JLG Telehandler 2733, 12010 Operation Safety Manual 3122554300
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Operation Safety Manual
Model: JLG 2733, 12010 Telehandler
Part Number: 3122554300
Publication Date: 2025
Number of Pages: 196 Pages
31225543 Cover Page
Revision Log
Read This First
Brand: JLG
31225543 Cover Page
Revision Log
Read This First
Machine Configuration
General Safety PracticesHazard Classification System
1.1.1 Safety Alert System and Safety Signal Words
General Precautions
Operation Safety
1.3.1 Electrical Hazards
1.3.2 Tip Over Hazard
1.3.3 Travel Hazard
1.3.4 Load Falling Hazard
1.3.5 Lifting Personnel
1.3.6 Driving Hazards on Slopes
1.3.7 Pinch Points and Crush Hazards
1.3.8 Fall Hazard
1.3.9 Chemical Hazards
Radio Frequency (RF) Information
1.4.1 Federal Communications Commission (FCC)
1.4.2 Innovation, Science and Economic Development (ISED)
1.4.3 European Union Conformity (CE)
Pre-Operation and InspectionPreparation, Inspection, and Maintenance
Pre-Operation Check and Inspection
Safety Decals
2.3.1 ANSI (If Equipped)
2.3.2 ISO (if equipped)
Walk-Around Inspection
Warm-Up and Operational Checks
2.5.1 Warm-Up Check
2.5.2 Operational Check
Operator Cab
Enclosed Cab Windows
2.7.1 Cab Door Window
2.7.2 Rear Window
Controls and IndicatorsGeneral
Controls
3.2.1 Instrument Panel
3.2.2 LCD Display
3.2.3 Left Dash Control Panel
3.2.4 Right Dash Control Panel
3.2.5 Ignition
3.2.6 Park Brake
3.2.7 Parking Procedure
3.2.8 Transmission Control Lever
3.2.9 Accessory Control Lever (if equipped)
3.2.10 Steering Column Adjuster
3.2.11 Reversing Fan Switch (if equipped)
3.2.12 SmartLoad Technology System (if equipped)
3.2.13 Load Stability Indicator - LSI
3.2.14 Joystick
Anti-Theft Functionality (if enabled)
3.3.1 Instrument Panel Input
3.3.2 Multifunction Display Input
Steer Modes
3.4.1 Manual Steering Alignment Mode Change
3.4.2 All Wheel Assisted Steering Alignment Mode Change
Operator Seat
3.5.1 Adjustments
3.5.2 Seat Belt
Boom Extension Indicators
Reverse Systems (if equipped)
3.7.1 Reverse Sensing System
3.7.2 Multi—View Camera
Attachment Recognition (if equipped)
Multifunction Display (if equipped)
3.9.1 General Information
3.9.2 Multifunction Display and Buttons
3.9.3 Home Screen
3.9.4 Main Menu
3.9.5 Operation and Maintenance
3.9.6 Troubleshooting
Beacons - Telehandler
3.10.1 ClearSky® LED Motion / Amber Beacon (CS550)
3.10.2 Amber Beacon
OperationEngine
4.1.1 Starting the Engine in Normal Conditions
4.1.2 Extreme Cold Weather Starting (if equipped)
4.1.3 Battery Boosted Starting
4.1.4 Normal Engine Operation
4.1.5 Shut-Down Procedure
After-Treatment System (ATS) (if equipped for ULS)
4.2.1 Automatic Exhaust System Cleaning (In-Mission)
4.2.2 Stationary Exhaust System Cleaning (Non-Mission)
Operating with a Non-Suspended Load
4.3.1 Lift Load Safely
4.3.2 Picking Up a Load
4.3.3 Transporting a Load
4.3.4 Leveling Procedure
4.3.5 Placing a Load
4.3.6 Disengaging a Load
Operating with a Suspended Load
4.4.1 Lift Load Safely
4.4.2 Picking Up a Suspended Load
4.4.3 Transporting a Suspended Load
4.4.4 Leveling Procedure
4.4.5 Placing a Suspended Load
4.4.6 Disengaging a Suspended Load
Road Operation (if equipped)
Loading and Securing for Transport
4.6.1 Beacon Fold-Down
4.6.2 Tiedown
4.6.3 Lifting
ClearSky Smart Fleet
Access Control (Telehandler)
AttachmentsApproved Attachments
5.1.1 Coupler Mounted Attachments
5.1.2 JLG Supplied Fork Mounted Attachments
5.1.3 Non-OEM Fork Mounted Attachments
Unapproved Attachments
5.3.1 General Requirements
5.3.2 Non-OEM Attachments
Equivalent Load
5.4.1 Load Centers Beyond 24 Inches
5.4.2 Fork Mounted Attachments Equivalent Load
JLG Supplied Attachments
Telehandler/Attachment/Fork Capacity
Use of the Capacity Chart
5.7.1 Capacity Indicator Locations
5.7.2 Sample Capacity Chart
5.7.3 Example
Attachment Installation
5.8.1 Coupler
5.8.2 Auxiliary Hydraulic Decompression
Adjusting/Moving Forks
Attachment Operation
5.10.1 Carriage with Forks
5.10.2 Side Shift Carriage with Fork Positioning
5.10.3 Dual Fork Positioning Carriage
5.10.4 Bucket
5.10.5 Grapple Bucket
5.10.6 Truss Boom — 3 Position
5.10.7 Winch, Coupler Mounted
5.10.8 Pipe Grapple
5.10.9 Tire Handler
5.10.10 Log Handler
5.10.11 Steel Coil Handler
5.10.12 Personnel Work Platform - Fork Mounted
Emergency ProceduresTowing a Disabled Product
6.1.1 Moving Short Distances
6.1.2 Moving Longer Distance
Emergency Lowering of Boom
Emergency Exit from Enclosed Cab
6.3.1 Inside Cab
6.3.2 Outside Cab
ClearSky Smart Fleet - Locked Out State
Lubrication and MaintenanceIntroduction
7.1.1 Clothing and Safety Gear
General Maintenance Instructions
Maintenance Schedules
7.3.1 Every 10 Hours
7.3.2 First 50 Hours
7.3.3 Every 50 Hours
7.3.4 First 250 Hours
7.3.5 Every 250 Hours
7.3.6 First 500 Hours
7.3.7 Every 500 Hours
7.3.8 Every 1000 Hours
7.3.9 Every 1500 Hours
7.3.10 Every 2000 Hours
7.3.11 Every 4000 Hours
7.3.12 Every 5000 Hours
Lubrication Schedules
7.4.1 2733, 12010
Operator Maintenance Instructions
7.5.1 Engine Maintenance Components
7.5.2 Fuel System
7.5.3 Emission System (if equipped for ULS)
7.5.4 Engine Oil
7.5.5 Air Intake System
7.5.6 Tires
7.5.7 Hydraulic Oil
7.5.8 Brake Fluid
7.5.9 Engine Cooling System
7.5.10 Windshield Washer System
7.5.11 Cab Air Filters (if equipped)
7.5.12 Load Stability Indicator System
Additional ChecksGeneral
Reverse Sensing System (if equipped)
Air Shutoff Valve (ASOV) (if equipped)
SpecificationsProduct Specifications
9.1.1 Fluids
9.1.2 Capacities
9.1.3 Tires
9.1.4 Performance
9.1.5 Dimensions
- SuperPac Parts Manual
- StratoLift Parts Manual
