JLG Telehandler 1043 Parts Catalog 31222444
Brand: JLG
Type of Machine: Telehandler
Model: JLG 1043 Telehandler
Part Number: 31222444
Publication Date: 2025
Number of Pages: 1120 Pages
SECTION 1 - FRAME AND ATTACHING PARTS
Brand: JLG
FIGURE 1-1. ENGINE ENCLOSURE INSTALLATION
FIGURE 1-2. ENGINE ENCLOSURE COVER INSTALLATION
FIGURE 1-3. HOOD ASSEMBLY (1043)
FIGURE 1-4. COVER INSTALLATION (OUTRIGGERS) (ULS)
FIGURE 1-5. COVER INSTALLATION (OUTRIGGERS) (LS)
FIGURE 1-6. TANK INSTALLATION
FIGURE 1-7. FUEL TANK INSTALLATION (Prior to SN 0160131339)
FIGURE 1-8. FUEL TANK INSTALLATION (SN 0160131563 to Present)
FIGURE 1-9. HYDRAULIC TANK INSTALLATION
FIGURE 1-10. FUEL CAP ASSEMBLY
FIGURE 1-11. OUTRIGGERS INSTALLATION
FIGURE 1-12. MIRROR INSTALLATION
FIGURE 1-13. BOOM PROP INSTALLATION (ANSI)
FIGURE 1-14. BOOM PROP INSTALLATION (CANADA)
FIGURE 1-15. BOOM PROP BRACKET
FIGURE 1-16. COUNTERWEIGHT INSTALLATION
SECTION 2 - BOOMFIGURE 2-1. BOOM ASSEMBLY
FIGURE 2-2. FIRST BOOM SECTION ASSEMBLY
FIGURE 2-3. SECOND BOOM SECTION ASSEMBLY
FIGURE 2-4. THIRD BOOM SECTION ASSEMBLY
FIGURE 2-5. RETRACT CHAIN INSTALLATION
FIGURE 2-6. EXTEND CHAIN INSTALLATION
FIGURE 2-7. PINS INSTALLATION
FIGURE 2-8. RETRACT CHAIN SHEAVE
FIGURE 2-9. EXTEND CHAIN ROLLER
FIGURE 2-10. HOSE BRACKET INSTALLATION
FIGURE 2-11. BOOM PINNING INSTALLATION
FIGURE 2-12. LIFT CYLINDER PINS INSTALLATION
FIGURE 2-13. COMPENSATION CYLINDER PINS INSTALLATION
FIGURE 2-14. BOOM PIVOT PIN INSTALLATION
FIGURE 2-15. MANUAL QUICK COUPLER INSTALLATION
FIGURE 2-16. HYDRAULIC QUICK COUPLER INSTALLATION
FIGURE 2-17. BOOM PIN INSTALLATION
FIGURE 2-18. TILT CYLINDER PIN INSTALLATION
FIGURE 2-19. BOOM ANGLE INDICATOR INSTALLATION
FIGURE 2-20. BOOM BRUSHES INSTALLATION
FIGURE 2-21. QUICK COUPLER ASSEMBLY
SECTION 3 - ATTACHMENTSFIGURE 3-1. BASKET, PERSONNEL - 4FT X 8FT (ASME)
FIGURE 3-2. BASKET, PERSONNEL - 4FT X 8FT (DOMESTIC)
FIGURE 3-3. BASKET, PERSONNEL - 4FT X 8FT (ISO)
FIGURE 3-4. BASKET, FORK MOUNTED
FIGURE 3-5. BOOM - ADJUSTABLE (CARRIAGE MOUNTED)
FIGURE 3-6. BOOM - ADJUSTABLE (FORK MOUNTED)
FIGURE 3-7. BOOM - 3FT WITH WINCH
FIGURE 3-8. BOOM - 12FT WITH WINCH
FIGURE 3-9. BOOM - 12FT WITHOUT WINCH
FIGURE 3-10. BOOM - 15FT WITHOUT WINCH
FIGURE 3-11. BUCKET - 60IN (1.3 CU YD) (FORK MOUNTED)
FIGURE 3-12. BUCKET - 72IN (1.0 CU YD)
FIGURE 3-13. BUCKET - 96IN (1.5 CU YD)
FIGURE 3-14. BUCKET - 96IN GRAPPLE
FIGURE 3-15. BUCKET - 102IN (2.0 CU YD)
FIGURE 3-16. CARRIAGE ASSEMBLY - 48IN/12000# CAPACITY SIDE SHIFT
FIGURE 3-17. CARRIAGE ASSEMBLY - 50IN/1270MM
FIGURE 3-18. CARRIAGE ASSEMBLY - FORK POSITIONING WITH FORKS (4.5 TON)
FIGURE 3-19. CARRIAGE ASSEMBLY - 50IN/12000# CAPACITY SIDE TILT
FIGURE 3-20. CARRIAGE ASSEMBLY - 60IN/1524MM
FIGURE 3-21. CARRIAGE ASSEMBLY - 60IN/12000# CAPACITY SIDE TILT
FIGURE 3-22. CARRIAGE ASSEMBLY - 72IN/1829MM
FIGURE 3-23. CARRIAGE ASSEMBLY - 72IN 90 DEGREE SWING (Prior to SN 0160129991)
FIGURE 3-24. CARRIAGE ASSEMBLY - 72IN 90 DEGREE SWING (SN 0160130042 to Present)
FIGURE 3-25. CARRIAGE ASSEMBLY - 72IN/12000# CAPACITY SIDE TILT
FIGURE 3-26. CARRIAGE ASSEMBLY - 96IN/12000# CAPACITY STANDARD (SN 0160130613 to Present)
FIGURE 3-27. CARRIAGE ASSEMBLY - DRYWALL (SWING)
FIGURE 3-28. CARRIAGE ASSEMBLY - DRYWALL SWING CARRIAGE
FIGURE 3-29. CARRIAGE ASSEMBLY - DRYWALL BOARD HANDLER
FIGURE 3-30. CARRIAGE ASSEMBLY - DRYWALL PIVOT FRAME
FIGURE 3-31. CARRIAGE ASSEMBLY - DRYWALL CYLINDER
FIGURE 3-32. CARRIAGE ASSEMBLY - DRYWALL HYDRAULICS
FIGURE 3-33. CARRIAGE ASSEMBLY - DRYWALL VALVE ASSEMBLY
FIGURE 3-34. CARRIAGE ASSEMBLY - DRYWALL CYLINDER
FIGURE 3-35. CARRIAGE ASSEMBLY - DRYWALL FORKS
FIGURE 3-36. FORK 2X2X48 / 1940# CAPACITY
FIGURE 3-37. FORK 2.36X4X48 / 5000# CAPACITY
FIGURE 3-38. FORK 2.36X4X48 / 5475# CAPACITY
FIGURE 3-39. FORK 2.00X6X48 / 6005# CAPACITY
FIGURE 3-40. FORK 2.36X5X48 / 6850# CAPACITY
FIGURE 3-41. FORK 2.36X4X60 / 5000# CAPACITY
FIGURE 3-42. FORK 2.36X5X60 / 6850# CAPACITY
FIGURE 3-43. FORK 2.36X6X60 / 8150# CAPACITY
FIGURE 3-44. FORK 2.00X6X72 / 6610# CAPACITY
FIGURE 3-45. FORK 2.36X5X72 / 6850# CAPACITY
FIGURE 3-46. FORK 40X150X1540
FIGURE 3-47. FORK 50X180X1540
FIGURE 3-48. FORK 2.36X5X96 / 12000# CAPACITY (SN 0160130613 to Present)
FIGURE 3-49. FORK EXTENSION - 90IN
FIGURE 3-50. FORK CLAMPS INSTALLATION
FIGURE 3-51. PLATFORM (FORK MOUNTED) (4X9.8)
FIGURE 3-52. PLATFORM (FORK MOUNTED) (4X8 WITH DOORS)
FIGURE 3-53. HOOK, COUPLING
FIGURE 3-54. HOOK, CRANE
FIGURE 3-55. LIFTING HOOK (10K)
FIGURE 3-56. MAST, VERTICAL - 8FT (STANDARD)
FIGURE 3-57. MAST, VERTICAL - 8FT (SIDE TILT ELECTRIC MAST)
FIGURE 3-58. MAST, VERTICAL - DECAL KIT
FIGURE 3-59. MAST, VERTICAL - CYLINDER
FIGURE 3-60. SWEEPER ASSEMBLY
FIGURE 3-61. SWEEPER ASSEMBLY - HOPPER
FIGURE 3-62. SWEEPER ASSEMBLY - BODY
FIGURE 3-63. SWEEPER ASSEMBLY - MOTOR
FIGURE 3-64. SWEEPER ASSEMBLY - IDLER
FIGURE 3-65. SWEEPER ASSEMBLY - CORE
FIGURE 3-66. SWEEPER ASSEMBLY - HYDRAULIC SINGLE MOTOR ASSEMBLY
FIGURE 3-67. TRASH HOPPER
FIGURE 3-68. TELESCOPE PIVOT ADJUSTABLE JIB (10K)
SECTION 4 - ENGINE AND ATTACHING PARTSFIGURE 4-1. ENGINE INSTALLATION, 110HP (ULS)
FIGURE 4-2. ENGINE COMPONENTS, 110HP (ULS)
FIGURE 4-3. ENGINE INSTALLATION, 110HP (LS)
FIGURE 4-4. ENGINE COMPONENTS, 110HP (LS)
FIGURE 4-5. ENGINE MOUNTING INSTALLATION
FIGURE 4-6. ENGINE PARTS INSTALLATION (NO HEATER)
FIGURE 4-7. ENGINE PARTS INSTALLATION (HEATER)
FIGURE 4-8. A/C PUMP INSTALLATION (LS)
FIGURE 4-9. A/C PUMP INSTALLATION (ULS)
FIGURE 4-10. A/C LINES INSTALLATION
FIGURE 4-11. AIR CLEANER INSTALLATION (LS)
FIGURE 4-12. AIR CLEANER INSTALLATION (ULS)
FIGURE 4-13. AIR CLEANER FILTER ASSEMBLY (ULS)
FIGURE 4-14. AIR CLEANER ASSEMBLY, 110HP
FIGURE 4-15. AIR INTAKE DUCT INSTALLATION
FIGURE 4-16. AIR CLEANER LINES INSTALLATION (LS)
FIGURE 4-17. AIR CLEANER LINES INSTALLATION (ULS)
FIGURE 4-18. AIR INTAKE SHUT OFF VALVE INSTALLATION
FIGURE 4-19. COOLING PACKAGE INSTALLATION (LS)
FIGURE 4-20. COOLING PACKAGE INSTALLATION (ULS)
FIGURE 4-21. CAC LINES INSTALLATION (LS)
FIGURE 4-22. CAC LINES INSTALLATION (ULS)
FIGURE 4-23. COOLANT LINES INSTALLATION (LS)
FIGURE 4-24. COOLANT LINES INSTALLATION (ULS)
FIGURE 4-25. HOC LINES INSTALLATION
FIGURE 4-26. RADIATOR COOLING PACKAGE
FIGURE 4-27. SURGE TANK INSTALLATION
FIGURE 4-28. TOC LINES INSTALLATION
FIGURE 4-29. EXHAUST INSTALLATION, 110HP (LS)
FIGURE 4-30. MUFFLER INSTALLATION (LS)
FIGURE 4-31. DEF LINES INSTALLATION
FIGURE 4-32. EXHAUST INSTALLATION, 110HP (ULS)
FIGURE 4-33. DEF TANK INSTALLATION
FIGURE 4-34. DEF TANK ASSEMBLY
FIGURE 4-35. DEF BREATHER VALVE
FIGURE 4-36. DEF PUMP AND CONTROL INSTALLATION
FIGURE 4-37. UREA PUMP
FIGURE 4-38. DEF PUMP LINES INSTALLATION
FIGURE 4-39. FUEL LINES INSTALLATION (LS)
FIGURE 4-40. FUEL LINES INSTALLATION (ULS)
FIGURE 4-41. FAN INSTALLATION, 110HP
FIGURE 4-42. FAN GUARD INSTALLATION
FIGURE 4-43. FUEL TANK ASSEMBLY (Prior to SN 0160131339)
FIGURE 4-44. FUEL TANK ASSEMBLY (SN 0160131563 to Present)
FIGURE 4-45. PRIMARY FUEL FILTER INSTALLATION (LS)
FIGURE 4-46. PRIMARY FUEL FILTER INSTALLATION (ULS)
FIGURE 4-47. ENGINE OIL QUICK DRAIN INSTALLATION
SECTION 5 - DRIVE TRAINFIGURE 5-1. TRANSMISSION INSTALLATION
FIGURE 5-2. POWERSHIFT TRANSMISSION
FIGURE 5-3. TRANSMISION, ENGINE CONNECTION
FIGURE 5-4. TRANSMISSION, CONVERTER
FIGURE 5-5. TRANSMISSION, INPUT
FIGURE 5-6. TRANSMISSION, HOUSING GROUP 1
FIGURE 5-7. TRANSMISSION, HOUSING GROUP 2
FIGURE 5-8. TRANSMISSION, CLUTCH GROUP 1
FIGURE 5-9. TRANSMISSION, CLUTCH GROUP 2
FIGURE 5-10. TRANSMISSION, COUPLING GROUP 1
FIGURE 5-11. TRANSMISSION, COUPLING GROUP 2
FIGURE 5-12. TRANSMISSION, COUPLING GROUP 3
FIGURE 5-13. TRANSMISSION, COUPLING GROUP 4
FIGURE 5-14. TRANSMISSION, OUTPUT
FIGURE 5-15. TRANSMISSION, POWER TAKE-OFF
FIGURE 5-16. TRANSMISSION, CONTROL UNIT
FIGURE 5-17. TRANSMISSION, SHIFT SYSTEM
FIGURE 5-18. TRANSMISSION, PRESSURE REGULATOR
FIGURE 5-19. TRANSMISSION, PRESSURE OIL PUMP
FIGURE 5-20. TRANSMISSION, INDUCTIVE TRANSMITTER
FIGURE 5-21. TRANSMISSION, FILTER
FIGURE 5-22. TRANSMISSION, ACCESSORIES GROUP 1
FIGURE 5-23. TRANSMISSION, PERIPHERALS GROUP 1
FIGURE 5-24. TRANSMISSION, PERIPHERALS GROUP 2
FIGURE 5-25. TRANSMISSION, ACCESSORIES GROUP 2
FIGURE 5-26. TRANSMISSION, TRANSFER BOX
FIGURE 5-27. TRANSMISSION, TRANSFER BOX HOUSING 1
FIGURE 5-28. TRANSMISSION, TRANSFER BOX HOUSING 2
FIGURE 5-29. TRANSMISSION, TRANSFER BOX HOUSING INPUT
FIGURE 5-30. TRANSMISSION, TRANSFER BOX HOUSING OUTPUT 1
FIGURE 5-31. TRANMISSION, TRANSFER BOX HOUSING OUTPUT 2
FIGURE 5-32. DRIVE SHAFTS INSTALLATION
FIGURE 5-33. FRONT DRIVE SHAFT INSTALLATION
FIGURE 5-34. FRONT DRIVE SHAFT ASSEMBLY
FIGURE 5-35. REAR DRIVE SHAFT INSTALLATION
FIGURE 5-36. DRIVETRAIN INSTALLATION
FIGURE 5-37. FRONT AXLE INSTALLATION
FIGURE 5-38. FRONT AXLE LINES INSTALLATION
FIGURE 5-39. FRONT AXLE MOUNTING INSTALLATION (Prior to SN 0160129344)
FIGURE 5-40. FRONT AXLE MOUNTING INSTALLATION (SN 0160129344 to Present)
FIGURE 5-41. FRONT AXLE (Prior to SN 0160129344)
FIGURE 5-42. FRONT AXLE, BRAKES (Prior to SN 0160129344)
FIGURE 5-43. FRONT AXLE, CENTRAL HOUSING (Prior to SN 0160129344)
FIGURE 5-44. FRONT AXLE, DIFFERENTIAL (Prior to SN 0160129344)
FIGURE 5-45. FRONT AXLE, HUB REDUCTION (Prior to SN 0160129344)
FIGURE 5-46. FRONT AXLE, STEERING (Prior to SN 0160129344)
FIGURE 5-47. FRONT AXLE, TRUNION (Prior to SN 0160129344)
FIGURE 5-48. FRONT AXLE, DIFFERENTIAL KIT (Prior to SN 0160129344)
FIGURE 5-49. FRONT AXLE, PLANET GEAR CARRIER (Prior to SN 0160129344)
FIGURE 5-50. FRONT AXLE, RING GEAR SUPPORT (Prior to SN 0160129344)
FIGURE 5-51. FRONT AXLE, PLANET GEAR CARRIER (Prior to SN 0160129344)
FIGURE 5-52. FRONT AXLE, SUPPORT (Prior to SN 0160129344)
FIGURE 5-53. FRONT AXLE ASSEMBLY - CENTRAL HOUSING (SN 0160129344 to Present)
FIGURE 5-54. FRONT AXLE ASSEMBLY - DIFFERENTIAL (SN 0160129344 to Present)
FIGURE 5-55. FRONT AXLE ASSEMBLY - HUB REDUCTION (SN 0160129344 to Present)
FIGURE 5-56. FRONT AXLE ASSEMBLY - BRAKES (SN 0160129344 to Present)
FIGURE 5-57. FRONT AXLE ASSEMBLY - STEERING (SN 0160129344 to Present)
FIGURE 5-58. FRONT AXLE ASSEMBLY - TRUNION (SN 0160129344 to Present)
FIGURE 5-59. REAR AXLE INSTALLATION
FIGURE 5-60. REAR AXLE LINES INSTALLATION
FIGURE 5-61. REAR AXLE MOUNTING INSTALLATION (Prior to SN 0160129344)
FIGURE 5-62. REAR AXLE MOUNTING INSTALLATION (SN 0160129344 to Present)
FIGURE 5-63. REAR AXLE ASSEMBLY - CENTRAL HOUSING (Prior to SN 0160129344)
FIGURE 5-64. REAR AXLE ASSEMBLY - CENTRAL HOUSING (SN 0160129344 to Present)
FIGURE 5-65. REAR AXLE ASSEMBLY - DIFFERENTIAL (SN 0160129344 to Present)
FIGURE 5-66. REAR AXLE ASSEMBLY - HUB REDUCTION (SN 0160129344 to Present)
FIGURE 5-67. REAR AXLE ASSEMBLY - BRAKES (SN 0160129344 to Present)
FIGURE 5-68. REAR AXLE ASSEMBLY - STEERING (SN 0160129344 to Present)
FIGURE 5-69. REAR AXLE ASSEMBLY - TRUNION (SN 0160129344 to Present)
FIGURE 5-70. LSI AXLE SENSOR INSTALLATION
FIGURE 5-71. TIRE/WHEEL SET 360/85-28 - SOLID
FIGURE 5-72. TIRE/WHEEL SET 400/75-28 PNEUMATIC
FIGURE 5-73. TIRE/WHEEL SET 400/75-28 PNEUMATIC NON-MARKING
FIGURE 5-74. TIRE/WHEEL SET 400/75-28 - FOAM-FILLED
FIGURE 5-75. TIRE/WHEEL SET 400/75-28 NON-MARKING - FOAM-FILLED
FIGURE 5-76. TIRE/WHEEL SET 14-24 16PR PNEUMATIC
FIGURE 5-77. TIRE/WHEEL SET 14-24 12PR - FOAM-FILLED
FIGURE 5-78. TIRE/WHEEL SET 14-24 12PR - FOAM-FILLED (E-3) (SUNSHINE)
FIGURE 5-79. TIRE/WHEEL SET 14-24 - FOAM-FILLED (E-3) (NON-MARKING) (SUNSHINE)
FIGURE 5-80. TIRE/WHEEL SET 14-24 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-81. TIRE/WHEEL SET 14-24 SOLIDEAL (DIRECTIONAL
FIGURE 5-82. TIRE/WHEEL SET 14-28 SOLIDBOSS (DIRECTIONAL)
FIGURE 5-83. TIRE/WHEEL SET 14-28 SOLIDBOSS (NON-DIRECTIONAL)
FIGURE 5-84. TIRE/WHEEL SET 18 X 625 (PNUEMATIC TURF)
FIGURE 5-85. FENDER INSTALLATION
FIGURE 5-86. WHEEL CHOCK INSTALLATION
FIGURE 5-87. TOOLBOX INSTALLATION
SECTION 6 - CABFIGURE 6-1. CAB MOUNTING
FIGURE 6-2. CAB MOUNTS INSTALLATION
FIGURE 6-3. FRONT CAB OUTRIGGER INSTALLATION
FIGURE 6-4. CAB FENDER INSTALLATION
FIGURE 6-5. CAB FENDER INSTALLATION REAR (LH)
FIGURE 6-6. OROPS CAB INSTALLATION
FIGURE 6-7. EROPS CAB INSTALLATION
FIGURE 6-8. CAB, TRIM KIT
FIGURE 6-9. CAB, TRIM KIT
FIGURE 6-10. OPEN CAB ASSEMBLY
FIGURE 6-11. LSI OPEN CAB INSTALLATION
FIGURE 6-12. OPEN CAB PLUG GROUP
FIGURE 6-13. CAB, EPD CAULK
FIGURE 6-14. ENCLOSED CAB ASSEMBLY
FIGURE 6-15. LSI EMCLOSED CAB INSTALLATION
FIGURE 6-16. REAR WINDOW INSTALLATION
FIGURE 6-17. REAR WINDOW INSTALLATION (WO/WIPER) (ANSI)
FIGURE 6-18. REAR WINDOW INSTALLATION (WO/WIPER) (ISO)
FIGURE 6-19. REAR WINDOW INSTALLATION (WO/WIPER) (ENG/SPAN)
FIGURE 6-20. REAR WINDOW ASSEMBLY
FIGURE 6-21. DOOR INSTALLATION
FIGURE 6-22. DOOR UPPER GLASS ASSEMBLY
FIGURE 6-23. CAB LATCH ASSEMBLY
FIGURE 6-24. CAB DOOR TRIGGER ASSEMBLY
FIGURE 6-25. DOOR ASSEMBLY
FIGURE 6-26. CAB DOOR
FIGURE 6-27. DOOR STRAP INSTALLATION
FIGURE 6-28. ENCLOSED CAB PLUG GROUP
FIGURE 6-29. LSI DISPLAY INSTALLATION (OPEN CAB)
FIGURE 6-30. LSI DISPLAY INSTALLATION (ENCLOSED CAB)
FIGURE 6-31. BASIC MIRROR INSTALLATION
FIGURE 6-32. FRONT COVER INSTALLATION (OPEN CAB)
FIGURE 6-33. FRONT COVER INSTALLATION (ENCLOSED CAB)
FIGURE 6-34. FIRE EXTINGUISHER INSTALLATION
FIGURE 6-35. FILTER TRAY PANEL
FIGURE 6-36. FRONT DUCT COVER
FIGURE 6-37. LEVEL INDICATOR INSTALLATION
FIGURE 6-38. SEAT INSTALLATION - CLOTH (ORANGE SEAT BELT)
FIGURE 6-39. SEAT INSTALLATION - VINYL
FIGURE 6-40. SEAT ASSEMBLY - CLOTH (ORANGE SEAT BELT)
FIGURE 6-41. SEAT ASSEMBLY
FIGURE 6-42. SEAT BELT INSTALLATION (3 INCH)
FIGURE 6-43. HEATER INSTALLATION
FIGURE 6-44. HEATER AND A/C INSTALLATION (CAB PARTS)
FIGURE 6-45. HEATER ASSEMBLY
FIGURE 6-46. HEATER ASSEMBLY
FIGURE 6-47. HEATER AND A/C ASSEMBLY
FIGURE 6-48. HEATER AND A/C ASSEMBLY
FIGURE 6-49. CAB CONDENSER ASSEMBLY
FIGURE 6-50. A/C RECEIVER DRIER
FIGURE 6-51. CONDENSER
FIGURE 6-52. FRONT WIPER INSTALLATION
FIGURE 6-53. REAR WIPER INSTALLATION
FIGURE 6-54. ROOF WIPER INSTALLATION
FIGURE 6-55. HEADLINER INSTALLATION
FIGURE 6-56. TRIM INSTALLATION - OPEN CAB
FIGURE 6-57. TRIM INSTALLATION - ENCLOSED CAB
FIGURE 6-58. DASH COVER ASSEMBLY - ENCLOSED CAB
FIGURE 6-59. ARMREST
FIGURE 6-60. OPEN CAB FRONT COVER INSTALLATION
FIGURE 6-61. ENCLOSED CAB FRONT COVER INSTALLATION
FIGURE 6-62. ROOF CAP INSTALLATION (A/C)
FIGURE 6-63. ROOF CAP INSTALLATION (NO A/C)
FIGURE 6-64. NON SKID TAPE INSTALLATION
FIGURE 6-65. EXTERNAL WINDOW RELEASE INSTALLATION (CAN & ISO)
FIGURE 6-66. WASHER TANK INSTALLATION
FIGURE 6-67. WASHER BOTTLE
FIGURE 6-68. CAB GUARD INSTALLATION (TOP AND FRONT)
FIGURE 6-69. CAB GUARD INSTALLATION (TOP)
FIGURE 6-70. CAB GUARD INSTALLATION (FRONT)
FIGURE 6-71. ROOF PIGTAIL CAP INSTALLATION
FIGURE 6-72. ROOF PIGTAIL INSTALLATION
FIGURE 6-73. NO SUNSCREEN INSTALLATION
FIGURE 6-74. RETRACTABLE SUNSCREEN INSTALLATION
SECTION 7 - CONTROLSFIGURE 7-1. ACCELERATOR PEDAL INSTALLATION
FIGURE 7-2. ACCELERATOR PEDAL
FIGURE 7-3. BRAKE PEDAL INSTALLATION
FIGURE 7-4. BRAKE PEDAL
FIGURE 7-5. BRAKE PEDAL PLATE
FIGURE 7-6. COLUMN CLAMP INSTALLATION
FIGURE 7-7. HORN BUTTON INSTALLATION
FIGURE 7-8. JOYSTICK INSTALLATION (ELOBAU BRAND)
FIGURE 7-9. JOYSTICK INSTALLATION (BOSCH/REXROTH BRAND)
FIGURE 7-10. JOYSTICK ASSEMBLY (ELOBAU BRAND)
FIGURE 7-11. JOYSTICK ASSEMBLY (BOSCH/REXROTH BRAND)
FIGURE 7-12. STEERING WHEEL INSTALLATION
FIGURE 7-13. OUTRIGGER SWITCHES INSTALLATION
FIGURE 7-14. STEERING COLUMN INSTALLATION
FIGURE 7-15. EMERGENCY STEERING COLUMN INSTALLATION
FIGURE 7-16. STEERING WHEEL
FIGURE 7-17. WIPER-TURN SWITCH
SECTION 8 - HYDRAULIC CIRCUITSFIGURE 8-1. MAIN HYDRAULIC INSTALLATION (OUTRIGGERS)
FIGURE 8-2. MAIN HYDRAULIC INSTALLATION, EMERGENCY STEERING (OUTRIGGERS)
FIGURE 8-3. BOOM HYDRAULIC INSTALLATION
FIGURE 8-4. BOOM AUXILIARY HYDRAULICS
FIGURE 8-5. BOOM AUXILIARY HYDRAULICS (HYDRAULIC COUPLER)
FIGURE 8-6. QUICK COUPLER VALVE ASSEMBLY
FIGURE 8-7. BOOM HYDRAULIC TUBES INSTALLATION
FIGURE 8-8. CAB HYDRAULIC INSTALLATION
FIGURE 8-9. CAB HYDRAULIC INSTALLATION, EMERGENCY STEERING
FIGURE 8-10. COUNTERBALANCE VALVE INSTALLATION (LIFT - GLS NO RIDE CONTROL)
FIGURE 8-11. COUNTERBALANCE VALVE HYDRAULIC LINES (LIFT - RIDE CONTROL)
FIGURE 8-12. COUNTERBALANCE VALVE HYDRAULIC LINES (LIFT - RIDE CONTROL)
FIGURE 8-13. EMERGENCY STEERING MANIFOLD & FITTINGS ASSEMBLY
FIGURE 8-14. FRAME HYDRAULICS INSTALLATION
FIGURE 8-15. FRAME LEVEL INSTALLATION
FIGURE 8-16. FRAME LEVEL HYDRAULICS INSTALLATION (OUTRIGGERS)
FIGURE 8-17. PISTON PUMP INSTALLATION
FIGURE 8-18. PISTON PUMP ASSEMBLY
FIGURE 8-19. REAR AXLE STABILIZER INSTALLATION
FIGURE 8-20. VALVE INSTALLATION (OUTRIGGERS)
FIGURE 8-21. VALVE INSTALLATION - FRAME LEVEL AND OUTRIGGER
FIGURE 8-22. VALVE ASSEMBLY - FRAME LEVEL AND OUTRIGGER
FIGURE 8-23. VALVES INSTALLATION - MAIN & PRIORITY
FIGURE 8-24. VALVE INSTALLATION - MAIN
FIGURE 8-25. VALVE AND FITTINGS ASSEMBLY- MAIN
FIGURE 8-26. VALVE INSTALLATION – PRIORITY
FIGURE 8-27. VALVE ASSEMBLY - PRIORITY FUNCTION MANIFOLD
FIGURE 8-28. VALVE INSTALLATION - SAHR BRAKE
FIGURE 8-29. VALVE ASSEMBLY - SAHR BRAKE
FIGURE 8-30. VALVES MOUNTING INSTALLATION - STEER SELECT
FIGURE 8-31. VALVE INSTALLATION - STEER SELECT
FIGURE 8-32. VALVE AND FITTINGS ASSEMBLY- STEER SELECT
FIGURE 8-33. VALVE ASSEMBLY - GLS (NO RIDE CONTROL)
SECTION 9 - HYDRAULIC COMPONENTSFIGURE 9-1. COUPLER - HYDRAULIC COUPLER
FIGURE 9-2. CYLINDER GROUP INSTALLATION
FIGURE 9-3. CYLINDER ASSEMBLY - CARRIAGE SIDE SHIFT
FIGURE 9-4. CYLINDER ASSEMBLY - CARRIAGE SIDE TILT
FIGURE 9-5. CYLINDER ASSEMBLY - CARRIAGE SWING
FIGURE 9-6. CYLINDER ASSEMBLY - COMPENSATION
FIGURE 9-7. CYLINDER SUB-ASSEMLY - EXTEND/RETRACT
FIGURE 9-8. CYLINDER ASSEMBLY - EXTEND/RETRACT
FIGURE 9-9. CYLINDER ASSEMBLY - FORK POSITIONING
FIGURE 9-10. CYLINDER INSTALLATION - FRAME LEVEL
FIGURE 9-11. CYLINDER ASSEMBLY - FRAME LEVEL
FIGURE 9-12. CYLINDER ASSEMBLY - GRAPPLE BUCKET
FIGURE 9-13. LIFT CYLINDER ASSEMBLY, INSTALLATION
FIGURE 9-14. CYLINDER ASSEMBLY - LIFT
FIGURE 9-15. CYLINDER SUB-ASSEMBLY - QUICK COUPLER
FIGURE 9-16. CYLINDER ASSEMBLY - QUICK COUPLER
FIGURE 9-17. CYLINDER & VALVE INSTALLATION - STABILIZER (REAR AXLE)
FIGURE 9-18. CYLINDER ASSEMBLY - STABILIZER (REAR AXLE)
FIGURE 9-19. CYLINDER SUB-ASSEMBLY - TILT
FIGURE 9-20. CYLINDER ASSEMBLY - TILT
FIGURE 9-21. CYLINDER ASSEMBLY - OUTRIGGER
FIGURE 9-22. PUMP ASSEMBLY - PISTON
FIGURE 9-23. HYDRAULIC TANK
FIGURE 9-24. HYDRAULIC TANK FILTER ASSEMBLY
FIGURE 9-25. VALVE, AIR SHUT OFF
FIGURE 9-26. VALVE AND FITTINGS - CARRIAGE (DUAL FORK)
FIGURE 9-27. VALVE - CARRIAGE DUAL FORK FLOW DIVIDER
FIGURE 9-28. VALVE ASSEMBLY - FRAME LEVEL AND OUTRIGGER
FIGURE 9-29. VALVE ASSEMBLY - MAIN CONTROL
FIGURE 9-30. VALVE ASSEMBLY – PRIORITY
FIGURE 9-31. VALVE ASSEMBLY - QUICK COUPLER
FIGURE 9-32. VALVE ASSEMBLY - SAHR BRAKE
FIGURE 9-33. VALVE ASSEMBLY - STABILIZER (REAR AXLE)
FIGURE 9-34. VALVE ASSEMBLY - STEERING
FIGURE 9-35. VALVE ASSEMBLY - STEERING ORBITAL
FIGURE 9-36. VALVE ASSEMBLY - STEERING SELECT
SECTION 10 - ELECTRICALFIGURE 10-1. MAIN ELECTRICAL INSTALLATION (ULS)
FIGURE 10-2. MAIN ELECTRICAL INSTALLATION (LS)
FIGURE 10-3. A/C OPTION HARNESS
FIGURE 10-4. AIR SHUT OFF VALVE HARNESS - CAB
FIGURE 10-5. AIR SHUT OFF VALVE HARNESS - ENGINE
FIGURE 10-6. ALARM INSTALLATION - BACK UP (97DB)
FIGURE 10-7. ALARM INSTALLATION - BACK UP (120DB)
FIGURE 10-8. ALARM INSTALLATION - BACK UP (WHITE NOISE)
FIGURE 10-9. ARCTIC COLD WEATHER PACKAGE INSTALLATION (ULS)
FIGURE 10-10. ARCTIC COLD WEATHER PACKAGE INSTALLATION (LS)
FIGURE 10-11. BATTERY INSTALLATION
FIGURE 10-12. BATTERY INSTALLATION - ARCTIC PACKAGE
FIGURE 10-13. BOOM ANGLE SENSOR INSTALLATION (STANDARD)
FIGURE 10-14. BOOM ANGLE SENSOR INSTALLATION (LSI)
FIGURE 10-15. BOOM ELECTRICAL HARNESS INSTALLATION
FIGURE 10-16. BOOM ELECTRIC HARNESS
FIGURE 10-17. BOOM AUXILIARY ELECTRIC INSTALLATION
FIGURE 10-18. BOOM AUXILIARY ELECTRIC HARNESS INSTALLATION
FIGURE 10-19. CAB DASH ELECTRICAL (ULS)
FIGURE 10-20. CAB DASH ELECTRICAL (LS)
FIGURE 10-21. CAB ELECTRICAL INSTALLATION
FIGURE 10-22. CAB ELECTRICAL BOARD ASSEMBLY
FIGURE 10-23. CAB ELECTRICAL COMMUNICATION CABLE
FIGURE 10-24. CAB HARNESS
FIGURE 10-25. CAB ELECTRICAL INSTALLATION - ENCLOSED
FIGURE 10-26. CAB ELECTRICAL INSTALLATION - OPEN
FIGURE 10-27. CAB OPTION 1 ELECTRICAL BOARD
FIGURE 10-28. CAB OPTION 2 ELECTRICAL BOARD
FIGURE 10-29. CAB OPTION HARNESS
FIGURE 10-30. CAB OPTION 1 HARNESS
FIGURE 10-31. CAB OPTION 2 HARNESS
FIGURE 10-32. CAB - KEY HARNESS
FIGURE 10-33. CAB MULTIFUNCTION DISPLAY INSTALLATION
FIGURE 10-34. CAB SEAT BELT ALARM HARNESS
FIGURE 10-35. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 10-36. CLEARSKY HARNESS - CS550 BEACON
FIGURE 10-37. DEF PURGE LIGHT HARNESS (ULS)
FIGURE 10-38. ENGINE - WIRING INSTALLATION (ULS)
FIGURE 10-39. ENGINE - WIRING INSTALLATION (LS)
FIGURE 10-40. ENGINE HARNESS (ULS)
FIGURE 10-41. ENGINE HARNESS (LS)
FIGURE 10-42. ENGINE BAY - ELECTRICAL INSTALLATION (ULS)
FIGURE 10-43. ENGINE BAY - ELECTRICAL INSTALLATION (LS)
FIGURE 10-44. ENGINE BAY - WIRING INSTALLATION (ULS)
FIGURE 10-45. ENGINE BAY - WIRING INSTALLATION (LS)
FIGURE 10-46. ENGINE/CHASSIS HARNESS (ULS)
FIGURE 10-47. ENGINE - ECU INSTALLATION (ULS)
FIGURE 10-48. ENGINE - ECU INSTALLATION (LS)
FIGURE 10-49. ENGINE TBAP HARNESS
FIGURE 10-50. FRAME - ELECTRICAL INSTALLATION
FIGURE 10-51. FRAME - POWER DISTRIBUTION BOX
FIGURE 10-52. FRAME - WIRING INSTALLATION (ULS)
FIGURE 10-53. FRAME - WIRING INSTALLATION (LS)
FIGURE 10-54. FRAME HARNESS – FRONT
FIGURE 10-55. FRAME HARNESS - REAR
FIGURE 10-56. HEATER HARNESS - CUMMINS BREATHER (ULS)
FIGURE 10-57. HEATER HARNESS - FUEL FILTER
FIGURE 10-58. HEATER HARNESS - HYDRAULIC TANK
FIGURE 10-59. HVAC ACTUATOR HARNESS
FIGURE 10-60. JOYSTICK HARNESS
FIGURE 10-61. LIGHTS - BOOM WORK LIGHTS SWITCH/HARNESS INSTALLATION (LED)
FIGURE 10-62. LIGHTS - BOOM WORK LIGHTS HARNESS INSTALLATION (LED)
FIGURE 10-63. LIGHTS - BOOM WORK LIGHTS HARNESS
FIGURE 10-64. LIGHTS - CAB WORK LIGHTS INSTALLATION (NO A/C) (LED)
FIGURE 10-65. LIGHTS - CAB WORK LIGHTS INSTALLATION (A/C) (LED)
FIGURE 10-66. LIGHTS - ROADLIGHTS INSTALLATION
FIGURE 10-67. LIGHTS - ROADLIGHTS HEADLIGHT HARNESS
FIGURE 10-68. LIGHTS - ROADLIGHTS TAILLIGHTS HARNESS
FIGURE 10-69. LIGHTS - SWITCH INSTALLATION
FIGURE 10-70. LSI HARNESS - BOOM RETRACT
FIGURE 10-71. OUTRIGGER HARNESS
FIGURE 10-72. PLATFORM HARNESS
FIGURE 10-73. REVERSE CAMERA INSTALLATION
FIGURE 10-74. MULTI VIEW CAMERA INSTALLATION
FIGURE 10-75. REVERSE SENSOR INSTALLATION
FIGURE 10-76. REVERSE SENSOR HARNESS
FIGURE 10-77. RIDE CONTROL VALVE HARNESS INSTALLATION
FIGURE 10-78. RIDE CONTROL VALVE HARNESS
FIGURE 10-79. ROOF PIGTAIL HARNESS
FIGURE 10-80. TELEMATICS READY INSTALLATION
FIGURE 10-81. TELEMATICS READY HARNESS
FIGURE 10-82. USB CHARGER INSTALLATION
SECTION 11 - DECALSFIGURE 11-1. DECAL INSTALLATION (ANSI)
FIGURE 11-2. DECAL INSTALLATION HRC 110HP
FIGURE 11-3. DECAL INSTALLATION (CSA ENGLISH/FRENCH)
FIGURE 11-4. DECAL INSTALLATION HRC 74HP
FIGURE 11-5. DECAL INSTALLATION (ISO)
FIGURE 11-6. DECAL INSTALLATION (LATIN AMERICAN ENGLISH/SPANISH)
FIGURE 11-7. DECAL INSTALLATION - CLEARSKY CS550 BEACON
FIGURE 11-8. BRAND AND MODEL DECAL INSTALLATION
FIGURE 11-9. CAPACITY CHART BOOKLET (ANSI) (OUTRIGGERS)
FIGURE 11-10. CAPACITY CHART BOOKLET (ISO) (OUTRIGGERS)
FIGURE 11-11. CAPACITY CHART HOLDER INSTALLATION
FIGURE 11-12. REVERSE SENSOR SYSTEM DECAL (ENGLISH)
FIGURE 11-13. REVERSE SENSOR SYSTEM DECAL (ENGLISH/SPANISH)
SECTION 12 - RECOMMENDED SERVICE PARTS STOCKFIGURE 12-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 13 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 13-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
