JLG Telehandler 2733 12010 Parts Manual 3122348900
Brand: JLG
Type of Machine: Telehandler
Model: JLG 2733, 12010 Telehandler
Part Number: 3122348900
Publication Date: 2025
Number of Pages: 918 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. HITCHPIN INSTALLATION
FIGURE 1-2. ENGINE ENCLOSURE INSTALLATION
FIGURE 1-3. ENCLOSURE SKIRT INSTALLATION
FIGURE 1-4. HOOD INSTALLATION
FIGURE 1-5. CLOSURE INSTALLATION (2733)
FIGURE 1-6. CLOSURE INSTALLATION (12010)
FIGURE 1-7. FRAME COVER INSTALLATION
FIGURE 1-8. HYDRAULIC TANK INSTALLATION
FIGURE 1-9. HYDRAULIC TANK ASSEMBLY
FIGURE 1-10. FUEL TANK INSTALLATION
FIGURE 1-11. FUEL TANK ASSEMBLY
FIGURE 1-12. REMOTE FILL INSTALLATION
FIGURE 1-13. PAD LOCK
FIGURE 1-14. BOOM PROP INSTALLATION
FIGURE 1-15. GROMMETS INSTALLATION
FIGURE 1-16. MIRROR INSTALLATION
FIGURE 1-17. RIGHT SIDE CAMERA INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM INSTALLATION
FIGURE 2-2. BOOM ASSEMBLY
FIGURE 2-3. BASE BOOM SECTION ASSEMBLY
FIGURE 2-4. FLY BOOM SECTION ASSEMBLY
FIGURE 2-5. ATTACH COUPLER INSTALLATION (MANUAL)
FIGURE 2-6. ATTACH COUPLER INSTALLATION (HYDRAULIC)
FIGURE 2-7. QUICK COUPLER INSTALLATION
FIGURE 2-8. MANUAL COUPLER PIN HOLDER INSTALLATION
FIGURE 2-9. BOOM ANGLE INDICATOR INSTALLATION
FIGURE 2-10. BOOM BRUSHES INSTALLATION
SECTION 3 - ATTACHMENTSFIGURE 3-1. BASKET - PLATFORM DOCKING STATION KIT
FIGURE 3-2. BASKET - FORK MOUNTED PLATFORM (ANSI)
FIGURE 3-3. BASKET - FORK MOUNTED PLATFORM (CSA)
FIGURE 3-4. BASKET - FORK MOUNTED PLATFORM (ISO)
FIGURE 3-5. BASKET - PLATFORM SIDE ENTRY
FIGURE 3-6. BUCKET, GENERAL PURPOSE (94", 3.9YD3)
FIGURE 3-7. BUCKET, LIGHT MATERIAL (102", 6.5YD3)
FIGURE 3-8. BUCKET, GRAPPLE (2.4 M X 3.0M³)
FIGURE 3-9. CARRIAGE ASSEMBLY (60 INCH)
FIGURE 3-10. CARRIAGE ASSEMBLY (72 INCH)
FIGURE 3-11. CARRIAGE ASSEMBLY (87 INCH)
FIGURE 3-12. CARRIAGE ASSEMBLY - DUAL FORK POSITIONING CARRIAGE, (72IN/1829MM)
FIGURE 3-13. CARRIAGE ASSEMBLY - DUAL FORK POSITIONING SIDE SHIFT CARRIAGE
FIGURE 3-14. FORK - PALLET (2.75X7.87X48)
FIGURE 3-15. FORK - PALLET (2.75X7.87X60)
FIGURE 3-16. FORK - PALLET (2.75X7.87X72)
FIGURE 3-17. FORK - PALLET (2.75X7.87X96)
FIGURE 3-18. LIFTING HOOK (30K)
FIGURE 3-19. LOG CLAMP INSTALLATION
FIGURE 3-20. PIPE GRAPPLE INSTALLATION
FIGURE 3-21. STEEL COIL HANDLER INSTALLATION
FIGURE 3-22. TIRE HANDLER INSTALLATION (2500KG)
FIGURE 3-23. TRUSS BEAM INSTALLATION
FIGURE 3-24. WINCH INSTALLATION - TRUSS BOOM
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE MOUNT INSTALLATION
FIGURE 4-2. CUMMINS ENGINE, QSB 4.5L (2733)
FIGURE 4-3. CUMMINS ENGINE, QSB 4.5L (12010)
FIGURE 4-4. AIR CLEANER LINES INSTALLATION (2733)
FIGURE 4-5. AIR INTAKE LINES INSTALLATION (12010)
FIGURE 4-6. AIR CLEANER INSTALLATION (2733)
FIGURE 4-7. AIR CLEANER INSTALLATION ( (12010)
FIGURE 4-8. AIR CLEANER FILTER ASSEMBLY (90/100KW) (2733)
FIGURE 4-9. AIR FILTER, RAIN CAP INSTALLATION
FIGURE 4-10. PRE-CLEANER, AIR FILTER INSTALLATION
FIGURE 4-11. FUEL FILTER INSTALLATION (2733)
FIGURE 4-12. FUEL FILTER INSTALLATION (12010)
FIGURE 4-13. FUEL LINES INSTALLATION (2733)
FIGURE 4-14. FUEL INTAKE LINES INSTALLATION (12010)
FIGURE 4-15. HYDROSTATIC DRIVE PUMP INSTALLATION
FIGURE 4-16. FUEL FILTER & FITTINGS ASSEMBLY (12010)
FIGURE 4-17. HYDROSTATIC PUMP ASSEMBLY
FIGURE 4-18. HYDRAULIC PUMP INSTALLATION
FIGURE 4-19. IMPLEMENT PUMP ASSEMBLY
FIGURE 4-20. DEF COOLANT LINES INSTALLATION
FIGURE 4-21. DEF TANK INSTALLATION
FIGURE 4-22. DEF TANK ASSEMBLY
FIGURE 4-23. DEF BREATHER VALVE
FIGURE 4-24. COOLING PACKAGE INSTALLATION (CUMMINS 4.5L) (2733)
FIGURE 4-25. COOLING PACKAGE INSTALLATION (CUMMINS 4.5L) (12010)
FIGURE 4-26. COOLING PACKAGE INSTALLATION (ASOV) (2733)
FIGURE 4-27. COOLING PACKAGE INSTALLATION (ASOV) (12010)
FIGURE 4-28. RADIATOR ASSEMBLY (2733)
FIGURE 4-29. RADIATOR ASSEMBLY (12010)
FIGURE 4-30. SURGE TANK INSTALLATION
FIGURE 4-31. COOLANT LINES INSTALLATION (2733)
FIGURE 4-32. COOLANT LINES INSTALLATION (12010)
FIGURE 4-33. CAC LINES INSTALLATION (CUMMINS 4.5L) (2733)
FIGURE 4-34. CAC LINES INSTALLATION (CUMMINS 4.5L) (12010)
FIGURE 4-35. CAC LINES INSTALLATION (ASOV) (2733)
FIGURE 4-36. CAC LINES INSTALLATION (ASOV) (12010)
FIGURE 4-37. ASOV LINES INSTALLATION
FIGURE 4-38. FAN GUARD INSTALLATION
FIGURE 4-39. COOLING FAN INSTALLATION
FIGURE 4-40. REVERSING FAN INSTALLATION
FIGURE 4-41. COMPRESSOR COVER INSTALLATION
FIGURE 4-42. EXHAUST INSTALLATION (CUMMINS 4.5L) (2733)
FIGURE 4-43. EXHAUST INSTALLATION (CUMMINS 4.5L) (12010)
FIGURE 4-44. CAB - HEATER LINES INSTALLATION (2733)
FIGURE 4-45. CAB - HEATER LINES INSTALLATION (12010)
FIGURE 4-46. DEF PUMP AND CONTROL INSTALLATION
FIGURE 4-47. DEF LINES INSTALLATION
FIGURE 4-48. DOC INSTALLATION
FIGURE 4-49. SCR INSTALLATION
FIGURE 4-50. A/C PUMP INSTALLATION (CUMMINS 4.5L)
FIGURE 4-51. A/C LINES INSTALLATION
FIGURE 4-52. BREATHER TUBE HEATER INSTALLATION
FIGURE 4-53. TRANSMISSION HYDROSTATIC ADAPTER INSTALLATION
FIGURE 4-54. REMOTE OIL FILTER INSTALLATION (2733)
FIGURE 4-55. REMOTE OIL FILTER INSTALLATION (12010)
FIGURE 4-56. OIL DRAIN HOSE INSTALLATION
FIGURE 4-57. QUICK DRAIN OIL VALVE INSTALLATION
FIGURE 4-58. UREA PUMP
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVETRAIN INSTALLATION
FIGURE 5-2. GEARBOX INSTALLATION
FIGURE 5-3. GEARBOX ASSEMBLY - INPUT SHAFT
FIGURE 5-4. GEARBOX ASSEMBLY - INPUT HOUSING
FIGURE 5-5. GEARBOX ASSEMBLY - SHAFT CLUTCH
FIGURE 5-6. GEARBOX ASSEMBLY - OUTPUT SHAFT
FIGURE 5-7. GEARBOX ASSEMBLY - GEAR SHIFTING
FIGURE 5-8. HYDRAULIC MOTOR INSTALLATION
FIGURE 5-9. FRONT DRIVESHAFT INSTALLATION
FIGURE 5-10. REAR DRIVESHAFT INSTALLATION
FIGURE 5-11. FRONT AXLE LINES INSTALLATION
FIGURE 5-12. FRONT AXLE MOUNTING INSTALLATION
FIGURE 5-13. FRONT AXLE - CENTRAL HOUSING
FIGURE 5-14. FRONT AXLE - DIFFERENTIAL
FIGURE 5-15. FRONT AXLE - HUB REDUCTION
FIGURE 5-16. FRONT AXLE - BRAKES
FIGURE 5-17. FRONT AXLE - STEERING
FIGURE 5-18. FRONT AXLE - TRUNION
FIGURE 5-19. REAR AXLE LINES INSTALLATION
FIGURE 5-20. REAR AXLE MOUNTING INSTALLATION
FIGURE 5-21. REAR AXLE - CENTRAL HOUSING
FIGURE 5-22. REAR AXLE - DIFFERENTIAL
FIGURE 5-23. REAR AXLE - HUB REDUCTION
FIGURE 5-24. REAR AXLE - BRAKES
FIGURE 5-25. REAR AXLE - STEERING
FIGURE 5-26. REAR AXLE - TRUNION
FIGURE 5-27. TIRE/WHEEL SET (AIR 17.5-25 - 20 PLY) (CAMSO L2)
FIGURE 5-28. TIRE/WHEEL SET (AIR 17.5-25 - 20 PLY) (CAMSO L3)
FIGURE 5-29. TIRE/WHEEL SET (FOAM 17.5-25 - 20 PLY) (CAMSO L2)
FIGURE 5-30. TIRE/WHEEL SET (FOAM 17.5-25 - 20 PLY) (CAMSO L3)
FIGURE 5-31. CAB FENDER INSTALLATION
FIGURE 5-32. FENDER INSTALLATION
FIGURE 5-33. RH FENDER ASSEMBLY
FIGURE 5-34. LH FENDER ASSEMBLY
SECTION 6 - CABFIGURE 6-1. CAB MOUNTING
FIGURE 6-2. CAB INSTALLATION
FIGURE 6-3. CAB ASSEMBLY
FIGURE 6-4. DOOR INSTALLATION
FIGURE 6-5. DOOR ASSEMBLY (AG)
FIGURE 6-6. CAB DOOR
FIGURE 6-7. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-8. CAB LATCH ASSEMBLY
FIGURE 6-9. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-10. DOOR STRAP INSTALLATION
FIGURE 6-11. REAR WINDOW INSTALLATION
FIGURE 6-12. REAR WINDOW GROUP
FIGURE 6-13. CAB PLUG GROUP
FIGURE 6-14. BASIC MIRROR INSTALLATION
FIGURE 6-15. FRONT WIPER INSTALLATION
FIGURE 6-16. WASHER TANK INSTALLATION
FIGURE 6-17. WASHER BOTTLE
FIGURE 6-18. FRONT COVER INSTALLATION
FIGURE 6-19. FIRE EXTINGUISHER INSTALLATION
FIGURE 6-20. FRONT DUCT COVER
FIGURE 6-21. FILTER TRAY PANEL
FIGURE 6-22. LEVEL INDICATOR INSTALLATION
FIGURE 6-23. CAB STORAGE TRAY INSTALLATION
FIGURE 6-24. GRAB HANDLE INSTALLATION
FIGURE 6-25. REAR WIPER INSTALLATION
FIGURE 6-26. MULTIFUNCTION DISPLAY INSTALLATION
FIGURE 6-27. SEAT INSTALLATION
FIGURE 6-28. SUSPENSION SEAT ASSEMBLY
FIGURE 6-29. SEAT INSTALLATION (CLOTH)
FIGURE 6-30. SEAT ASSEMBLY
FIGURE 6-31. SEAT INSTALLATION (AIR SUSPENSION - STANDARD)
FIGURE 6-32. SEAT ASSEMBLY (AIR SUSPENSION - STANDARD)
FIGURE 6-33. UPPER SEAT ASSEMBLY
FIGURE 6-34. SUSPENSION KIT
FIGURE 6-35. SEAT INSTALLATION (AIR SUSPENSION - PREMIUM)
FIGURE 6-36. SEAT INSTALLATION (CLOTH) (SEAOP)
FIGURE 6-37. SEAT ASSEMBLY (AIR SUSPENSION - PREMIUM)
FIGURE 6-38. HEATER INSTALLATION
FIGURE 6-39. HEATER AND A/C INSTALLATION (CAB PARTS)
FIGURE 6-40. CAB CONDENSER ASSEMBLY
FIGURE 6-41. CONDENSER
FIGURE 6-42. A/C RECEIVER DRIER
FIGURE 6-43. HEATER ASSEMBLY
FIGURE 6-44. HEATER AND A/C ASSEMBLY
FIGURE 6-45. HEATER
FIGURE 6-46. HEATER AND A/C ASSEMBLY
FIGURE 6-47. ROOF WIPER INSTALLATION
FIGURE 6-48. HEADLINER INSTALLATION
FIGURE 6-49. HEADLINER/RADIO READY PACKAGE INSTALLATION
FIGURE 6-50. CAB TRIM INSTALLATION
FIGURE 6-51. DASH COVER ASSEMBLY
FIGURE 6-52. REAR PANEL COVER ASSEMBLY
FIGURE 6-53. ADJUSTABLE ARMREST INSTALLATION
FIGURE 6-54. ROOF CAP INSTALLATION (NO A/C)
FIGURE 6-55. ROOF CAP INSTALLATION (A/C)
FIGURE 6-56. NO SUNSCREEN INSTALLATION
FIGURE 6-57. RETRACTABLE SUNSCREEN INSTALLATION
FIGURE 6-58. NON SKID TAPE INSTALLATION
FIGURE 6-59. FLOOR MAT INSTALLATION
FIGURE 6-60. SEAT BELT INSTALLATION (3IN)
FIGURE 6-61. SEAT BELT INSTALLATION (3 INCH)
FIGURE 6-62. ENCLOSED CAB FRONT COVER INSTALLATION
FIGURE 6-63. CAB GUARD INSTALLATION (TOP)
FIGURE 6-64. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-65. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-66. EXTERNAL WINDOW RELEASE INSTALLATION (ANSI)
FIGURE 6-67. REAR WINDOW INSTALLATION (WO/WIPER) (ISO)
FIGURE 6-68. EXTERNAL WINDOW RELEASE INSTALLATION (CAN & ISO)
FIGURE 6-69. ARMREST
FIGURE 6-70. FIXED ARMREST BRACKET
FIGURE 6-71. MOVING ARMREST BRACKET
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL ASSEMBLY
FIGURE 7-5. BRAKE SENSOR INSTALLATION
FIGURE 7-6. SWITCH PLATE ASSEMBLY
FIGURE 7-7. TILT STEERING COLUMN INSTALLATION
FIGURE 7-8. COLUMN SHIFT INSTALLATION (2 SPEED)
FIGURE 7-9. STEERING WHEEL INSTALLATION
FIGURE 7-10. STEERING WHEEL
FIGURE 7-11. HORN BUTTON INSTALLATION
FIGURE 7-12. JOYSTICK INSTALLATION (2 SPEED)
FIGURE 7-13. WIPER-TURN SWITCH
FIGURE 7-14. COLUMN CLAMP INSTALLATION
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. BOOM HYDRAULIC INSTALLATION
FIGURE 8-2. BOOM HYDRAULIC LINES INSTALLATION
FIGURE 8-3. BOOM AUX HYDRAULIC INSTALLATION (MANUAL - SINGLE)
FIGURE 8-4. BOOM AUX HYDRAULIC INSTALLATION (HYDRAULIC - TWIN)
FIGURE 8-5. BOOM AUX HYDRAULIC INSTALLATION (MANUAL - TWIN)
FIGURE 8-6. DUAL COUPLER AUX HYDRAULIC INSTALLATION
FIGURE 8-7. AUXILIARY HYDRAULIC VALVE INSTALLATION
FIGURE 8-8. AUXILIARY HYDRAULIC VALVE INSTALLATION
FIGURE 8-9. VALVE AUX HTDRAULIC INSTALLATION
FIGURE 8-10. BOOM RAISE HOSE INSTALLATION (WITHOUT RIDE CONTROL)
FIGURE 8-11. BOOM RAISE HOSE INSTALLATION (RIDE CONTROL)
FIGURE 8-12. CAB HYDRAULICS INSTALLATION
FIGURE 8-13. CHECK VALVE INSTALLATION
FIGURE 8-14. CAB CHECK VALVE & FITTING ASSEMBLY
FIGURE 8-15. CHARGE FILTER HOSE INSTALLATION
FIGURE 8-16. CHARGE FILTER INSTALLATION
FIGURE 8-17. IMPLEMENT PUMP FILTER ASSEMBLY
FIGURE 8-18. ENGINE BAY HYDRAULIC INSTALLATION
FIGURE 8-19. FRAME HYDRAULICS INSTALLATION
FIGURE 8-20. FRAME SWAY INSTALLATION
FIGURE 8-21. FRAME SWAY CYLINDER INSTALLATION
FIGURE 8-22. FRAME SWAY CONTROL VALVE INSTALLATION
FIGURE 8-23. FRAME SWAY CONTROL VALVE & FITTING ASEMBLY
FIGURE 8-24. MAIN CONTROL VALVE INSTALLATION
FIGURE 8-25. MAIN CONTROL VALVE & FITTINGS ASSEMBLY
FIGURE 8-26. PRIORITY VALVE INSTALLATION
FIGURE 8-27. PRIORITY VALVE & FITTING ASSEMBLY
FIGURE 8-28. COUNTERBALANCE VALVE ASSEMBLY
FIGURE 8-29. RIDE AND FLOAT VALVE ASSEMBLY
FIGURE 8-30. SAHR VALVE INSTALLATION
FIGURE 8-31. SAHR BRAKE VALVE & FITTING ASSEMBLY
FIGURE 8-32. SAHR BRAKE VALVE ASSEMBLY
FIGURE 8-33. BRAKE VALVE RELAY INSTALLATION
FIGURE 8-34. BRAKE VALVE RELAY ASSEMBLY
FIGURE 8-35. SPEED CONTROL VALVE INSTALLATION
FIGURE 8-36. STEERING SELECT VALVE INSTALLATION
FIGURE 8-37. STEERING SELECT VALVE & FITTING ASSEMBLY
FIGURE 8-38. EMERGENCY LOWERING INSTALLATION
FIGURE 8-39. POWER UNIT INSTALLATION
FIGURE 8-40. AUXILIARY REDUCING VALVE ASSEMBLY
FIGURE 8-41. AUX POWER PUMP
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. CYLINDER INSTALLATION - EXTEND/RETRACT
FIGURE 9-2. CYLINDER ASSEMBLY- EXTEND/RETRACT
FIGURE 9-3. CYLINDER ASSEMBLY - FRAME LEVEL
FIGURE 9-4. CYLINDER INSTALLATION - LIFT
FIGURE 9-5. CYLINDER ASSEMBLY - LIFT
FIGURE 9-6. CYLINDER ASSEMBLY - LOG CLAMP
FIGURE 9-7. CYLINDER ASSEMBLY - QUICK COUPLER
FIGURE 9-8. CYLINDER ASSEMBLY - TILT
FIGURE 9-9. MOTOR ASSEMBLY – HYDRAULIC
FIGURE 9-10. PUMP ASSEMBLY - CHARGE
FIGURE 9-11. PUMP ASSEMBLY - DEF MODULE
FIGURE 9-12. PUMP ASSEMBLY - DRIVE
FIGURE 9-13. PUMP ASSEMBLY - PISTON
FIGURE 9-14. PUMP ASSEMBLY
FIGURE 9-15. VALVE ASSEMBLY - CHARGE FLOW CONTROL VALVE ASSEMBLY
FIGURE 9-16. VALVE ASSEMBLY - DIVERTOR VALVE
FIGURE 9-17. VALVE ASSEMBLY - LEVEL AND STABILIZATION VALVE
FIGURE 9-18. VALVE ASSEMBLY - MAIN CONTROL VALVE
FIGURE 9-19. VALVE ASSEMBLY - PRIORITY VALVE
FIGURE 9-20. VALVE ASSEMBLY - SAHR BRAKE VALVE
FIGURE 9-21. VALVE ASSEMBLY - DUAL AUXILIARY DIVERTOR VALVE
FIGURE 9-22. VALVE ASSEMBLY - STEERING SELECT VALVE
FIGURE 9-23. VALVE INSTALLATION - COUNTERBALANCE VALVE
FIGURE 9-24. VALVE ASSEMBLY - COUNTERBALANCE VALVE
SECTION 10 - ELECTRICALFIGURE 10-1. ELECTRICAL LAYOUT
FIGURE 10-2. ALARM INSTALLATION - BACKUP
FIGURE 10-3. ALARM INSTALLATION - BACKUP (WHITE NOISE)
FIGURE 10-4. ASOV HARNESS
FIGURE 10-5. ATTACHMENT RECOGNITION INSTALLATION (2733)
FIGURE 10-6. ATTACHMENT RECOGNITION INSTALLATION (12010)
FIGURE 10-7. ATTACHMENT RECOGNITION HARNESS
FIGURE 10-8. BATTERY INSTALLATION - DUAL
FIGURE 10-9. BATTERY INSTALLATION - DUAL (WITH BREATHER TUBE HEATER)
FIGURE 10-10. BATTERIES INSTALLATION - ARCTIC (115V)
FIGURE 10-11. BOOM TO FRAME HARNESS
FIGURE 10-12. COUPLER ANGLE SENSOR INSTALLATION
FIGURE 10-13. BOOM ANGLE SENSOR INSTALLATION (STD)
FIGURE 10-14. BOOM RETRACT SENSOR INSTALLATION
FIGURE 10-15. BOOM RETRACT SOFT STOP HARNESS
FIGURE 10-16. BOOM RIDE/FLOAT HARNESS
FIGURE 10-17. CAB ELECTRICAL INSTALLATION
FIGURE 10-18. CAB HARNESS
FIGURE 10-19. CAB - STANDARD ELECTRICAL BOARD ASSEMBLY
FIGURE 10-20. CAB - OPTION 1 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-21. CAB - OPTION 2 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-22. CAB - A/C OPTION HARNESS
FIGURE 10-23. CAB - DASH ELECTRICAL INSTALLATION (2733)
FIGURE 10-24. CAB - DASH ELECTRICAL INSTALLATION (12010)
FIGURE 10-25. CAB - IGNITION SWITCH HARNESS
FIGURE 10-26. CAB - LIGHT SWITCH INSTALLATION
FIGURE 10-27. CAB OPTION HARNESS
FIGURE 10-28. CAB - SEAT ADAPTOR HARNESS
FIGURE 10-29. CAB SEAT BELT ALARM HARNESS
FIGURE 10-30. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 10-31. CLEARSKY HARNESS - CS550 BEACON
FIGURE 10-32. COLD WEATHER PACKAGE INSTALLATION (ARCTIC)
FIGURE 10-33. CUMMINS HEATER JUMPER HARNESS
FIGURE 10-34. EMERGENCY STOP EXTERNAL INSTALLATION
FIGURE 10-35. ENGINE BAY ELECTRICAL INSTALLATION (2733)
FIGURE 10-36. ENGINE BAY ELECTRICAL INSTALLATION (12010)
FIGURE 10-37. ENGINE BAY WIRING INSTALLATION (2733)
FIGURE 10-38. ENGINE BAY WIRING INSTALLATION (12010)
FIGURE 10-39. ENGINE - ENGINE HARNESS (CUMMINS)
FIGURE 10-40. ENGINE - DEF PURGE LIGHT HARNESS
FIGURE 10-41. ENGINE WIRING INSTALLATION (2733)
FIGURE 10-42. ENGINE WIRING INSTALLATION (12010)
FIGURE 10-43. ENGINE HARNESS (CUMMINS) (2733)
FIGURE 10-44. ENGINE HARNESS (CUMMINS) (12010)
FIGURE 10-45. FRAME ELECTRICAL INSTALLATION
FIGURE 10-46. FRAME - ELECTRICAL POWER DISTRIBUTION BOX
FIGURE 10-47. FRAME WIRING INSTALLATION (2733)
FIGURE 10-48. FRAME WIRING INSTALLATION (12010)
FIGURE 10-49. FRAME - FRONT FRAME POWER HARNESS
FIGURE 10-50. FRAME - REAR FRAME POWER HARNESS
FIGURE 10-51. FRONT FRAME HARNESS
FIGURE 10-52. FRAME - REAR FRAME MODULE INSTALLATION
FIGURE 10-53. FRAME - RIDE CONTROL WIRING INSTALLATION
FIGURE 10-54. HEATER INSTALLATION - FUEL FILTER
FIGURE 10-55. HEATER INSTALLATION - HYDRAULIC TANK
FIGURE 10-56. HEATER INSTALLATION - OIL PAN
FIGURE 10-57. HVAC ACTUATOR HARNESS
FIGURE 10-58. LIGHTS - BOOM WORKLIGHTS INSTALLATION (LED)
FIGURE 10-59. LIGHTS - BOOM WORKLIGHTS HARNESS
FIGURE 10-60. LIGHTS - CAB WORKLIGHTS INSTALLATION (NO A/C - LED)
FIGURE 10-61. LIGHTS - CAB WORKLIGHTS INSTALLATION (A/C - LED)
FIGURE 10-62. LIGHTS - HEADLIGHT HARNESS
FIGURE 10-63. LIGHTS - ROAD LIGHTS INSTALLATION (LED)
FIGURE 10-64. LIGHTS - TAILIGHT HARNESS
FIGURE 10-65. LMIS INSTALLATION
FIGURE 10-66. LMIS BEACON LIGHT INSTALLATION
FIGURE 10-67. LMIS BEACON OPTION HARNESS
FIGURE 10-68. LMIS BOOM HARNESS
FIGURE 10-69. LMIS CABLE REEL INSTALLATION
FIGURE 10-70. LMIS CHASSIS OPTION HARNESS
FIGURE 10-71. LMIS TILT SENSOR INSTALLATION
FIGURE 10-72. LSI INSTALLATION
FIGURE 10-73. LSI DISPLAY INSTALLATION
FIGURE 10-74. LSI SENSOR INSTALLATION
FIGURE 10-75. PLATFORM HARNESS
FIGURE 10-76. PLATFORM READY HARNESS
FIGURE 10-77. REVERSE CAMERA INSTALLATION
FIGURE 10-78. REVERSE SENSOR INSTALLATION
FIGURE 10-79. REVERSE SENSOR HARNESS
FIGURE 10-80. REVERSING FAN HARNESS
FIGURE 10-81. RIGHT SIDE CAMERA INSTALLATION
FIGURE 10-82. MULTI VIEW CAMERA INSTALLATION
FIGURE 10-83. REMOTE BOOM CONTROL INSTALLATION
FIGURE 10-84. REMOTE CONTROL POWER HARNESS
FIGURE 10-85. REMOTE CONTROL EMERGENCY STOP SWITCH INSTALLATION
FIGURE 10-86. TELEMATICS READY INSTALLATION
FIGURE 10-87. TELEMATICS READY HARNESS
FIGURE 10-88. TILT SENSOR JUMPER HARNESS
FIGURE 10-89. TBAP HARNESS
FIGURE 10-90. TELEMATICS GATEWAY INSTALLATION (Prior to SN 0160146852)
FIGURE 10-91. TELEMATICS GATEWAY PLUS (SN 0160146853 to Present)
FIGURE 10-92. TELEMATICS GATEWAY HARNESS
FIGURE 10-93. EMERGENCY LOWERING HARNESS
SECTION 11 - DECALSFIGURE 11-1. DECAL INSTALLATION (2733)
FIGURE 11-2. DECAL INSTALLATION (12010)
FIGURE 11-3. DECAL INSTALLATION (ANSI)
FIGURE 11-4. DECAL INSTALLATION (ISO)
FIGURE 11-5. DECAL INSTALLATION (CSA ENGLISH/FRENCH)
FIGURE 11-6. DECAL INSTALLATION (AUS - 2733)
FIGURE 11-7. DECAL INSTALLATION (AUS - 2733)
FIGURE 11-8. DECAL INSTALLATION - CLEARSKY CS550 BEACON
FIGURE 11-9. BOOM DECAL INSTALLATION
FIGURE 11-10. LOADCHARTS (ANSI) (2733)
FIGURE 11-11. LOADCHARTS (ISO) (12010)
FIGURE 11-12. LOAD CHART REMOTE INSTALLATION (ANSI) (2733)
FIGURE 11-13. LOAD CHART REMOTE INSTALLATION (ISO) (2733)
FIGURE 11-14. LOAD CHART REMOTE INSTALLATION (ISO) (12010)
FIGURE 11-15. CAPACITY CHART HOLDER INSTALLATION
FIGURE 11-16. REVERSE SENSOR SYSTEM DECAL (ENGLISH)
FIGURE 11-17. REVERSE SENSOR SYSTEM DECAL (ISO)
FIGURE 11-18. REVERSE SENSING SYSTEM DECAL, (ENGLISH/FRENCH)
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
