
FIGURE 10-60. REVERSE CAMERA JD INSTALLATION
FIGURE 10-61. REVERSE SENSING INSTALLATION
FIGURE 10-62. REVERSE SENSING HARNESS
FIGURE 10-63. SEAT BELT ALARM HARNESS
FIGURE 10-64. TRAILER ELECTRICS INSTALLATION
FIGURE 10-65. TRAILER CONNECTOR HARNESS
SECTION 11 - DECALSFIGURE 11-1. DECALS INSTALLATION
FIGURE 11-2. DECALS INSTALLATION - SAFETY
FIGURE 11-3. DECALS INSTALLATION - SAFETY
FIGURE 11-4. CAPACITY CHART
FIGURE 11-5. DECAL INSTALLATION - CLEARSKY CS550 BEACON
FIGURE 11-6. TRIANGLE INSTALLATION - SLOW MOVING VEHICLE
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
