Hyundai
86
176,834
JLG Scissor Lift RT4069 ERT4069 RT4769 ERT4769 Service & Maintenance Manual 3122567000 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT4069, ERT4069, RT4769, ERT4769 Scissor Lift
Part Number: 3122567000
Publication Date: 2025
Number of Pages: 604 Pages
Coverpage
Effectivity Page
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specification​
2.1.2 Machine Specifications - For ERT​
2.1.3 Dimensional Data​
2.1.4 Tires​
2.1.5 Batteries (For ERT)​
2.1.6 Battery Charger (ERT Machines)​
2.1.7 Elevation/Tilt Limit Settings​
2.1.8 Hydraulic Pressure Settings​
2.1.9 Hydraulic Cylinder Specifications​
2.1.10 Critical Stability Weights​
2.1.11 Generator Specifications (If Equipped)​
2.1.12 Drive Information​
2.1.13 Steering Information​
2.1.14 Quicklevel Information​
2.1.15 Engine Specifications​
Serial Number Location​
Fluids and Lubrication​
2.3.1 Hydraulic System​
2.3.2 Hydraulic Oil​
2.3.3 Changing Hydraulic Oil​
2.3.4 Lubrication Specifications​
2.3.5 Fluid Capacities - For RT​
2.3.6 Fluid Capacities - For ERT​
2.3.7 Oil Information​
2.3.8 Fluids​
Clearsky Smart Fleet (If Equipped)​
2.4.1 General​
2.4.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Lubrication and Servicing​
Preventive Maintenance and Inspection Schedule​
3.3.1 Maintenance and Inspection Schedule Codes​
Pins and Composite Bearing Repair Guidelines​
Tires & Wheels​
3.5.1 Tire Damage​
3.5.2 Tire Replacement​
3.5.3 Wheel Replacement​
Battery Charger​
3.6.1 Delta-Q - Battery Charger​
3.6.2 Battery Charging​
3.6.3 Battery Charger Maintenance​
3.6.4 IC Series Setup and Troubleshooting Guide​
3.6.5 IC650 DC Wiring Instructions​
3.6.6 IC900 & IC1200 DC Wiring Instructions​
3.6.7 Signals and Control Connector​
3.6.8 IC-Series Charger Interface​
3.6.9 State-of-Charge Indicators​
Service Maintenance Components​
3.7.1 Setting Scissor Arm Safety Prop​
3.7.2 General Maintenance Tips​
3.7.3 Fuel Tank​
3.7.4 Drive Hub​
3.7.5 Hydraulic Oil Tank​
3.7.6 Engine Coolant​
3.7.7 Oil Change with Filter​
3.7.8 Fuel Strainer (Diesel)​
3.7.9 Fuel Filter (Gas)​
3.7.10 Air Filter​
3.7.11 Fuel/Water Separator Filter (Diesel)​
3.7.12 Fan Belt​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter​
4.1.2 Continuity Measurement Over Long Distances​
4.1.3 Requirements​
4.1.4 Procedure​
4.1.5 Threadlocking Compound​
4.1.6 Tool List (Drive Hub – 2WD For RT)​
4.1.7 Tool List (Drive Hub — For ERT)​
Testing Procedures​
4.2.1 Preparation​
4.2.2 Testing LSS Control System Warnings and Interlocks:​
4.2.3 Testing LSS Platform Load Performance with Calibrated Weights:​
4.2.4 Testing LSS Platform Load Reading with a Known Weight:​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
Special Procedures​
4.4.1 Joystick Controller​
4.4.2 Cylinder Checking Procedure​
4.4.3 Cylinder Drift Test​
4.4.4 Initial Start-Up Procedures​
4.4.5 Dual Fuel/LPG System​
4.4.6 Hydraulic Component Start-Up Procedures & Recommendations​
Service Mode Procedures​
4.5.1 Elevation Service​
4.5.2 EEPROM Reset​
4.5.3 Allow Drive​
4.5.4 Allow Leveling Jack Retract​
4.5.5 Set Main Relief​
4.5.6 Hydraulic System Flush​
4.5.7 QLA Pressure Set​
Operating Characteristics​
4.6.1 Leveling Jacks (If Equipped)​
4.6.2 Manual Level Adjustment (Trim)​
4.6.3 Quiklevel Advanced (Dual Oscillating Axles) (If Equipped)​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Description​
5.1.3 Connecting The Jlg Control System Analyzer​
5.1.4 Machine Setup Menu​
5.1.5 Load Sensing Calibration​
JLG Analyzer​
5.2.1 Analyzer​
5.2.2 Analyzer Menu Flow Chart (Software Version P1.11) (For RT)​
5.2.3 Analyzer Menu Flow Chart (Software Version P1.10) (For ERT)​
Analyzer Software Accessibility​
5.3.1 Machine Configuration and Programming Settings (For RT)​
5.3.2 Machine Configuration and Programming Settings (For ERT)​
5.4.1 ClearSky Smart FleetTM CS550 Configuration​
5.4.2 Troubleshooting​
Fault Codes
Introduction​
6.1.1 System Fault/DTC Indication​
Diagnostic Trouble Codes (DTC)​
DTC Check Tables​
6.3.1 DTC and Flash Codes​
6.3.2 ClearSky CSV3 Smart Fleet DTC Fault Codes​
6.3.3 Troubleshooting​
6.3.4 Help Menu & Fault Codes​
6.3.5 LSS Troubleshooting​
6.3.6 Troubleshooting​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
Theories of Operation​
7.1.1 Cylinders​
7.1.2 Valves​
Torque Values​
7.2.1 Main Hydraulic Valve​
7.2.2 Junction Manifold Valve​
7.2.3 Lift Down Valve​
7.2.4 Electric Option Valve​
7.2.5 Leveling Jack Valves (If Equipped)​
7.2.6 Dual Axle Option Valve​
7.2.7 Traction Valve (2WD)​
7.2.8 Traction Valve (4WD)​
Gear Pump​
7.3.1 General Repair Instructions​
7.3.2 Gear Pump Priming​
Electricals
General Information​
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors​
8.1.3 AMP Mate-N-Lok​
8.1.4 AMP Faston​
8.1.5 AMP Micro-Fit​
8.1.6 AMP Mini Fit Jr​
8.1.7 Mini Fit Sr​
8.1.8 DIN Connectors​
8.1.9 Exceptions​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Harness Layout​
8.3.1 Electrical Layout For RT4069, RT4769​
8.3.2 Electrical Layout For ERT4069, ERT4769​
Board Layouts​
8.4.1 Ground Control Module (For RT)​
8.4.2 Ground Control Module (For ERT)​
AMP Connector​
8.5.1 Assembly​
8.5.2 Disassembly​
8.5.3 Wedge Lock​
8.5.4 Service - Voltage Reading​
Switches​
8.6.1 Basic check​
8.6.2 Limit Switches​
8.6.3 Automatic Switches​
8.6.4 Switch Wiring - Low Side, High Side​
Wheels​
9.1.1 Wheel Installation​
Battery​
9.2.1 Battery Removal For RT​
9.2.2 Battery Removal For ERT​
Chassis Tilt Sensor Installation​
Ground Control Station​
9.4.1 Control Station Removal​
9.4.2 Removal​
9.4.3 Installation​
9.4.4 Ground Control Station Components​
Hydraulic Tank​
9.5.1 Tank Installation For RT​
9.5.2 Tank Installation For ERT​
Scissor Arms​
9.6.1 Lift Cylinder Removal​
9.6.2 Scissor Arms Removal​
9.6.3 Scissor Arm Assembly Removal​
Platform​
Drive Assembly​
9.8.1 Spindle Assembly Hub - For RT (2WD)​
9.8.2 Drive Assembly - For ERT​
Axle Installation​
Steer Installation​
9.10.1 Steering Assembly - For RT​
9.10.2 Steering Assembly - For ERT​
9.10.3 Oscillating Axle Cylinder​
Leveling Jacks​
9.11.1 Cylinder Removal​
9.11.2 Cylinder Removal​
9.11.3 Assembly Removal​
Side Compartment Covers​
Hydraulic Valves​
9.13.1 Pressure Relief Valve - Setting Procedures (For RT)​
Location of Additional Sensors​
Drive Motor (Sauer)​
9.15.1 Description​
9.15.2 Shaft Seal Replacement​
9.15.3 Loop Flushing Valve​
Engine​
9.16.1 Exhaust System​
9.16.2 Exhaust System (Kubota Engine)​
9.16.3 Air Cleaner System​
9.16.4 Radiator​
9.16.5 Engine Electrical Component Locations​
Generator​
9.17.1 Belt Routing​
Hydraulic Pump Installation​
Pump Coupling Assembly​
Ground Control Panel​
9.20.1 Ground Control Panel Installation​
9.21.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub (2WD for RT)​
10.1.2 Drive Hub (4WD for RT)​
10.1.3 DRIVE HUB (FOR ERT)​
10.1.4 Drive Motor (Sauer)​
Scissor Arm Assembly​
10.2.1 Scissor Arm Assembly​
Platform Control Station​
Hydraulic Cylinders​
10.4.1 Cylinder Repair​
10.4.2 Cylinder Assemblies​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
12.1.1 Hydraulic Schematics (for RT)​
12.1.2 Hydraulic Schematics (for ERT)​
Electrical Schematics​
12.2.1 Electrical Schematic (For RT)​
12.2.2 Electrical Schematic (For ERT)​
