Hyundai
86
176,834
JLG Scissor Lift RT5394 Service & Maintenance Manual 3122566300 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT5394 Scissor Lift
Part Number: 3122566300
Publication Date: 2025
Number of Pages: 386 Pages
Coverpage
Effectivity Page
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Operating Specifications​
2.1.2 Dimensional Data​
2.1.3 Tires​
2.1.4 Platform Height/Tilt Limit Settings​
2.1.5 Hydraulic Pressure Settings​
2.1.6 Critical Stability Weights​
2.1.7 Major Component Weights​
2.1.8 Generator Specifications (If Equipped)​
2.1.9 Drive Information​
2.1.10 Steering Information​
2.1.11 Hydraulic Cylinder Specifications​
2.1.12 Engine Specifications​
Serial Number Locations​
Fluids and Lubrication​
2.3.1 Hydraulic System​
2.3.2 Changing Hydraulic Oil​
2.3.3 Oil Information​
2.3.4 Hydraulic Oil Specifications​
2.3.5 Lubrication Specifications​
2.3.6 Capacities​
2.3.7 Fluids​
Clearsky Smart Fleet (If Equipped)​
2.4.1 General​
2.4.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Lubrication and Servicing​
Preventive Maintenance and Inspection Schedule​
3.3.1 Maintenance and Inspection Schedule Codes​
Pins and Composite Bearing Repair Guidelines​
Tires & Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
3.5.3 Tire Replacement​
3.5.4 Wheel Replacement​
Service Maintenance Components​
3.6.1 Setting Scissor Arm Safety Prop​
3.6.2 General Maintenance Tips​
3.6.3 Fuel Tank​
3.6.4 Drive Hub​
3.6.5 Scissor Arms - Sliding Wear Pads​
3.6.6 Hydraulic Oil Tank​
3.6.7 Hydraulic Charge Filter​
3.6.8 Oil Change with Filter​
3.6.9 Fuel/Water Separator Filter (Diesel) - Kubota​
3.6.10 Fuel Strainer (Diesel) - Kubota​
3.6.11 Fuel Filter (Gas) - Kubota​
3.6.12 Air Filter​
3.6.13 Engine Coolant​
Drive Motor (Hengli) Inspection​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Continuity Measurement Over Long Distances​
4.1.3 Requirements​
4.1.4 Procedure​
4.1.5 Threadlocking Compound​
4.1.6 Tool List​
Testing Procedures​
4.2.1 Preparation​
4.2.2 Testing LSS Control System Warnings and Interlocks:​
4.2.3 Testing LSS Platform Load Performance with Calibrated Weights:​
4.2.4 Testing LSS Platform Load Reading with a Known Weight:​
4.2.5 Oscillating Axle - Lockout Cylinder Test (if equipped)​
4.2.6 Roll and Leak Testing​
4.2.7 Tightening and Torquing Bolts​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Testing & Evaluation​
4.3.5 Chassis Tilt Sensor Calibration​
4.3.6 Oscillating Axle Tilt Sensor​
4.3.7 Set Stow Elevation​
Special Procedures​
4.4.1 Joystick Controller​
4.4.2 Cylinder Checking Procedure​
4.4.3 Cylinder Drift Test​
4.4.4 Re-Aligning Torque Hub Input Coupling​
4.4.5 Hydraulic Component Start-Up Procedures and Recommendations​
4.4.6 Oscillating Axle Cylinder Bleeding Procedure​
4.4.7 Drive Pump Start-Up Procedure​
4.4.8 Drive Pump Pre-Fill Procedure​
4.4.9 Pressure Relief Valve - Setting Procedures​
4.4.10 Initial Start-up Procedures​
4.4.11 Start-Up Procedure​
Service Mode Procedures​
4.5.1 ECM Override (Dual Fuel Only)​
4.5.2 Elevation Service​
4.5.3 EEPROM Reset​
4.5.4 Allow Drive​
4.5.5 Allow Leveling Jack Retract​
Operating Characteristics​
4.6.1 Leveling Jacks​
4.6.2 Generator​
4.6.3 Lift​
4.6.4 Drive​
Calibration Menu​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Description​
5.1.3 LSS Connector Pin Assignments​
5.1.4 Personalities​
5.1.5 Diagnostic Menu​
5.1.6 Machine Setup Menu​
JLG Analyzer​
5.2.1 Connecting the JLG Control System Analyzer​
5.2.2 Connecting the JLG Control System Analyzer​
5.2.3 Hand Held Analyzer​
5.2.4 To Connect the Hand Held Analyzer​
5.2.5 Using the Analyzer​
5.2.6 Changing the Access Level of the Hand Held Analyzer​
5.2.7 Adjusting Parameters Using the Hand Held Analyzer​
5.2.8 Analyzer Menu Flow Charts​
Analyzer Software Accessibility​
5.3.1 Machine Configuration and Programming Settings​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction​
6.1.1 System Fault/DTC Indication​
Diagnostic Trouble Codes (DTC) (concept)​
DTC Check Tables​
6.3.1 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description​
6.3.2 Help Menu and Fault Codes​
6.3.3 ClearSky Smart Fleet DTC Fault Codes​
6.3.4 LSS Troubleshooting​
6.3.5 Drive Motor (Sauer) Troubleshooting​
Hydraulics
Theories of Operation​
7.1.1 Cylinders​
7.1.2 Valves​
Torque Values​
7.2.1 Main Hydraulic Valve​
7.2.2 Flow Divider Valve​
7.2.3 Leveling Jack Directional Valve​
7.2.4 Leveling Jack Valves​
7.2.5 Lift Cylinder Valve Cartridge​
7.2.6 Leveling Jack​
Gear Pump​
7.3.1 Gear Pump Priming​
Hydraulic Diagrams​
7.4.1 Oscillating Axle​
Electricals
General Information​
8.1.1 General​
8.1.2 Applying Silicone Dielectric Compound to Electrical Connections​
8.1.3 Dielectric Grease Application​
8.1.4 AMP Mate-N-Lok​
8.1.5 AMP Faston​
8.1.6 AMP Micro-Fit​
8.1.7 AMP Mini Fit Jr​
8.1.8 Mini Fit Sr​
8.1.9 DIN Connectors​
8.1.10 Exceptions​
Electrical Connectors​
8.2.1 Deutsch Connectors​
AMP Connector​
8.3.1 Assembly​
8.3.2 Disassembly​
8.3.3 Wedge Lock​
8.3.4 Service - Voltage Reading​
Switches​
8.4.1 Basic Check​
8.4.2 Leveling Jacks Limit Switch​
8.4.3 Automatic Switches​
8.4.4 Switch Wiring - Low Side, High Side​
Location of Additional Sensors​
Board Layouts​
8.6.1 Jack/Option Control Module Pin Connections​
Wheels​
9.1.1 Wheel Installation​
Battery​
9.2.1 Removal​
9.2.2 Installation​
Chassis Tilt Sensor Installation​
9.3.1 Removal​
9.3.2 Installation​
Ground Control Station​
9.4.1 Control Station Removal​
9.4.2 Options Control Module​
Hydraulic Tank​
9.5.1 Removal​
9.5.2 Installation​
Scissor Arms​
9.6.1 Lift Cylinder​
9.6.2 Scissor Arms Removal​
9.6.3 Scissor Arm Assembly Removal​
Platform​
9.7.1 Removal​
9.7.2 Installation​
Axle Installation​
9.8.1 Front Axle Assembly (Fixed)​
9.8.2 Front Axle Assembly (Oscillating)​
9.8.3 Steering Assembly​
9.8.4 Axle Lockout Cylinder​
Leveling Jacks​
9.9.1 Leveling Jack Assembly​
9.9.2 Leveling Jack Cylinder​
Side Compartment Covers​
9.10.1 Removal​
9.10.2 Installation​
Fuel Tank​
9.11.1 Removal​
9.11.2 Installation​
Kubota Engine​
9.12.1 Engine Tray - Swing Out​
9.12.2 Engine Removal and Installation​
9.12.3 Dual Fuel/LPG System​
9.12.4 Changing From Gasoline to LP Gas​
9.12.5 Changing From LP Gas to Gasoline​
9.12.6 Using Liquid Petroleum (LP) Gas​
9.12.7 Propane Fuel System Pressure Relief​
9.12.8 Propane Fuel System Leak Test​
9.12.9 Generator (if equipped)​
9.12.10 Exhaust System​
9.12.11 Dual Fuel - Gas/LPG​
9.12.12 Diesel​
9.12.13 Air Cleaner System​
9.12.14 Radiator​
9.12.15 Engine Electrical Component Locations​
9.12.16 Hydraulic Pump​
9.12.17 Pump Coupling Assembly​
9.12.18 Engine Speed Sensor (Kubota Diesel Engine)​
9.12.19 Throttle Actuator Adjustment​
9.12.20 Air Gap Setting​
9.12.21 Diagnosis of Actuator​
9.12.22 Adjustment of the Actuator​
9.12.23 Adjustment Verification of Actuator​
Drive Assembly​
9.13.1 Removal​
9.13.2 Installation​
Charge Pump Filter​
9.14.1 Removal​
9.14.2 Installation​
Drive Motor (Hengli)​
Hydraulic Valves​
9.16.1 Removal​
9.16.2 Installation​
Axial HI 45 Pump​
9.17.1 General Repair Instructions​
9.17.2 Pump Removal​
9.17.3 Electric Control Module​
9.17.4 Control Solenoids​
9.17.5 Shaft Seal, Roller Bearing & Shaft Replacement​
9.17.6 Charge Pump​
9.17.7 Charge Check/HPRV​
9.17.8 Charge Pressure Relief Valve​
9.17.9 Pressure Limiter Valve Replacement​
Ladder Assembly​
9.18.1 Removal​
9.18.2 Installation​
9.19.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Main Disassembly for Drive Hub​
10.1.2 Hub-Spindle Disassembly​
10.1.3 Cover Disassembly​
10.1.4 Carrier Disassembly​
10.1.5 Carrier Assembly​
10.1.6 Cover Sub-Assembly​
10.1.7 Hub-Spindle Sub-Assembly​
10.1.8 Main Assembly​
Scissor Arm Assembly​
Platform Control Station​
10.3.1 Disassembly​
10.3.2 Assembly​
10.4.1 Ground Control Station Components​
10.4.2 Disassembly​
10.4.3 Assembly​
Cylinder Repair​
10.5.1 Disassembly​
10.5.2 Cleaning and Inspection​
10.5.3 Assembly​
Cylinder Assemblies​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections​
11.1.8 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections​
11.1.9 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.10 Assembly Instructions for 45° SAE Flare Fittings​
11.1.11 Assembly Instructions for O-ring Face Seal (ORFS) Fittings​
11.1.12 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.13 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.14 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.15 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings​
11.1.16 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.17 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.18 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.19 Double Wrench Method​
11.1.20 FFWR and TFFT Methods​
11.1.21 Adjustable Stud End Assembly​
11.1.22 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
