Hyundai
86
176,834
JLG Telehandler 1644 1732 7013H 8010H Service Manual 3122331500 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 1644, 1732, 7013H, 8010H Telehandler
Part Number: 3122331500
Publication Date: 2025
Number of Pages: 628 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Travel Speed​
2.1.2 Hydraulic Cylinder Performance​
2.1.3 Cylinder Drift​
2.1.4 Steering Angle Specifications​
2.1.5 Electrical System​
2.1.6 Engine Performance Specifications​
2.1.7 Tires​
Machine Temperature Chart​
Serial Number Location​
Fluid and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
After Treatment System​
2.5.1 Stationary Exhaust System Cleaning​
ClearSky Smart Fleet​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ – Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Service and Maintenance Schedules​
3.3.2 Axle Specifications and Maintenance Information​
3.3.3 Transmission Specifications and Maintenance Information​
3.3.4 Engine Specifications and Maintenance Information​
Pins and Composite Bearing Repair Guidelines​
3.4.1 Filament Wound Bearings​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance​
3.6.1 Service Brake Bleeding​
3.6.2 Park Brake Bleeding​
3.6.3 Brake Inspection​
DEF Tank Inspection​
3.7.1 DEF Tank Inspection​
Boom Inspection and Maintenance​
3.8.1 Wear Pad Inspection​
Hydraulic Filter Replacement​
3.9.1 Hydraulic Filter Removal​
3.9.2 Hydraulic Filter Installation​
Testing, Calibrations and Special Procedures
Special Tools (reference)​
4.1.1 Multimeter​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Engine​
4.2.2 Fuel Level Sender​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Inching System Calibration​
4.3.3 Boom Angle Sensor Calibration​
4.3.4 Load Stability Indicator (LSI) System Calibration​
4.3.5 LMIS (Load Moment Indicator System) Calibration​
4.3.6 Attachment Recognition Calibration​
4.3.7 Park Brake Calibration/Maximum Drive Traction Test​
4.3.8 Brake Pedal Calibration​
Special Procedures​
4.4.1 Emergency Lowering Procedure​
4.4.2 Towing a Disabled Machine​
4.4.3 Transmission Oil Replacement​
4.4.4 Charge Air Cooler (CAC) Hose Replacement​
4.4.5 Diesel Exhaust Fluid (DEF) System Cleaning (If Equipped for ULS)​
4.4.6 Fuel Tank​
4.4.7 Hydraulic Pressure Checks and Adjustments​
4.4.8 Hydraulic Circuits​
4.4.9 Hydraulic Pressures​
4.4.10 Pressure Specifications​
4.4.11 Hydraulic Reservoir​
4.4.12 Accumulators​
System Software
Load Stability Indicator (LSI)​
5.1.1 Load Stability Indicator​
5.1.2 LSI Sensor​
Analyzer​
5.2.1 Machine Data Access​
5.2.2 JLG Hand Held Analyzer​
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer​
5.2.4 PC Analyzer/Loglifter​
5.2.5 Analyzer Software (Version P26.0)​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostics​
5.3.3 Machine Setup (Software Version P26.0)​
5.3.4 Personalities (Software Version P26.0)​
5.3.5 Operator Tools (Software Version P26.0)​
5.3.6 Calibrations (Software Version P26.0)​
Multifunction display (If Equipped)​
5.4.1 Technical Specification​
5.4.2 Multifunction Display and Control Buttons​
5.4.3 Main Menu​
5.4.4 Setup and Maintenance​
5.4.5 Troubleshooting​
5.5.1 ClearSky Smart FleetTM CS550 Configuration​
5.5.2 Troubleshooting​
Fault Codes
Introduction​
Engine Diagnostic​
6.2.1 EMR5 Diagnosis and Error codes​
Machine Fault Codes​
Air Shutoff Valve (ASOV) Controller​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories Of Operation (reference)​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Component​
7.3.1 1644, 7013H​
7.3.2 1732, 8010H​
Torque Values​
7.4.1 Cylinder Torque Specifications​
Electricals
General Information (reference)​
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
8.3.1 General Overview​
Harness Layouts​
Board Layouts​
8.5.1 Cab Power Distribution Board​
8.5.2 Frame Power Distribution Board​
8.5.3 Option 1 Distribution Board​
8.5.4 Option 2 Distribution Board​
8.5.5 Engine Harness Fuses and Relays​
Telematics Gateway​
Wheels​
9.1.1 Removing Wheel and Tire Assembly from Machine​
9.1.2 Installing Wheel and Tire Assembly onto Machine​
Drive Assembly​
9.2.1 Axle Serial Number​
9.2.2 Axle​
9.2.3 Steering Angle Adjustment​
9.2.4 Axle Assembly and Drive Shaft Troubleshooting​
9.2.5 Drive Shaft​
Boom​
9.3.1 Component Terminology​
9.3.2 Boom System Operation​
9.3.3 Complete Boom​
9.3.4 Precision Gravity Lower System (PGLS)​
9.3.5 Accumulator​
9.3.6 Quick Coupler​
9.3.7 Forks​
9.3.8 Boom Wear Pad Installation, Lubrication​
9.3.9 Boom Angle Sensor​
9.3.10 Boom Prop (If Equipped)​
9.3.11 Troubleshooting​
Cab​
9.4.1 Component Terminology​
9.4.2 Operator Cab Safety​
9.4.3 Serial Number Plate​
9.4.4 Cab Removal and Installation​
9.4.5 Steering Wheel​
9.4.6 Steering Column/Orbital Valve​
9.4.7 Service Brake​
9.4.8 Electronic Throttle Pedal​
9.4.9 Joystick Assembly​
9.4.10 Ignition Key Switch​
9.4.11 Dash Switches​
9.4.12 Window Wiper Assembly (IF Equipped)​
9.4.13 Multifunction Display (If Equipped)​
9.4.14 Heater System​
9.4.15 Heater and Air Conditioning System (If Equipped)​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Surge Tank Cap​
9.5.4 Thermostat Replacement​
9.5.5 Radiator Assembly Replacement​
9.5.6 Engine Coolant Temperature Sensor​
9.5.7 Engine Electrical System​
9.5.8 Diesel Fuel​
9.5.9 Diesel Exhaust Fluid (DEF) Tank (If Equipped for ULS)​
9.5.10 Diesel Exhaust Fluid (DEF) System Header (If Equipped for ULS)​
9.5.11 Diesel Exhaust Fluid (DEF) Pump Filter (if equipped for ULS)​
9.5.12 Hydraulic Oil Reservoir Removal/Installation​
9.5.13 Fuel Tank​
9.5.14 Engine Exhaust System​
9.5.15 Air Cleaner Assembly​
9.5.16 Engine Replacement​
9.5.17 Starter​
9.5.18 Alternator​
9.5.19 Troubleshooting​
Transmission​
9.6.1 Component Terminology​
9.6.2 Transmission Serial Number​
9.6.3 Transmission Removal/Installation​
9.6.4 Hydrostatic Transmission Pump Replacement​
9.6.5 Dual Pump Drive Replacement​
9.6.6 Drive Motor​
9.6.7 Gearbox Replacement​
9.6.8 Reverse Alarm​
Hydraulic Cylinders​
9.7.1 General Cylinder​
9.7.2 Steering Cylinders​
Hydraulic Valves​
9.8.1 Main Control Valve​
9.8.2 Priority Valve​
9.8.3 Service Brake Valve​
9.8.4 Steering Orbital Valve​
9.8.5 Frame Leveling Valve or Outrigger/ Frame Leveling Valve (if equipped)​
9.8.6 Steer Select Valve​
9.8.7 Inching Valve​
Hydraulic Pump​
9.9.1 Implement Pump​
Electrical Components​
9.10.1 Battery​
9.10.2 Electrical Master Switch​
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Axle Assembly​
10.1.2 Transmission Assembly​
Boom​
10.2.1 Boom Assembly Maintenance - 1644, 7013H​
10.2.2 Boom Assembly Maintenance - 1732, 8010H​
Cab​
Engine Components (reference)​
10.4.1 Fuel Tank​
Transmission​
10.5.1 Implement Pump​
10.6.1 General Cylinder​
Hydraulic Valves​
10.7.1 Main Control Valve​
10.7.2 Priority Valve​
Hydraulic Components​
10.8.1 Hydraulic Oil Reservoir​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics​
12.1.1 1644, 7013H​
12.1.2 1732, 8010H​
Electrical Schematics​
