Hyundai
86
176,834
JLG Telehandler 1075 4523 Service Manual 3122550100 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 1075, 4523 Telehandler
Part Number: 3122550100
Publication Date: 2025
Number of Pages: 640 Pages
Safety
General (concept)​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards (task)​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals (concept)​
Machine Verification (concept)​
Specifications (reference)​
2.1.1 Travel Speed​
2.1.2 Hydraulic Cylinder Performance​
2.1.3 Cylinder Drift​
2.1.4 Steering Angle Specifications​
2.1.5 Electrical System​
2.1.6 Engine Performance Specifications​
2.1.7 Tires​
Machine Temperature Chart (reference)​
Serial Number Location​
Fluids and Lubrication (reference)​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
After Treatment System​
2.5.1 Automatic Exhaust System Cleaning (In-Mission)​
2.5.2 Stationary Exhaust System Cleaning (Non-Mission)​
ClearSky Smart Fleet​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ – Access Control​
Machine Preparation, Inspection, and Maintenance (reference)​
3.1.1 Preparation, Inspection, and Maintenance​
3.1.2 Pre-Start Inspection​
3.1.3 Pre-Delivery Inspection​
Service and Guidelines (reference)​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule (reference)​
3.3.1 Every 10 Hours​
3.3.2 First 50 Hours​
3.3.3 Every 50 Hours​
3.3.4 First 250 Hours​
3.3.5 Every 250 Hours​
3.3.6 First 500 Hours or 6 Months​
3.3.7 Every 500 Hours​
3.3.8 Every 1000 Hours or 1 Year​
3.3.9 Every 1500 Hours​
3.3.10 Every 2000 Hours or 2 Years​
3.3.11 Every 4000 Hours or 3 Years​
3.3.12 Every 5000 Hours​
Pins and Composite Bearing Repair Guidelines (task)​
3.4.1 Filament Wound Bearings​
Tires and Wheels (task)​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Brake Maintenance (reference)​
3.6.1 Service Brake Bleeding​
3.6.2 Park Brake Bleeding (SAHR)​
DEF Tank Inspection (task)​
Boom Inspection and Maintenance (reference)​
3.8.1 Boom Sections Adjustment​
3.8.2 Boom Extend and Retract Chains​
3.8.3 Inspection Guidelines​
3.8.4 Expose Chains for Inspection​
3.8.5 Chain Lubrication​
3.8.6 Boom Wear Pads​
Hydraulic Filter Replacement (task)​
3.9.1 Hydraulic Filter Removal​
3.9.2 Hydraulic Filter Installation​
Testing, Calibrations and Special Procedures
Special Tools (reference)​
4.1.1 Multimeter​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures (reference)​
4.2.1 Starter​
4.2.2 Fuel Level Sending Indicator Testing​
Calibration Procedures (reference)​
4.3.1 JLG Analyzer​
4.3.2 Boom Angle Sensor Calibration​
4.3.3 Load Stability Indicator (LSI) System Calibration​
4.3.4 Park Brake Calibration/Maximum Drive Traction Test​
Special Procedures (task)​
4.4.1 Emergency Lowering Procedure​
4.4.2 Lowering Procedure with Precision Gravity Lower System (PGLS)​
4.4.3 Towing a Disabled Machine​
4.4.4 Releasing Parking Brake for Towing When Engine is not Running​
4.4.5 Transmission Fluid Replacement​
4.4.6 Charge Air Cooler (CAC) Hose Draining​
4.4.7 Hydraulic Oil Reservoir​
4.4.8 Diesel Exhaust Fluid (DEF) System Cleaning​
4.4.9 Fuel Tank Cleaning and Drying​
4.4.10 Accumulators​
4.4.11 Hydraulic Pressure Settings and Adjustments​
4.4.12 Cylinder Checking Procedure​
4.4.13 Cylinder Drift Test​
4.4.14 Hydraulic Circuits​
4.4.15 Hydraulic Pressures​
4.4.16 Pressure Specifications​
System Software
Load Stability Indicator (LSI)​
5.1.1 Load Stability Indicator​
5.1.2 LSI Sensor​
High Integrity Rear Axle Stabilization (HiRAS)​
5.2.1 RAS Cylinder and Pressure Reducing Valve and Key Sub-components​
5.2.2 HiRAS Integrity Check Procedure (Recommended)​
5.2.3 HiRAS Health Check Failure Troubleshooting​
5.2.4 Alternate Gauge Locations​
Analyzer​
5.3.1 Machine Data Access​
5.3.2 JLG Hand Held Analyzer​
5.3.3 JLG Mobile Analyzer​
5.3.4 PC Analyzer/Loglifter​
5.3.5 Analyzer Software (Version P27.0)​
Access Level​
Diagnostics (Software Version P27.0)​
Machine Setup (Software Version P27.0)​
Personalities (Software Version P27.0)​
Operator Tools (Software Version P27.0)​
Calibrations (Software Version P27.0)​
Multifunction Display(If Equipped)​
5.10.1 Technical Specification​
5.10.2 Multifunction Display and Control Buttons​
5.10.3 Main Menu​
5.10.4 Calibrations​
5.10.5 Setup and Maintenance​
5.10.6 Troubleshooting​
5.11.1 ClearSky Smart FleetTM CS550 Configuration​
5.11.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Engine Diagnostic (reference)​
Fault Codes - Help Comment (00x)​
Fault Codes - Power-Up (21x)​
Fault Codes - Ground Inputs (23x)​
Fault Codes - Other Inputs (24x)​
Fault Codes - Function Prevented (25x)​
Fault Codes - Line Contactor, Open-Circuit (31x)​
Fault Codes - Line Contactor, Short-Circuit (32x)​
Fault Codes - Output Drivers (33x)​
Fault Codes - Engine (43x)​
Fault Codes - Battery Supply (44x)​
Fault Codes - Transmission and Drive System (46x)​
Fault Codes - Communications (66x)​
Fault Codes - Telematics (68x)​
Fault Codes - Tilt Sensor (81x)​
Fault Codes - Envelope Control (84x)​
Fault Codes - Load Moment (85x)​
Fault Codes - Steering (86x)​
Fault Codes - Service Required (87x)​
Fault Codes - Hardware (99x)​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety (reference)​
Theories Of Operation (reference)​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components (concept)​
Torque Values (reference)​
7.4.1 Cylinder Torque Specifications​
Electricals
General Information (reference)​
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Electrical Connector Examples​
Electrical Connectors​
Electrical Component Terminology​
8.3.1 General Overview​
Harness Layouts (reference)​
8.4.1 Harness Layout​
8.4.2 Component Layout​
8.4.3 Harness Layout​
8.4.4 Component Layout​
8.4.5 Harness Layout​
8.4.6 Component Layout​
Board Layouts (reference)​
8.5.1 Cab Power Distribution Board​
8.5.2 Frame Power Distribution Board​
8.5.3 Option 1 Distribution Board​
8.5.4 Option 2 Distribution Board​
8.5.5 Engine Harness Fuses and Relays​
Telematics Gateway​
8.6.1 Telematics Gateway Table​
8.6.2 Component Location​
8.6.3 Telematics-Ready (TCU) Plug​
8.6.4 Telematics Gateway Harness Breakdown​
Wheels (reference)​
9.1.1 Removing Wheel and Tire Assembly from Machine​
9.1.2 Installing Wheel and Tire Assembly onto Machine​
Drive Assembly (reference)​
9.2.1 Axle Assembly and Drive Shaft Troubleshooting​
9.2.2 Axle​
9.2.3 Drive Shafts​
9.2.4 Transmission Components​
Boom​
9.3.1 Boom System Component Terminology​
9.3.2 Troubleshooting​
9.3.3 Boom System​
9.3.4 Precision Gravity Lower System (PGLS)​
9.3.5 Accumulator​
9.3.6 Manual Quick Coupler​
9.3.7 Hydraulic Quick Coupler​
9.3.8 Forks​
9.3.9 Boom Prop (if equipped)​
9.3.10 Boom Wear Pad Installation, Lubrication​
9.3.11 Boom Angle Sensor​
Cab Components (reference)​
9.4.1 Serial Number Plate​
9.4.2 Cab Removal/Installation​
9.4.3 Steering Wheel​
9.4.4 Service Brake​
9.4.5 Electronic Throttle Pedal​
9.4.6 Joystick Assembly​
9.4.7 Ignition Key Switch​
9.4.8 Dash Switches​
9.4.9 Front Windshield Wiper Motor​
9.4.10 Rear Window Wiper Motor​
9.4.11 Roof Window Wiper Motor​
9.4.12 Washer Fluid Reservoir​
9.4.13 Heater System (If Equipped)​
9.4.14 Heater and Air Conditioning System(If Equipped)​
9.4.15 Multifunction Display (If Equipped)​
9.4.16 Right Side Cameras​
Engine (reference)​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Engine Replacement​
9.5.4 Surge Tank Cap​
9.5.5 Thermostat Replacement​
9.5.6 Engine Coolant Temperature Sensor​
9.5.7 Radiator Assembly Replacement​
9.5.8 Hydraulic Oil Reservoir Removal/Installation​
9.5.9 Diesel Exhaust Fluid (DEF) Tank​
9.5.10 Diesel Exhaust Fluid (DEF) System Header​
9.5.11 Diesel Exhaust Fluid (DEF) Pump Filter​
9.5.12 Fuel Tank​
9.5.13 Engine Exhaust System​
9.5.14 Air Cleaner Assembly​
9.5.15 Starter​
9.5.16 Alternator​
Transmission (reference)​
9.6.1 Component Terminology​
9.6.2 Transmission Serial Number​
9.6.3 Transmission Removal/Installation​
9.6.4 Hydrostatic Transmission Pump​
9.6.5 Dual Pump Drive​
9.6.6 Drive Motor​
9.6.7 Gearbox​
9.6.8 Back-up Alarm​
Hydraulic Cylinders (reference)​
9.7.1 General Cylinder Removal Instructions​
9.7.2 Steering Cylinders​
Hydraulic Pumps (reference)​
9.8.1 Implement Pump​
Hydraulic Valves (reference)​
9.9.1 Main Control Valve​
9.9.2 Priority Valve​
9.9.3 Steering Column/Orbital Valve​
9.9.4 Frame Leveling Valve or Outrigger/Frame Leveling Valve​
9.9.5 Steer Select Valve​
9.9.6 Ride Control Valve​
Electrical Components (reference)​
9.10.1 Battery​
9.10.2 Electrical Master Switch​
9.11.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
10.1.1 Axle Assembly​
10.1.2 Transmission Assembly​
Boom (reference)​
10.2.1 Fifth Boom Section Removal​
10.2.2 Fourth Boom Section Removal​
10.2.3 Third Boom Section Removal​
10.2.4 Second Boom Section Removal​
10.2.5 Hose Carrier Removal - Installation​
10.2.6 Second Boom Section Installation​
10.2.7 Third Boom Section Installation​
10.2.8 Fourth Boom Section Installation​
10.2.9 Fifth Boom Section Installation​
10.2.10 Fifth Boom Section Removal/ Installation Only​
10.2.11 Hose Carrier Assembly​
Cab (concept)​
Engine Components (reference)​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
10.5.1 Hydrostatic Pump​
10.5.2 Gearbox​
10.5.3 Drive Motor​
Hydraulic Cylinders (task)​
10.6.1 General Cylinder Disassembly​
10.6.2 Hydraulic Cylinder Repair Information​
10.7.1 Main Control Valve​
10.7.2 Priority Valve​
Hydraulic Components (reference)​
10.8.1 Hydraulic Oil Reservoir​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Definitions​
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.5 Assembly Instructions for 45° SAE Flare Fittings​
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings​
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)​
11.1.14 Double Wrench Method​
11.1.15 FFWR and TFFT Methods​
11.1.16 Adjustable Stud End Assembly​
11.1.17 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE​
11.2.2 Metric​
Schematics
Hydraulic Schematics (concept)​
Electrical Schematics​
