JLG Scissor Lift RT5394 Service & Maintenance Manual 31221548 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT5394 Scissor Lift
Part Number: 31221548
Publication Date: 2025
Number of Pages: 378 Pages
Coverpage
Effectivity Page
Safety
Brand: JLG
Coverpage
Effectivity Page
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Operating Specifications
2.1.2 Dimensional Data
2.1.3 Tires
2.1.4 Platform Height/Tilt Limit Settings
2.1.5 Hydraulic Pressure Settings
2.1.6 Critical Stability Weights
2.1.7 Major Component Weights
2.1.8 Generator Specifications (If Equipped)
2.1.9 Drive Information
2.1.10 Steering Information
2.1.11 Hydraulic Cylinder Specifications
2.1.12 Engine Specifications
Serial Number Locations
Fluids and Lubrication
2.3.1 Hydraulic System
2.3.2 Changing Hydraulic Oil
2.3.3 Oil Information
2.3.4 Hydraulic Oil Specifications
2.3.5 Lubrication Specifications
2.3.6 Capacities
2.3.7 Fluids
Clearsky Smart Fleet (If Equipped)
2.4.1 General
2.4.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Lubrication and Servicing
Preventive Maintenance and Inspection Schedule
3.3.1 Maintenance and Inspection Schedule Codes
Pins and Composite Bearing Repair Guidelines
Tires & Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
3.5.3 Tire Replacement
3.5.4 Wheel Replacement
Service Maintenance Components
3.6.1 Setting Scissor Arm Safety Prop
3.6.2 General Maintenance Tips
3.6.3 Fuel Tank
3.6.4 Drive Hub
3.6.5 Scissor Arms - Sliding Wear Pads
3.6.6 Hydraulic Oil Tank
3.6.7 Hydraulic Charge Filter
3.6.8 Oil Change with Filter
3.6.9 Fuel/Water Separator Filter (Diesel) - Kubota
3.6.10 Fuel Strainer (Diesel) - Kubota
3.6.11 Fuel Filter (Gas) - Kubota
3.6.12 Air Filter
3.6.13 Engine Coolant
Drive Motor (Hengli) Inspection
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Continuity Measurement Over Long Distances
4.1.3 Requirements
4.1.4 Procedure
4.1.5 Threadlocking Compound
4.1.6 Tool List
Testing Procedures
4.2.1 Preparation
4.2.2 Testing LSS Control System Warnings and Interlocks:
4.2.3 Testing LSS Platform Load Performance with Calibrated Weights:
4.2.4 Testing LSS Platform Load Reading with a Known Weight:
4.2.5 Oscillating Axle - Lockout Cylinder Test (if equipped)
4.2.6 Roll and Leak Testing
4.2.7 Tightening and Torquing Bolts
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
4.3.4 Testing & Evaluation
4.3.5 Chassis Tilt Sensor Calibration
4.3.6 Oscillating Axle Tilt Sensor
4.3.7 Set Stow Elevation
Special Procedures
4.4.1 Joystick Controller
4.4.2 Cylinder Checking Procedure
4.4.3 Cylinder Drift Test
4.4.4 Re-Aligning Torque Hub Input Coupling
4.4.5 Hydraulic Component Start-Up Procedures and Recommendations
4.4.6 Oscillating Axle Cylinder Bleeding Procedure
4.4.7 Drive Pump Start-Up Procedure
4.4.8 Drive Pump Pre-Fill Procedure
4.4.9 Pressure Relief Valve - Setting Procedures
4.4.10 Initial Start-up Procedures
4.4.11 Start-Up Procedure
Service Mode Procedures
4.5.1 ECM Override (Dual Fuel Only)
4.5.2 Elevation Service
4.5.3 EEPROM Reset
4.5.4 Allow Drive
4.5.5 Allow Leveling Jack Retract
Operating Characteristics
4.6.1 Leveling Jacks
4.6.2 Generator
4.6.3 Lift
4.6.4 Drive
Calibration Menu
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Description
5.1.3 LSS Connector Pin Assignments
5.1.4 Personalities
5.1.5 Diagnostic Menu
5.1.6 Machine Setup Menu
JLG Analyzer
5.2.1 Connecting the JLG Control System Analyzer
5.2.2 Connecting the JLG Control System Analyzer
5.2.3 Hand Held Analyzer
5.2.4 To Connect the Hand Held Analyzer
5.2.5 Using the Analyzer
5.2.6 Changing the Access Level of the Hand Held Analyzer
5.2.7 Adjusting Parameters Using the Hand Held Analyzer
5.2.8 Analyzer Menu Flow Charts
Analyzer Software Accessibility
5.3.1 Machine Configuration and Programming Settings
ClearSky (CS550) Configuration and Troubleshooting
5.4.1 ClearSky Smart FleetTM CS550 Configuration
5.4.2 Troubleshooting
Fault CodesIntroduction
6.1.1 System Fault/DTC Indication
Diagnostic Trouble Codes (DTC) (concept)
DTC Check Tables
6.3.1 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description
6.3.2 Help Menu and Fault Codes
6.3.3 ClearSky Smart Fleet DTC Fault Codes
6.3.4 LSS Troubleshooting
6.3.5 Drive Motor (Sauer) Troubleshooting
HydraulicsTheories of Operation
7.1.1 Cylinders
7.1.2 Valves
Torque Values
7.2.1 Main Hydraulic Valve
7.2.2 Flow Divider Valve
7.2.3 Leveling Jack Directional Valve
7.2.4 Leveling Jack Valves
7.2.5 Lift Cylinder Valve Cartridge
7.2.6 Leveling Jack
Gear Pump
7.3.1 Gear Pump Priming
Hydraulic Diagrams
7.4.1 Oscillating Axle
ElectricalsGeneral Information
8.1.1 General
8.1.2 Applying Silicone Dielectric Compound to Electrical Connections
8.1.3 Dielectric Grease Application
8.1.4 AMP Mate-N-Lok
8.1.5 AMP Faston
8.1.6 AMP Micro-Fit
8.1.7 AMP Mini Fit Jr
8.1.8 Mini Fit Sr
8.1.9 DIN Connectors
8.1.10 Exceptions
Electrical Connectors
8.2.1 Deutsch Connectors
AMP Connector
8.3.1 Assembly
8.3.2 Disassembly
8.3.3 Wedge Lock
8.3.4 Service - Voltage Reading
Switches
8.4.1 Basic Check
8.4.2 Leveling Jacks Limit Switch
8.4.3 Automatic Switches
8.4.4 Switch Wiring - Low Side, High Side
Location of Additional Sensors
Board Layouts
8.6.1 Jack/Option Control Module Pin Connections
Removal and InstallationWheels
9.1.1 Wheel Installation
Battery
9.2.1 Removal
9.2.2 Installation
Chassis Tilt Sensor Installation
9.3.1 Removal
9.3.2 Installation
Ground Control Station
9.4.1 Control Station Removal
9.4.2 Options Control Module
Hydraulic Tank
9.5.1 Removal
9.5.2 Installation
Scissor Arms
9.6.1 Lift Cylinder
9.6.2 Scissor Arms Removal
9.6.3 Scissor Arm Assembly Removal
Platform
9.7.1 Removal
9.7.2 Installation
Axle Installation
9.8.1 Front Axle Assembly (Fixed)
9.8.2 Front Axle Assembly (Oscillating)
9.8.3 Steering Assembly
9.8.4 Axle Lockout Cylinder
Levelling Jacks
9.9.1 Leveling Jack Assembly
9.9.2 Leveling Jack Cylinder
Side Compartment Covers
9.10.1 Removal
9.10.2 Installation
9.11.1 Removal
9.11.2 Installation
Kubota Engine
9.12.1 Engine Tray - Swing Out
9.12.2 Engine Removal and Installation
9.12.3 Dual Fuel/LPG System
9.12.4 Changing From Gasoline to LP Gas
9.12.5 Changing From LP Gas to Gasoline
9.12.6 Using Liquid Petroleum (LP) Gas
9.12.7 Propane Fuel System Pressure Relief
9.12.8 Propane Fuel System Leak Test
9.12.9 Generator (if equipped)
9.12.10 Exhaust System
9.12.11 Dual Fuel - Gas/LPG
9.12.12 Diesel
9.12.13 Air Cleaner System
9.12.14 Radiator
9.12.15 Engine Electrical Component Locations
9.12.16 Hydraulic Pump Installation
9.12.17 Pump Coupling Assembly
9.12.18 Engine Speed Sensor (Kubota Diesel Engine)
9.12.19 Throttle Actuator Adjustment
9.12.20 Air Gap Setting
9.12.21 Diagnosis of Actuator
9.12.22 Adjustment of the Actuator
9.12.23 Adjustment Verification of Actuator
Drive Assembly
9.13.1 Removal
9.13.2 Installation
Charge Pump Filter
9.14.1 Removal
9.14.2 Installation
Hydraulic Valves
9.16.1 Removal
9.16.2 Installation
Axial HI 45 Pump
9.17.1 General Repair Instructions
9.17.2 Pump Removal
9.17.3 Electric Control Module
9.17.4 Control Solenoids
9.17.5 Shaft Seal, Roller Bearing & Shaft Replacement
9.17.6 Charge Pump
9.17.7 Charge Check/HPRV
9.17.8 Charge Pressure Relief Valve
9.17.9 Pressure Limiter Valve Replacement
Ladder Assembly
9.18.1 Removal
9.18.2 Installation
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.19.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Main Disassembly for Drive Hub
10.1.2 Hub-Spindle Disassembly
10.1.3 Cover Disassembly
10.1.4 Carrier Disassembly
10.1.5 Carrier Assembly
10.1.6 Cover Sub-Assembly
10.1.7 Hub-Spindle Sub-Assembly
10.1.8 Main Assembly
Platform Control Station
10.3.1 Disassembly
10.3.2 Assembly
10.4.1 Ground Control Station Components
10.4.2 Disassembly
10.4.3 Assembly
Cylinder Repair
10.5.1 Disassembly
10.5.2 Cleaning and Inspection
10.5.3 Assembly
Cylinder Assemblies
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 Assembly Instructions for American Standard Pipe Thread Tapered (NPTF) Connections
11.1.8 Assembly Instructions for British Standard Pipe Thread Tapered (BSPT) Connections
11.1.9 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.10 Assembly Instructions for 45° SAE Flare Fittings
11.1.11 Assembly Instructions for O-ring Face Seal (ORFS) Fittings
11.1.12 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.13 Assembly Instructions for Bulkhead (BH) Fittings
11.1.14 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.15 Assembly Instructions for Adjustable Port End Metric (MFF) Fittings
11.1.16 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.17 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.18 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.19 Double Wrench Method
11.1.20 FFWR and TFFT Methods
11.1.21 Adjustable Stud End Assembly
11.1.22 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
