Hyundai
86
176,834
JLG Telehandler 3010 3507 4008 Service Manual 3122550800 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 3010, 3507, 4008 Telehandler
Part Number: 3122550800
Publication Date: 2025
Number of Pages: 634 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specification​
2.1.1 Travel Speed​
2.1.2 Steering Angle Specification​
Cylinder Specification​
2.2.1 Hydraulic Cylinder Performance​
2.2.2 Cylinder Drift​
Electrical System Specification​
2.3.1 Electrical System​
Engine Specification​
2.4.1 Engine Performance Specifications​
2.4.2 Transmission Performance Specifications​
Tire Specification​
2.5.1 Tires​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.8.1 General Information​
2.8.2 Hydraulic Oil​
2.8.3 Changing Hydraulic Oil​
2.8.4 Lubrication Specifications​
2.8.5 Fluids​
2.8.6 Capacities​
2.8.7 Lubrication Schedule​
ClearSky Smart Fleet™​
2.9.1 General​
2.9.2 ClearSky Smart Fleet™ – Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Every 10 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 First 250 Hours​
3.3.5 Every 250 Hours​
3.3.6 Every 500 Hours​
3.3.7 Every 750 Hours​
3.3.8 Every 1000 Hours​
3.3.9 Every 1500 Hours​
3.3.10 Every 3000 Hours​
3.3.11 Every 6000 Hours​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Service Brake Bleeding​
Boom Inspection and Maintenance​
3.7.1 Boom Wear Pads​
Hydraulic Filter Replacement​
3.8.1 Hydraulic Filter Removal​
3.8.2 Hydraulic Filter Installation​
Transmission Fluid/Filter Replacement​
Transmission Fluid Level Check​
Brake Inspection​
Specification and Maintenance Information​
3.12.1 Axle​
3.12.2 Transmission​
3.12.3 Engine​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Thread Locking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 Charging Circuit​
Calibration Procedures​
4.3.1 Analyzer​
4.3.2 Boom Angle Sensor Calibration​
4.3.3 Load Stability Indicator (LSI) System Calibration​
4.3.4 LMIS (Load Moment Indicator System) Calibration​
4.3.5 Brake Pedal Calibration​
4.3.6 Reversing Camera Calibration​
Special Procedures​
4.4.1 Emergency Boom Lowering Procedure​
4.4.2 Towing a Disabled Machine​
4.4.3 Charge Air Cooler (CAC) Hose Draining​
4.4.4 Hydraulic Oil Tank​
4.4.5 Fuel Tank Cleaning and Drying​
4.4.6 Accumulators​
4.4.7 Hydraulic Pressure Settings and Adjustments​
4.4.8 Cylinder Checking Procedure​
4.4.9 Cylinder Drift Test​
4.4.10 Hydraulic Circuits​
4.4.11 Hydraulic Pressures​
4.4.12 Pressure Specifications​
4.4.13 Steering Angle Adjustment​
4.4.14 Steering Cylinders​
4.4.15 Lift Cylinder Bleeding Procedure​
4.4.16 Extend/Retract Cylinder Bleeding Procedure - 3010​
4.4.17 Extend/Retract Cylinder Bleeding Procedure - 3507 and 4008​
4.4.18 Tilt Cylinder Bleeding Procedure​
4.4.19 Steering System Bleeding Procedure​
System Software
Load Stability Indicator (LSI) (If Equipped)​
5.1.1 Load Stability Indicator​
5.1.2 LSI Sensor​
Analyzer​
5.2.1 Machine Data Access​
5.2.2 JLG Hand Held Analyzer​
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer​
5.2.4 PC Analyzer/Loglifter​
5.2.5 Analyzer Software (Version P27.0)​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostics​
Machine Setup​
Personalities​
Operator Tools (Software Version P27.0)​
Calibrations​
Premium Display​
5.8.1 Home Screen and Touch Screen Soft Buttons​
5.8.2 Main Menu​
5.8.3 Reprogramming Menu​
Reprogramming the Premium Display​
5.9.1 Software Installation​
5.9.2 Load Charts Programming​
5.9.3 Premium Display Reassembly​
5.10.1 ClearSky Smart FleetTM CS550 Configuration​
5.10.2 Troubleshooting​
Fault Codes
Introduction​
Engine Diagnostic​
6.2.1 EMR5 Diagnosis and Error codes​
Fault Codes - Help Comment (00x)​
Fault Codes - Power-Up (21x)​
Fault Codes - Ground Inputs (23x)​
Fault Codes - Other Inputs (24x)​
Fault Codes - Function Prevented (25x)​
Fault Codes - Line Contactor, Open-Circuit (31x)​
Fault Codes - Line Contactor, Short-Circuit (32x)​
Fault Codes - Output Drivers (33x)​
Fault Codes - Engine (43x)​
Fault Codes - Battery Supply (44x)​
Fault Codes - Transmission and Drive System (46x)​
Fault Codes - Communications (66x)​
Fault Codes - Telematics (68x)​
Fault Codes - Tilt Sensor (81x)​
Fault Codes - Envelope Control (84x)​
Fault Codes - Load Moment (85x)​
Fault Codes - Steering (86x)​
Fault Codes - Service Required (87x)​
Fault Codes - Hardware (99x)​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
General Information (reference)​
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
8.3.1 General Overview​
Harness Layouts​
Board Layouts​
8.5.1 Cab Power Distribution Board​
8.5.2 Frame Power Distribution Board​
8.5.3 Option 1 Distribution Board​
8.5.4 Option 2 Distribution Board​
8.5.5 Engine Harness Fuses and Relays​
Solenoids and Sensors and Senders​
8.6.1 Transmission Solenoid Valves​
8.6.2 Fuel Level Sender​
Wheels​
9.1.1 Removing Wheel and Tire Assembly from Machine​
9.1.2 Installing Wheel and Tire Assembly onto Machine​
Drive Assembly​
9.2.1 Axle Assembly and Drive Shaft Troubleshooting​
9.2.2 Axle​
9.2.3 Drive Shafts​
9.2.4 Transmission Components​
Boom​
9.3.1 Boom System Component Terminology​
9.3.2 Troubleshooting​
9.3.3 Boom System​
9.3.4 Accumulator​
9.3.5 Manual Quick Coupler​
9.3.6 Hydraulic Quick Coupler​
9.3.7 Forks​
9.3.8 Boom Prop​
9.3.9 Boom Wear Pad Installation, Lubrication​
9.3.10 Boom Angle Sensor​
9.3.11 Boom Retract Sensor​
Cab​
9.4.1 Serial Number Plate​
9.4.2 Cab Removal/Installation​
9.4.3 Steering Wheel​
9.4.4 Service Brake​
9.4.5 Brake Accumulator​
9.4.6 Electronic Throttle Pedal​
9.4.7 Joystick Assembly​
9.4.8 Ignition Key Switch​
9.4.9 Dash Switches​
9.4.10 Front Windshield Wiper Motor​
9.4.11 Rear Window Wiper Motor​
9.4.12 Roof Window Wiper Motor​
9.4.13 Washer Fluid Reservoir​
9.4.14 Cab Air Conditioning​
9.4.15 Air Conditioning System​
9.4.16 Premium Display​
9.4.17 Reversing Camera​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Diesel Fuel​
9.5.4 Engine Replacement​
9.5.5 Surge Tank Cap​
9.5.6 Thermostat Replacement​
9.5.7 Engine Coolant Temperature Sensor​
9.5.8 Radiator Assembly Replacement​
9.5.9 Hydraulic Oil Tank​
9.5.10 Fuel Tank​
9.5.11 Engine Exhaust System​
9.5.12 Air Cleaner Assembly​
9.5.13 Starter​
9.5.14 Alternator​
9.5.15 Air Conditioner (AC) Compressor​
Transmission​
9.6.1 Component Terminology​
9.6.2 Transmission Serial Number​
9.6.3 Transmission Removal/Installation​
9.6.4 Reverse Alarm​
9.6.5 Torque Converter Diaphragm​
9.6.6 Transmission Oil Temperature Sensor​
9.6.7 Transmission Mounted Speed Sensor​
Hydraulic Cylinders​
9.7.1 General Cylinder Instructions​
9.7.2 Steering Cylinders​
Hydraulic Valves​
9.8.1 Main Control Valve​
9.8.2 Priority Valve​
9.8.3 Steering Column/Orbital Valve​
9.8.4 Steering Orbital Valve​
9.8.5 Steer Select Valve​
Hydraulic Pumps​
9.9.1 Implement Pump​
Electrical Components​
9.10.1 Battery​
9.10.2 Electrical Master Switch​
ClearSky® LED Motion / Amber Beacon (CS550)​
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550)​
Disassembly and Assembly
Boom​
10.1.1 Boom Assembly Maintenance - 3507/4008​
10.1.2 Boom Assembly Maintenance - 3010​
10.1.3 Third Boom Section Removal/Installation Only - 3010​
Drive Assembly​
10.2.1 Axle Assembly​
10.2.2 Transmission Assembly​
Cab​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
Transmission​
10.6.1 General Cylinder Instruction​
10.6.2 Hydraulic Cylinder Repair Information​
Hydraulic Valves​
10.7.1 Main Control Valve​
10.7.2 Priority Valve​
10.7.3 Steer Select Valve​
Hydraulic Components​
10.8.1 Hydraulic Oil Tank​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
Electrical Schematics​
