Hyundai
86
178,635
JLG Scissor Lift RT4069 RT4769 ERT4069 ERT4769 Service & Maintenance Manual 31215924 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT4069 RT4769 ERT4069 ERT4769 Scissor Lift
Part Number: 31215924
Publication Date: 2025
Number of Pages: 452 Pages
Section 1. Specifications​
1.1 Specifications​
1.2 Serial Number Location​
1.3 Lubrication​
1.4 Hydraulic Pressure Settings​
1.5 Hydraulic Cylinder Specifications​
1.6 Engine Specifications​
1.7 Battery Charger (ERT Machines)​
1.8 Elevation/Tilt Limit Settings​
1.9 Threadlocking Compound​
1.10 Torque Charts​
Section 2. General​
2.1 Machine Preparation, Inspection, and Maintenance​
2.2 Preventive Maintenance and Inspection Schedule​
2.3 Service and Guidelines​
2.4 Lubrication and Information​
2.5 Service Maintenance Components​
2.6 Cylinder Drift Test​
2.7 Pins and Composite Bearing Repair Guidelines​
Section 3. Chassis, Platform, & Scissor Arms​
3.1 Operating Characteristics​
3.2 Tires, Wheels & Drive Assembly​
3.3 Drive Hub (2WD For RT)​
3.4 Drive Hub (4WD For RT)​
3.5 Drive Hub (For ERT)​
3.6 Drive Motor (Sauer)​
3.7 Axle Installation​
3.8 Steer Installation​
3.9 Leveling Jacks (If Equipped)​
3.10 Platform​
3.11 Scissor Arms​
3.12 Side Compartment Covers​
3.13 Ground Control Station​
3.14 Battery​
3.15 Tank​
3.16 Battery Charger​
Section 4. Basic Hydraulic Information & Schematics​
4.1 Cylinders - Theory of Operation​
4.2 Valves - Theory of Operation​
4.3 Cylinder Checking Procedure​
4.4 Oscillating Axle - Lockout Cylinder Test​
4.5 Gear Pump Priming​
4.6 Hydraulic Component Start-Up Procedures & Recommendations​
4.7 Hydraulic Connection Assembly and Torque Specification​
4.8 Hydraulic Valves​
4.9 Gear Pump​
4.10 Cylinder Repair​
4.11 Cylinder Assemblies​
4.12 Hydraulic Schematics (For RT)​
4.13 Hydraulic Schematics (For ERT)​
Section 5. JLG Control System​
5.1 Analyzer​
5.2 Analyzer Menu Flow Chart (For RT)​
5.3 Analyzer Menu Flow Chart (For ERT)​
5.4 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description (For RT)​
5.5 Diagnostic Troubleshooting Codes (DTC’s) and Flash Codes Description (For ERT)​
5.6 Chassis Tilt Sensor Installation​
5.7 Location of Additional Sensors​
5.8 Calibration Procedures​
5.9 Service Mode Procedures​
5.10 Machine Configuration and Programming Settings (For RT)​
5.11 Machine Configuration and Programming Settings (For ERT)​
Section 6. LSS Setup/Calibration/Service​
6.1 Connecting the JLG Control System Analyzer​
6.2 Help Menu & Fault Codes​
6.3 Machine Setup Menu​
6.4 Service​
6.5 Calibration​
6.6 Troubleshooting​
Section 7. General Electrical Information & Schematics​
7.1 General​
7.2 Multimeter Basics​
7.3 Applying Silicone Dielectric Compound to Electrical Connections​
7.4 Dielectric Grease Application​
7.5 AMP Connector​
7.6 Working with Deutsch Connectors​
7.7 Switches​
7.8 Electrical Schematics (For RT)​
7.9 Electrical Schematics (For ERT)​
