Hyundai
86
176,834
JLG Telehandler 2733 12010 Operation Safety Manual 3122312300
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Operation Safety Manual
Model: JLG 2733 12010 Telehandler
Part Number: 3122312300
Publication Date: 2024
Number of Pages: 186 Pages
3122312300 Cover Page
Revision Log
Read This First
Machine Configuration​
General Safety Practices
Hazard Classification System​
1.1.1 Safety Alert System and Safety Signal Words​
General Precautions​
Operation Safety​
1.3.1 Electrical Hazards​
1.3.2 Tip Over Hazard​
1.3.3 Travel Hazard​
1.3.4 Load Falling Hazard​
1.3.5 Lifting Personnel​
1.3.6 Driving Hazards on Slopes​
1.3.7 Pinch Points and Crush Hazards​
1.3.8 Fall Hazard​
1.3.9 Chemical Hazards​
Radio Frequency (RF) Information​
1.4.1 Federal Communications Commission (FCC)​
1.4.2 Innovation, Science and Economic Development (ISED)​
Pre-Operation and Inspection
Preparation, Inspection, and Maintenance​
Pre-Operation Check and Inspection​
Safety Decals​
2.3.1 ANSI (If Equipped)​
2.3.2 ISO (if equipped)​
Walk-Around Inspection​
Warm-Up and Operational Checks​
2.5.1 Warm-Up Check​
2.5.2 Operational Check​
Operator Cab​
Enclosed Cab Windows​
2.7.1 Cab Door Window​
2.7.2 Rear Window​
Controls and Indicators
General​
Controls​
3.2.1 Instrument Panel​
3.2.2 LCD Display​
3.2.3 Left Dash Control Panel​
3.2.4 Right Dash Control Panel​
3.2.5 Ignition​
3.2.6 Park Brake​
3.2.7 Parking Procedure​
3.2.8 Transmission Control Lever​
3.2.9 Accessory Control Lever (if equipped)​
3.2.10 Steering Column Adjuster​
3.2.11 Reversing Fan Switch (if equipped)​
3.2.12 SmartLoad Technology System (if equipped)​
3.2.13 Load Stability Indicator - LSI​
3.2.14 Joystick​
Anti-Theft Functionality (if enabled)​
3.3.1 Instrument Panel Input​
3.3.2 Multifunction Display Input​
Steer Modes​
3.4.1 Manual Steering Alignment Mode Change​
3.4.2 All Wheel Assisted Steering Alignment Mode Change​
Operator Seat​
3.5.1 Adjustments​
3.5.2 Seat Belt​
Boom Extension Indicators​
Reverse Systems (if equipped)​
3.7.1 Reverse Sensing System​
3.7.2 Multi—View Camera​
Attachment Recognition (if equipped)​
Multifunction Display (if equipped)​
3.9.1 General Information​
3.9.2 Multifunction Display and Buttons​
3.9.3 Home Screen​
3.9.4 Main Menu​
3.9.5 Operation and Maintenance​
3.9.6 Troubleshooting​
Beacons​
3.10.1 ClearSky® LED Motion / Amber Beacon (CS550)​
3.10.2 Amber Beacon​
Operation
Engine​
4.1.1 Starting the Engine in Normal Conditions​
4.1.2 Extreme Cold Weather Starting (if equipped)​
4.1.3 Battery Boosted Starting​
4.1.4 Normal Engine Operation​
4.1.5 Shut-Down Procedure​
After-Treatment System (ATS) (if equipped for ULS)​
4.2.1 Automatic Exhaust System Cleaning (In-Mission)​
4.2.2 Stationary Exhaust System Cleaning (Non-Mission)​
Operating with a Non-Suspended Load​
4.3.1 Lift Load Safely​
4.3.2 Picking Up a Load​
4.3.3 Transporting a Load​
4.3.4 Leveling Procedure​
4.3.5 Placing a Load​
4.3.6 Disengaging a Load​
Operating with a Suspended Load​
4.4.1 Lift Load Safely​
4.4.2 Picking Up a Suspended Load​
4.4.3 Transporting a Suspended Load​
4.4.4 Leveling Procedure​
4.4.5 Placing a Suspended Load​
4.4.6 Disengaging a Suspended Load​
Road Operation (if equipped)​
Loading and Securing for Transport​
4.6.1 Beacon Fold-Down​
4.6.2 Tiedown​
4.6.3 Lifting​
ClearSky Smart Fleet​
Access Control (Telehandler)​
Approved Attachments​
5.1.1 Coupler Mounted Attachments​
5.1.2 JLG Supplied Fork Mounted Attachments​
5.1.3 Non-OEM Fork Mounted Attachments​
Unapproved Attachments​
5.3.1 General Requirements​
5.3.2 Non-OEM Attachments​
Equivalent Load​
5.4.1 Load Centers Beyond 24 Inches​
5.4.2 Fork Mounted Attachments Equivalent Load​
JLG Supplied Attachments​
Telehandler/Attachment/Fork Capacity​
Use of the Capacity Chart​
5.7.1 Capacity Indicator Locations​
5.7.2 Sample Capacity Chart​
5.7.3 Example​
Attachment Installation​
5.8.1 Coupler​
5.8.2 Auxiliary Hydraulic Decompression​
Adjusting/Moving Forks​
Attachment Operation​
5.10.1 Carriage with Forks​
5.10.2 Side Shift Carriage with Fork Positioning​
5.10.3 Dual Fork Positioning Carriage​
5.10.4 Bucket​
5.10.5 Grapple Bucket​
5.10.6 Truss Boom — 3 Position​
5.10.7 Winch, Coupler Mounted​
5.10.8 Pipe Grapple​
5.10.9 Tire Handler​
5.10.10 Log Handler​
5.10.11 Steel Coil Handler​
5.10.12 Personnel Work Platform - Fork Mounted​
Emergency Procedures
Towing a Disabled Product​
6.1.1 Moving Short Distances​
6.1.2 Moving Longer Distance​
Emergency Lowering of Boom​
Emergency Exit from Enclosed Cab​
6.3.1 Inside Cab​
6.3.2 Outside Cab​
ClearSky Smart Fleet - Locked Out State​
Lubrication and Maintenance
Introduction​
7.1.1 Clothing and Safety Gear​
General Maintenance Instructions​
Maintenance Schedules​
7.3.1 Every 10 Hours​
7.3.2 First 50 Hours​
7.3.3 Every 50 Hours​
7.3.4 First 250 Hours​
7.3.5 Every 250 Hours​
7.3.6 First 500 Hours​
7.3.7 Every 500 Hours​
7.3.8 Every 1000 Hours​
7.3.9 Every 1500 Hours​
7.3.10 Every 2000 Hours​
7.3.11 Every 4000 Hours​
7.3.12 Every 5000 Hours​
Lubrication Schedules​
7.4.1 2733, 12010​
Operator Maintenance Instructions​
7.5.1 Engine Maintenance Components​
7.5.2 Fuel System​
7.5.3 Emission System (if equipped for ULS)​
7.5.4 Engine Oil​
7.5.5 Air Intake System​
7.5.6 Tires​
7.5.7 Hydraulic Oil​
7.5.8 Brake Fluid​
7.5.9 Engine Cooling System​
7.5.10 Windshield Washer System​
7.5.11 Cab Air Filters (if equipped)​
7.5.12 Load Stability Indicator System​
Additional Checks
General​
Reverse Sensing System (if equipped)​
Air Shutoff Valve (ASOV) (if equipped)​
Specifications
Product Specifications​
9.1.1 Fluids​
9.1.2 Capacities​
9.1.3 Tires​
9.1.4 Performance​
9.1.5 Dimensions​
