JLG Telehandler 1055 1255 Parts Manual 3122330200
Brand: JLG
Type of Machine: Telehandler
Model: JLG 1055, 1255 Telehandler
Part Number: 3122330200
Publication Date: 2025
Number of Pages: 1182 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. FRAME COVER INSTALLATION (ULS)
FIGURE 1-2. FRAME COVER INSTALLATION (LS)
FIGURE 1-3. FRAME LEVEL CYLINDER PIN INSTALLATION
FIGURE 1-4. REAR STABILIZER CYLINDER PIN INSTALLATION
FIGURE 1-5. OUTRIGGERS INSTALLATION
FIGURE 1-6. TANK INSTALLATION
FIGURE 1-7. FUEL TANK INSTALLATION
FIGURE 1-8. HYDRAULIC TANK INSTALLATION
FIGURE 1-9. ENGINE MOUNTING INSTALLATION
FIGURE 1-10. ENGINE ENCLOSURE INSTALLATION
FIGURE 1-11. ENGINE ENCLOSURE COVER INSTALLATION
FIGURE 1-12. HOOD ASSEMBLY
FIGURE 1-13. MIRROR INSTALLATION
FIGURE 1-14. TOOLBOX INSTALLATION (Prior to SN 0160139974, Prior to SN 0160139955, Including 0160073784 and 0160130180)
FIGURE 1-15. COUNTERWEIGHT INSTALLATION (1055)
FIGURE 1-16. COUNTERWEIGHT INSTALLATION (1255)
SECTION 2 - BOOMFIGURE 2-1. BOOM ASSEMBLY (1055)
FIGURE 2-2. BOOM ASSEMBLY (1255)
FIGURE 2-3. FIRST BOOM ASSEMBLY (1055)
FIGURE 2-4. FIRST BOOM ASSEMBLY (1255)
FIGURE 2-5. SECOND BOOM ASSEMBLY (1055)
FIGURE 2-6. SECOND BOOM ASSEMBLY (1255)
FIGURE 2-7. THIRD BOOM ASSEMBLY (1055)
FIGURE 2-8. THIRD BOOM ASSEMBLY (1255)
FIGURE 2-9. FOURTH BOOM ASSEMBLY (1055)
FIGURE 2-10. FOURTH BOOM ASSEMBLY (1255)
FIGURE 2-11. EXTEND CYLINDER PINS INSTALLATION
FIGURE 2-12. EXTEND CHAIN INSTALLATION - SECOND BOOM SECTION (1055)
FIGURE 2-13. EXTEND CHAIN INSTALLATION - SECOND BOOM SECTION (1255)
FIGURE 2-14. EXTEND CHAIN INSTALLATION - SECOND BOOM SECTION (1055)
FIGURE 2-15. EXTEND CHAIN INSTALLATION - SECOND BOOM SECTION (1255)
FIGURE 2-16. RETRACT CHAIN INSTALLATION - THIRD BOOM SECTION
FIGURE 2-17. RETRACT CHAIN INSTALLATION - THIRD BOOM SECTION (1055)
FIGURE 2-18. RETRACT CHAIN INSTALLATION - THIRD BOOM SECTION (1255)
FIGURE 2-19. BOOM PIN INSTALLATION
FIGURE 2-20. BOOM PIVOT PIN INSTALLATION
FIGURE 2-21. LIFT CYLINDER PIN INSTALLATION
FIGURE 2-22. COMPENSATION CYLINDER PIN INSTALLATION
FIGURE 2-23. BOOM BRUSHES INSTALLATION
FIGURE 2-24. BOOM ANGLE INDICATOR INSTALLATION
FIGURE 2-25. MANUAL QUICK COUPLER INSTALLATION
FIGURE 2-26. HYDRAULIC QUICK COUPLER INSTALLATION
FIGURE 2-27. HYDRAULIC QUICK COUPLER INSTALLATION
FIGURE 2-28. QUICK COUPLING CYLINDER & FITTING ASSEMBLY
FIGURE 2-29. COUPLING PIN INSTALLATION
FIGURE 2-30. TILT CYLINDER PIN INSTALLATION
FIGURE 2-31. QUICK COUPLER ASSEMBLY
FIGURE 2-32. BOOM PROP INSTALLATION (ANSI)
FIGURE 2-33. BOOM PROP INSTALLATION (CANADA)
FIGURE 2-34. BOOM PROP BRACKET
SECTION 3 - ATTACHMENTSFIGURE 3-1. BASKET, PERSONNEL (ENGLISH DECALS)
FIGURE 3-2. BASKET, PERSONNEL (ENGLISH/FRENCH DECALS)
FIGURE 3-3. BASKET, PERSONNEL (ISO DECALS)
FIGURE 3-4. BASKET ASSEMBLY
FIGURE 3-5. BOOM - ADJUSTABLE
FIGURE 3-6. BOOM - ADJUSTABLE (FORK MOUNTED)
FIGURE 3-7. BOOM - 3FT WITH WINCH
FIGURE 3-8. BOOM - 12FT WITH WINCH
FIGURE 3-9. BOOM - 12FT WITHOUT WINCH (WELDED ON HOOK)
FIGURE 3-10. BOOM - 12FT WITHOUT WINCH (BOLTED ON HOOK)
FIGURE 3-11. BOOM - 15FT WITHOUT WINCH (WELDED ON HOOK)
FIGURE 3-12. BOOM - 15FT WITHOUT WINCH (BOLTED ON HOOK)
FIGURE 3-13. BUCKET - 72IN 1.0 YD³
FIGURE 3-14. BUCKET - 96IN 1.3 YD³ (GENERAL PURPOSE)
FIGURE 3-15. BUCKET - 96IN 1.3 YD³ (MULTI-PURPOSE)
FIGURE 3-16. BUCKET - 102IN 2.0 YD³
FIGURE 3-17. BUCKET - FORK MOUNTED (1.0 M³)
FIGURE 3-18. CARRIAGE ASSEMBLY - 48IN SIDE SHIFT
FIGURE 3-19. CARRIAGE ASSEMBLY - 50IN
FIGURE 3-20. CARRIAGE ASSEMBLY - 50IN DUAL FORK POSITIONING (10K)
FIGURE 3-21. CARRIAGE ASSEMBLY - 50IN DUAL FORK POSITIONING (12K)
FIGURE 3-22. CARRIAGE ASSEMBLY - DUAL FORK VALVE & FITTINGS
FIGURE 3-23. CARRIAGE ASSEMBLY - 50IN/12000# CAPACITY SIDE TILT (WITH BASE PIVOT WEAR PADS)
FIGURE 3-24. CARRIAGE ASSEMBLY - 50IN/12000# CAPACITY SIDE TILT (WITHOUT BASE PIVOT WEAR PADS)
FIGURE 3-25. CARRIAGE ASSEMBLY - 60IN
FIGURE 3-26. CARRIAGE ASSEMBLY - 60IN/12000# CAPACITY SIDE TILT (WITH BASE PIVOT WEAR PADS)
FIGURE 3-27. CARRIAGE ASSEMBLY - 60IN/12000# CAPACITY SIDE TILT (WITHOUT BASE PIVOT WEAR PADS)
FIGURE 3-28. CARRIAGE ASSEMBLY - 72IN
FIGURE 3-29. CARRIAGE ASSEMBLY - 72IN FORK POSITIONING (12K)
FIGURE 3-30. CARRIAGE ASSEMBLY - 72IN/12000# CAPACITY SIDE TILT (WITHOUT BASE PIVOT WEAR PADS)
FIGURE 3-31. CARRIAGE ASSEMBLY - 72IN/12000# CAPACITY SIDE TILT (WITH BASE PIVOT WEAR PADS)
FIGURE 3-32. CARRIAGE ASSEMBLY - 72IN 90 DEGREE SWING
FIGURE 3-33. CARRIAGE ASSEMBLY – 96IN/12000 CAPACITY STANDARD
FIGURE 3-34. CARRIAGE ASSEMBLY - SWING (180 )
FIGURE 3-35. CARRIAGE INSTALLATION - DRYWALL SWING
FIGURE 3-36. CARRIAGE ASSEMBLY - DRYWALL ROTATING CARRIAGE
FIGURE 3-37. CARRIAGE ASSEMBLY - DRYWALL BOARD HANDLER
FIGURE 3-38. CARRIAGE ASSEMBLY - DRYWALL PIVOT FRAME GROUP
FIGURE 3-39. CARRIAGE ASSEMBLY - DRYWALL CYLINDER
FIGURE 3-40. CARRIAGE ASSEMBLY - DRYWALL HYDRAULIC GROUP
FIGURE 3-41. CARRIAGE ASSEMBLY - DRYWALL VALVE ASSEMBLY
FIGURE 3-42. CARRIAGE ASSEMBLY - DRYWALL CYLINDER
FIGURE 3-43. CARRIAGE ASSEMBLY - DRYWALL FORK GROUP
FIGURE 3-44. FORK - 1.6INX6INX60INLUMBER FORK
FIGURE 3-45. FORK - 2INX2INX48IN BLOCK FORK
FIGURE 3-46. FORK - 2INX6INX48IN TAPERED FORK
FIGURE 3-47. FORK - 2INX6INX72IN LUMBER FORK
FIGURE 3-48. FORK - 2INX7INX60INLUMBER FORK
FIGURE 3-49. FORK - 2.36INX4INX48IN PALLET FORK
FIGURE 3-50. FORK - 2.36INX4INX48IN PALLET FORK (DUAL:FORK POSITIONING)
FIGURE 3-51. FORK - 2.36INX4INX60IN PALLET FORK (DUAL:FORK POSITIONING)
FIGURE 3-52. FORK - 2.36INX5INX48IN PALLET FORK (WITH OR WITHOUT DUAL FORK POSITIONING)
FIGURE 3-53. FORK - 2.36INX5INX60IN PALLET FORK (WITH OR WITHOUT DUAL FORK POSITIONING)
FIGURE 3-54. FORK - 2.36INX5INX72IN PALLET FORK (DUAL:FORK POSITIONING) (Prior to SN 0160139974, Prior to SN 0160139955, Including 0160073784 and 0160130180)
FIGURE 3-55. FORK - 2.36INX6INX60IN PALLET FORK
FIGURE 3-56. FORK 2.36X5X96/12000# CAPACITY
FIGURE 3-57. FORK CLAMPS INSTALLATION
FIGURE 3-58. FORK EXTENSION - 90IN
FIGURE 3-59. PLATFORM (FORK MOUNTED) (4X9.8)
FIGURE 3-60. PLATFORM (FORK MOUNTED) (4X8 WITH DOORS)
FIGURE 3-61. HOOK - COUPLER MOUNTED
FIGURE 3-62. HOOK - FORK MOUNTED
FIGURE 3-63. LIFTING HOOK (10K)
FIGURE 3-64. MAST - 8FT
FIGURE 3-65. MAST - 8FT SIDE TILT
FIGURE 3-66. MAST CYLINDER ASSEMBLY
FIGURE 3-67. MAST DECAL KIT
FIGURE 3-68. PIPE HANDLER
FIGURE 3-69. SWEEPER ASSEMBLY
FIGURE 3-70. SWEEPER - HOPPER ASSEMBLY
FIGURE 3-71. SWEEPER - BODY ASSEMBLY
FIGURE 3-72. SWEEPER - MOTOR ASSEMBLY
FIGURE 3-73. SWEEPER - IDLER ASSEMBLY
FIGURE 3-74. SWEEPER - CORE ASSEMBLY
FIGURE 3-75. SWEEPER - HYDRAULIC SINGLE MOTOR ASSEMBLY
FIGURE 3-76. TRASH HOPPER
FIGURE 3-77. TELESCOPE PIVOT ADJUSTABLE JIB (10K)
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION (ULS)
FIGURE 4-2. ENGINE INSTALLATION (LS)
FIGURE 4-3. 3.8L ENGINE (ULS)
FIGURE 4-4. 3.8L ENGINE (LS)
FIGURE 4-5. FUEL LINES INSTALLATION (ULS)
FIGURE 4-6. FUEL LINES INSTALLATION (LS)
FIGURE 4-7. PRIMARY FUEL FILTER INSTALLATION (ULS)
FIGURE 4-8. PRIMARY FUEL FILTER INSTALLATION (LS)
FIGURE 4-9. FUEL TANK ASSEMBLY
FIGURE 4-10. COOLING PACKAGE INSTALLATION (ULS)
FIGURE 4-11. COOLING PACKAGE INSTALLATION (LS)
FIGURE 4-12. RADIATOR COOLING PACKAGE
FIGURE 4-13. HOC LINES INSTALLATION
FIGURE 4-14. COOLANT LINES INSTALLATION (ULS)
FIGURE 4-15. COOLANT LINES INSTALLATION (LS)
FIGURE 4-16. CAC LINES INSTALLATION (ULS)
FIGURE 4-17. CAC LINES INSTALLATION (LS)
FIGURE 4-18. TOC LINES INSTALLATION
FIGURE 4-19. SURGE TANK INSTALLATION
FIGURE 4-20. FAN INSTALLATION
FIGURE 4-21. FAN GUARD INSTALLATION
FIGURE 4-22. AIR INTAKE LINES INSTALLATION (ULS)
FIGURE 4-23. AIR CLEANER LINES INSTALLATION (LS)
FIGURE 4-24. AIR CLEANER INSTALLATION (ULS)
FIGURE 4-25. AIR CLEANER INSTALLATION (LS)
FIGURE 4-26. AIR CLEANER ASSEMBLY (90/100KW)
FIGURE 4-27. AIR INTAKE DUCT INSTALLATION
FIGURE 4-28. EXHAUST INSTALLATION (ULS)
FIGURE 4-29. EXHAUST INSTALLATION (LS)
FIGURE 4-30. MUFFLER INSTALLATION (LS)
FIGURE 4-31. DEF LINES INSTALLATION
FIGURE 4-32. DEF PUMP LINES INSTALLATION
FIGURE 4-33. DEF TANK INSTALLATION
FIGURE 4-34. DEF PUMP AND CONTROL INSTALLATION
FIGURE 4-35. UREA PUMP
FIGURE 4-36. DEF TANK ASSEMBLY
FIGURE 4-37. DEF BREATHER VALVE
FIGURE 4-38. ENGINE PARTS INSTALLATION (NO HEATER)
FIGURE 4-39. ENGINE PARTS INSTALLATION (HEATER)
FIGURE 4-40. A/C PUMP INSTALLATION (ULS)
FIGURE 4-41. A/C PUMP INSTALLATION (LS)
FIGURE 4-42. A/C LINES INSTALLATION
FIGURE 4-43. ENGINE OIL QUICK DRAIN INSTALLATION
FIGURE 4-44. FUEL CAP ASSEMBLY
FIGURE 4-45. HEATER BREATHER (Prior to SN 0160143912, Prior to SN 0160143931)
FIGURE 4-46. HEATER BREATHER - CUMMINS (110HP) (SN 0160143913 to Present, SN 0160143932 to Present)
FIGURE 4-47. AIR INTAKE SHUT OFF VALVE INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. TRANSMISSION INSTALLATION
FIGURE 5-2. POWERSHIFT TRANSMISSION
FIGURE 5-3. TRANSMISION, ENGINE CONNECTION
FIGURE 5-4. TRANSMISSION, CONVERTER
FIGURE 5-5. TRANSMISSION, INPUT
FIGURE 5-6. TRANSMISSION, HOUSING GROUP 1
FIGURE 5-7. TRANSMISSION, HOUSING GROUP 2
FIGURE 5-8. TRANSMISSION, CLUTCH GROUP 1
FIGURE 5-9. TRANSMISSION, CLUTCH GROUP 2
FIGURE 5-10. TRANSMISSION, COUPLING GROUP 1
FIGURE 5-11. TRANSMISSION, COUPLING GROUP 2
FIGURE 5-12. TRANSMISSION, COUPLING GROUP 3
FIGURE 5-13. TRANSMISSION, COUPLING GROUP 4
FIGURE 5-14. TRANSMISSION, OUTPUT
FIGURE 5-15. TRANSMISSION, POWER TAKE-OFF
FIGURE 5-16. TRANSMISSION, CONTROL UNIT
FIGURE 5-17. TRANSMISSION, SHIFT SYSTEM
FIGURE 5-18. TRANSMISSION, PRESSURE REGULATOR
FIGURE 5-19. TRANSMISSION, PRESSURE OIL PUMP
FIGURE 5-20. TRANSMISSION, INDUCTIVE TRANSMITTER
FIGURE 5-21. TRANSMISSION, FILTER
FIGURE 5-22. TRANSMISSION, OIL DIPSTICK
FIGURE 5-23. TRANSMISSION, ACCESSORIES
FIGURE 5-24. TRANSMISSION, TRANSFER BOX HOUSING 1
FIGURE 5-25. TRANSMISSION, TRANSFER BOX HOUSING 2
FIGURE 5-26. TRANSMISSION, TRANSFER BOX HOUSING INPUT
FIGURE 5-27. TRANSMISSION, TRANSFER BOX HOUSING OUTPUT 1
FIGURE 5-28. TRANSMISSION, TRANSFER BOX HOUSING OUTPUT 2
FIGURE 5-29. DRIVE TRAIN INSTALLATION
FIGURE 5-30. DRIVE SHAFTS INSTALLATION
FIGURE 5-31. FRONT DRIVE SHAFT INSTALLATION
FIGURE 5-32. FRONT DRIVE SHAFT ASSEMBLY
FIGURE 5-33. FRONT MID SHAFT INSTALLATION
FIGURE 5-34. FRONT MID DRIVE SHAFT ASSEMBLY
FIGURE 5-35. REAR DRIVE SHAFT INSTALLATION
FIGURE 5-36. REAR DRIVE SHAFT ASSEMBLY
FIGURE 5-37. FRONT AXLE INSTALLATION
FIGURE 5-38. FRONT AXLE MOUNTING INSTALLATION, 110HP
FIGURE 5-39. FRONT AXLE ASSEMBLY - CENTRAL HOUSING
FIGURE 5-40. FRONT AXLE ASSEMBLY - DIFFERENTIAL
FIGURE 5-41. FRONT AXLE ASSEMBLY - HUB REDUCTION
FIGURE 5-42. FRONT AXLE ASSEMBLY - BRAKES
FIGURE 5-43. FRONT AXLE ASSEMBLY - STEERING
FIGURE 5-44. FRONT AXLE ASSEMBLY - TRUION
FIGURE 5-45. REAR AXLE INSTALLATION
FIGURE 5-46. REAR AXLE MOUNTING INSTALLATION
FIGURE 5-47. REAR AXLE ASSEMBLY - CENTRAL HOUSING
FIGURE 5-48. REAR AXLE ASSEMBLY - DIFFERENTIAL
FIGURE 5-49. REAR AXLE ASSEMBLY - HUB REDUCTION
FIGURE 5-50. REAR AXLE ASSEMBLY - BRAKES
FIGURE 5-51. REAR AXLE ASSEMBLY - STEERING
FIGURE 5-52. REAR AXLE ASSEMBLY - TRUNION
FIGURE 5-53. LSI AXLE SENSOR INSTALLATION
FIGURE 5-54. LSI SENSOR INSTALLATION
FIGURE 5-55. TIRE/WHEEL SET 14-24 16PR - AIR
FIGURE 5-56. TIRE/WHEEL SET - 14.00-24 FOAM FILLED
FIGURE 5-57. TIRE/WHEEL SET - 14.00-24 E-3 FOAM FILLED (SUNSHINE)
FIGURE 5-58. TIRE/WHEEL SET 14-24 - FOAM-FILLED (E-3) (NON-MARKING) (SUNSHINE)
FIGURE 5-59. TIRE/WHEEL SET 14-24 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-60. TIRE/WHEEL SET - 14.00-24 SOLIDEAL (DIRECTIONAL)
FIGURE 5-61. TIRE/WHEEL SET 14-28 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-62. TIRE/WHEEL SET 14-28 SOLIDBOSS (NON-DIRECTIONAL)
FIGURE 5-63. TIRE/WHEEL SET - 17.50-25 AIR
FIGURE 5-64. TIRE/WHEEL SET - 17.50-25 - FOAM FILLED
FIGURE 5-65. TIRE SET - 18 X 625 (TURF PNEUMATIC)
FIGURE 5-66. TIRE/WHEEL SET 360/85-28 - SOLID
FIGURE 5-67. TIRE/WHEEL SET 400/75-28 - AIR
FIGURE 5-68. TIRE/WHEEL SET - 400/75-28 - PNEUMATIC NON MARKING
FIGURE 5-69. TIRE/WHEEL SET 400/75-28 - FOAM FILLED
FIGURE 5-70. TIRE/WHEEL SET 400/75-28 - FOAM FILLED NON MARKING
FIGURE 5-71. FENDER INSTALLATION
FIGURE 5-72. WHEEL CHOCK INSTALLATION (Prior to SN 0160139974, Prior to SN 0160139955, Including 0160073784 and 0160130180)
SECTION 6 - CABFIGURE 6-1. CAB MOUNTING
FIGURE 6-2. CAB MOUNTS INSTALLATION
FIGURE 6-3. FRONT CAB OUTRIGGER INSTALLATION
FIGURE 6-4. CAB FENDER INSTALLATION
FIGURE 6-5. CAB FENDER INSTALLATION REAR (LH)
FIGURE 6-6. CAB GUARD INSTALLATION (TOP)
FIGURE 6-7. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-8. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-9. OROPS CAB INSTALLATION
FIGURE 6-10. EROPS CAB INSTALLATION
FIGURE 6-11. LSI ENCLOSED CAB INSTALLATION
FIGURE 6-12. LSI OPEN CAB INSTALLATION
FIGURE 6-13. CAB, TRIM KIT
FIGURE 6-14. CAB, TRIM KIT
FIGURE 6-15. CAB, EPD CAULK
FIGURE 6-16. OPEN CAB ASSEMBLY
FIGURE 6-17. OPEN CAB PLUG GROUP
FIGURE 6-18. OPEN CAB, LSI DISPLAY INSTALLATION
FIGURE 6-19. ENCLOSED CAB ASSEMBLY
FIGURE 6-20. REAR WINDOW INSTALLATION
FIGURE 6-21. DOOR INSTALLATION
FIGURE 6-22. ENCLOSED CAB PLUG GROUP
FIGURE 6-23. LSI DISPLAY INSTALLATION
FIGURE 6-24. BASIC MIRROR INSTALLATION
FIGURE 6-25. FRONT COVER INSTALLATION (ENCLOSED CAB)
FIGURE 6-26. FRONT COVER INSTALLATION (OPEN CAB)
FIGURE 6-27. LEVEL INDICATOR INSTALLATION
FIGURE 6-28. FRONT WIPER INSTALLATION
FIGURE 6-29. WASHER TANK INSTALLATION
FIGURE 6-30. REAR WINDOW INSTALLATION (WO/WIPER) (ANSI)
FIGURE 6-31. REAR WINDOW INSTALLATION (WO/WIPER) (ISO)
FIGURE 6-32. REAR WINDOW INSTALLATION (WO/WIPER) (ENG/SPAN)
FIGURE 6-33. HEADLINER INSTALLATION
FIGURE 6-34. TRIM INSTALLATION - OPEN CAB
FIGURE 6-35. TRIM INSTALLATION - ENCLOSED CAB
FIGURE 6-36. DASH COVER ASSEMBLY - ENCLOSED CAB
FIGURE 6-37. OPEN CAB FRONT COVER
FIGURE 6-38. ENCLOSED CAB FRONT COVER
FIGURE 6-39. SEAT INSTALLATION - CLOTH (ORANGE SEAT BELT)
FIGURE 6-40. SEAT INSTALLATION - VINYL
FIGURE 6-41. SEAT (ORANGE SEAT BELT)
FIGURE 6-42. SEAT ASSEMBLY
FIGURE 6-43. ARMREST
FIGURE 6-44. SEAT BELT INSTALLATION (3 INCH)
FIGURE 6-45. HEATER INSTALLATION
FIGURE 6-46. HEATER AND A/C INSTALLATION (CAB PARTS)
FIGURE 6-47. HEATER ASSEMBLY
FIGURE 6-48. HEATER ASSEMBLY
FIGURE 6-49. HEATER AND A/C ASSEMBLY
FIGURE 6-50. HEATER AND A/C ASSEMBLY
FIGURE 6-51. CAB CONDENSER ASSEMBLY
FIGURE 6-52. A/C RECEIVER DRIER
FIGURE 6-53. CONDENSER
FIGURE 6-54. REAR WIPER INSTALLATION
FIGURE 6-55. ROOF WIPER INSTALLATION
FIGURE 6-56. ROOF CAP INSTALLATION (A/C)
FIGURE 6-57. ROOF CAP INSTALLATION (NO A/C)
FIGURE 6-58. NON SKID TAPE INSTALLATION
FIGURE 6-59. EXTERNAL WINDOW RELEASE INSTALLATION (CAN & ISO)
FIGURE 6-60. SWITCH LIGHT INSTALLATION
FIGURE 6-61. ROOF PIGTAIL CAP INSTALLATION
FIGURE 6-62. NO SUNSCREEN INSTALLATION
FIGURE 6-63. RETRACTABLE SUNSCREEN INSTALLATION
FIGURE 6-64. REAR WINDOW EXIT DECAL INSTALLATION - ENCLOSED CAB
FIGURE 6-65. ROOF PIGTAIL INSTALLATION
FIGURE 6-66. FILTER TRAY PANEL
FIGURE 6-67. FRONT DUCT COVER
FIGURE 6-68. WASHER BOTTLE
FIGURE 6-69. REAR WINDOW ASSEMBLY
FIGURE 6-70. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-71. CAB LATCH ASSEMBLY
FIGURE 6-72. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-73. DOOR ASSEMBLY
FIGURE 6-74. DOOR STRAP INSTALLATION
FIGURE 6-75. CAB DOOR
FIGURE 6-76. FIRE EXTINGUISHER INSTALLATION
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL
FIGURE 7-5. BRAKE PEDAL PLATE
FIGURE 7-6. STEERING COLUMN INSTALLATION NO FNR LEVER
FIGURE 7-7. STEERING COLUMN INSTALLATION
FIGURE 7-8. STEERING WHEEL INSTALLATION
FIGURE 7-9. STEERING WHEEL
FIGURE 7-10. HORN BUTTON INSTALLATION
FIGURE 7-11. JOYSTICK INSTALLATION (ELOBAU BRAND)
FIGURE 7-12. JOYSTICK INSTALLATION (BOSCH/REXROTH BRAND)
FIGURE 7-13. JOYSTICK ASSEMBLY (ELOBAU BRAND)
FIGURE 7-14. JOYSTICK ASSEMBLY (BOSCH/REXROTH BRAND)
FIGURE 7-15. OUTRIGGER SWITCHES INSTALLATION
FIGURE 7-16. COLUMN CLAMP INSTALLATION
FIGURE 7-17. WIPER-TURN SWITCH INSTALLATION
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. MAIN HYDRAULICS INSTALLATION
FIGURE 8-2. AXLE (FRONT) LINES INSTALLATION
FIGURE 8-3. AXLE (REAR) LINES INSTALLATION
FIGURE 8-4. BOOM HYDRAULIC INSTALLATION
FIGURE 8-5. BOOM HYDRAULIC TUBES INSTALLATION
FIGURE 8-6. BOOM HOSES INSTALLATION
FIGURE 8-7. BOOM AUXILIARY HYDRAULIC INSTALLATION
FIGURE 8-8. BOOM AUXILIARY HYDRAULIC INSTALLATION WITH HYDRAULIC COUPLER
FIGURE 8-9. CAB HYDRAULIC INSTALLATION
FIGURE 8-10. COUPLER VALVE & FITTING ASSEMBLY
FIGURE 8-11. ENGINE BAY HYDRAULIC INSTALLATION
FIGURE 8-12. EXTEND/RETRACT CYLINDER VALVE INSTALLATION
FIGURE 8-13. FRAME HYDRAULIC INSTALLATION
FIGURE 8-14. FRAME LEVEL AND OUTRIGGER VALVE INSTALLATION
FIGURE 8-15. FRAME LEVEL CYLINDER INSTALLATION
FIGURE 8-16. FRAME LEVEL AND OUTRIGGER VALVE & FITTINGS ASSEMBLY
FIGURE 8-17. LIFT CYLINDER VALVE INSTALLATION WITHOUT RIDE CONTROL
FIGURE 8-18. LIFT CYLINDER & FITTING ASSEMBLY (1055)
FIGURE 8-19. LIFT CYLINDER INSTALLATION (1255)
FIGURE 8-20. MAIN CONTROL VALVE INSTALLATION
FIGURE 8-21. MAIN CONTROL VALVE & FITTINGS ASSEMBLY
FIGURE 8-22. PIPE HANDLER VALVE & FITTINGS ASSEMBLY
FIGURE 8-23. PISTON PUMP INSTALLATION
FIGURE 8-24. PISTON PUMP & FITTINGS ASSEMBLY
FIGURE 8-25. PRIORITY FUNCTION MANIFOLD INSTALLATION
FIGURE 8-26. PRIORITY FUNCTION MANIFOLD & FITTINGS ASSEMBLY
FIGURE 8-27. CYLINDER & VALVE INSTALLATION - STABILIZER (REAR AXLE) (Prior to SN 0160141595, Prior to SN 0160141573)
FIGURE 8-28. CYLINDER & VALVE INSTALLATION - STABILIZER (REAR AXLE) (SN 0160141596 to Present, SN 0160141574 to Present)
FIGURE 8-29. RIDE CONTROL INSTALLATION (1055)
FIGURE 8-30. RIDE CONTROL INSTALLATION (1255)
FIGURE 8-31. RIDE CONTROL HYDRAULIC LINES
FIGURE 8-32. SAHR BRAKE VALVE INSTALLATION
FIGURE 8-33. SAHR BRAKE VALVE & FITTINGS ASSEMBLY
FIGURE 8-34. STEER COLUMN CHECK VALE & FITTINGS ASSEMBLY
FIGURE 8-35. STEER SELECT VALVE INSTALLATION
FIGURE 8-36. STEER SELECT VALVE & FITTINGS ASSEMBLY
FIGURE 8-37. VALVE ASSEMBLY - STABILIZER (REAR AXLE) (Prior to SN 0160141595, Prior to SN 0160141573)
FIGURE 8-38. VALVE ASSEMBLY - STABILIZER (REAR AXLE) (SN 0160141596 to Present, SN 0160141574 to Present)
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. CYLINDER GROUP INSTALLATION (1055)
FIGURE 9-2. CYLINDER GROUP INSTALLATION (1255)
FIGURE 9-3. CYLINDER ASSEMBLY - BUCKET (GRAPPLE)
FIGURE 9-4. CYLINDER ASSEMBLY - CARRIAGE DUAL FORKS
FIGURE 9-5. CYLINDER ASSEMBLY - CARRIAGE SIDE SHIFT
FIGURE 9-6. CYLINDER ASSEMBLY - CARRIAGE SIDE SHIFT
FIGURE 9-7. CYLINDER ASSEMBLY - CARRIAGE SIDE TILT
FIGURE 9-8. CYLINDER ASSEMBLY - CARRIAGE SWING
FIGURE 9-9. CYLINDER ASSEMBLY - COMPENSATION (1055)
FIGURE 9-10. CYLINDER ASSEMBLY - COMPENSATION (1255)
FIGURE 9-11. CYLINDER ASSEMBLY - COUPLER
FIGURE 9-12. CYLINDER ASSEMBLY - EXTENT/RETRACT
FIGURE 9-13. CYLINDER ASSEMBLY - FORK POSITIONING
FIGURE 9-14. CYLINDER ASSEMBLY - FRAME LEVEL
FIGURE 9-15. CYLINDER ASSEMBLY - LIFT (1055)
FIGURE 9-16. CYLINDER ASSEMBLY - LIFT (1255)
FIGURE 9-17. CYLINDER ASSEMBLY - OUTRIGGER
FIGURE 9-18. CYLINDER ASSEMBLY - PIPE HANDLER
FIGURE 9-19. CYLINDER ASSEMBLY - STABILIZER (REAR AXLE)
FIGURE 9-20. CYLINDER AND FITTINGS ASSEMBLY - TILT (1055)
FIGURE 9-21. CYLINDER ASSEMBLY - TILT (1055)
FIGURE 9-22. CYLINDER AND FITTINGS ASSEMBLY - TILT (1255)
FIGURE 9-23. CYLINDER ASSEMBLY - TILT (1255)
FIGURE 9-24. PUMP ASSEMBLY - PISTON
FIGURE 9-25. TANK ASSEMBLY - HYDRAULIC
FIGURE 9-26. TANK FILTER ASSEMBLY - HYDRAULIC
FIGURE 9-27. VALVE ASSEMBLY - AIR SHUT OFF
FIGURE 9-28. VALVE ASSEMBLY - COUNTERBALANCE
FIGURE 9-29. VALVE ASSEMBLY - COUPLER DIVERTER
FIGURE 9-30. VALVE ASSEMBLY - FLOW DIVIDER (CARRIAGE WITH DUAL FORKS)
FIGURE 9-31. VALVE ASSEMBLY - FRAME & OUTRIGGER
FIGURE 9-32. VALVE ASSEMBLY - MAIN CONTROL
FIGURE 9-33. VALVE ASSEMBLY - PRIORITY MANIFOLD VALVE
FIGURE 9-34. VALVE ASSEMBLY - SAHR BRAKE
FIGURE 9-35. VALVE ASSEMBLY - STABILIZER (REAR AXLE)
FIGURE 9-36. VALVE ASSEMBLY - STEER VALVE
FIGURE 9-37. VALVE ASSEMBLY - STEER VALVE (ORBITAL)
SECTION 10 - ELECTRICALFIGURE 10-1. MAIN ELECTRICAL INSTALLATION (ULS)
FIGURE 10-2. MAIN ELECTRICAL INSTALLATION (LS)
FIGURE 10-3. AIR SHUT OFF VALVE HARNESS
FIGURE 10-4. AIR SHUT OFF VALVE HARNESS (ENGINE)
FIGURE 10-5. ALARM INSTALLATION - BACKUP
FIGURE 10-6. ALARM INSTALLATION - WHITE NOISE
FIGURE 10-7. ARCTIC COLD WEATHER PACKAGE INSTALLATION (ULS) (Prior to SN 0160143912, Prior to SN 0160143931)
FIGURE 10-8. ARCTIC COLD WEATHER PACKAGE INSTALLATION )110HP) (ULS) (SN 0160143913 to Present, SN 0160143932 to Present)
FIGURE 10-9. ARCTIC COLD WEATHER PACKAGE INSTALLATION (LS)
FIGURE 10-10. BATTERY INSTALLATION
FIGURE 10-11. BATTERY INSTALLATION - ARCTIC
FIGURE 10-12. BOOM ANGLE SENSOR INSTALLATION
FIGURE 10-13. BOOM ANGLE SENSOR INSTALLATION (CAN ONLY)
FIGURE 10-14. BOOM AUXILIARY ELECTRIC INSTALLATION
FIGURE 10-15. BOOM AUXILIARY ELECTRIC HARNESS INSTALLATION
FIGURE 10-16. BOOM AUXILIARY ELECTRIC HARNESS
FIGURE 10-17. CAB ELECTRICAL INSTALLATION
FIGURE 10-18. CAB HARNESS
FIGURE 10-19. CAB (ENCLOSED) ELECTRICAL INSTALLATION WITH OPTIONS
FIGURE 10-20. CAB ELECTRICAL INSTALLATION - OPEN
FIGURE 10-21. CAB OPTION 1 HARNESS
FIGURE 10-22. CAB OPTION 2 HARNESS
FIGURE 10-23. CAB - OPTION HARNESS
FIGURE 10-24. CAB ALARM HARNESS - SEAT BELT
FIGURE 10-25. CAB - A/C OPTION HARNESS
FIGURE 10-26. CAB - COMMUNICATION ANALYZER CABLE
FIGURE 10-27. CAB - DASH ELECTRICAL INSTALLATION (LS)
FIGURE 10-28. CAB - DASH ELECTRICAL INSTALLATION (ULS)
FIGURE 10-29. CAB FUSE BOARD ASSEMBLY - STANDARD
FIGURE 10-30. CAB FUSE BOARD ASSEMBLY - OPTION 1
FIGURE 10-31. CAB FUSE BOARD ASSEMBLY - OPTION 2
FIGURE 10-32. CAB KEY HARNESS
FIGURE 10-33. CAB - MULTIFUNCTION DISPLAY INSTALLATION
FIGURE 10-34. CAMERA INSTALLATION - REVERSE
FIGURE 10-35. MULTI VIEW CAMERA INSTALLATION
FIGURE 10-36. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 10-37. CLEARSKY HARNESS - CS550 BEACON
FIGURE 10-38. TELEMATICS READY INSTALLATION
FIGURE 10-39. TELEMATICS READY INSTALLATION
FIGURE 10-40. TELEMATICS INSTALLATION (CUSTOMER SUPPLIED)
FIGURE 10-41. TELEMATICS HARNESS - CUSTOMER SUPPLIED VERSION
FIGURE 10-42. DEF PURGE LIGHT HARNESS
FIGURE 10-43. ENGINE BAY ELECTRICAL INSTALLATION (LS)
FIGURE 10-44. ENGINE BAY ELECTRICAL INSTALLATION (ULS)
FIGURE 10-45. ENGINE BAY WIRING INSTALLATION (LS)
FIGURE 10-46. ENGINE BAY WIRING INSTALLATION (ULS)
FIGURE 10-47. ENGINE WIRING INSTALLATION (LS)
FIGURE 10-48. ENGINE WIRING INSTALLATION (ULS)
FIGURE 10-49. ENGINE HARNESS
FIGURE 10-50. ENGINE HARNESS
FIGURE 10-51. ENGINE ECU INSTALLATION (LS)
FIGURE 10-52. ENGINE ECU INSTALLATION (ULS)
FIGURE 10-53. ENGINE/FRAME HARNESS
FIGURE 10-54. FRAME ELECTRICAL INSTALLATION
FIGURE 10-55. FRAME POWER DISTRIBUTION ELECTRICAL BOX
FIGURE 10-56. FRAME WIRING INSTALLATION (LS)
FIGURE 10-57. FRAME WIRING INSTALLATION (ULS)
FIGURE 10-58. FRONT FRAME HARNESS
FIGURE 10-59. FRAME HARNESS - FRONT
FIGURE 10-60. FRAME HARNESS - FRONT
FIGURE 10-61. FRAME HARNESS - REAR
FIGURE 10-62. HEATER INSTALLATION - FUEL FILTER
FIGURE 10-63. HEATER INSTALLATION - TANK (HYDRAULIC)
FIGURE 10-64. HVAC ACTUATOR HARNESS
FIGURE 10-65. JOYSTICK HARNESS
FIGURE 10-66. LIGHTS - BOOM WORKLIGHTS & SWITCH INSTALLATION
FIGURE 10-67. LIGHTS - BOOM WORKLIGHTS HARNESS INSTALLATION (LED)
FIGURE 10-68. LIGHTS - BOOM WORKKLIGHTS HARNESS
FIGURE 10-69. LIGHTS - CAB WORK LIGHTS INSTALLATION (A/C) (LED)
FIGURE 10-70. LIGHTS - CAB WORK LIGHTS INSTALLATION (NO A/C) (LED)
FIGURE 10-71. LIGHTS - ROADLIGHTS INSTALLATION
FIGURE 10-72. LIGHTS - ROADLIGHTS DRIVING LIGHTS (LH)
FIGURE 10-73. LIGHTS - ROADLIGHTS DRIVING LIGHTS (RH)
FIGURE 10-74. LIGHTS - ROADLIGHTS DRIVING LIGHTS HARNESS
FIGURE 10-75. LIGHTS - ROADLIGHTS TAILLIGHT (LH)
FIGURE 10-76. LIGHTS - ROADLIGHTS TAILLIGHT (RH)
FIGURE 10-77. LIGHTS - TAILLIGHTS HARNESS
FIGURE 10-78. LSI HARNESS - BOOM RETRACT
FIGURE 10-79. PLATFORM HARNESS
FIGURE 10-80. REVERSE SENSOR INSTALLATION
FIGURE 10-81. REVERSE SENSOR HARNESS
FIGURE 10-82. RIDE CONTROL HARNESS INSTALLATION
FIGURE 10-83. RIDE CONTROL BOOM FLAT HARNESS
FIGURE 10-84. ROOF PIGTAIL HARNESS INSTALLATION
FIGURE 10-85. ROOF PIGTAIL HARNESS
FIGURE 10-86. TBAP HARNESS
FIGURE 10-87. USB CHARGER INSTALLATION
SECTION 11 - DECALSFIGURE 11-1. CAPACITY CHART HOLDER INSTALLATION
FIGURE 11-2. DECAL INSTALLATION (1055)
FIGURE 11-3. DECAL INSTALLATION (1255)
FIGURE 11-4. DECAL INSTALLATION (ANSI)
FIGURE 11-5. DECAL INSTALLATION (ISO)
FIGURE 11-6. DECAL INSTALLATION
FIGURE 11-7. DECAL INSTALLATION (ENGLISH/SPANISH)
FIGURE 11-8. DECAL INSTALLATION - CLEARSKY CS550 BEACON
FIGURE 11-9. CAPACITY CHART (ANSI) (1055)
FIGURE 11-10. CAPACITY CHART (ANSI) (1255)
FIGURE 11-11. CAPACITY CHART (METRIC) (1055)
FIGURE 11-12. CAPACITY CHART (METRIC) (1255)
FIGURE 11-13. DECAL INSTALLATION - JLG (74HP)
FIGURE 11-14. DECAL INSTALLATION - JLG (110HP)
FIGURE 11-15. REVERSE SENSOR SYSTEM DECAL (ENGLISH)
FIGURE 11-16. REVERSE SENSOR SYSTEM DECAL
FIGURE 11-17. REVERSE SENSING SYSTEM DECAL, (ENGLISH/FRENCH)
FIGURE 11-18. REVERSE SENSOR SYSTEM DECAL (ENGLISH/SPANISH)
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
