JLG Telehandler 1044C-54 Series II Parts Catalog 31200069
Brand: JLG
Type of Machine: Telehandler
Model: JLG 1044C-54 Series II Telehandler
Part Number: 31200069
Publication Date: 2025
Number of Pages: 492 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. MAIN FRAME ASSEMBLY
FIGURE 1-2. OUTRIGGER ASSEMBLY
SECTION 2 - BOOMFIGURE 2-1. FIRST BOOM SECTION (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 2-2. FIRST BOOM SECTION (SN 0160037900 to Present, Including 0160037855)
FIGURE 2-3. BEARING PADS, SPACERS AND SHIMS, (FIRST BOOM SECTION) (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 2-4. BEARING PADS, SPACERS AND SHIMS, (FIRST BOOM SECTION) (SN 0160037900 to Present, Including 0160037855)
FIGURE 2-5. SECOND BOOM SECTION (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 2-6. SECOND BOOM SECTION (SN 0160037900 to Present, Including 0160037855)
FIGURE 2-7. BEARING PADS, SPACERS AND SHIMS, (SECOND BOOM SECTION) (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 2-8. BEARING PADS, SPACERS AND SHIMS, (SECOND BOOM SECTION) (SN 0160037900 to Present, Including 0160037855)
FIGURE 2-9. THIRD BOOM SECTION (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 2-10. THIRD BOOM SECTION (SN 0160037900 to Present, Including 0160037855)
FIGURE 2-11. FOURTH BOOM SECTION (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 2-12. FOURTH BOOM SECTION (SN 0160037900 to Present, Including 0160037855)
FIGURE 2-13. TRANSFER CARRIAGE/BOOM CRADLE ASSEMBLY
FIGURE 2-14. QUICK ATTACH GROUP INSTALLATION (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 2-15. QUICK ATTACH GROUP INSTALLATION (SN 0160037900 to Present, Including 0160037855)
SECTION 3 - ATTACHMENTSFIGURE 3-1. CARRIAGE ASSEMBLY (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-2. CARRIAGE ASSEMBLY (SN 0160037900 through 0160051920, Including 0160037855)
FIGURE 3-3. CARRIAGE ASSEMBLY (SN 0160051921 to Present)
FIGURE 3-4. TILT CARRIAGE ASSEMBLY (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-5. TILT CARRIAGE ASSEMBLY (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-6. SWING CARRIAGE ASSEMBLY (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-7. SWING CARRIAGE ASSEMBLY (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-8. UTILITY BUCKET (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-9. 50IN SINGLE FORK POSITIONING CARRIAGE ASSEMBLY (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-10. 50IN DUAL FORK POSITIONING CARRIAGE ASSEMBLY (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-11. 50IN DUAL FORK POSITIONING CARRIAGE ASSEMBLY (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-12. TRUSS BOOM ASSEMBLY (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-13. TRUSS BOOM ASSEMBLY (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-14. 12FT TRUSS BOOM WITH WINCH (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-15. 12FT TRUSS BOOM WITH WINCH (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-16. CARRIAGE ASSEMBLY WITH 8FT VERTICAL MAST (NON-TILT) (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-17. CARRIAGE ASSEMBLY WITH 8FT VERTICAL MAST (TILT) (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-18. 8FT VERTICAL MAST ASSEMBLY (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 3-19. FORKS
FIGURE 3-20. FORK MOUNTED PLATFORM
FIGURE 3-21. SWEEPER ASSEMBLY (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-22. GRAPPLE BUCKET (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-23. FORK MOUNTED LIFTING HOOK (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-24. MAST ASSEMBLY - 8FT (4500LBS) (WITHOUT SIDE TILT) (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-25. MAST ASSEMBLY - 8FT (4500LBS) (WITH SIDE TILT) (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-26. BUCKETS (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-27. FORK PIN LOCK INSTALLATION (SN 0160037900 to Present, Including 0160037855)
FIGURE 3-28. SHEET MATERIAL HANDLER
FIGURE 3-29. 50IN SIDE SHIFT CARRIAGE (SN 0160037900 to Present, Including 0160037855)
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION (SN 0160009654 through 0160018506, Including 0160008714)
FIGURE 4-2. ENGINE INSTALLATION (SN 0160018507 through 0160040407, Excluding 0160037824 and 0160038521)
FIGURE 4-3. ENGINE INSTALLATION (SN 0160040413 to Present, Including 0160037824 and 0160038521)
FIGURE 4-4. ENGINE (SN 0160009654 through 0160018506, Including 0160008714)
FIGURE 4-5. ENGINE (SN 0160018507 through 0160040407, Excluding 0160037824 and 0160038521)
FIGURE 4-6. ENGINE (SN 0160040413 to Present, Including 0160037824 and 0160038521)
FIGURE 4-7. RADIATOR ASSEMBLY (SN 0160018507 through 0160040407, Excluding 0160037824 and 0160038521)
FIGURE 4-8. RADIATOR ASSEMBLY (SN 0160040413 to Present, Including 0160037824 and 0160038521)
FIGURE 4-9. AIR CLEANER INSTALLATION (SN 0160018507 through 0160040407, Excluding 0160037824 and 0160038521)
FIGURE 4-10. AIR CLEANER INSTALLATION (SN 0160040413 to Present, Including 0160037824 and 0160038521)
FIGURE 4-11. EXHAUST INSTALLATION (SN 0160009654 through 0160040407, Excluding 0160037824 and 0160038521)
FIGURE 4-12. EXHAUST INSTALLATION (SN 0160040413 to Present, Including 0160037824 and 0160038521)
SECTION 5 - DRIVE TRAINFIGURE 5-1. DRIVE TRAIN COMPONENTS
FIGURE 5-2. FRONT AXLE ASSEMBLY
FIGURE 5-3. FRONT AXLE - INPUT
FIGURE 5-4. FRONT AXLE - LIMITED SLIP DIFFERENTIAL
FIGURE 5-5. FRONT AXLE - AXLE CASING
FIGURE 5-6. FRONT AXLE - M-DISC BRAKE
FIGURE 5-7. FRONT AXLE - BRAKE
FIGURE 5-8. FRONT AXLE - JOINT HOUSING
FIGURE 5-9. FRONT AXLE - PLANETARY DRIVE
FIGURE 5-10. REAR AXLE ASSEMBLY
FIGURE 5-11. REAR AXLE - INPUT (PRIOR TO SN 0160051140, EXCLUDING 0160050734 AND 0160050735)
FIGURE 5-12. REAR AXLE - INPUT (SN 0160051140 TO PRESENT, INCLUDING 0160050734 AND 0160050735)
FIGURE 5-13. REAR AXLE - DIFFERENTIAL (PRIOR TO SN 0160051140, EXCLUDING 0160050734 AND 0160050735)
FIGURE 5-14. REAR AXLE - DIFFERENTIAL (SN 0160051140 TO PRESENT, INCLUDING 0160050734 AND 0160050735)
FIGURE 5-15. REAR AXLE - AXLE CASING (PRIOR TO SN 0160051140, EXCLUDING 0160050734 AND 0160050735)
FIGURE 5-16. REAR AXLE - AXLE CASING (SN 0160051140 TO PRESENT, INCLUDING 0160050734 AND 0160050735)
FIGURE 5-17. REAR AXLE - M-DISC BRAKE (PRIOR TO SN 0160051140, EXCLUDING 0160050734 AND 0160050735)
FIGURE 5-18. REAR AXLE - M-DISC BRAKE (SN 0160051140 TO PRESENT, INCLUDING 0160050734 AND 0160050735)
FIGURE 5-19. REAR AXLE - BRAKE
FIGURE 5-20. REAR AXLE - JOINT HOUSING (PRIOR TO SN 0160051140, EXCLUDING 0160050734 AND 0160050735)
FIGURE 5-21. REAR AXLE - JOINT HOUSING (SN 0160051140 TO PRESENT, INCLUDING 0160050734 AND 0160050735)
FIGURE 5-22. REAR AXLE - PLANETARY DRIVE (PRIOR TO SN 0160051140, EXCLUDING 0160050734 AND 0160050735)
FIGURE 5-23. REAR AXLE - PLANETARY DRIVE (SN 0160051140 TO PRESENT, INCLUDING 0160050734 AND 0160050735)
FIGURE 5-24. ZF TRANSMISSION - CONVERTER AND INPUT
FIGURE 5-25. ZF TRANSMISSION - GEARBOX HOUSING
FIGURE 5-26. ZF TRANSMISSION - REVERSING GEAR KV
FIGURE 5-27. ZF TRANSMISSION - REVERSING GEAR KR
FIGURE 5-28. ZF TRANSMISSION - COUPLING GROUP K1
FIGURE 5-29. ZF TRANSMISSION - COUPLING GROUP K2
FIGURE 5-30. ZF TRANSMISSION - COUPLING GROUP K3
FIGURE 5-31. ZF TRANSMISSION - COUPLING GROUP K4
FIGURE 5-32. ZF TRANSMISSION - OUTPUT
FIGURE 5-33. ZF TRANSMISSION - CONTROL UNIT
FIGURE 5-34. ZF TRANSMISSION - GEARSHIFT SYSTEM
FIGURE 5-35. ZF TRANSMISSION - GEARSHIFT SYSTEM
FIGURE 5-36. ZF TRANSMISSION - OIL PUMP, FILTER AND DIPSTICK
FIGURE 5-37. DRIVE SHAFT
FIGURE 5-38. TIRES AND RIMS
SECTION 6 - CABFIGURE 6-1. OPERATORS COMPARTMENT ASSEMBLY
FIGURE 6-2. CAB ENCLOSURE KIT
FIGURE 6-3. WINDSHIELD WIPER ASSEMBLY
FIGURE 6-4. WINDSHIELD ASSEMBLY
FIGURE 6-5. WINDOW ASSEMBLY
FIGURE 6-6. DOOR ASSEMBLY
FIGURE 6-7. INSULATION INSTALLATION
FIGURE 6-8. INSTRUMENT PANEL ASSEMBLY
FIGURE 6-9. OPERATOR'S SEAT (SN 0160009654 through 0160013146, Including 0160008714)
FIGURE 6-10. OPERATOR'S SEAT (SN 0160013147 to Present)
FIGURE 6-11. HEATER AND AIR CONDITIONING SYSTEM (Prior to SN 0160040413, Excluding 0160037824 and 0160038521)
FIGURE 6-12. HEATER AND AIR CONDITIONING SYSTEM (SN 0160040413 to Present, Including 0160037824 and 0160038521)
SECTION 7 - CONTROLSFIGURE 7-1. JOYSTICK (Prior to SN 0160048698)
FIGURE 7-2. JOYSTICK (SN 0160048698 to Present)
FIGURE 7-3. FRAME LEVEL AND OUTRIGGER JOYSTICK ASSEMBLY (Prior to SN 0160048698)
FIGURE 7-4. FRAME LEVEL AND OUTRIGGER JOYSTICK ASSEMBLY (SN 0160048698 to Present)
FIGURE 7-5. STEER COLUMN ASSEMBLY (Prior to SN 0160049803)
FIGURE 7-6. STEER COLUMN ASSEMBLY (SN 0160049803 to Present)
FIGURE 7-7. BRAKE VALVE ASSEMBLY
FIGURE 7-8. ACCELERATOR PEDAL
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. PUMP, SUCTION - RETURN
FIGURE 8-2. BOOM HYDRAULIC CYLINDER
FIGURE 8-3. HOIST AND REAR CARRIAGE TILT
FIGURE 8-4. SECOND AUXILIARY CIRCUIT
FIGURE 8-5. TRANSFER CYLINDER
FIGURE 8-6. OUTRIGGER CYLINDER AND JOYSTICK
FIGURE 8-7. FRAME LEVEL AND REAR AXLE STABILIZER
FIGURE 8-8. STEERING CYLINDER
FIGURE 8-9. JOYSTICK CONTROL CIRCUIT
FIGURE 8-10. SERVICE BRAKE CIRCUIT
FIGURE 8-11. PARK BRAKE CIRCUIT
FIGURE 8-12. TEST PORT HYDRAULIC ASSEMBLY
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. FRONT CARRIAGE TILT CYLINDER (Prior to SN 0160037900, Excluding 0160037855)
FIGURE 9-2. FRONT CARRIAGE TILT CYLINDER (SN 0160037900 to Present, Including 0160037855)
FIGURE 9-3. REAR CARRIAGE TILT CYLINDER
FIGURE 9-4. FRAME TILT CYLINDER
FIGURE 9-5. HOIST CYLINDER
FIGURE 9-6. BOOM EXTENSION CYLINDER
FIGURE 9-7. TRANSFER CYLINDER
FIGURE 9-8. OUTRIGGER CYLINDER (Prior to SN 0160058596)
FIGURE 9-9. OUTRIGGER CYLINDER (SN 0160058596 to Present)
FIGURE 9-10. REAR STABILIZER CYLINDER (Including 1001140447)
FIGURE 9-11. STEERING CYLINDER
FIGURE 9-12. HYDRAULIC CONTROL VALVE ASSEMBLY
FIGURE 9-13. TANDEM PUMP
FIGURE 9-14. ACCUMULATOR CHARGE VALVE
FIGURE 9-15. 6-PORT CIRCUIT SELECTOR VALVE ASSEMBLY
FIGURE 9-16. HYDRAULIC RETURN LINE FILTER ASSEMBLY
FIGURE 9-17. PRESSURE FILTER ASSEMBLY
FIGURE 9-18. INLINE FILTER ASSEMBLY
FIGURE 9-19. ACCUMULATOR ASSEMBLY
FIGURE 9-20. REAR AXLE STABILIZER CONTROL VALVE, (UNDER CAB)
FIGURE 9-21. REAR AXLE STABILIZER VALVE, (ON REAR AXLE)
FIGURE 9-22. FUEL/HYDRAULIC TANK ASSY
FIGURE 9-23. BOOM EXTEND LOCKOUT VALVE ASSEMBLY
FIGURE 9-24. PARK BRAKE VALVE ASSEMBLY
FIGURE 9-25. VALVE PLATE COMPONENTS ASSEMBLY
FIGURE 9-26. SIDE TILT CARRIAGE CYLINDER
FIGURE 9-27. 72IN 90, SWING CARRIAGE CYLINDER
FIGURE 9-28. GRAPPLE BUCKET CYLINDER
FIGURE 9-29. 50IN SIDE SHIFT CARRIAGE CYLINDER (SN 0160037900 to Present, Including 0160037855)
FIGURE 9-30. SHUTTLE VALVE (SN 0160048698 to Present)
SECTION 10 - ELECTRICALFIGURE 10-1. FRAME HARNESS INSTALLATION (SN 0160009654 through 0160017144, Including 0160008714)
FIGURE 10-2. FRAME HARNESS INSTALLATION (SN 0160017145 to Present)
FIGURE 10-3. OUTRIGGER/BOOM EXTEND LOCKOUT HARNESS INSTALLATION
FIGURE 10-4. ENGINE ELECTRICAL GROUP (Prior to SN 0160040407, Excluding 0160037824 and 0160038521)
FIGURE 10-5. ENGINE ELECTRICAL GROUP (SN 0160040413 to Present, Including 0160037824 and 0160038521)
FIGURE 10-6. TRANSMISSION HARNESS INSTALLATION
FIGURE 10-7. OPERATOR'S COMPARTMENT ELECTRICAL GROUP INSTALLATION
FIGURE 10-8. FUSES, RELAYS AND BUZZER MOUNTING PANEL
FIGURE 10-9. ENGINE ECU HARNESS (SN 0160040413 to Present, Including 0160037824 and 0160038521)
FIGURE 10-10. ECM POWER HARNESS (SN 0160040413 to Present, Including 0160037824 and 0160038521)
FIGURE 10-11. ELECTRICAL OPTIONS HARNESS (SN 0160032761 to Present)
SECTION 11 - DECALSFIGURE 11-1. DECAL GROUP
SECTION 12 - OPTIONSFIGURE 12-1. WORKLIGHT OPTION INSTALLATION (SN 0160009654 through 0160019928, Including 0160008714)
FIGURE 12-2. WORKLIGHT OPTION INSTALLATION (SN 0160019929 through 0160030844)
FIGURE 12-3. WORKLIGHT OPTION INSTALLATION (SN 0160030845 to Present)
FIGURE 12-4. ROADWAY LIGHT OPTION INSTALLATION (SN 0160009654 through 0160032760, Including 0160008714)
FIGURE 12-5. ROADWAY LIGHT OPTION INSTALLATION (SN 0160032761 through 0160051139, Excluding 0160050734 and 0160050735)
FIGURE 12-6. ROADWAY LIGHT OPTION INSTALLATION (SN 0160051140 to Present, Including 0160050734 and 0160050735)
FIGURE 12-7. STROBE/ROTATING BEACON LIGHT OPTION INSTALLATION (SN 0160009654 through 0160032760, Including 0160008714)
FIGURE 12-8. STROBE/ROTATING BEACON LIGHT OPTION INSTALLATION (SN 0160032761 to Present)
FIGURE 12-9. TILTING CARRIAGE CYLINDER
FIGURE 12-10. TOWER CYLINDER
FIGURE 12-11. FORK POSITIONING CYLINDER
FIGURE 12-12. LOCKABLE ENGINE SIDE PANELS INSTALLATION
FIGURE 12-13. BATTERY COLD START INSTALLATION
FIGURE 12-14. FRAME LEVEL AND OUTRIGGER JOYSTICK REPAIR KIT (Prior to SN 0160048698)
SECTION 13 - RECOMMENDED SPARE PARTSFIGURE 13-1. RECOMMENDED SPARE PARTS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
