JLG Telehandler 2733 12010 Parts Catalog 31211486
Brand: JLG
Type of Machine: Telehandler
Model: JLG 2733 12010 Telehandler
Part Number: 31211486
Publication Date: 2025
Number of Pages: 878 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. HITCHPIN INSTALLATION
FIGURE 1-2. ENGINE ENCLOSURE INSTALLATION
FIGURE 1-3. ENCLOSURE SKIRT INSTALLATION
FIGURE 1-4. HOOD INSTALLATION
FIGURE 1-5. CLOSURE INSTALLATION (2733)
FIGURE 1-6. CLOSURE INSTALLATION (12010)
FIGURE 1-7. FRAME COVER INSTALLATION
FIGURE 1-8. HYDRAULIC TANK INSTALLATION
FIGURE 1-9. HYDRAULIC TANK ASSEMBLY
FIGURE 1-10. FUEL TANK INSTALLATION
FIGURE 1-11. FUEL TANK ASSEMBLY
FIGURE 1-12. REMOTE FILL INSTALLATION
FIGURE 1-13. WHEEL CHOCK INSTALLATION
FIGURE 1-14. PAD LOCK
FIGURE 1-15. BOOM PROP INSTALLATION
FIGURE 1-16. GROMMETS INSTALLATION
FIGURE 1-17. MIRROR INSTALLATION
FIGURE 1-18. RIGHT SIDE CAMERA INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM INSTALLATION
FIGURE 2-2. BOOM ASSEMBLY
FIGURE 2-3. BASE BOOM SECTION ASSEMBLY
FIGURE 2-4. FLY BOOM SECTION ASSEMBLY
FIGURE 2-5. ATTACH COUPLER INSTALLATION (MANUAL)
FIGURE 2-6. ATTACH COUPLER INSTALLATION (HYDRAULIC)
FIGURE 2-7. QUICK COUPLER INSTALLATION
FIGURE 2-8. MANUAL COUPLER PIN HOLDER INSTALLATION
FIGURE 2-9. BOOM ANGLE INDICATOR INSTALLATION
FIGURE 2-10. BOOM BRUSHES INSTALLATION
SECTION 3 - ATTACHMENTSFIGURE 3-1. BUCKET, GENERAL PURPOSE (94", 3.9YD3)
FIGURE 3-2. BUCKET, GRAPPLE
FIGURE 3-3. BUCKET, LIGHT MATERIAL (102", 6.5YD3)
FIGURE 3-4. CARRIAGE ASSEMBLY (60 INCH)
FIGURE 3-5. CARRIAGE ASSEMBLY (72 INCH)
FIGURE 3-6. CARRIAGE ASSEMBLY (87 INCH)
FIGURE 3-7. CARRIAGE ASSEMBLY - DUAL FORK POSITIONING (72 INCH)
FIGURE 3-8. CARRIAGE ASSEMBLY - DUAL FORK POSITIONING WITH SIDE SHIFT (72 INCH)
FIGURE 3-9. FORK - PALLET (2.75X7.87X48)
FIGURE 3-10. FORK - PALLET (2.75X7.87X60)
FIGURE 3-11. FORK - PALLET (2.75X7.87X72)
FIGURE 3-12. FORK - PALLET (2.75X7.87X96)
FIGURE 3-13. LOG CLAMP INSTALLATION
FIGURE 3-14. PIPE GRAPPLE INSTALLATION
FIGURE 3-15. PLATFORM DOCKING STATION KIT (2733)
FIGURE 3-16. PLATFORM - FORK MOUNTED (ANSI) (2733)
FIGURE 3-17. PLATFORM - FORK MOUNTED (CSA) (2733)
FIGURE 3-18. PLATFORM - FORK MOUNTED (ISO) (12010)
FIGURE 3-19. PLATFORM SIDE ENTRY
FIGURE 3-20. STEEL COIL HANDLER INSTALLATION
FIGURE 3-21. TIRE HANDLER INSTALLATION
FIGURE 3-22. TRUSS BEAM STYLE INSTALLATION
FIGURE 3-23. WINCH INSTALLATION - TRUSS BOOM
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE MOUNT INSTALLATION
FIGURE 4-2. CUMMINS ENGINE, QSB 4.5L
FIGURE 4-3. AIR CLEANER LINES INSTALLATION
FIGURE 4-4. AIR CLEANER INSTALLATION
FIGURE 4-5. AIR CLEANER FILTER ASSEMBLY (90/100KW)
FIGURE 4-6. AIR FILTER, RAIN CAP INSTALLATION
FIGURE 4-7. PRE-CLEANER, AIR FILTER INSTALLATION
FIGURE 4-8. PRIMARY FUEL FILTER INSTALLATION
FIGURE 4-9. FUEL LINES INSTALLATION
FIGURE 4-10. HYDROSTATIC DRIVE PUMP INSTALLATION
FIGURE 4-11. HYDROSTATIC PUMP ASSEMBLY
FIGURE 4-12. HYDRAULIC PUMP INSTALLATION
FIGURE 4-13. IMPLEMENT PUMP ASSEMBLY
FIGURE 4-14. DEF COOLANT LINES INSTALLATION
FIGURE 4-15. DEF TANK INSTALLATION (Prior to SN 0160110012)
FIGURE 4-16. DEF TANK INSTALLATION (SN 0160110012 to Present)
FIGURE 4-17. DEF TANK ASSEMBLY (Prior to SN 0160110012)
FIGURE 4-18. DEF TANK ASSEMBLY (SN 0160110012 to Present)
FIGURE 4-19. DEF BREATHER VALVE
FIGURE 4-20. COOLING PACKAGE INSTALLATION (CUMMINS 4.5L)
FIGURE 4-21. COOLING PACKAGE INSTALLATION (ASOV)
FIGURE 4-22. RADIATOR ASSEMBLY
FIGURE 4-23. SURGE TANK INSTALLATION
FIGURE 4-24. COOLANT LINES INSTALLATION
FIGURE 4-25. CAC LINES INSTALLATION
FIGURE 4-26. CAC LINES INSTALLATION (ASOV)
FIGURE 4-27. ASOV LINES INSTALLATION
FIGURE 4-28. FAN GUARD INSTALLATION
FIGURE 4-29. COOLING FAN INSTALLATION
FIGURE 4-30. REVERSING FAN INSTALLATION
FIGURE 4-31. COMPRESSOR COVER INSTALLATION
FIGURE 4-32. EXHAUST INSTALLATION (CUMMINS 4.5L) (2733)
FIGURE 4-33. EXHAUST INSTALLATION (CUMMINS 4.5L) (12010)
FIGURE 4-34. CAB - HEATER LINES INSTALLATION (2733)
FIGURE 4-35. CAB - HEATER LINES INSTALLATION (12010)
FIGURE 4-36. DEF PUMP AND CONTROL INSTALLATION
FIGURE 4-37. DEF LINES INSTALLATION
FIGURE 4-38. DOC INSTALLATION
FIGURE 4-39. SCR INSTALLATION
FIGURE 4-40. A/C PUMP INSTALLATION (CUMMINS 4.5L)
FIGURE 4-41. A/C LINES INSTALLATION
FIGURE 4-42. BREATHER TUBE HEATER INSTALLATION
FIGURE 4-43. TRANSMISSION HYDROSTATIC ADAPTER INSTALLATION
FIGURE 4-44. REMOTE OIL FILTER INSTALLATION
FIGURE 4-45. OIL DRAIN HOSE INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVETRAIN INSTALLATION
FIGURE 5-2. GEARBOX INSTALLATION
FIGURE 5-3. GEARBOX ASSEMBLY
FIGURE 5-4. HYDRAULIC MOTOR INSTALLATION
FIGURE 5-5. FRONT DRIVESHAFT INSTALLATION
FIGURE 5-6. REAR DRIVESHAFT INSTALLATION
FIGURE 5-7. FRONT AXLE LINES INSTALLATION
FIGURE 5-8. FRONT AXLE MOUNTING INSTALLATION
FIGURE 5-9. FRONT AXLE - CENTRAL HOUSING
FIGURE 5-10. FRONT AXLE - DIFFERENTIAL
FIGURE 5-11. FRONT AXLE - HUB REDUCTION
FIGURE 5-12. FRONT AXLE - BRAKES
FIGURE 5-13. FRONT AXLE - STEERING
FIGURE 5-14. FRONT AXLE - TRUNION
FIGURE 5-15. REAR AXLE LINES INSTALLATION
FIGURE 5-16. REAR AXLE MOUNTING INSTALLATION
FIGURE 5-17. REAR AXLE - CENTRAL HOUSING
FIGURE 5-18. REAR AXLE - DIFFERENTIAL
FIGURE 5-19. REAR AXLE - HUB REDUCTION
FIGURE 5-20. REAR AXLE - BRAKES
FIGURE 5-21. REAR AXLE - STEERING
FIGURE 5-22. REAR AXLE - TRUNION
FIGURE 5-23. TIRE/WHEEL SET (AIR 17.5-25 - 20 PLY), CAMSO L2
FIGURE 5-24. TIRE/WHEEL SET (AIR 17.5-25 - 20 PLY), CAMSO L3
FIGURE 5-25. TIRE/WHEEL SET (FOAM 17.5-25 - 20 PLY), CAMSO L2
FIGURE 5-26. TIRE/WHEEL SET (FOAM 17.5-25 - 20 PLY), CAMSO L3
FIGURE 5-27. CAB FENDER INSTALLATION
FIGURE 5-28. FENDER INSTALLATION
FIGURE 5-29. RH FENDER ASSEMBLY
FIGURE 5-30. LH FENDER ASSEMBLY
SECTION 6 - CABFIGURE 6-1. CAB MOUNTING
FIGURE 6-2. CAB INSTALLATION
FIGURE 6-3. CAB ASSEMBLY
FIGURE 6-4. DOOR INSTALLATION
FIGURE 6-5. DOOR ASSEMBLY (AG)
FIGURE 6-6. CAB DOOR
FIGURE 6-7. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-8. CAB LATCH ASSEMBLY
FIGURE 6-9. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-10. DOOR STRAP INSTALLATION
FIGURE 6-11. REAR WINDOW INSTALLATION
FIGURE 6-12. REAR WINDOW GROUP
FIGURE 6-13. CAB PLUG GROUP
FIGURE 6-14. BASIC MIRROR INSTALLATION
FIGURE 6-15. FRONT WIPER INSTALLATION
FIGURE 6-16. WASHER TANK INSTALLATION
FIGURE 6-17. WASHER BOTTLE
FIGURE 6-18. FRONT COVER INSTALLATION
FIGURE 6-19. FIRE EXTINGUISHER INSTALLATION
FIGURE 6-20. FRONT DUCT COVER
FIGURE 6-21. FILTER TRAY PANEL
FIGURE 6-22. LEVEL INDICATOR INSTALLATION
FIGURE 6-23. CAB STORAGE TRAY INSTALLATION
FIGURE 6-24. GRAB HANDLE INSTALLATION
FIGURE 6-25. REAR WIPER INSTALLATION
FIGURE 6-26. MULTIFUNCTION DISPLAY INSTALLATION
FIGURE 6-27. SEAT INSTALLATION
FIGURE 6-28. SUSPENSION SEAT ASSEMBLY
FIGURE 6-29. SEAT INSTALLATION (CLOTH)
FIGURE 6-30. SEAT ASSEMBLY
FIGURE 6-31. SEAT INSTALLATION (AIR SUSPENSION - STANDARD)
FIGURE 6-32. SEAT ASSEMBLY (AIR SUSPENSION - STANDARD)
FIGURE 6-33. UPPER SEAT ASSEMBLY
FIGURE 6-34. SUSPENSION KIT
FIGURE 6-35. SEAT INSTALLATION (AIR SUSPENSION - PREMIUM)
FIGURE 6-36. SEAT ASSEMBLY (AIR SUSPENSION - PREMIUM)
FIGURE 6-37. HEATER INSTALLATION (Prior to SN 0160110014)
FIGURE 6-38. HEATER INSTALLATION (SN 0160110014 to Present)
FIGURE 6-39. HEATER AND A/C INSTALLATION (CAB PARTS) (Prior to SN 0160110014)
FIGURE 6-40. HEATER AND A/C INSTALLATION (CAB PARTS) (SN 0160110014 to Present)
FIGURE 6-41. CAB CONDENSER ASSEMBLY
FIGURE 6-42. CONDENSER
FIGURE 6-43. A/C RECEIVER DRIER
FIGURE 6-44. HEATER ASSEMBLY (Prior to SN 0160110014)
FIGURE 6-45. HEATER ASSEMBLY (SN 0160110014 to Present)
FIGURE 6-46. HEATER AND A/C ASSEMBLY (Prior to SN 0160110014)
FIGURE 6-47. HEATER AND A/C ASSEMBLY (SN 0160110014 to Present)
FIGURE 6-48. HEATER (Prior to SN 0160110014)
FIGURE 6-49. HEATER (SN 0160110014 to Present)
FIGURE 6-50. HEATER AND A/C (Prior to SN 0160110014)
FIGURE 6-51. HEATER AND A/C (SN 0160110014 to Present)
FIGURE 6-52. ROOF WIPER INSTALLATION
FIGURE 6-53. HEADLINER INSTALLATION
FIGURE 6-54. HEADLINER/RADIO READY PACKAGE INSTALLATION
FIGURE 6-55. CAB TRIM INSTALLATION
FIGURE 6-56. DASH COVER ASSEMBLY
FIGURE 6-57. REAR PANEL COVER ASSEMBLY
FIGURE 6-58. ADJUSTABLE ARMREST INSTALLATION
FIGURE 6-59. ROOF CAP INSTALLATION (NO A/C)
FIGURE 6-60. ROOF CAP INSTALLATION (A/C)
FIGURE 6-61. NO SUNSCREEN INSTALLATION
FIGURE 6-62. RETRACTABLE SUNSCREEN INSTALLATION
FIGURE 6-63. NON SKID TAPE INSTALLATION
FIGURE 6-64. FLOOR MAT INSTALLATION
FIGURE 6-65. SEAT BELT INSTALLATION (3IN)
FIGURE 6-66. SEAT BELT INSTALLATION (2IN)
FIGURE 6-67. ENCLOSED CAB FRONT COVER INSTALLATION
FIGURE 6-68. CAB GUARD INSTALLATION (TOP)
FIGURE 6-69. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-70. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-71. EXTERNAL WINDOW RELEASE INSTALLATION (ANSI) (2733)
FIGURE 6-72. EXTERNAL WINDOW RELEASE INSTALLATION (CAN) (2733)
FIGURE 6-73. EXTERNAL WINDOW RELEASE INSTALLATION (ISO) (12010)
FIGURE 6-74. ARMREST
FIGURE 6-75. FIXED ARMREST BRACKET
FIGURE 6-76. MOVING ARMREST BRACKET
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL ASSEMBLY
FIGURE 7-5. BRAKE SENSOR INSTALLATION
FIGURE 7-6. SWITCH PLATE ASSEMBLY
FIGURE 7-7. TILT STEERING COLUMN INSTALLATION
FIGURE 7-8. COLUMN SHIFT INSTALLATION (2 SPEED)
FIGURE 7-9. STEERING WHEEL INSTALLATION
FIGURE 7-10. STEERING WHEEL
FIGURE 7-11. HORN BUTTON INSTALLATION
FIGURE 7-12. JOYSTICK INSTALLATION (2 SPEED)
FIGURE 7-13. WIPER-TURN SWITCH
FIGURE 7-14. COLUMN CLAMP INSTALLATION
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. BOOM HYDRAULIC INSTALLATION
FIGURE 8-2. BOOM HYDRAULIC LINES INSTALLATION
FIGURE 8-3. BOOM AUX HYDRAULIC INSTALLATION (MANUAL - SINGLE)
FIGURE 8-4. BOOM AUX HYDRAULIC INSTALLATION (HYDRAULIC - TWIN)
FIGURE 8-5. BOOM AUX HYDRAULIC INSTALLATION (MANUAL - TWIN)
FIGURE 8-6. DUAL COUPLER AUX HYDRAULIC INSTALLATION
FIGURE 8-7. AUXILIARY HYDRAULIC VALVE INSTALLATION
FIGURE 8-8. AUXILIARY HYDRAULIC VALVE INSTALLATION
FIGURE 8-9. VALVE AUX HTDRAULIC INSTALLATION
FIGURE 8-10. BOOM RAISE HOSE INSTALLATION (WITHOUT RIDE CONTROL)
FIGURE 8-11. BOOM RAISE HOSE INSTALLATION (RIDE CONTROL)
FIGURE 8-12. CAB HYDRAULICS INSTALLATION
FIGURE 8-13. CHECK VALVE INSTALLATION
FIGURE 8-14. CAB CHECK VALVE & FITTING ASSEMBLY
FIGURE 8-15. CHARGE FILTER HOSE INSTALLATION
FIGURE 8-16. CHARGE FILTER INSTALLATION
FIGURE 8-17. IMPLEMENT PUMP FILTER ASSEMBLY
FIGURE 8-18. ENGINE BAY HYDRAULIC INSTALLATION
FIGURE 8-19. FRAME HYDRAULICS INSTALLATION
FIGURE 8-20. FRAME SWAY INSTALLATION
FIGURE 8-21. FRAME SWAY CYLINDER INSTALLATION
FIGURE 8-22. FRAME SWAY CONTROL VALVE INSTALLATION
FIGURE 8-23. FRAME SWAY CONTROL VALVE & FITTING ASEMBLY
FIGURE 8-24. MAIN CONTROL VALVE INSTALLATION
FIGURE 8-25. MAIN CONTROL VALVE & FITTINGS ASSEMBLY
FIGURE 8-26. PRIORITY VALVE INSTALLATION
FIGURE 8-27. PRIORITY VALVE & FITTING ASSEMBLY
FIGURE 8-28. COUNTERBALANCE VALVE ASSEMBLY
FIGURE 8-29. RIDE AND FLOAT VALVE ASSEMBLY
FIGURE 8-30. SAHR VALVE INSTALLATION
FIGURE 8-31. SAHR BRAKE VALVE & FITTING ASSEMBLY
FIGURE 8-32. BRAKE VALVE RELAY INSTALLATION
FIGURE 8-33. BRAKE VALVE RELAY ASSEMBLY
FIGURE 8-34. SPEED CONTROL VALVE INSTALLATION
FIGURE 8-35. STEERING SELECT VALVE INSTALLATION
FIGURE 8-36. STEERING SELECT VALVE & FITTING ASSEMBLY
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. CYLINDER INSTALLATION - EXTEND/RETRACT
FIGURE 9-2. CYLINDER ASSEMBLY- EXTEND/RETRACT
FIGURE 9-3. CYLINDER ASSEMBLY - FRAME LEVEL
FIGURE 9-4. CYLINDER INSTALLATION - LIFT
FIGURE 9-5. CYLINDER ASSEMBLY - LIFT
FIGURE 9-6. CYLINDER ASSEMBLY - QUICK COUPLER
FIGURE 9-7. CYLINDER ASSEMBLY - TILT
FIGURE 9-8. GRAPPLE BUCKET CYLINDER ASSEMBLY
FIGURE 9-9. LOG HANDLER CARRIAGE CYLINDER ASSEMBLY
FIGURE 9-10. MOTOR ASSEMBLY – HYDRAULIC
FIGURE 9-11. PIPE HANDLER CARRIAGE - LOWER CYLINDER ASSEMBLY
FIGURE 9-12. PIPE HANDLER CARRIAGE - UPPER CYLINDER ASSEMBLY
FIGURE 9-13. PUMP ASSEMBLY - CHARGE
FIGURE 9-14. PUMP ASSEMBLY - DEF MODULE
FIGURE 9-15. PUMP ASSEMBLY - DRIVE
FIGURE 9-16. PUMP ASSEMBLY - PISTON
FIGURE 9-17. SIDE SHIFT CARRIAGE - FORK POSITIONING CYLINDER ASSEMBLY
FIGURE 9-18. SIDE SHIFT CARRIAGE - SIDE SHIFT CYLINDER ASSEMBLY
FIGURE 9-19. VALVE ASSEMBLY - CHARGE FLOW CONTROL VALVE ASSEMBLY
FIGURE 9-20. VALVE ASSEMBLY - DIVERTOR VALVE
FIGURE 9-21. VALVE ASSEMBLY - LEVEL AND STABILIZATION VALVE
FIGURE 9-22. VALVE ASSEMBLY - MAIN CONTROL VALVE
FIGURE 9-23. VALVE ASSEMBLY - PRIORITY VALVE
FIGURE 9-24. VALVE ASSEMBLY - SAHR BRAKE VALVE
FIGURE 9-25. VALVE ASSEMBLY - DUAL AUXILIARY DIVERTOR VALVE
FIGURE 9-26. VALVE ASSEMBLY - STEERING SELECT VALVE
FIGURE 9-27. VALVE INSTALLATION - COUNTERBALANCE VALVE
FIGURE 9-28. VALVE ASSEMBLY - COUNTERBALANCE VALVE
SECTION 10 - ELECTRICALFIGURE 10-1. 2733 ELECTRICAL LAYOUT
FIGURE 10-2. ALARM INSTALLATION - BACKUP (12010,2733)
FIGURE 10-3. ALARM INSTALLATION - BACKUP (WHITE NOISE) (2733)
FIGURE 10-4. ASOV HARNESS
FIGURE 10-5. ATTACHMENT RECOGNITION INSTALLATION
FIGURE 10-6. ATTACHMENT RECOGNITION HARNESS (12010,2733)
FIGURE 10-7. ATTACHMENT RECOGNITION HARNESS (EURO) (12010)
FIGURE 10-8. BATTERY INSTALLATION - DUAL
FIGURE 10-9. BATTERY INSTALLATION - DUAL (WITH BREATHER TUBE HEATER)
FIGURE 10-10. BATTERIES INSTALLATION - ARCTIC (115V)
FIGURE 10-11. BEACON INSTALLATION (LED)
FIGURE 10-12. BEACON (LED) (REMOTE BOOM CONTROL) INSTALLATION
FIGURE 10-13. BOOM TO FRAME HARNESS
FIGURE 10-14. BOOM ANGLE SENSOR INSTALLATION (STD)
FIGURE 10-15. BOOM RETRACT SENSOR INSTALLATION
FIGURE 10-16. BOOM RETRACT SOFT STOP HARNESS
FIGURE 10-17. BOOM RIDE/FLOAT HARNESS
FIGURE 10-18. CAB ELECTRICAL INSTALLATION
FIGURE 10-19. CAB HARNESS
FIGURE 10-20. CAB - STANDARD ELECTRICAL BOARD ASSEMBLY
FIGURE 10-21. CAB - OPTION 1 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-22. CAB - OPTION 2 ELECTRICAL BOARD ASSEMBLY
FIGURE 10-23. CAB - A/C OPTION HARNESS
FIGURE 10-24. CAB - DASH ELECTRICAL INSTALLATION (2733)
FIGURE 10-25. CAB - DASH ELECTRICAL INSTALLATION (12010)
FIGURE 10-26. CAB - IGNITION SWITCH HARNESS
FIGURE 10-27. CAB - LIGHT SWITCH INSTALLATION
FIGURE 10-28. CAB OPTION HARNESS
FIGURE 10-29. CAB - SEAT ADAPTOR HARNESS
FIGURE 10-30. COLD WEATHER PACKAGE INSTALLATION (ARCTIC) (2733)
FIGURE 10-31. COUPLER ANGLE SENSOR INSTALLATION
FIGURE 10-32. EMERGENCY STOP EXTERNAL INSTALLATION
FIGURE 10-33. ENGINE BAY ELECTRICAL INSTALLATION (2733)
FIGURE 10-34. ENGINE BAY ELECTRICAL INSTALLATION (12010)
FIGURE 10-35. ENGINE BAY WIRING INSTALLATION (2733)
FIGURE 10-36. ENGINE BAY WIRING INSTALLATION (12010)
FIGURE 10-37. ENGINE - DEF PURGE LIGHT HARNESS
FIGURE 10-38. ENGINE WIRING INSTALLATION
FIGURE 10-39. ENGINE - ENGINE HARNESS (CUMMINS)
FIGURE 10-40. FRAME ELECTRICAL INSTALLATION (Prior to SN 0160110014)
FIGURE 10-41. FRAME ELECTRICAL INSTALLATION (SN 0160110014 to Present)
FIGURE 10-42. FRAME - ELECTRICAL POWER DISTRIBUTION BOX
FIGURE 10-43. FRAME WIRING INSTALLATION (2733)
FIGURE 10-44. FRAME WIRING INSTALLATION (12010)
FIGURE 10-45. FRAME - ENGINE CHASSIS HARNESS (CUMMINS)
FIGURE 10-46. FRAME - FRONT FRAME HARNESS
FIGURE 10-47. FRAME - FRONT FRAME POWER HARNESS
FIGURE 10-48. FRAME - REAR FRAME POWER HARNESS
FIGURE 10-49. FRAME - REAR FRAME MODULE INSTALLATION (Prior to SN 0160110014)
FIGURE 10-50. FRAME - REAR FRAME MODULE INSTALLATION (SN 0160110014 to Present)
FIGURE 10-51. FRAME - RIDE CONTROL WIRING INSTALLATION
FIGURE 10-52. HEATER INSTALLATION - FUEL FILTER
FIGURE 10-53. HEATER INSTALLATION - HYDRAULIC TANK
FIGURE 10-54. HEATER INSTALLATION - OIL PAN
FIGURE 10-55. HVAC ACTUATOR HARNESS (Prior to SN 0160110014)
FIGURE 10-56. HVAC ACTUATOR HARNESS (SN 0160110014 to Present)
FIGURE 10-57. LIGHTS - BOOM WORKLIGHTS INSTALLATION (LED)
FIGURE 10-58. LIGHTS - BOOM WORKLIGHTS HARNESS
FIGURE 10-59. LIGHTS - CAB WORKLIGHTS INSTALLATION (NO A/C - LED)
FIGURE 10-60. LIGHTS - CAB WORKLIGHTS INSTALLATION (A/C - LED)
FIGURE 10-61. LIGHTS - HEADLIGHT HARNESS
FIGURE 10-62. LIGHTS - ROAD LIGHTS INSTALLATION (LED)
FIGURE 10-63. LIGHTS - TAILIGHT HARNESS
FIGURE 10-64. LMIS INSTALLATION
FIGURE 10-65. LMIS BEACON LIGHT INSTALLATION
FIGURE 10-66. LMIS BEACON OPTION HARNESS
FIGURE 10-67. LMIS BOOM HARNESS
FIGURE 10-68. LMIS CABLE REEL INSTALLATION
FIGURE 10-69. LMIS CHASSIS OPTION HARNESS
FIGURE 10-70. LMIS TILT SENSOR INSTALLATION
FIGURE 10-71. LSI INSTALLATION
FIGURE 10-72. LSI DISPLAY INSTALLATION
FIGURE 10-73. LSI SENSOR INSTALLATION
FIGURE 10-74. PLATFORM HARNESS
FIGURE 10-75. PLATFORM READY HARNESS
FIGURE 10-76. REVERSE CAMERA INSTALLATION
FIGURE 10-77. REVERSE SENSOR INSTALLATION
FIGURE 10-78. REVERSE SENSOR HARNESS
FIGURE 10-79. REVERSING FAN HARNESS
FIGURE 10-80. RIGHT SIDE CAMERA INSTALLATION
FIGURE 10-81. TBAP HARNESS
FIGURE 10-82. TELEMATICS CANBUS INSTALLATION
FIGURE 10-83. TELEMATICS CLEARSKY HARNESS - CANBUS
FIGURE 10-84. TELEMATICS CLEARSKY INSTALLATION 3-WIRE (ANSI)
FIGURE 10-85. TELEMATICS CLEARSKY HARNESS - 3-WIRE
FIGURE 10-86. TELEMATICS READY INSTALLATION
FIGURE 10-87. TELEMATICS READY HARNESS
FIGURE 10-88. TILT SENSOR HARNESS
SECTION 11 - DECALSFIGURE 11-1. BRANDING DECAL INSTALLATION - 2733 (2733)
FIGURE 11-2. BRANDING DECAL INSTALLATION - 12010 (12010)
FIGURE 11-3. DECAL INSTALLATION (ANSI) (2733)
FIGURE 11-4. DECAL INSTALLATION (AUS) (12010)
FIGURE 11-5. DECAL INSTALLATION (CSA ENGLISH/FRENCH) (2733)
FIGURE 11-6. DECAL INSTALLATION (ISO) (12010)
FIGURE 11-7. DECAL INSTALLATION (RUS) (12010)
FIGURE 11-8. LOADCHARTS (ANSI)
FIGURE 11-9. CAPACITY CHART HOLDER INSTALLATION
FIGURE 11-10. REVERSE SENSOR SYSTEM DECAL (ENGLISH) (2733)
FIGURE 11-11. REVERSE SENSING SYSTEM DECAL, (ENGLISH/FRENCH) (2733)
FIGURE 11-12. REVERSE SENSING SYSTEM DECAL, (ISO) (12010)
FIGURE 11-13. CLEARSKY DECAL INSTALLATION
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
