JLG Scissor Lift RT4069 RT4769 Parts Manual 31220318
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT4069 RT4769 Scissor Lift
Part Number: 31220318
Publication Date: 2025
Number of Pages: 452 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - SINGLE OSCILLATING (WITHOUT SENSORS)
FIGURE 1-2. AXLE INSTALLATION - SINGLE OSCILLATING (WITH SENSORS)
FIGURE 1-3. AXLE INSTALLATION - DUAL OSCILLATING
FIGURE 1-4. VALVE ASSEMBLY - DUAL AXLE
FIGURE 1-5. STEERING INSTALLATION (Prior to SN M200089839, Excluding M200088804 and M200089132)
FIGURE 1-6. STEERING INSTALLATION (SN M200089839 to Present, Including M200088804 and M200089132)
FIGURE 1-7. DRIVE INSTALLATION (2WD)
FIGURE 1-8. DRIVE INSTALLATION (4WD) (Prior to SN M200102539)
FIGURE 1-9. DRIVE INSTALLATION (4WD) (SN M200102539 to Present)
FIGURE 1-10. DRIVE MOTOR ASSEMBLY - REAR (2WD & 4WD)
FIGURE 1-11. HUB/SPINDLE ASSEMBLY - FRONT (4WD) (Prior to SN M200102539)
FIGURE 1-12. HUB/SPINDLE ASSEMBLY - FRONT (4WD) (SN M200102539 to Present)
FIGURE 1-13. DRIVE HUB AND BRAKE ASSEMBLY (2WD REAR)
FIGURE 1-14. DRIVE HUB AND BRAKE ASSEMBLY (4WD)
FIGURE 1-15. HUB/SPINDLE ASSEMBLY (2WD FRONT)
FIGURE 1-16. VALVE ASSEMBLY - TRACTION (2WD)
FIGURE 1-17. VALVE ASSEMBLY - TRACTION (4WD)
FIGURE 1-18. TIRE AND WHEEL INSTALLATION - FOAM-FILLIED
FIGURE 1-19. TIRE AND WHEEL INSTALLATION - FOAM-FILLIED NON-MARKING
FIGURE 1-20. TIRE AND WHEEL INSTALLATION - FOAM-FILLIED TURF NON-MARKING
FIGURE 1-21. LEVELING JACKS INSTALLATION - PARTIAL COVERS
FIGURE 1-22. LEVELING JACKS INSTALLATION - FULL COVERS
FIGURE 1-23. LEVELING JACKS VALVE ASSEMBLY
FIGURE 1-24. OIL COOLER INSTALLATION (Prior to SN M200064805)
FIGURE 1-25. OIL COOLER INSTALLATION (Including M200064805)
FIGURE 1-26. ONBOARD GENERATOR INSTALLATION (SINGLE OSCILLATING AXLE)
FIGURE 1-27. ONBOARD GENERATOR INSTALLATION (DUAL OSCILLATING AXLES)
FIGURE 1-28. ONBOARD GENERATOR ASSEMBLY
FIGURE 1-29. ONBOARD GENERATOR TRAY INSTALLATION (SINGLE OSCILLATING AXLE)
FIGURE 1-30. ONBOARD GENERATOR TRAY INSTALLATION (DUAL OSCILLATING AXLES)
FIGURE 1-31. FRAME COVERS INSTALLATION (RT4069)
FIGURE 1-32. FRAME COVERS INSTALLATION (RT4769)
FIGURE 1-33. LADDER INSTALLATION (RT4069)
FIGURE 1-34. LADDER INSTALLATION (RT4769) (Prior to SN M200063437)
FIGURE 1-35. LADDER INSTALLATION (RT4769) (SN M200063437 to Present)
SECTION 2 - GROUND CONTROLSFIGURE 2-1. HYDRAULIC COMPONENTS INSTALLATION - DIESEL
FIGURE 2-2. HYDRAULIC COMPONENTS INSTALLATION - DUAL FUEL
FIGURE 2-3. VALVE ASSEMBLY - MAIN CONTROL
FIGURE 2-4. HYDRAULIC TANK ASSEMBLY
FIGURE 2-5. ELECTRICAL COMPONENTS INSTALLATION (RT4069) (Prior to SN M200059938, Except SN M200059349 through M200059352, Except SN M200059437 through M200059448, Except SN M200059849 through M200059852)
FIGURE 2-6. ELECTRICAL COMPONENTS INSTALLATION (RT4069) (SN M200059349 through M200059352, SN M200059437 through M200059448, SN M200059849 through M200059852, SN M200059938 to Present, Including M200080006)
FIGURE 2-7. ELECTRICAL COMPONENTS INSTALLATION (RT4069) (SN M200080007 to Present)
FIGURE 2-8. ELECTRICAL COMPONENTS INSTALLATION (RT4769) (Prior to SN M200060047, Except SN M200059571 through M200059573)
FIGURE 2-9. ELECTRICAL COMPONENTS INSTALLATION (RT4769) (SN M200059571 through M200059573, SN M200060047 through M200078314)
FIGURE 2-10. ELECTRICAL COMPONENTS INSTALLATION (RT4769) (SN M200078315 to Present)
FIGURE 2-11. GROUND CONTROL ASSEMBLY (RT4069) (Prior to SN M200080005)
FIGURE 2-12. GROUND CONTROL ASSEMBLY (RT4069) (SN M200080007 to Present)
FIGURE 2-13. GROUND CONTROL ASSEMBLY (RT4769) (Prior to SN M200078315)
FIGURE 2-14. GROUND CONTROL ASSEMBLY (RT4769) (SN M200078315 to Present)
FIGURE 2-15. ALARM INSTALLATION (HORN)
FIGURE 2-16. ALARM INSTALLATION (WHITE NOISE)
FIGURE 2-17. BEACON/STROBE LIGHT INSTALLATION - SINGLE (WITHOUT CLEARSKY BEACON))
FIGURE 2-18. BEACON/STROBE LIGHT INSTALLATION - DUAL (WITHOUT CLEARSKY BEACON))
FIGURE 2-19. COVER WITHOUT BEACON INSTALLATION
FIGURE 2-20. HOODS INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. ENGINE MOUNTING INSTALLATION (Prior to SN M200063437)
FIGURE 3-2. ENGINE MOUNTING INSTALLATION (SN M200063437 to Present)
FIGURE 3-3. ENGINE AND PUMP ASSEMBLY - DIESEL
FIGURE 3-4. PUMP ASSEMBLY - DIESEL
FIGURE 3-5. ENGINE COMPONENTS - DIESEL
FIGURE 3-6. COUPLING ASSEMBLY - ENGINE PUMP (DIESEL)
FIGURE 3-7. ENGINE FUEL LINES INSTALLATION - DIESEL
FIGURE 3-8. ENGINE ELECTRICAL INSTALLATION - DIESEL
FIGURE 3-9. ENGINE COOLING SYSTEM INSTALLATION - DIESEL
FIGURE 3-10. AIR INTAKE INSTALLATION - DIESEL
FIGURE 3-11. EXHAUST INSTALLATION - DIESEL
FIGURE 3-12. OIL FILTER INSTALLATION - REMOTE - DIESEL
FIGURE 3-13. ENGINE AND PUMP ASSEMBLY - DUAL FUEL (Prior to SN M200088676, Excluding M200087779)
FIGURE 3-14. ENGINE AND PUMP ASSEMBLY - DUAL FUEL (SN M200088676 to Present, Including M200087779)
FIGURE 3-15. PUMP ASSEMBLY - DUAL FUEL
FIGURE 3-16. ENGINE COMPONENTS - DUAL FUEL (Prior to SN M200088676, Excluding M200087779)
FIGURE 3-17. ENGINE COMPONENTS - DUAL FUEL (SN M200088676 to Present, Including M200087779)
FIGURE 3-18. COUPLING ASSEMBLY - ENGINE PUMP (DUAL FUEL)
FIGURE 3-19. ENGINE FUEL LINES INSTALLATION - DUAL FUEL (Prior to SN M200084868)
FIGURE 3-20. ENGINE FUEL LINES INSTALLATION - DUAL FUEL (SN M200084868 to Present)
FIGURE 3-21. ENGINE ELECTRICAL INSTALLATION - DUAL FUEL
FIGURE 3-22. ENGINE COOLING SYSTEM INSTALLATION - DUAL FUEL
FIGURE 3-23. AIR INTAKE INSTALLATION - DUAL FUEL
FIGURE 3-24. EXHAUST INSTALLATION - DUAL FUEL
FIGURE 3-25. OIL FILTER INSTALLATION - REMOTE - DUAL FUEL
FIGURE 3-26. GENERATOR INSTALLATION - 2500W/60HZ (DIESEL MACHINES) (Prior to SN M200076032)
FIGURE 3-27. GENERATOR INSTALLATION - 2500W/60HZ (DIESEL MACHINES) (SN M200076032 to Present)
FIGURE 3-28. GENERATOR INSTALLATION - 2500W/60HZ (DUAL FUEL MACHINES) (Prior to SN M200076032)
FIGURE 3-29. GENERATOR INSTALLATION - 2500W/60HZ (DUAL FUEL MACHINES) (SN M200076032 to Present)
FIGURE 3-30. GENERATOR INSTALLATION - 2300W/50HZ (Prior to SN M200076032)
FIGURE 3-31. GENERATOR INSTALLATION - 2300W/50HZ (SN M200076032 to Present)
FIGURE 3-32. LP TANK BRACKETS INSTALLATION (SINGLE TANK)
FIGURE 3-33. LP TANK BRACKETS INSTALLATION (DUAL TANKS)
SECTION 4 - SCISSORS ARMSFIGURE 4-1. ARMS INSTALLATION (RT4069)
FIGURE 4-2. ARMS ASSEMBLY (RT4069)
FIGURE 4-3. CYLINDER AND LIFT DOWN VALVE ASSEMBLY (RT4069)
FIGURE 4-4. ARMS INSTALLATION (RT4769)
FIGURE 4-5. ARMS ASSEMBLY (RT4769)
FIGURE 4-6. CYLINDER AND LIFT DOWN VALVE ASSEMBLY - LOWER (RT4769)
FIGURE 4-7. CYLINDER AND LIFT DOWN VALVE ASSEMBLY - UPPER (RT4769)
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM INSTALLATION
FIGURE 5-2. PLATFORM EXTENSION INSTALLATION (SINGLE) (Prior to SN M200067004, Including M200067504, Excluding M200066376)
FIGURE 5-3. PLATFORM EXTENSION INSTALLATION (SINGLE) (SN M200067004 through M200087469, Including M200066376, Excluding M200067504)
FIGURE 5-4. PLATFORM EXTENSION INSTALLATION (SINGLE) (SN M200087470 to Present)
FIGURE 5-5. PLATFORM RAILS INSTALLATION (SINGLE EXTENSION)
FIGURE 5-6. PLATFORM RAILS INSTALLATION WITH PLUGS (SINGLE EXTENSION)
FIGURE 5-7. PLATFORM CONTROL BOX INSTALLATION - SIDE MOUNT
FIGURE 5-8. PLATFORM CONTROL BOX INSTALLATION - FRONT MOUNT (Prior to SN M200097861)
FIGURE 5-9. PLATFORM CONTROL BOX INSTALLATION - FRONT MOUNT (SN M200097861 to Present)
FIGURE 5-10. CONTROLLER ASSEMBLY
FIGURE 6-2. LEVELING JACK CYLINDER ASSEMBLY
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - LOWER
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - UPPER (RT4769)
FIGURE 6-5. STEER CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (DUAL OSCILLATING)
FIGURE 7-2. HYDRAULIC DIAGRAM - LEVELING JACKS
FIGURE 7-3. HYDRAULIC DIAGRAM - STANDARD (2WD)
FIGURE 7-4. HYDRAULIC DIAGRAM - STANDARD (4WD)
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED PLUG & RECEPTACLE (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ALL SPECS)
FIGURE 8-10. AUXILIARY DESCENT HARNESS
FIGURE 8-11. AXLE HARNESS - REAR OSCILLATING
FIGURE 8-12. BREAKER BOX KIT - 1 DOUBLE BREAKER (CE & UK CA SPECS)
FIGURE 8-13. BREAKER BOX KIT - 1 DOUBLE & 1 SINGLE BREAKER (CE & UK CA SPECS)
FIGURE 8-14. CHASSIS HARNESS (RT4069) (Prior to SN M200059938, Except SN M200059349 through M200059352, Except SN M200059437 through M200059448, Except SN M200059571 through M200059573, Except SN M200059849 through M200059852)
FIGURE 8-15. CHASSIS HARNESS (RT4069) (SN M200059938 through M200080006, SN M200059349 through M200059352, SN M200059437 through M200059448, SN M200059571 through M200059573, Including M200059849)
FIGURE 8-16. CHASSIS HARNESS (RT4069) (SN M200080007 to Present)
FIGURE 8-17. CHASSIS HARNESS (RT4769) (Prior to SN M200060047, Except SN M200059571 through M200059573)
FIGURE 8-18. CHASSIS HARNESS (RT4769) (SN M200059571 through M200059573, SN M200060047 through M200078314, Including )
FIGURE 8-19. CHASSIS HARNESS (RT4769) (SN M200078315 to Present)
FIGURE 8-20. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (AUSTRALIAN SPECS)
FIGURE 8-21. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (CE SPECS)
FIGURE 8-22. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (CE SPECS)
FIGURE 8-23. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (NA)
FIGURE 8-24. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (CE SPECS)
FIGURE 8-25. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-26. CLEARSKY CANBUS TELEMATICS HARNESS
FIGURE 8-27. CLEARSKY 3-WIRE TELEMATICS HARNESS
FIGURE 8-28. CLEARSKY 3-WIRE XIRGO JUMPER HARNESS
FIGURE 8-29. ENGINE HARNESS - DIESEL
FIGURE 8-30. ENGINE HARNESS - DUAL FUEL
FIGURE 8-31. GENERATOR HARNESS
FIGURE 8-32. GROUND TO PLATFORM HARNESS (RT4069)
FIGURE 8-33. GROUND TO PLATFORM HARNESS (RT4769)
FIGURE 8-34. LEVELING JACK HARNESS
FIGURE 8-35. LIFT DOWN HARNESS - LOWER
FIGURE 8-36. LIFT DOWN HARNESS - UPPER (RT4769)
FIGURE 8-37. LSS HARNESS
FIGURE 8-38. OIL COOLER HARNESS
FIGURE 8-39. ONBOARD GENERATOR CABLE
FIGURE 8-40. PLATFORM HARNESS
FIGURE 8-41. PLATFORM CABLE INSTALLATION – WITHOUT FOOTSWITCH
FIGURE 8-42. PLATFORM CABLE HARNESS – WITHOUT FOOTSWITCH
FIGURE 8-43. PLATFORM CABLE INSTALLATION – WITH FOOTSWITCH
FIGURE 8-44. PLATFORM CABLE HARNESS – WITH FOOTSWITCH
FIGURE 8-45. PLATFORM CONTROL BOX HARNESS
FIGURE 8-46. RECEPTACLE BOX KIT - 110V GFI
FIGURE 8-47. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-48. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-49. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 8-50. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 8-51. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 8-52. TILT SENSOR HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI SPECS (ENGLISH LANGUAGE) (RT4069)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN,CE & UK CA SPECS (ENGLISH LANGUAGE) (RT4069)
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (SPANISH/PORTUGUESE LANGUAGES) (RT4069)
FIGURE 9-4. DECAL INSTALLATION - CHINA SPECS (ENGLISH/CHINESE LANGUAGES) (RT4069)
FIGURE 9-5. DECAL INSTALLATION - CSA SPECS (ENGLISH/FRENCH LANGUAGES) (RT4069)
FIGURE 9-6. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN LANGUAGES) (RT4069)
FIGURE 9-7. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/KSPANISH LANGUAGES) (RT4069)
FIGURE 9-8. DECAL INSTALLATION - ANSI SPECS (ENGLISH LANGUAGE) (RT4769)
FIGURE 9-9. DECAL INSTALLATION - AUSTRALIAN,CE & UK CA SPECS (ENGLISH LANGUAGE) (RT4769)
FIGURE 9-10. DECAL INSTALLATION - BRAZIL SPECS (SPANISH/PORTUGUESE LANGUAGES) (RT4769)
FIGURE 9-11. DECAL INSTALLATION - CHINA SPECS (ENGLISH/CHINESE LANGUAGES) (RT4769)
FIGURE 9-12. DECAL INSTALLATION - CSA SPECS (ENGLISH/FRENCH LANGUAGES) (RT4769)
FIGURE 9-13. DECAL INSTALLATION - KOREAN SPECS (ENGLISH/KOREAN LANGUAGES) (RT4769)
FIGURE 9-14. DECAL INSTALLATION - LATIN AMERICAN SPECS (ENGLISH/KSPANISH LANGUAGES) (RT4769)
FIGURE 9-15. DECAL INSTALLATION - OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
