Hyundai
86
176,684
JLG Telehandler 2733 12010 Parts Manual 3122331000
Brand: JLG
Type of Machine: Telehandler
Model: JLG 2733, 12010 Telehandler
Part Number: 3122331000
Publication Date: 2025
Number of Pages: 946 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
FIGURE 1-1. HITCHPIN INSTALLATION​
FIGURE 1-2. ENGINE ENCLOSURE INSTALLATION​
FIGURE 1-3. ENCLOSURE SKIRT INSTALLATION​
FIGURE 1-4. HOOD INSTALLATION​
FIGURE 1-5. CLOSURE INSTALLATION (2733)​
FIGURE 1-6. CLOSURE INSTALLATION (12010)​
FIGURE 1-7. FRAME COVER INSTALLATION​
FIGURE 1-8. HYDRAULIC TANK INSTALLATION​
FIGURE 1-9. HYDRAULIC TANK ASSEMBLY​
FIGURE 1-10. FUEL TANK INSTALLATION​
FIGURE 1-11. FUEL TANK ASSEMBLY​
FIGURE 1-12. REMOTE FILL INSTALLATION​
FIGURE 1-13. WHEEL CHOCK INSTALLATION (Prior to SN 0160140788)​
FIGURE 1-14. PAD LOCK​
FIGURE 1-15. BOOM PROP INSTALLATION​
FIGURE 1-16. GROMMETS INSTALLATION​
FIGURE 1-17. MIRROR INSTALLATION​
FIGURE 1-18. RIGHT SIDE CAMERA INSTALLATION​
SECTION 2 - BOOM
FIGURE 2-1. BOOM INSTALLATION​
FIGURE 2-2. BOOM ASSEMBLY​
FIGURE 2-3. BASE BOOM SECTION ASSEMBLY​
FIGURE 2-4. FLY BOOM SECTION ASSEMBLY​
FIGURE 2-5. ATTACH COUPLER INSTALLATION (MANUAL)​
FIGURE 2-6. ATTACH COUPLER INSTALLATION (HYDRAULIC)​
FIGURE 2-7. QUICK COUPLER INSTALLATION​
FIGURE 2-8. MANUAL COUPLER PIN HOLDER INSTALLATION​
FIGURE 2-9. BOOM ANGLE INDICATOR INSTALLATION​
FIGURE 2-10. BOOM BRUSHES INSTALLATION​
SECTION 3 - ATTACHMENTS
FIGURE 3-1. BASKET - PLATFORM DOCKING STATION KIT​
FIGURE 3-2. BASKET - FORK MOUNTED PLATFORM (ANSI)​
FIGURE 3-3. BASKET - FORK MOUNTED PLATFORM (CSA)​
FIGURE 3-4. BASKET - FORK MOUNTED PLATFORM (ISO)​
FIGURE 3-5. BASKET - PLATFORM SIDE ENTRY​
FIGURE 3-6. BUCKET, GENERAL PURPOSE (94", 3.9YD3)​
FIGURE 3-7. BUCKET, LIGHT MATERIAL (102", 6.5YD3)​
FIGURE 3-8. BUCKET, GRAPPLE (2.4 M X 3.0M³)​
FIGURE 3-9. CARRIAGE ASSEMBLY (60 INCH)​
FIGURE 3-10. CARRIAGE ASSEMBLY (72 INCH)​
FIGURE 3-11. CARRIAGE ASSEMBLY (87 INCH)​
FIGURE 3-12. CARRIAGE ASSEMBLY - DUAL FORK POSITIONING CARRIAGE, (72IN/1829MM)​
FIGURE 3-13. CARRIAGE ASSEMBLY - DUAL FORK POSITIONING SIDE SHIFT CARRIAGE​
FIGURE 3-14. FORK - PALLET (2.75X7.87X48)​
FIGURE 3-15. FORK - PALLET (2.75X7.87X60)​
FIGURE 3-16. FORK - PALLET (2.75X7.87X72)​
FIGURE 3-17. FORK - PALLET (2.75X7.87X96)​
FIGURE 3-18. LIFTING HOOK (30K)​
FIGURE 3-19. LOG CLAMP INSTALLATION​
FIGURE 3-20. PIPE GRAPPLE INSTALLATION​
FIGURE 3-21. STEEL COIL HANDLER INSTALLATION​
FIGURE 3-22. TIRE HANDLER INSTALLATION (2500KG)​
FIGURE 3-23. TIRE HANDLER INSTALLATION (2500KG)​
FIGURE 3-24. TRUSS BEAM STYLE INSTALLATION​
FIGURE 3-25. WINCH INSTALLATION - TRUSS BOOM​
SECTION 4 - ENGINE AND ATTACHING PARTS
FIGURE 4-1. ENGINE MOUNT INSTALLATION​
FIGURE 4-2. CUMMINS ENGINE, QSB 4.5L (2733)​
FIGURE 4-3. CUMMINS ENGINE, QSB 4.5L (12010)​
FIGURE 4-4. AIR CLEANER LINES INSTALLATION (2733)​
FIGURE 4-5. AIR INTAKE LINES INSTALLATION (12010)​
FIGURE 4-6. AIR CLEANER INSTALLATION (2733)​
FIGURE 4-7. AIR CLEANER INSTALLATION ( (12010)​
FIGURE 4-8. AIR CLEANER FILTER ASSEMBLY (90/100KW) (2733)​
FIGURE 4-9. AIR FILTER, RAIN CAP INSTALLATION​
FIGURE 4-10. PRE-CLEANER, AIR FILTER INSTALLATION​
FIGURE 4-11. FUEL FILTER INSTALLATION (2733)​
FIGURE 4-12. FUEL FILTER INSTALLATION (12010)​
FIGURE 4-13. FUEL LINES INSTALLATION (2733)​
FIGURE 4-14. FUEL INTAKE LINES INSTALLATION (12010)​
FIGURE 4-15. HYDROSTATIC DRIVE PUMP INSTALLATION​
FIGURE 4-16. FUEL FILTER & FITTINGS ASSEMBLY (12010)​
FIGURE 4-17. HYDROSTATIC PUMP ASSEMBLY​
FIGURE 4-18. HYDRAULIC PUMP INSTALLATION​
FIGURE 4-19. IMPLEMENT PUMP ASSEMBLY​
FIGURE 4-20. DEF COOLANT LINES INSTALLATION​
FIGURE 4-21. DEF TANK INSTALLATION​
FIGURE 4-22. DEF TANK ASSEMBLY​
FIGURE 4-23. DEF BREATHER VALVE​
FIGURE 4-24. COOLING PACKAGE INSTALLATION (CUMMINS 4.5L) (2733)​
FIGURE 4-25. COOLING PACKAGE INSTALLATION (CUMMINS 4.5L) (12010)​
FIGURE 4-26. COOLING PACKAGE INSTALLATION (ASOV) (2733)​
FIGURE 4-27. COOLING PACKAGE INSTALLATION (ASOV) (12010)​
FIGURE 4-28. RADIATOR ASSEMBLY (2733)​
FIGURE 4-29. RADIATOR ASSEMBLY (12010)​
FIGURE 4-30. SURGE TANK INSTALLATION​
FIGURE 4-31. COOLANT LINES INSTALLATION (2733)​
FIGURE 4-32. COOLANT LINES INSTALLATION (12010)​
FIGURE 4-33. CAC LINES INSTALLATION (CUMMINS 4.5L) (2733)​
FIGURE 4-34. CAC LINES INSTALLATION (CUMMINS 4.5L) (12010)​
FIGURE 4-35. CAC LINES INSTALLATION (ASOV) (2733)​
FIGURE 4-36. CAC LINES INSTALLATION (ASOV) (12010)​
FIGURE 4-37. ASOV LINES INSTALLATION​
FIGURE 4-38. FAN GUARD INSTALLATION​
FIGURE 4-39. COOLING FAN INSTALLATION​
FIGURE 4-40. REVERSING FAN INSTALLATION​
FIGURE 4-41. COMPRESSOR COVER INSTALLATION​
FIGURE 4-42. EXHAUST INSTALLATION (CUMMINS 4.5L) (2733)​
FIGURE 4-43. EXHAUST INSTALLATION (CUMMINS 4.5L) (12010)​
FIGURE 4-44. CAB - HEATER LINES INSTALLATION (2733)​
FIGURE 4-45. CAB - HEATER LINES INSTALLATION (12010)​
FIGURE 4-46. DEF PUMP AND CONTROL INSTALLATION​
FIGURE 4-47. DEF LINES INSTALLATION​
FIGURE 4-48. DOC INSTALLATION​
FIGURE 4-49. SCR INSTALLATION​
FIGURE 4-50. A/C PUMP INSTALLATION (CUMMINS 4.5L)​
FIGURE 4-51. A/C LINES INSTALLATION​
FIGURE 4-52. BREATHER TUBE HEATER INSTALLATION​
FIGURE 4-53. TRANSMISSION HYDROSTATIC ADAPTER INSTALLATION​
FIGURE 4-54. REMOTE OIL FILTER INSTALLATION (2733)​
FIGURE 4-55. REMOTE OIL FILTER INSTALLATION (12010)​
FIGURE 4-56. OIL DRAIN HOSE INSTALLATION​
FIGURE 4-57. QUICK DRAIN OIL VALVE INSTALLATION​
FIGURE 4-58. UREA PUMP​
SECTION 5 - DRIVE TRAIN
FIGURE 5-1. DRIVETRAIN INSTALLATION​
FIGURE 5-2. GEARBOX INSTALLATION​
FIGURE 5-3. GEARBOX ASSEMBLY - INPUT SHAFT​
FIGURE 5-4. GEARBOX ASSEMBLY - INPUT HOUSING​
FIGURE 5-5. GEARBOX ASSEMBLY - SHAFT CLUTCH​
FIGURE 5-6. GEARBOX ASSEMBLY - OUTPUT SHAFT​
FIGURE 5-7. GEARBOX ASSEMBLY - GEAR SHIFTING​
FIGURE 5-8. HYDRAULIC MOTOR INSTALLATION​
FIGURE 5-9. FRONT DRIVESHAFT INSTALLATION​
FIGURE 5-10. REAR DRIVESHAFT INSTALLATION​
FIGURE 5-11. FRONT AXLE LINES INSTALLATION​
FIGURE 5-12. FRONT AXLE MOUNTING INSTALLATION​
FIGURE 5-13. FRONT AXLE - CENTRAL HOUSING​
FIGURE 5-14. FRONT AXLE - DIFFERENTIAL​
FIGURE 5-15. FRONT AXLE - HUB REDUCTION​
FIGURE 5-16. FRONT AXLE - BRAKES​
FIGURE 5-17. FRONT AXLE - STEERING​
FIGURE 5-18. FRONT AXLE - TRUNION​
FIGURE 5-19. REAR AXLE LINES INSTALLATION​
FIGURE 5-20. REAR AXLE MOUNTING INSTALLATION​
FIGURE 5-21. REAR AXLE - CENTRAL HOUSING​
FIGURE 5-22. REAR AXLE - DIFFERENTIAL​
FIGURE 5-23. REAR AXLE - HUB REDUCTION​
FIGURE 5-24. REAR AXLE - BRAKES​
FIGURE 5-25. REAR AXLE - STEERING​
FIGURE 5-26. REAR AXLE - TRUNION​
FIGURE 5-27. TIRE/WHEEL SET (AIR 17.5-25 - 20 PLY) (CAMSO L2)​
FIGURE 5-28. TIRE/WHEEL SET (AIR 17.5-25 - 20 PLY) (CAMSO L3)​
FIGURE 5-29. TIRE/WHEEL SET (FOAM 17.5-25 - 20 PLY) (CAMSO L2)​
FIGURE 5-30. TIRE/WHEEL SET (FOAM 17.5-25 - 20 PLY) (CAMSO L3)​
FIGURE 5-31. CAB FENDER INSTALLATION​
FIGURE 5-32. FENDER INSTALLATION​
FIGURE 5-33. RH FENDER ASSEMBLY​
FIGURE 5-34. LH FENDER ASSEMBLY​
SECTION 6 - CAB
FIGURE 6-1. CAB MOUNTING​
FIGURE 6-2. CAB INSTALLATION​
FIGURE 6-3. CAB ASSEMBLY​
FIGURE 6-4. DOOR INSTALLATION​
FIGURE 6-5. DOOR ASSEMBLY (AG)​
FIGURE 6-6. CAB DOOR​
FIGURE 6-7. DOOR UPPER GLASS ASSEMBLY​
FIGURE 6-8. CAB LATCH ASSEMBLY​
FIGURE 6-9. CAB DOOR TRIGGER ASSEMBLY​
FIGURE 6-10. DOOR STRAP INSTALLATION​
FIGURE 6-11. REAR WINDOW INSTALLATION​
FIGURE 6-12. REAR WINDOW GROUP​
FIGURE 6-13. CAB PLUG GROUP​
FIGURE 6-14. BASIC MIRROR INSTALLATION​
FIGURE 6-15. FRONT WIPER INSTALLATION​
FIGURE 6-16. WASHER TANK INSTALLATION​
FIGURE 6-17. WASHER BOTTLE​
FIGURE 6-18. FRONT COVER INSTALLATION​
FIGURE 6-19. FIRE EXTINGUISHER INSTALLATION​
FIGURE 6-20. FRONT DUCT COVER​
FIGURE 6-21. FILTER TRAY PANEL​
FIGURE 6-22. LEVEL INDICATOR INSTALLATION​
FIGURE 6-23. CAB STORAGE TRAY INSTALLATION​
FIGURE 6-24. GRAB HANDLE INSTALLATION​
FIGURE 6-25. REAR WIPER INSTALLATION​
FIGURE 6-26. MULTIFUNCTION DISPLAY INSTALLATION​
FIGURE 6-27. SEAT INSTALLATION​
FIGURE 6-28. SUSPENSION SEAT ASSEMBLY​
FIGURE 6-29. SEAT INSTALLATION (CLOTH)​
FIGURE 6-30. SEAT ASSEMBLY​
FIGURE 6-31. SEAT INSTALLATION (AIR SUSPENSION - STANDARD)​
FIGURE 6-32. SEAT ASSEMBLY (AIR SUSPENSION - STANDARD)​
FIGURE 6-33. UPPER SEAT ASSEMBLY​
FIGURE 6-34. SUSPENSION KIT​
FIGURE 6-35. SEAT INSTALLATION (AIR SUSPENSION - PREMIUM) (Prior to SN 0160141755)​
FIGURE 6-36. SEAT INSTALLATION (AIR SUSPENSION - PREMIUM) (SN 0160141756 to Present)​
FIGURE 6-37. SEAT INSTALLATION (CLOTH) (SEAOP)​
FIGURE 6-38. SEAT ASSEMBLY (AIR SUSPENSION - PREMIUM) (Prior to SN 0160141755)​
FIGURE 6-39. SEAT ASSEMBLY (AIR SUSPENSION - PREMIUM) (SN 0160141756 to Present)​
FIGURE 6-40. HEATER INSTALLATION​
FIGURE 6-41. HEATER AND A/C INSTALLATION (CAB PARTS)​
FIGURE 6-42. CAB CONDENSER ASSEMBLY​
FIGURE 6-43. CONDENSER​
FIGURE 6-44. A/C RECEIVER DRIER​
FIGURE 6-45. HEATER ASSEMBLY​
FIGURE 6-46. HEATER AND A/C ASSEMBLY​
FIGURE 6-47. HEATER​
FIGURE 6-48. HEATER AND A/C ASSEMBLY​
FIGURE 6-49. ROOF WIPER INSTALLATION​
FIGURE 6-50. HEADLINER INSTALLATION​
FIGURE 6-51. HEADLINER/RADIO READY PACKAGE INSTALLATION​
FIGURE 6-52. CAB TRIM INSTALLATION​
FIGURE 6-53. DASH COVER ASSEMBLY​
FIGURE 6-54. REAR PANEL COVER ASSEMBLY​
FIGURE 6-55. ADJUSTABLE ARMREST INSTALLATION​
FIGURE 6-56. ROOF CAP INSTALLATION (NO A/C)​
FIGURE 6-57. ROOF CAP INSTALLATION (A/C)​
FIGURE 6-58. NO SUNSCREEN INSTALLATION​
FIGURE 6-59. RETRACTABLE SUNSCREEN INSTALLATION​
FIGURE 6-60. NON SKID TAPE INSTALLATION​
FIGURE 6-61. FLOOR MAT INSTALLATION​
FIGURE 6-62. SEAT BELT INSTALLATION (3IN)​
FIGURE 6-63. SEAT BELT INSTALLATION (2IN) (Prior to SN 0160140788)​
FIGURE 6-64. SEAT BELT INSTALLATION (3 INCH)​
FIGURE 6-65. ENCLOSED CAB FRONT COVER INSTALLATION​
FIGURE 6-66. CAB GUARD INSTALLATION (TOP)​
FIGURE 6-67. CAB GUARD INSTALLATION (FRONT)​
FIGURE 6-68. CAB GUARD INSTALLATION (TOP AND FRONT)​
FIGURE 6-69. EXTERNAL WINDOW RELEASE INSTALLATION (ANSI)​
FIGURE 6-70. REAR WINDOW INSTALLATION (WO/WIPER) (ISO)​
FIGURE 6-71. EXTERNAL WINDOW RELEASE INSTALLATION (CAN & ISO)​
FIGURE 6-72. ARMREST​
FIGURE 6-73. FIXED ARMREST BRACKET​
FIGURE 6-74. MOVING ARMREST BRACKET​
SECTION 7 - CONTROLS
FIGURE 7-1. ACCELERATOR PEDAL INSTALLATION​
FIGURE 7-2. ACCELERATOR PEDAL​
FIGURE 7-3. BRAKE PEDAL INSTALLATION​
FIGURE 7-4. BRAKE PEDAL ASSEMBLY​
FIGURE 7-5. BRAKE SENSOR INSTALLATION​
FIGURE 7-6. SWITCH PLATE ASSEMBLY​
FIGURE 7-7. TILT STEERING COLUMN INSTALLATION​
FIGURE 7-8. COLUMN SHIFT INSTALLATION (2 SPEED)​
FIGURE 7-9. STEERING WHEEL INSTALLATION​
FIGURE 7-10. STEERING WHEEL​
FIGURE 7-11. HORN BUTTON INSTALLATION​
FIGURE 7-12. JOYSTICK INSTALLATION (2 SPEED)​
FIGURE 7-13. WIPER-TURN SWITCH​
FIGURE 7-14. COLUMN CLAMP INSTALLATION​
SECTION 8 - HYDRAULIC CIRCUITS
FIGURE 8-1. BOOM HYDRAULIC INSTALLATION​
FIGURE 8-2. BOOM HYDRAULIC LINES INSTALLATION​
FIGURE 8-3. BOOM AUX HYDRAULIC INSTALLATION (MANUAL - SINGLE)​
FIGURE 8-4. BOOM AUX HYDRAULIC INSTALLATION (HYDRAULIC - TWIN)​
FIGURE 8-5. BOOM AUX HYDRAULIC INSTALLATION (MANUAL - TWIN)​
FIGURE 8-6. DUAL COUPLER AUX HYDRAULIC INSTALLATION​
FIGURE 8-7. AUXILIARY HYDRAULIC VALVE INSTALLATION​
FIGURE 8-8. AUXILIARY HYDRAULIC VALVE INSTALLATION​
FIGURE 8-9. VALVE AUX HTDRAULIC INSTALLATION​
FIGURE 8-10. BOOM RAISE HOSE INSTALLATION (WITHOUT RIDE CONTROL)​
FIGURE 8-11. BOOM RAISE HOSE INSTALLATION (RIDE CONTROL)​
FIGURE 8-12. CAB HYDRAULICS INSTALLATION​
FIGURE 8-13. CHECK VALVE INSTALLATION​
FIGURE 8-14. CAB CHECK VALVE & FITTING ASSEMBLY​
FIGURE 8-15. CHARGE FILTER HOSE INSTALLATION​
FIGURE 8-16. CHARGE FILTER INSTALLATION​
FIGURE 8-17. IMPLEMENT PUMP FILTER ASSEMBLY​
FIGURE 8-18. ENGINE BAY HYDRAULIC INSTALLATION​
FIGURE 8-19. FRAME HYDRAULICS INSTALLATION​
FIGURE 8-20. FRAME SWAY INSTALLATION​
FIGURE 8-21. FRAME SWAY CYLINDER INSTALLATION​
FIGURE 8-22. FRAME SWAY CONTROL VALVE INSTALLATION​
FIGURE 8-23. FRAME SWAY CONTROL VALVE & FITTING ASEMBLY​
FIGURE 8-24. MAIN CONTROL VALVE INSTALLATION​
FIGURE 8-25. MAIN CONTROL VALVE & FITTINGS ASSEMBLY​
FIGURE 8-26. PRIORITY VALVE INSTALLATION​
FIGURE 8-27. PRIORITY VALVE & FITTING ASSEMBLY​
FIGURE 8-28. COUNTERBALANCE VALVE ASSEMBLY​
FIGURE 8-29. RIDE AND FLOAT VALVE ASSEMBLY​
FIGURE 8-30. SAHR VALVE INSTALLATION​
FIGURE 8-31. SAHR BRAKE VALVE & FITTING ASSEMBLY​
FIGURE 8-32. SAHR BRAKE VALVE ASSEMBLY​
FIGURE 8-33. BRAKE VALVE RELAY INSTALLATION​
FIGURE 8-34. BRAKE VALVE RELAY ASSEMBLY​
FIGURE 8-35. SPEED CONTROL VALVE INSTALLATION​
FIGURE 8-36. STEERING SELECT VALVE INSTALLATION​
FIGURE 8-37. STEERING SELECT VALVE & FITTING ASSEMBLY​
FIGURE 8-38. EMERGENCY LOWERING INSTALLATION​
FIGURE 8-39. POWER UNIT INSTALLATION​
FIGURE 8-40. AUXILIARY REDUCING VALVE ASSEMBLY​
FIGURE 8-41. AUX POWER PUMP​
SECTION 9 - HYDRAULIC COMPONENTS
FIGURE 9-1. CYLINDER INSTALLATION - EXTEND/RETRACT​
FIGURE 9-2. CYLINDER ASSEMBLY- EXTEND/RETRACT​
FIGURE 9-3. CYLINDER ASSEMBLY - FRAME LEVEL​
FIGURE 9-4. CYLINDER INSTALLATION - LIFT​
FIGURE 9-5. CYLINDER ASSEMBLY - LIFT​
FIGURE 9-6. CYLINDER ASSEMBLY - QUICK COUPLER​
FIGURE 9-7. CYLINDER ASSEMBLY - TILT​
FIGURE 9-8. MOTOR ASSEMBLY – HYDRAULIC​
FIGURE 9-9. PUMP ASSEMBLY - CHARGE​
FIGURE 9-10. PUMP ASSEMBLY - DEF MODULE​
FIGURE 9-11. PUMP ASSEMBLY - DRIVE​
FIGURE 9-12. PUMP ASSEMBLY - PISTON​
FIGURE 9-13. PUMP ASSEMBLY​
FIGURE 9-14. VALVE ASSEMBLY - CHARGE FLOW CONTROL VALVE ASSEMBLY​
FIGURE 9-15. VALVE ASSEMBLY - DIVERTOR VALVE​
FIGURE 9-16. VALVE ASSEMBLY - LEVEL AND STABILIZATION VALVE​
FIGURE 9-17. VALVE ASSEMBLY - MAIN CONTROL VALVE​
FIGURE 9-18. VALVE ASSEMBLY - PRIORITY VALVE​
FIGURE 9-19. VALVE ASSEMBLY - SAHR BRAKE VALVE​
FIGURE 9-20. VALVE ASSEMBLY - DUAL AUXILIARY DIVERTOR VALVE​
FIGURE 9-21. VALVE ASSEMBLY - STEERING SELECT VALVE​
FIGURE 9-22. VALVE INSTALLATION - COUNTERBALANCE VALVE​
FIGURE 9-23. VALVE ASSEMBLY - COUNTERBALANCE VALVE​
SECTION 10 - ELECTRICAL
FIGURE 10-1. ELECTRICAL LAYOUT​
FIGURE 10-2. ALARM INSTALLATION - BACKUP​
FIGURE 10-3. ALARM INSTALLATION - BACKUP (WHITE NOISE)​
FIGURE 10-4. ASOV HARNESS​
FIGURE 10-5. ATTACHMENT RECOGNITION INSTALLATION (2733)​
FIGURE 10-6. ATTACHMENT RECOGNITION INSTALLATION (12010)​
FIGURE 10-7. ATTACHMENT RECOGNITION HARNESS​
FIGURE 10-8. BATTERY INSTALLATION - DUAL​
FIGURE 10-9. BATTERY INSTALLATION - DUAL (WITH BREATHER TUBE HEATER)​
FIGURE 10-10. BATTERIES INSTALLATION - ARCTIC (115V)​
FIGURE 10-11. BOOM TO FRAME HARNESS​
FIGURE 10-12. COUPLER ANGLE SENSOR INSTALLATION​
FIGURE 10-13. BOOM ANGLE SENSOR INSTALLATION (STD)​
FIGURE 10-14. BOOM RETRACT SENSOR INSTALLATION​
FIGURE 10-15. BOOM RETRACT SOFT STOP HARNESS​
FIGURE 10-16. BOOM RIDE/FLOAT HARNESS​
FIGURE 10-17. CAB ELECTRICAL INSTALLATION​
FIGURE 10-18. CAB HARNESS​
FIGURE 10-19. CAB - STANDARD ELECTRICAL BOARD ASSEMBLY​
FIGURE 10-20. CAB - OPTION 1 ELECTRICAL BOARD ASSEMBLY​
FIGURE 10-21. CAB - OPTION 2 ELECTRICAL BOARD ASSEMBLY​
FIGURE 10-22. CAB - A/C OPTION HARNESS​
FIGURE 10-23. CAB - DASH ELECTRICAL INSTALLATION (2733)​
FIGURE 10-24. CAB - DASH ELECTRICAL INSTALLATION (12010)​
FIGURE 10-25. CAB - IGNITION SWITCH HARNESS​
FIGURE 10-26. CAB - LIGHT SWITCH INSTALLATION​
FIGURE 10-27. CAB OPTION HARNESS​
FIGURE 10-28. CAB - SEAT ADAPTOR HARNESS​
FIGURE 10-29. CAB SEAT BELT ALARM HARNESS​
FIGURE 10-30. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 10-31. CLEARSKY HARNESS - CS550 BEACON​
FIGURE 10-32. COLD WEATHER PACKAGE INSTALLATION (ARCTIC)​
FIGURE 10-33. CUMMINS HEATER JUMPER HARNESS​
FIGURE 10-34. EMERGENCY STOP EXTERNAL INSTALLATION​
FIGURE 10-35. ENGINE BAY ELECTRICAL INSTALLATION (2733)​
FIGURE 10-36. ENGINE BAY ELECTRICAL INSTALLATION (12010)​
FIGURE 10-37. ENGINE BAY WIRING INSTALLATION (2733)​
FIGURE 10-38. ENGINE BAY WIRING INSTALLATION (12010)​
FIGURE 10-39. ENGINE - ENGINE HARNESS (CUMMINS)​
FIGURE 10-40. ENGINE - DEF PURGE LIGHT HARNESS​
FIGURE 10-41. ENGINE WIRING INSTALLATION (2733)​
FIGURE 10-42. ENGINE WIRING INSTALLATION (12010)​
FIGURE 10-43. ENGINE HARNESS (CUMMINS) (2733)​
FIGURE 10-44. ENGINE HARNESS (CUMMINS) (12010)​
FIGURE 10-45. FRAME ELECTRICAL INSTALLATION​
FIGURE 10-46. FRAME - ELECTRICAL POWER DISTRIBUTION BOX​
FIGURE 10-47. FRAME WIRING INSTALLATION (2733)​
FIGURE 10-48. FRAME WIRING INSTALLATION (12010)​
FIGURE 10-49. FRAME - FRONT FRAME POWER HARNESS​
FIGURE 10-50. FRAME - REAR FRAME POWER HARNESS​
FIGURE 10-51. FRONT FRAME HARNESS​
FIGURE 10-52. FRAME - REAR FRAME MODULE INSTALLATION​
FIGURE 10-53. FRAME - RIDE CONTROL WIRING INSTALLATION​
FIGURE 10-54. HEATER INSTALLATION - FUEL FILTER​
FIGURE 10-55. HEATER INSTALLATION - HYDRAULIC TANK​
FIGURE 10-56. HEATER INSTALLATION - OIL PAN​
FIGURE 10-57. HVAC ACTUATOR HARNESS​
FIGURE 10-58. LIGHTS - BOOM WORKLIGHTS INSTALLATION (LED)​
FIGURE 10-59. LIGHTS - BOOM WORKLIGHTS HARNESS​
FIGURE 10-60. LIGHTS - CAB WORKLIGHTS INSTALLATION (NO A/C - LED)​
FIGURE 10-61. LIGHTS - CAB WORKLIGHTS INSTALLATION (A/C - LED)​
FIGURE 10-62. LIGHTS - HEADLIGHT HARNESS​
FIGURE 10-63. LIGHTS - ROAD LIGHTS INSTALLATION (LED)​
FIGURE 10-64. LIGHTS - TAILIGHT HARNESS​
FIGURE 10-65. LMIS INSTALLATION​
FIGURE 10-66. LMIS BEACON LIGHT INSTALLATION​
FIGURE 10-67. LMIS BEACON OPTION HARNESS​
FIGURE 10-68. LMIS BOOM HARNESS​
FIGURE 10-69. LMIS CABLE REEL INSTALLATION​
FIGURE 10-70. LMIS CHASSIS OPTION HARNESS​
FIGURE 10-71. LMIS TILT SENSOR INSTALLATION​
FIGURE 10-72. LSI INSTALLATION​
FIGURE 10-73. LSI DISPLAY INSTALLATION​
FIGURE 10-74. LSI SENSOR INSTALLATION​
FIGURE 10-75. PLATFORM HARNESS​
FIGURE 10-76. PLATFORM READY HARNESS​
FIGURE 10-77. REVERSE CAMERA INSTALLATION​
FIGURE 10-78. REVERSE SENSOR INSTALLATION​
FIGURE 10-79. REVERSE SENSOR HARNESS​
FIGURE 10-80. REVERSING FAN HARNESS​
FIGURE 10-81. RIGHT SIDE CAMERA INSTALLATION​
FIGURE 10-82. MULTI VIEW CAMERA INSTALLATION​
FIGURE 10-83. REMOTE BOOM CONTROL INSTALLATION​
FIGURE 10-84. REMOTE CONTROL POWER HARNESS​
FIGURE 10-85. REMOTE CONTROL EMERGENCY STOP SWITCH INSTALLATION​
FIGURE 10-86. TELEMATICS READY INSTALLATION​
FIGURE 10-87. TELEMATICS READY HARNESS​
FIGURE 10-88. TILT SENSOR JUMPER HARNESS​
FIGURE 10-89. TBAP HARNESS​
FIGURE 10-90. TELEMATICS GATEWAY INSTALLATION​
FIGURE 10-91. TELEMATICS GATEWAY HARNESS​
FIGURE 10-92. EMERGENCY LOWERING HARNESS​
FIGURE 10-93. TELEMATICS GATEWAY PLUS​
SECTION 11 - DECALS
FIGURE 11-1. DECAL INSTALLATION (2733)​
FIGURE 11-2. DECAL INSTALLATION (12010)​
FIGURE 11-3. DECAL INSTALLATION (ANSI)​
FIGURE 11-4. DECAL INSTALLATION (ISO)​
FIGURE 11-5. DECAL INSTALLATION (CSA ENGLISH/FRENCH)​
FIGURE 11-6. DECAL INSTALLATION (AUS)​
FIGURE 11-7. DECAL INSTALLATION (CIS)​
FIGURE 11-8. DECAL INSTALLATION - CLEARSKY CS550 BEACON​
FIGURE 11-9. BOOM DECAL INSTALLATION​
FIGURE 11-10. LOADCHARTS (ANSI) (2733)​
FIGURE 11-11. LOADCHARTS (ISO) (12010)​
FIGURE 11-12. LOAD CHART REMOTE INSTALLATION (ANSI) (2733)​
FIGURE 11-13. LOAD CHART REMOTE INSTALLATION (ISO) (2733)​
FIGURE 11-14. LOAD CHART REMOTE INSTALLATION (ISO) (12010)​
FIGURE 11-15. CAPACITY CHART HOLDER INSTALLATION​
FIGURE 11-16. REVERSE SENSOR SYSTEM DECAL (ENGLISH)​
FIGURE 11-17. REVERSE SENSOR SYSTEM DECAL (ISO)​
FIGURE 11-18. REVERSE SENSING SYSTEM DECAL, (ENGLISH/FRENCH)​
SECTION 12 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK​
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITS
FIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS​
PART NUMBER INDEX
