JLG Telehandler 1644 1732 7013 8010 Service Manual 3122350000 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 1644, 1732, 7013, 8010 Telehandler
Part Number: 3122350000
Publication Date: 2025
Number of Pages: 648 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Travel Speed
2.1.2 Hydraulic Cylinder Performance
2.1.3 Cylinder Drift
2.1.4 Steering Angle Specifications
2.1.5 Electrical System
2.1.6 Engine Performance Specifications
2.1.7 Tires
Machine Temperature Chart
Serial Number Location
Fluid and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
After Treatment System
2.5.1 Stationary Exhaust System Cleaning
ClearSky Smart Fleet
2.6.1 General
2.6.2 ClearSky Smart Fleet™ – Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Service and Maintenance Schedules
3.3.2 Axle Specifications and Maintenance Information
3.3.3 Transmission Specifications and Maintenance Information
3.3.4 Engine Specifications and Maintenance Information
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Service Brake Bleeding
3.6.2 Park Brake Bleeding
3.6.3 Brake Inspection
DEF Tank Inspection
3.7.1 DEF Tank Inspection
Boom Inspection and Maintenance
3.8.1 Wear Pad Inspection
Hydraulic Filter Replacement
3.9.1 Hydraulic Filter Removal
3.9.2 Hydraulic Filter Installation
Testing, Calibrations and Special ProceduresSpecial Tools (reference)
4.1.1 Multimeter
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Engine
4.2.2 Fuel Level Sender
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Inching System Calibration
4.3.3 Boom Angle Sensor Calibration
4.3.4 Load Stability Indicator (LSI) System Calibration
4.3.5 LMIS (Load Moment Indicator System) Calibration
4.3.6 Attachment Recognition Calibration
4.3.7 Park Brake Calibration/Maximum Drive Traction Test
4.3.8 Brake Pedal Calibration
Special Procedures
4.4.1 Emergency Lowering Procedure
4.4.2 Towing a Disabled Machine
4.4.3 Transmission Oil Replacement
4.4.4 Charge Air Cooler (CAC) Hose Replacement
4.4.5 Diesel Exhaust Fluid (DEF) System Cleaning (If Equipped for ULS)
4.4.6 Fuel Tank
4.4.7 Hydraulic Pressure Checks and Adjustments
4.4.8 Hydraulic Circuits
4.4.9 Hydraulic Pressures
4.4.10 Pressure Specifications
4.4.11 Hydraulic Reservoir
4.4.12 Accumulators
System SoftwareLoad Stability Indicator (LSI)
5.1.1 Load Stability Indicator
5.1.2 LSI Sensor
Analyzer
5.2.1 Machine Data Access
5.2.2 JLG Hand Held Analyzer
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer
5.2.4 PC Analyzer/Loglifter
5.2.5 Analyzer Software (Version P27.0)
Access Level
Diagnostics (Software Version P27.0)
Machine Setup (Software Version P27.0)
Personalities (Software Version P27.0)
Operator Tools (Software Version P27.0)
Calibrations (Software Version P27.0)
Multifunction display (If Equipped)
5.9.1 Technical Specification
5.9.2 Multifunction Display and Control Buttons
5.9.3 Main Menu
5.9.4 Setup and Maintenance
5.9.5 Troubleshooting
ClearSky (CS550) Configuration and Troubleshooting
5.10.1 ClearSky Smart FleetTM CS550 Configuration
5.10.2 Troubleshooting
Fault CodesIntroduction
Engine Diagnostic
6.2.1 EMR5 Diagnosis and Error codes
Fault Codes - Help Comment (00x)
Fault Codes - Power-Up (21x)
Fault Codes - Ground Inputs (23x)
Fault Codes - Other Inputs (24x)
Fault Codes - Function Prevented (25x)
Fault Codes - Line Contactor, Open-Circuit (31x)
Fault Codes - Line Contactor, Short-Circuit (32x)
Fault Codes - Output Drivers (33x)
Fault Codes - Engine (43x)
Fault Codes - Battery Supply (44x)
Fault Codes - Transmission and Drive System (46x)
Fault Codes - Communications (66x)
Fault Codes - Telematics (68x)
Fault Codes - Tilt Sensor (81x)
Fault Codes - Envelope Control (84x)
Fault Codes - Load Moment (85x)
Fault Codes - Steering (86x)
Fault Codes - Service Required (87x)
Fault Codes - Hardware (99x)
Air Shutoff Valve (ASOV) Controller
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories Of Operation (reference)
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 1644, 7013
7.3.2 1732, 8010
Torque Values
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information (reference)
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
8.3.1 General Overview
Harness Layouts
Board Layouts
8.5.1 Cab Power Distribution Board
8.5.2 Frame Power Distribution Board
8.5.3 Option 1 Distribution Board
8.5.4 Option 2 Distribution Board
8.5.5 Engine Harness Fuses and Relays
Telematics Gateway
Removal and InstallationWheels
9.1.1 Removing Wheel and Tire Assembly from Machine
9.1.2 Installing Wheel and Tire Assembly onto Machine
Drive Assembly
9.2.1 Axle Serial Number
9.2.2 Axle
9.2.3 Steering Angle Adjustment
9.2.4 Axle Assembly and Drive Shaft Troubleshooting
9.2.5 Drive Shaft
Boom
9.3.1 Component Terminology
9.3.2 Boom System Operation
9.3.3 Complete Boom
9.3.4 Precision Gravity Lower System (PGLS)
9.3.5 Accumulator
9.3.6 Quick Coupler
9.3.7 Forks
9.3.8 Boom Wear Pad Installation, Lubrication
9.3.9 Boom Angle Sensor
9.3.10 Boom Prop (If Equipped)
9.3.11 Troubleshooting
9.4.1 Component Terminology
9.4.2 Operator Cab Safety
9.4.3 Serial Number Plate
9.4.4 Cab Removal and Installation
9.4.5 Steering Wheel
9.4.6 Steering Column/Orbital Valve
9.4.7 Service Brake
9.4.8 Electronic Throttle Pedal
9.4.9 Joystick Assembly
9.4.10 Ignition Key Switch
9.4.11 Dash Switches
9.4.12 Window Wiper Assembly (IF Equipped)
9.4.13 Multifunction Display (If Equipped)
9.4.14 Heater System
9.4.15 Heater and Air Conditioning System (If Equipped)
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Surge Tank Cap
9.5.4 Thermostat Replacement
9.5.5 Radiator Assembly Replacement
9.5.6 Engine Coolant Temperature Sensor
9.5.7 Engine Electrical System
9.5.8 Diesel Fuel
9.5.9 Diesel Exhaust Fluid (DEF) Tank (If Equipped for ULS)
9.5.10 Diesel Exhaust Fluid (DEF) System Header (If Equipped for ULS)
9.5.11 Diesel Exhaust Fluid (DEF) Pump Filter (if equipped for ULS)
9.5.12 Hydraulic Oil Reservoir Removal/Installation
9.5.13 Fuel Tank
9.5.14 Engine Exhaust System
9.5.15 Air Cleaner Assembly
9.5.16 Engine Replacement
9.5.17 Starter
9.5.18 Alternator
9.5.19 Troubleshooting
9.6.1 Component Terminology
9.6.2 Transmission Serial Number
9.6.3 Transmission Removal/Installation
9.6.4 Hydrostatic Transmission Pump Replacement
9.6.5 Dual Pump Drive Replacement
9.6.6 Drive Motor
9.6.7 Gearbox Replacement
9.6.8 Reverse Alarm
Hydraulic Cylinders
9.7.1 General Cylinder
9.7.2 Steering Cylinders
Hydraulic Valves
9.8.1 Main Control Valve
9.8.2 Priority Valve
9.8.3 Service Brake Valve
9.8.4 Steering Orbital Valve
9.8.5 Frame Leveling Valve or Outrigger/ Frame Leveling Valve (if equipped)
9.8.6 Steer Select Valve
9.8.7 Inching Valve
9.9.1 Implement Pump
Electrical Components
9.10.1 Battery
9.10.2 Electrical Master Switch
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Axle Assembly
10.1.2 Transmission Assembly
Boom
10.2.1 Boom Assembly Maintenance - 1644, 7013
10.2.2 Boom Assembly Maintenance - 1732, 8010
Engine Components (reference)
10.4.1 Fuel Tank
10.5.1 Implement Pump
Hydraulic Cylinders
10.6.1 General Cylinder
Hydraulic Valves
10.7.1 Main Control Valve
10.7.2 Priority Valve
10.8.1 Hydraulic Oil Reservoir
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
12.1.1 1644, 7013
12.1.2 1732, 8010
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
