Hyundai
86
176,834
JLG Scissor Lift RT5394 Parts Catalog 31220304
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT5394 Scissor Lift
Part Number: 31220304
Publication Date: 2025
Number of Pages: 402 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED​
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING​
FIGURE 1-3. STEER INSTALLATION​
FIGURE 1-4. WHEEL DRIVE INSTALLATION​
FIGURE 1-5. DRIVE HUB ASSEMBLY - FRONT​
FIGURE 1-6. DRIVE HUB AND BRAKE ASSEMBLY - REAR​
FIGURE 1-7. DRIVE MOTOR ASSEMBLY​
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED​
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED NON-MARKING​
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - IN395/45/D20 FOAM FILLED​
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - IN395/45/D20 FOAM FILLED NON-MARKING​
FIGURE 1-12. BEACON LIGHT INSTALLATION - OPTIONAL​
FIGURE 1-13. LEVELING JACKS INSTALLATION​
FIGURE 1-14. LEVELING JACKS ASSEMBLY​
FIGURE 1-15. LEVELING JACKS VALVE ASSEMBLY​
SECTION 2 - GROUND CONTROLS
FIGURE 2-1. VALVE INSTALLATION​
FIGURE 2-2. MAIN VALVE ASSEMBLY​
FIGURE 2-3. FLOW DIVIDER VALVE ASSEMBLY​
FIGURE 2-4. TANKS & HORN INSTALLATION - DIESEL​
FIGURE 2-5. TANKS AND HORN INSTALLATION - GASOLINE​
FIGURE 2-6. HYDRAULIC TANK ASSEMBLY​
FIGURE 2-7. ELECTRICAL COMPONENTS INSTALLATION - DIESEL (WITHOUT CLEARSKY V3 CONNECTION)​
FIGURE 2-8. ELECTRICAL COMPONENTS INSTALLATION - DIESEL (WITH CLEARSKY V3 CONNECTION)​
FIGURE 2-9. ELECTRICAL COMPONENTS INSTALLATION - GASOLINE (WITHOUT CLEARSKY V3 CONNECTION)​
FIGURE 2-10. ELECTRICAL COMPONENTS INSTALLATION - GASOLINE (WITH CLEARSKY V3 CONNECTION)​
FIGURE 2-11. GROUND CONTROL BOX ASSEMBLY - DIESEL​
FIGURE 2-12. GROUND CONTROL BOX ASSEMBLY - GASOLINE​
FIGURE 2-13. MOTION ALARM INSTALLATION​
FIGURE 2-14. WHITE NOISE ALARM INSTALLATION​
FIGURE 2-15. HOODS ANDLADDERS INSTALLATION​
SECTION 3 - ENGINE
FIGURE 3-1. ENGINE INSTALLATION - KUBOTA DIESEL T4F​
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL T4F​
FIGURE 3-3. ENGINE ASSEMBLY - KUBOTA DIESEL T4F - MACHINES WITH (Prior to SN M200058675, Excluding M200058667)​
FIGURE 3-4. ENGINE ASSEMBLY - KUBOTA DIESEL T4F (SN M200058675 to Present, Including M200058667)​
FIGURE 3-5. ENGINE INSTALLATION - KUBOTA DIESEL T4F WITH GENERATOR​
FIGURE 3-6. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA DIESEL T4F WITH GENERATOR​
FIGURE 3-7. ENGINE ASSEMBLY - KUBOTA DIESEL T4F WITH GENERATOR - MACHINES WITH (Prior to SN M200058675, Excluding M200058667)​
FIGURE 3-8. ENGINE ASSEMBLY - KUBOTA DIESEL T4F WITH GENERATOR (SN M200058675 to Present, Including M200058667)​
FIGURE 3-9. ENGINE COMPONENTS - KUBOTA DIESEL T4F​
FIGURE 3-10. ENGINE INSTALLATION - KUBOTA GASOLINE​
FIGURE 3-11. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE​
FIGURE 3-12. ENGINE ASSEMBLY - KUBOTA GASOLINE​
FIGURE 3-13. ENGINE INSTALLATION - KUBOTA GASOLINE WITH GENERATOR​
FIGURE 3-14. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR​
FIGURE 3-15. ENGINE ASSEMBLY - KUBOTA GASOLINE WITH GENERATOR​
FIGURE 3-16. ENGINE COMPONENTS - KUBOTA GASOLINE​
FIGURE 3-17. FUEL/WATER SEPARATOR ASSEMBLY - DIESEL ENGINES​
FIGURE 3-18. COUPLING KIT - DIESEL ENGINES​
FIGURE 3-19. COUPLING KIT - GASOLINE ENGINES​
FIGURE 3-20. PISTON PUMP ASSEMBLY​
FIGURE 3-21. FAN GUARD INSTALLATION - KUBOTA​
FIGURE 3-22. SPARK ARRESTOR MUFFLER - OPTIONAL (GASOLINE ENGINES)​
FIGURE 3-23. GENERATOR INSTALLATION - 4000W (KUBOTA DIESEL STAGE III)​
FIGURE 3-24. GENERATOR INSTALLATION - 4000W (KUBOTA DIESEL T4F)​
FIGURE 3-25. GENERATOR INSTALLATION - 4000W (KUBOTA GASOLINE) (DUAL FUEL)​
FIGURE 3-26. GENERATOR INSTALLATION - 7500W (KUBOTA DIESEL STAGE III)​
FIGURE 3-27. GENERATOR INSTALLATION - 7500W (KUBOTA DIESEL T4F)​
FIGURE 3-28. GENERATOR INSTALLATION - 7500W (KUBOTA GASOLINE) (DUAL FUEL)​
FIGURE 3-29. JUNCTION BOX ASSEMBLY - 4000W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 3-30. JUNCTION BOX ASSEMBLY - 7500W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 3-31. JUNCTION BOX ASSEMBLY - 4000W/7500W GENERATOR (AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 3-32. QUICKFIT OIL DRAIN INSTALLATION - KUBOTA DIESEL ENGINE​
FIGURE 3-33. QUICKFIT OIL DRAIN INSTALLATION - KUBOTA GASOLINE ENGINE​
SECTION 4 - SCISSORS ARMS
FIGURE 4-1. SCISSORS ARMS INSTALLATION WITH AC CABLE​
FIGURE 4-2. SCISSORS ARMS INSTALLATION WITH GENERATOR​
FIGURE 4-3. SCISSORS ARMS ASSEMBLY​
FIGURE 4-4. ARM GUARDS INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM WITH SINGLE EXTENTION INSTALLATION​
FIGURE 5-2. PLATFORM WITH DUAL EXTENSION INSTALLATION​
FIGURE 5-3. RAIL INSTALLATION - PLATFORM WITH SINGLE EXTENSION​
FIGURE 5-4. RAIL INSTALLATION - PLATFORM WITH DUAL EXTENSION​
FIGURE 5-5. PLATFORM CONSOLE BOX INSTALLATION - DIESEL MACHINES​
FIGURE 5-6. PLATFORM CONSOLE BOX INSTALLATION - GASOLINE MACHINES​
FIGURE 5-7. CONTROLLER ASSEMBLY​
FIGURE 5-8. PLATFORM MODULE INSTALLATION​
FIGURE 5-9. PIPE RACK INSTALLATION​
FIGURE 5-10. SKYWELDER INSTALLATION (OPTIONAL) (ANSI SPECS)​
FIGURE 5-11. SKYWELDER INSTALLATION (OPTIONAL) (CE & UK CA SPECS)​
FIGURE 5-12. WELDER ASSEMBLY​
FIGURE 5-13. WORKSTATION INSTALLATION (OPTIONAL)​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-2. LOWER LIFT CYLINDER​
FIGURE 6-3. UPPER LIFT CYLINDER​
FIGURE 6-4. LEVELING JACK CYLINDER ASSEMBLY​
FIGURE 6-5. STEER CYLINDER ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM - FIXED AXLE​
FIGURE 7-2. HYDRAULIC DIAGRAM - OSCILLATING AXLE​
FIGURE 7-3. HYDRAULIC DIAGRAM - SCISSOR ARMS​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS)​
FIGURE 8-2. BOX AT PLATFORM INSTALLATION - 220V (ANSI EXPORT, CSA, CHINA AND JAPANESE SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPEC)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 2X4 BOX (CE & UK CA SPEC)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 70X70 BOX (CE & UK CA SPEC)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 2X4 BOX (CE & UK CA SPEC)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 70X70 BOX (CE & UK CA SPEC)​
FIGURE 8-10. BATTERY CABLE KIT - DIESEL ENGINES​
FIGURE 8-11. BATTERY CABLE KIT - GASOLINE ENGINES​
FIGURE 8-12. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER​
FIGURE 8-13. CHASSIS HARNESS (WITHOUT CLEARSKY V3 CONNECTION)​
FIGURE 8-14. CHASSIS HARNESS (WITH CLEARSKY V3 CONNECTION)​
FIGURE 8-15. DUAL FUEL HARNESS​
FIGURE 8-16. ENGINE HARNESS - KUBOTA DIESEL​
FIGURE 8-17. ENGINE HARNESS - KUBOTA GASOLINE​
FIGURE 8-18. GENERATOR CONTROL HARNESS - 4000W GENERATOR (GENERATOR TO CONTROL BOX)​
FIGURE 8-19. GENERATOR CONTROL HARNESS - 4000W GENERATOR (CONTROL BOX TO GENERATOR CONTROL)​
FIGURE 8-20. GENERATOR CONTROL HARNESS - 7500W GENERATOR (GENERATOR TO CONTROL BOX)​
FIGURE 8-21. GENERATOR CONTROL HARNESS - 7500W GENERATOR (CONTROL BOX TO GENERATOR CONTROL)​
FIGURE 8-22. GROUND CONTROL BOX HARNESS - LOWER​
FIGURE 8-23. GROUND CONTROL BOX HARNESS - UPPER​
FIGURE 8-24. GROUND TO LOWER AUXILIARY HOLDING VALVE HARNESS​
FIGURE 8-25. GROUND TO UPPER AUXILIARY HOLDING VALVE HARNESS​
FIGURE 8-26. GROUND TO LOWER LIFT CYLINDER HARNESS​
FIGURE 8-27. GROUND TO UPPER LIFT CYLINDER HARNESS​
FIGURE 8-28. GROUND TO PLATFORM HARNESS​
FIGURE 8-29. HYDRAULIC COMPARTMENT HARNESS​
FIGURE 8-30. LEVELING JACK HARNESS​
FIGURE 8-31. LSS HARNESS​
FIGURE 8-32. NOTIFICATION UNIT HARNESS​
FIGURE 8-33. OSCILLATING AXLE HARNESS​
FIGURE 8-34. PLATFORM CONTROL BOX HARNESS​
FIGURE 8-35. PLATFORM MODULE HARNESS​
FIGURE 8-36. RECEPTACLE ASSEMBLY (MACHINES WITH GENERATORS) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPEC)​
FIGURE 8-37. RECEPTACLE BOX KIT - 110V GFI​
FIGURE 8-38. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-39. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-40. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)​
FIGURE 8-41. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)​
FIGURE 8-42. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPEC)​
FIGURE 8-43. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-44. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-45. SCISSORS ARMS GUARD HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS (ENGLISH)​
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN AND JAPANESE SPECS​
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (SPANISH/PORTUGUESE)​
FIGURE 9-4. DECAL INSTALLATION - CE & UK CA SPEC​
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPECS (ENGLISH/CHINESE)​
FIGURE 9-6. DECAL INSTALLATION - CSA (ENGLISH/FRENCH)​
FIGURE 9-7. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN)​
FIGURE 9-8. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/SPANISH)​
FIGURE 9-9. DECAL INSTALLATION - OPTIONS​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
