JLG Scissor Lift RT5394 Parts Manual 31219130
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT5394 Scissor Lift
Part Number: 31219130
Publication Date: 2024
Number of Pages: 416 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING
FIGURE 1-3. STEER INSTALLATION
FIGURE 1-4. WHEEL DRIVE INSTALLATION
FIGURE 1-5. DRIVE HUB ASSEMBLY - FRONT
FIGURE 1-6. DRIVE HUB AND BRAKE ASSEMBLY - REAR
FIGURE 1-7. DRIVE MOTOR ASSEMBLY
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED NON-MARKING
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - IN395/45/D20 FOAM FILLED
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - IN395/45/D20 FOAM FILLED NON-MARKING
FIGURE 1-12. BEACON LIGHT INSTALLATION - OPTIONAL
FIGURE 1-13. LEVELING JACKS INSTALLATION
FIGURE 1-14. LEVELING JACKS ASSEMBLY
FIGURE 1-15. LEVELING JACKS VALVE ASSEMBLY
SECTION 2 - GROUND CONTROLSFIGURE 2-1. VALVE INSTALLATION
FIGURE 2-2. MAIN VALVE ASSEMBLY
FIGURE 2-3. FLOW DIVIDER VALVE ASSEMBLY
FIGURE 2-4. TANKS & HORN INSTALLATION - DIESEL
FIGURE 2-5. TANKS AND HORN INSTALLATION - GASOLINE
FIGURE 2-6. HYDRAULIC TANK ASSEMBLY
FIGURE 2-7. ELECTRICAL COMPONENTS INSTALLATION - DIESEL
FIGURE 2-8. ELECTRICAL COMPONENTS INSTALLATION - KUBOTA GASOLINE
FIGURE 2-9. GROUND CONTROL BOX ASSEMBLY - KUBOTA DIESEL
FIGURE 2-10. GROUND CONTROL BOX ASSEMBLY - KUBOTA GASOLINE
FIGURE 2-11. MOTION ALARM INSTALLATION
FIGURE 2-12. WHITE NOISE ALARM INSTALLATION
FIGURE 2-13. HOODS ANDLADDERS INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. ENGINE INSTALLATION - KUBOTA DIESEL T4F
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL T4F
FIGURE 3-3. ENGINE ASSEMBLY - KUBOTA DIESEL T4F
FIGURE 3-4. ENGINE INSTALLATION - KUBOTA DIESEL T4F WITH GENERATOR
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL T4F WITH GENERATOR
FIGURE 3-6. ENGINE ASSEMBLY - KUBOTA DIESEL T4F WITH GENERATOR
FIGURE 3-7. ENGINE COMPONENTS - KUBOTA DIESEL T4F
FIGURE 3-8. ENGINE INSTALLATION - KUBOTA GASOLINE
FIGURE 3-9. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE
FIGURE 3-10. ENGINE ASSEMBLY - KUBOTA GASOLINE
FIGURE 3-11. ENGINE INSTALLATION - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-12. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-13. ENGINE ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR
FIGURE 3-14. ENGINE COMPONENTS - KUBOTA GASOLINE
FIGURE 3-15. FUEL/WATER SEPARATOR ASSEMBLY - DIESEL ENGINES
FIGURE 3-16. COUPLING KIT - DIESEL ENGINES
FIGURE 3-17. COUPLING KIT - GASOLINE ENGINES
FIGURE 3-18. PISTON PUMP ASSEMBLY
FIGURE 3-19. FAN GUARD INSTALLATION - KUBOTA
FIGURE 3-20. SPARK ARRESTOR MUFFLER - OPTIONAL (GASOLINE ENGINES)
FIGURE 3-21. GENERATOR INSTALLATION - 4000W (KUBOTA DIESEL STAGE III)
FIGURE 3-22. GENERATOR INSTALLATION - 4000W (KUBOTA DIESEL T4F) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 3-23. GENERATOR INSTALLATION - 4000W (KUBOTA DIESEL T4F) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 3-24. GENERATOR INSTALLATION - 4000W (KUBOTA GASOLINE) (DUAL FUEL) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 3-25. GENERATOR INSTALLATION - 4000W (KUBOTA GASOLINE) (DUAL FUEL) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 3-26. GENERATOR INSTALLATION - 7500W (KUBOTA DIESEL STAGE III)
FIGURE 3-27. GENERATOR INSTALLATION - 7500W (KUBOTA DIESEL T4F) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 3-28. GENERATOR INSTALLATION - 7500W (KUBOTA DIESEL T4F) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 3-29. GENERATOR INSTALLATION - 7500W (KUBOTA GASOLINE) (DUAL FUEL) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 3-30. GENERATOR INSTALLATION - 7500W (KUBOTA GASOLINE) (DUAL FUEL) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 3-31. JUNCTION BOX ASSEMBLY - 4000W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 3-32. JUNCTION BOX ASSEMBLY - 7500W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 3-33. JUNCTION BOX ASSEMBLY - 4000W/7500W GENERATOR (AUSTRALIAN, CE & UK CA SPECS)
SECTION 4 - SCISSORS ARMSFIGURE 4-1. SCISSORS ARMS ASSEMBLY
FIGURE 4-2. SCISSORS ARMS INSTALLATION WITH AC CABLE
FIGURE 4-3. SCISSORS ARMS INSTALLATION WITH GENERATOR
FIGURE 4-4. ARM GUARDS INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM WITH SINGLE EXTENTION INSTALLATION
FIGURE 5-2. PLATFORM WITH DUAL EXTENSION INSTALLATION
FIGURE 5-3. RAIL INSTALLATION - PLATFORM WITH SINGLE EXTENSION
FIGURE 5-4. RAIL INSTALLATION - PLATFORM WITH DUAL EXTENSION
FIGURE 5-5. PLATFORM CONSOLE BOX INSTALLATION - DIESEL MACHINES
FIGURE 5-6. PLATFORM CONSOLE BOX INSTALLATION - GASOLINE MACHINES
FIGURE 5-7. CONTROLLER ASSEMBLY
FIGURE 5-8. PLATFORM MODULE INSTALLATION
FIGURE 5-9. PIPE RACK INSTALLATION
FIGURE 5-10. SKYWELDER INSTALLATION (OPTIONAL) (ANSI SPECS)
FIGURE 5-11. SKYWELDER INSTALLATION (OPTIONAL) (CE & UK CA SPECS)
FIGURE 5-12. WELDER ASSEMBLY
FIGURE 5-13. WORKSTATION INSTALLATION (OPTIONAL)
FIGURE 6-2. LOWER LIFT CYLINDER
FIGURE 6-3. UPPER LIFT CYLINDER
FIGURE 6-4. LEVELING JACK CYLINDER ASSEMBLY
FIGURE 6-5. STEER CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - FIXED AXLE
FIGURE 7-2. HYDRAULIC DIAGRAM - OSCILLATING AXLE
FIGURE 7-3. HYDRAULIC DIAGRAM - SCISSOR ARMS
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-3. BOX AT PLATFORM INSTALLATION - 220V (ANSI EXPORT, CSA, CHINA AND JAPANESE SPECS) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-4. BOX AT PLATFORM INSTALLATION - 220V (ANSI EXPORT, CSA, CHINA AND JAPANESE SPECS) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPEC) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPEC) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPEC) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPEC) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPEC) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPEC) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 2X4 BOX (CE & UK CA SPEC) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 2X4 BOX (CE & UK CA SPEC) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 70X70 BOX (CE & UK CA SPEC) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 70X70 BOX (CE & UK CA SPEC) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 2X4 BOX (CE & UK CA SPEC) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 2X4 BOX (CE & UK CA SPEC) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 70X70 BOX (CE & UK CA SPEC) (Prior to SN M200052012, Excluding M200047449 and M200047476)
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 70X70 BOX (CE & UK CA SPEC) (SN M200052012 to Present, Including M200047449 and M200047476)
FIGURE 8-19. BATTERY CABLE KIT - DIESEL ENGINES
FIGURE 8-20. BATTERY CABLE KIT - GASOLINE ENGINES
FIGURE 8-21. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER
FIGURE 8-22. CHASSIS HARNESS
FIGURE 8-23. DUAL FUEL HARNESS
FIGURE 8-24. ENGINE HARNESS - KUBOTA DIESEL
FIGURE 8-25. ENGINE HARNESS - KUBOTA GASOLINE
FIGURE 8-26. GENERATOR CONTROL HARNESS - 4000W GENERATOR (GENERATOR TO CONTROL BOX)
FIGURE 8-27. GENERATOR CONTROL HARNESS - 4000W GENERATOR (CONTROL BOX TO GENERATOR CONTROL)
FIGURE 8-28. GENERATOR CONTROL HARNESS - 7500W GENERATOR (GENERATOR TO CONTROL BOX)
FIGURE 8-29. GENERATOR CONTROL HARNESS - 7500W GENERATOR (CONTROL BOX TO GENERATOR CONTROL)
FIGURE 8-30. GROUND CONTROL BOX HARNESS - LOWER
FIGURE 8-31. GROUND CONTROL BOX HARNESS - UPPER
FIGURE 8-32. GROUND TO LOWER AUXILIARY HOLDING VALVE HARNESS
FIGURE 8-33. GROUND TO UPPER AUXILIARY HOLDING VALVE HARNESS
FIGURE 8-34. GROUND TO LOWER LIFT CYLINDER HARNESS
FIGURE 8-35. GROUND TO UPPER LIFT CYLINDER HARNESS
FIGURE 8-36. GROUND TO PLATFORM HARNESS
FIGURE 8-37. HYDRAULIC COMPARTMENT HARNESS
FIGURE 8-38. LEVELING JACK HARNESS
FIGURE 8-39. LSS HARNESS
FIGURE 8-40. OSCILLATING AXLE HARNESS
FIGURE 8-41. PLATFORM CONTROL BOX HARNESS
FIGURE 8-42. PLATFORM MODULE HARNESS
FIGURE 8-43. RECEPTACLE ASSEMBLY (MACHINES WITH GENERATORS) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPEC)
FIGURE 8-44. RECEPTACLE BOX KIT - 110V GFI
FIGURE 8-45. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-46. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-47. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-48. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-49. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-50. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-51. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-52. SCISSORS ARMS GUARD HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN AND JAPANESE SPECS
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (SPANISH/PORTUGUESE)
FIGURE 9-4. DECAL INSTALLATION - CE & UK CA SPEC
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPECS (ENGLISH/CHINESE)
FIGURE 9-6. DECAL INSTALLATION - CSA (ENGLISH/FRENCH)
FIGURE 9-7. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN)
FIGURE 9-8. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/SPANISH)
FIGURE 9-9. DECAL INSTALLATION - OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
