JLG Telehandler 10042 10054 12054 Service Manual 3122346700 2025
Brand: JLG
Type of Machine: Telehandler
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: JLG 10042, 10054, 12054 Telehandler
Part Number: 3122346700
Publication Date: 2025
Number of Pages: 802 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards (task)
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Maximum Travel Speed
2.1.2 Transmission Speeds
2.1.3 Boom Performance Specifications
2.1.4 Battery
2.1.5 Engine Specifications
2.1.6 Tires
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedules
After-Treatment System (ATS)
2.5.1 Automatic Exhaust System Cleaning (In-Mission)
2.5.2 Stationary Exhaust System Cleaning (Non-Mission)
ClearSky Smart Fleet
2.6.1 General
2.6.2 ClearSky Smart Fleet™ – Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 Preparation, Inspection, and Maintenance
3.1.2 Pre-Start Inspection
3.1.3 Pre-Delivery Inspection
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Every 10 Hours
3.3.2 First 50 Hours
3.3.3 Every 50 Hours
3.3.4 First 250 Hours
3.3.5 Every 250 Hours
3.3.6 First 500 Hours
3.3.7 Every 500 Hours
3.3.8 Every 1000 Hours
3.3.9 Every 1500 Hours
3.3.10 Every 2000 Hours
3.3.11 Every 2000 Hours or 2 Years
3.3.12 Every 4000 Hours or 3 Years
3.3.13 Every 5000 Hours or 4 Years
Pins and Composite Bearing Repair Guidelines
3.4.1 Filament Wound Bearings
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Brake Maintenance
3.6.1 Park Brake Bleeding (Manually) (Front Axle Only)
3.6.2 Service Brake Bleeding
3.6.3 Brake System Check
DEF System Maintenance
3.7.1 Diesel Exhaust Fluid (DEF) System Cleaning
Boom Inspection and Maintenance
3.8.1 Boom Wear Pads
3.8.2 Boom Extend and Retract Chains
3.8.3 Boom Chain Tension Check and Adjustment (10042)
3.8.4 Boom Chain Tension Check and Adjustment (10054)
3.8.5 Boom Chain Tension Check and Adjustment (12054)
Hydraulic Filter Replacement
3.9.1 Removal
3.9.2 Installation
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Thread Locking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 Charging Circuit
4.2.3 Pressure Checks and Adjustments
4.2.4 Cylinder Checking Procedure
4.2.5 Cylinder Drift Test
Calibration Procedures
4.3.1 Analyzer
4.3.2 Calibration Preparation
4.3.3 Boom Angle Sensor Calibration
4.3.4 Load Stability Indicator (LSI) System Calibration
Special Procedures
4.4.1 Towing a Disabled Machine
4.4.2 Hydraulic Tank and Fuel Tank
4.4.3 Fuel Tank Cleaning and Drying
4.4.4 Evacuating and Recharging Air Conditioning (AC) System
Stabil-Trak™ and Boom Interlock System
4.5.1 Stabil-Trak™ System Component Terminology
4.5.2 Stabil-Trak™ Description
4.5.3 Stabil-Trak™ Operation
4.5.4 Stabil-Trak™ System Test
System SoftwareLoad Stability Indicator (LSI) (If Equipped)
5.1.1 Load Stability Indicator
5.1.2 LSI Sensor
Analyzer
5.2.1 Machine Data Access
5.2.2 JLG Hand Held Analyzer
5.2.3 JLG Mobile Analyzer and ClearSky SmartFleet Bluetooth Analyzer
5.2.4 PC Analyzer/Loglifter
5.2.5 Analyzer Software (Version P27.0)
Access Level
Diagnostics (Software Version P27.0)
Machine Setup (Software Version P27.0)
Personalities (Software Version P27.0)
Operator Tools (Software Version P27.0)
Calibrations (Software Version P27.0)
ClearSky (CS550) Configuration and Troubleshooting
5.9.1 ClearSky Smart FleetTM CS550 Configuration
5.9.2 Troubleshooting
Fault CodesIntroduction
6.1.1 Fault Code Display
Engine Fault Codes
Fault Codes - Help Comment (00x)
Fault Codes - Power-Up (21x)
Fault Codes - Ground Inputs (23x)
Fault Codes - Other Inputs (24x)
Fault Codes - Function Prevented (25x)
Fault Codes - Line Contactor, Open-Circuit (31x)
Fault Codes - Line Contactor, Short-Circuit (32x)
Fault Codes - Output Drivers (33x)
Fault Codes - Engine (43x)
Fault Codes - Battery Supply (44x)
Fault Codes - Transmission and Drive System (46x)
Fault Codes - Communications (66x)
Fault Codes - Telematics (68x)
Fault Codes - Tilt Sensor (81x)
Fault Codes - Envelope Control (84x)
Fault Codes - Load Moment (85x)
Fault Codes - Steering (86x)
Fault Codes - Service Required (87x)
Fault Codes - Hardware (99x)
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Tank
7.3.2 Hydraulic Circuits
7.3.3 Pressure Specifications
Torque Values
7.4.1 Cylinder Torque Values
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
8.1.3 Electrical Connector Examples
Electrical Connectors
Electrical Component Terminology
8.3.1 General Overview
Harness Layouts
Board Layouts
8.5.1 Cab Harness Fuses and Relays
8.5.2 Power Distribution Board
Telematics Gateway
8.6.1 Telematics-Ready (TCU) Plug
8.6.2 Component Locations
8.6.3 Telematics Gateway Harness Breakdown
Removal and InstallationWheels
Outrigger Assembly
Drive Assembly
9.3.1 Axle Assembly And Drive Shaft Troubleshooting
9.3.2 Axle
9.3.3 Drive Shafts
9.3.4 Input Drive Shaft
Boom
9.4.1 Boom System Component Terminology
9.4.2 Troubleshooting
9.4.3 Boom System (10042)
9.4.4 Boom System (10054)
9.4.5 Boom System (12054)
9.4.6 Quick Coupler
9.4.7 Forks
9.4.8 Boom Prop (If Equipped)
9.4.9 Boom Angle Sensor
9.5.1 Cab Components
9.5.2 Serial Number Plate
9.5.3 Cab Removal/Installation
9.5.4 Steering Wheel
9.5.5 Brake System
9.5.6 Throttle Pedal
9.5.7 Joystick Assembly
9.5.8 Ignition Key Switch
9.5.9 Dash Switches
9.5.10 Front Wiper Assembly (If Equipped)
9.5.11 Roof Wiper Assembly (If Equipped)
9.5.12 Windshield Washer Reservoir (If Equipped)
9.5.13 Heater System (If Equipped)
9.5.14 Heat, Ventilation and Air Conditioning System (If Equipped)
9.5.15 Steering Column and Steering Valve
9.5.16 Rear and Side View Camera (If Equipped)
9.5.17 Reverse Sensor (If Equipped)
9.6.1 Component Terminology
9.6.2 Diesel Fuel
9.6.3 Engine Serial Number
9.6.4 Engine Replacement
9.6.5 Engine Electrical System
9.6.6 Surge Tank Cap
9.6.7 Surge Tank
9.6.8 Thermostat
9.6.9 Engine Coolant Temperature Sensor
9.6.10 Radiator Assembly
9.6.11 Isolation Coupling
9.6.12 Air Filter Assembly (110 hp (82 kW) Engine (ULS) and 74 hp (55 kW) Engine)
9.6.13 Air Filter Assembly (110 hp (82 kW) Engine (LS))
9.6.14 Relay Assembly
9.6.15 Alternator
9.6.16 Starter
9.6.17 Fuel Tank
9.6.18 Pre-Fuel Filter and Fuel Pump
9.6.19 Engine Exhaust System (110 hp (82kW) Engine (ULS))
9.6.20 Engine Exhaust System (110 hp (82kW) Engine (LS))
9.6.21 Engine Exhaust System (74 hp (55kW) (ULS))
9.6.22 Air Conditioner (AC) Compressor (If equipped)
9.6.23 Diesel Exhaust Fluid (DEF) System (110 hp (82kW) Engine (ULS) Only)
9.7.1 Component Terminology
9.7.2 Transmission Serial Number
9.7.3 Transmission Replacement
9.7.4 Transmission Temperature Sensor Replacement
9.7.5 Transmission Speed Sensor Replacement
9.7.6 Transmission Oil Level Check
9.7.7 Transmission Oil Cooler Thermal Bypass Valve
9.7.8 Reverse Alarm
9.7.9 Transmission Troubleshooting
Hydraulic Cylinders
9.8.1 Frame Tilt Cylinder (10042, 10054)
9.8.2 Frame Tilt Cylinder (12054)
9.8.3 Stabil-Trak Cylinder (10042, 10054)
9.8.4 Stabil-Trak Cylinder (12054)
9.8.5 Lift Cylinder
9.8.6 Slave Cylinder
9.8.7 Boom Extend Cylinder
9.8.8 Attachment Tilt Cylinder
9.8.9 Outrigger Cylinder (10054, 12054 and If Equipped on 10042)
9.8.10 Steer Cylinders
Hydraulic Valves
9.9.1 Steer Select Valve and Park Brake Valve
9.9.2 Main Control Valve
9.9.3 Sway/Outrigger Valve (10054, 12054 and If Equipped on 10042)
9.9.4 Sway Valve (only 10042 without outriggers)
Electrical Components
9.11.1 Battery
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.12.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Axle Assembly
Boom
10.2.1 Boom Lubrication and Wear Pad Installation
10.2.2 Boom (10042)
10.2.3 Boom (10054)
10.2.4 Boom (12054)
Engine Components
10.3.1 Engine Components
DEF System
10.4.1 DEF Tank
10.4.2 DEF Pump
Hydraulic Cylinders
10.6.1 Boom Extend Cylinder (10042 without outriggers)
10.6.2 Boom Extend Cylinder (10042 with outriggers)
10.6.3 Boom Extend Cylinder (10054)
10.6.4 Boom Extend Cylinder (12054)
10.6.5 Attachment Tilt Cylinder (10042, 10054)
10.6.6 Attachment Tilt Cylinder (12054)
10.6.7 Lift Cylinder (10042, 10054)
10.6.8 Lift Cylinder (12054)
10.6.9 Slave Cylinder (10042)
10.6.10 Slave Cylinder (10054)
10.6.11 Slave Cylinder (12054)
10.6.12 Frame Tilt Cylinder (10042, 10054)
10.6.13 Outrigger, Frame Tilt (12054) and Stabil-Trak Cylinders
Hydraulic Valves
10.7.1 Main Control Valve
10.7.2 Steer Select and Park Brake Valve
10.7.3 Sway/Outrigger Valve (10054, 12054 and If Equipped on 10042)
10.7.4 Sway Valve (only 10042 without outriggers)
10.8.1 Hydraulic Tank
10.8.2 Hydraulic Pump
Torque/Connection InformationHydraulic Fittings
11.1.1 Definitions
11.1.2 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.3 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.4 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.5 Assembly Instructions for 45° SAE Flare Fittings
11.1.6 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.7 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.8 Assembly Instructions for Bulkhead (BH) Fittings
11.1.9 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.10 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.11 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.12 Assembly Instructions for Adjustable Port End (BSPP) Fittings
11.1.13 Assembly Instructions for Flange Connections (FL61 and FL62)
11.1.14 Double Wrench Method
11.1.15 FFWR and TFFT Methods
11.1.16 Adjustable Stud End Assembly
11.1.17 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE
11.2.2 Metric
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
