JLG Telehandler 1075 4523 Service Manual 3122555000 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 1075, 4523 Telehandler
Part Number: 3122555000
Publication Date: 2025
Number of Pages: 640 Pages
Safety
Brand: JLG
Safety
General (concept)
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals (concept)
Machine Verification (concept)
General Machine Information and SpecificationsSpecifications (reference)
2.1.1 Travel Speed
2.1.2 Hydraulic Cylinder Performance
2.1.3 Cylinder Drift
2.1.4 Steering Angle Specifications
2.1.5 Electrical System
2.1.6 Engine Performance Specifications
2.1.7 Tires
Machine Temperature Chart (reference)
Serial Number Location
Fluids and Lubrication (reference)
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
After Treatment System
2.5.1 Automatic Exhaust System Cleaning (In-Mission)
2.5.2 Stationary Exhaust System Cleaning (Non-Mission)
ClearSky Smart Fleet
2.6.1 General
2.6.2 ClearSky Smart Fleet™ – Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance (reference)
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines (reference)
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule (reference)
3.3.1 Every 10 Hours
3.3.2 First 50 Hours
3.3.3 Every 50 Hours
3.3.4 First 250 Hours
3.3.5 Every 250 Hours
3.3.6 First 500 Hours or 6 Months
3.3.7 Every 500 Hours
3.3.8 Every 1000 Hours or 1 Year
3.3.9 Every 1500 Hours
3.3.10 Every 2000 Hours or 2 Years
3.3.11 Every 4000 Hours or 3 Years
3.3.12 Every 5000 Hours
Pins and Composite Bearing Repair Guidelines (task)
3.4.1 Filament Wound Bearings
Tires and Wheels (task)
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance (reference)
3.6.1 Service Brake Bleeding
3.6.2 Park Brake Bleeding (SAHR)
DEF Tank Inspection (task)
Boom Inspection and Maintenance (reference)
3.8.1 Boom Sections Adjustment
3.8.2 Boom Extend and Retract Chains
3.8.3 Inspection Guidelines
3.8.4 Expose Chains for Inspection
3.8.5 Chain Lubrication
3.8.6 Boom Wear Pads
Hydraulic Filter Replacement (task)
3.9.1 Hydraulic Filter Removal
3.9.2 Hydraulic Filter Installation
Testing, Calibrations and Special ProceduresSpecial Tools (reference)
4.1.1 Multimeter
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures (reference)
4.2.1 Starter
4.2.2 Fuel Level Sending Indicator Testing
Calibration Procedures (reference)
4.3.1 JLG Analyzer
4.3.2 Boom Angle Sensor Calibration
4.3.3 Load Stability Indicator (LSI) System Calibration
4.3.4 Park Brake Calibration/Maximum Drive Traction Test
Special Procedures (task)
4.4.1 Emergency Lowering Procedure
4.4.2 Lowering Procedure with Precision Gravity Lower System (PGLS)
4.4.3 Towing a Disabled Machine
4.4.4 Releasing Parking Brake for Towing When Engine is not Running
4.4.5 Transmission Fluid Replacement
4.4.6 Charge Air Cooler (CAC) Hose Draining
4.4.7 Hydraulic Oil Reservoir
4.4.8 Diesel Exhaust Fluid (DEF) System Cleaning
4.4.9 Fuel Tank Cleaning and Drying
4.4.10 Accumulators
4.4.11 Hydraulic Pressure Settings and Adjustments
4.4.12 Cylinder Checking Procedure
4.4.13 Cylinder Drift Test
4.4.14 Hydraulic Circuits
4.4.15 Hydraulic Pressures
4.4.16 Pressure Specifications
System SoftwareLoad Stability Indicator (LSI)
5.1.1 Load Stability Indicator
5.1.2 LSI Sensor
High Integrity Rear Axle Stabilization (HiRAS)
5.2.1 RAS Cylinder and Pressure Reducing Valve and Key Sub-components
5.2.2 HiRAS Integrity Check Procedure (Recommended)
5.2.3 HiRAS Health Check Failure Troubleshooting
5.2.4 Alternate Gauge Locations
Analyzer
5.3.1 Machine Data Access
5.3.2 JLG Hand Held Analyzer
5.3.3 JLG Mobile Analyzer
5.3.4 PC Analyzer/Loglifter
5.3.5 Analyzer Software (Version P27.0)
Access Level
Diagnostics (Software Version P27.0)
Machine Setup (Software Version P27.0)
Personalities (Software Version P27.0)
Operator Tools (Software Version P27.0)
Calibrations (Software Version P27.0)
Multifunction Display(If Equipped)
5.10.1 Technical Specification
5.10.2 Multifunction Display and Control Buttons
5.10.3 Main Menu
5.10.4 Calibrations
5.10.5 Setup and Maintenance
5.10.6 Troubleshooting
ClearSky (CS550) Configuration and Troubleshooting
5.11.1 ClearSky Smart FleetTM CS550 Configuration
5.11.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic (reference)
Fault Codes - Help Comment (00x)
Fault Codes - Power-Up (21x)
Fault Codes - Ground Inputs (23x)
Fault Codes - Other Inputs (24x)
Fault Codes - Function Prevented (25x)
Fault Codes - Line Contactor, Open-Circuit (31x)
Fault Codes - Line Contactor, Short-Circuit (32x)
Fault Codes - Output Drivers (33x)
Fault Codes - Engine (43x)
Fault Codes - Battery Supply (44x)
Fault Codes - Transmission and Drive System (46x)
Fault Codes - Communications (66x)
Fault Codes - Telematics (68x)
Fault Codes - Tilt Sensor (81x)
Fault Codes - Envelope Control (84x)
Fault Codes - Load Moment (85x)
Fault Codes - Steering (86x)
Fault Codes - Service Required (87x)
Fault Codes - Hardware (99x)
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety (reference)
Theories Of Operation (reference)
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components (concept)
Torque Values (reference)
7.4.1 Cylinder Torque Specifications
ElectricalsGeneral Information (reference)
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
8.3.1 General Overview
Harness Layouts (reference)
8.4.1 Harness Layout
8.4.2 Component Layout
8.4.3 Harness Layout
8.4.4 Component Layout
8.4.5 Harness Layout
8.4.6 Component Layout
Board Layouts (reference)
8.5.1 Cab Power Distribution Board
8.5.2 Frame Power Distribution Board
8.5.3 Option 1 Distribution Board
8.5.4 Option 2 Distribution Board
8.5.5 Engine Harness Fuses and Relays
Telematics Gateway
8.6.1 Telematics Gateway Table
8.6.2 Component Location
8.6.3 Telematics-Ready (TCU) Plug
8.6.4 Telematics Gateway Harness Breakdown
Removal and InstallationWheels (reference)
9.1.1 Removing Wheel and Tire Assembly from Machine
9.1.2 Installing Wheel and Tire Assembly onto Machine
Drive Assembly (reference)
9.2.1 Axle Assembly and Drive Shaft Troubleshooting
9.2.2 Axle
9.2.3 Drive Shafts
9.2.4 Transmission Components
Boom
9.3.1 Boom System Component Terminology
9.3.2 Troubleshooting
9.3.3 Boom System
9.3.4 Precision Gravity Lower System (PGLS)
9.3.5 Accumulator
9.3.6 Manual Quick Coupler
9.3.7 Hydraulic Quick Coupler
9.3.8 Forks
9.3.9 Boom Prop (if equipped)
9.3.10 Boom Wear Pad Installation, Lubrication
9.3.11 Boom Angle Sensor
Cab Components (reference)
9.4.1 Serial Number Plate
9.4.2 Cab Removal/Installation
9.4.3 Steering Wheel
9.4.4 Service Brake
9.4.5 Electronic Throttle Pedal
9.4.6 Joystick Assembly
9.4.7 Ignition Key Switch
9.4.8 Dash Switches
9.4.9 Front Windshield Wiper Motor
9.4.10 Rear Window Wiper Motor
9.4.11 Roof Window Wiper Motor
9.4.12 Washer Fluid Reservoir
9.4.13 Heater System (If Equipped)
9.4.14 Heater and Air Conditioning System(If Equipped)
9.4.15 Multifunction Display (If Equipped)
9.4.16 Right Side Cameras
Engine (reference)
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank Cap
9.5.5 Thermostat Replacement
9.5.6 Engine Coolant Temperature Sensor
9.5.7 Radiator Assembly Replacement
9.5.8 Hydraulic Oil Reservoir Removal/Installation
9.5.9 Diesel Exhaust Fluid (DEF) Tank
9.5.10 Diesel Exhaust Fluid (DEF) System Header
9.5.11 Diesel Exhaust Fluid (DEF) Pump Filter
9.5.12 Fuel Tank
9.5.13 Engine Exhaust System
9.5.14 Air Cleaner Assembly
9.5.15 Starter
9.5.16 Alternator
Transmission (reference)
9.6.1 Component Terminology
9.6.2 Transmission Serial Number
9.6.3 Transmission Removal/Installation
9.6.4 Hydrostatic Transmission Pump
9.6.5 Dual Pump Drive
9.6.6 Drive Motor
9.6.7 Gearbox
9.6.8 Back-up Alarm
Hydraulic Cylinders (reference)
9.7.1 General Cylinder Removal Instructions
9.7.2 Steering Cylinders
Hydraulic Pumps (reference)
9.8.1 Implement Pump
Hydraulic Valves (reference)
9.9.1 Main Control Valve
9.9.2 Priority Valve
9.9.3 Steering Column/Orbital Valve
9.9.4 Frame Leveling Valve or Outrigger/Frame Leveling Valve
9.9.5 Steer Select Valve
9.9.6 Ride Control Valve
Electrical Components (reference)
9.10.1 Battery
9.10.2 Electrical Master Switch
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly (reference)
10.1.1 Axle Assembly
10.1.2 Transmission Assembly
Boom (reference)
10.2.1 Fifth Boom Section Removal
10.2.2 Fourth Boom Section Removal
10.2.3 Third Boom Section Removal
10.2.4 Second Boom Section Removal
10.2.5 Hose Carrier Removal - Installation
10.2.6 Second Boom Section Installation
10.2.7 Third Boom Section Installation
10.2.8 Fourth Boom Section Installation
10.2.9 Fifth Boom Section Installation
10.2.10 Fifth Boom Section Removal/ Installation Only
10.2.11 Hose Carrier Assembly
Cab (concept)
Engine Components (reference)
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
10.5.1 Hydrostatic Pump
10.5.2 Gearbox
10.5.3 Drive Motor
Hydraulic Cylinders (task)
10.6.1 General Cylinder Disassembly
10.6.2 Hydraulic Cylinder Repair Information
10.7.1 Main Control Valve
10.7.2 Priority Valve
Hydraulic Components (reference)
10.8.1 Hydraulic Oil Reservoir
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics (concept)
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
