JLG Scissor Lift RT4069 ERT4069 RT4769 ERT4769 Service & Maintenance Manual 31220317 2025
Brand: JLG
Type of Machine: Scissor Lift
Model: JLG RT4069, ERT4069, RT4769, ERT4769 Scissor Lift
Part Number: 31220317
Publication Date: 2025
Number of Pages: 604 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specification
2.1.2 Machine Specifications - For ERT
2.1.3 Dimensional Data
2.1.4 Tires
2.1.5 Batteries (For ERT)
2.1.6 Battery Charger (ERT Machines)
2.1.7 Elevation/Tilt Limit Settings
2.1.8 Hydraulic Pressure Settings
2.1.9 Hydraulic Cylinder Specifications
2.1.10 Critical Stability Weights
2.1.11 Generator Specifications (If Equipped)
2.1.12 Drive Information
2.1.13 Steering Information
2.1.14 Quicklevel Information
2.1.15 Engine Specifications
Serial Number Location
Fluids and Lubrication
2.3.1 Hydraulic System
2.3.2 Hydraulic Oil
2.3.3 Changing Hydraulic Oil
2.3.4 Lubrication Specifications
2.3.5 Fluid Capacities - For RT
2.3.6 Fluid Capacities - For ERT
2.3.7 Oil Information
2.3.8 Fluids
Clearsky Smart Fleet (If Equipped)
2.4.1 General
2.4.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Lubrication and Servicing
Preventive Maintenance and Inspection Schedule
3.3.1 Maintenance and Inspection Schedule Codes
Pins and Composite Bearing Repair Guidelines
Tires & Wheels
3.5.1 Tire Damage
3.5.2 Tire Replacement
3.5.3 Wheel Replacement
Battery Charger
3.6.1 Delta-Q - Battery Charger
3.6.2 Battery Charging
3.6.3 Battery Charger Maintenance
3.6.4 IC Series Setup and Troubleshooting Guide
3.6.5 IC650 DC Wiring Instructions
3.6.6 IC900 & IC1200 DC Wiring Instructions
3.6.7 Signals and Control Connector
3.6.8 IC-Series Charger Interface
3.6.9 State-of-Charge Indicators
Service Maintenance Components
3.7.1 Setting Scissor Arm Safety Prop
3.7.2 General Maintenance Tips
3.7.3 Fuel Tank
3.7.4 Drive Hub
3.7.5 Hydraulic Oil Tank
3.7.6 Engine Coolant
3.7.7 Oil Change with Filter
3.7.8 Fuel Strainer (Diesel)
3.7.9 Fuel Filter (Gas)
3.7.10 Air Filter
3.7.11 Fuel/Water Separator Filter (Diesel)
3.7.12 Fan Belt
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter
4.1.2 Continuity Measurement Over Long Distances
4.1.3 Requirements
4.1.4 Procedure
4.1.5 Threadlocking Compound
4.1.6 Tool List (Drive Hub – 2WD For RT)
4.1.7 Tool List (Drive Hub — For ERT)
Testing Procedures
4.2.1 Preparation
4.2.2 Testing LSS Control System Warnings and Interlocks:
4.2.3 Testing LSS Platform Load Performance with Calibrated Weights:
4.2.4 Testing LSS Platform Load Reading with a Known Weight:
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
Special Procedures
4.4.1 Joystick Controller
4.4.2 Cylinder Checking Procedure
4.4.3 Cylinder Drift Test
4.4.4 Initial Start-Up Procedures
4.4.5 Dual Fuel/LPG System
4.4.6 Hydraulic Component Start-Up Procedures & Recommendations
Service Mode Procedures
4.5.1 Elevation Service
4.5.2 EEPROM Reset
4.5.3 Allow Drive
4.5.4 Allow Leveling Jack Retract
4.5.5 Set Main Relief
4.5.6 Hydraulic System Flush
4.5.7 QLA Pressure Set
Operating Characteristics
4.6.1 Leveling Jacks (If Equipped)
4.6.2 Manual Level Adjustment (Trim)
4.6.3 Quiklevel Advanced (Dual Oscillating Axles) (If Equipped)
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Description
5.1.3 Connecting The Jlg Control System Analyzer
5.1.4 Machine Setup Menu
5.1.5 Load Sensing Calibration
JLG Analyzer
5.2.1 Analyzer
5.2.2 Analyzer Menu Flow Chart (Software Version P1.11) (For RT)
5.2.3 Analyzer Menu Flow Chart (Software Version P1.10) (For ERT)
Analyzer Software Accessibility
5.3.1 Machine Configuration and Programming Settings (For RT)
5.3.2 Machine Configuration and Programming Settings (For ERT)
ClearSky (CS550) Configuration and Troubleshooting
5.4.1 ClearSky Smart FleetTM CS550 Configuration
5.4.2 Troubleshooting
Fault CodesIntroduction
6.1.1 System Fault/DTC Indication
Diagnostic Trouble Codes (DTC)
DTC Check Tables
6.3.1 DTC and Flash Codes
6.3.2 ClearSky CSV3 Smart Fleet DTC Fault Codes
6.3.3 Troubleshooting
6.3.4 Help Menu & Fault Codes
6.3.5 LSS Troubleshooting
6.3.6 Troubleshooting
ClearSky CS550 Troubleshooting Procedures
HydraulicsTheories of Operation
7.1.1 Cylinders
7.1.2 Valves
Torque Values
7.2.1 Main Hydraulic Valve
7.2.2 Junction Manifold Valve
7.2.3 Lift Down Valve
7.2.4 Electric Option Valve
7.2.5 Leveling Jack Valves (If Equipped)
7.2.6 Dual Axle Option Valve
7.2.7 Traction Valve (2WD)
7.2.8 Traction Valve (4WD)
Gear Pump
7.3.1 General Repair Instructions
7.3.2 Gear Pump Priming
ElectricalGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Amp Connectors
8.1.2 Dielectric Grease Application
8.1.3 AMP Mate-N-Lok
8.1.4 AMP Faston
8.1.5 AMP Micro-Fit
8.1.6 AMP Mini Fit Jr
8.1.7 Mini Fit Sr
8.1.8 DIN Connectors
8.1.9 Exceptions
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Harness Layout
8.3.1 Electrical Layout For RT4069, RT4769
8.3.2 Electrical Layout For ERT4069, ERT4769
Board Layouts
8.4.1 Ground Control Module (For RT)
8.4.2 Ground Control Module (For ERT)
AMP Connector
8.5.1 Assembly
8.5.2 Disassembly
8.5.3 Wedge Lock
8.5.4 Service - Voltage Reading
Switches
8.6.1 Basic check
8.6.2 Limit Switches
8.6.3 Automatic Switches
8.6.4 Switch Wiring - Low Side, High Side
Removal and InstallationWheels
9.1.1 Wheel Installation
Battery
9.2.1 Battery Removal For RT
9.2.2 Battery Removal For ERT
Chassis Tilt Sensor Installation
Ground Control Station
9.4.1 Control Station Removal
9.4.2 Removal
9.4.3 Installation
9.4.4 Ground Control Station Components
Hydraulic Tank
9.5.1 Tank Installation For RT
9.5.2 Tank Installation For ERT
Scissor Arms
9.6.1 Lift Cylinder Removal
9.6.2 Scissor Arms Removal
9.6.3 Scissor Arm Assembly Removal
Platform
Drive Assembly
9.8.1 Spindle Assembly Hub - For RT (2WD)
9.8.2 Drive Assembly - For ERT
Axle Installation
Steer Installation
9.10.1 Steering Assembly - For RT
9.10.2 Steering Assembly - For ERT
9.10.3 Oscillating Axle Cylinder
Leveling Jacks
9.11.1 Cylinder Removal
9.11.2 Cylinder Removal
9.11.3 Assembly Removal
Side Compartment Covers
Hydraulic Valves
9.13.1 Pressure Relief Valve - Setting Procedures (For RT)
Location of Additional Sensors
Drive Motor (Sauer)
9.15.1 Description
9.15.2 Shaft Seal Replacement
9.15.3 Loop Flushing Valve
9.16.1 Exhaust System
9.16.2 Air Cleaner System
9.16.3 Radiator
9.16.4 Engine Electrical Component Locations
Generator
9.17.1 Belt Routing
Hydraulic Pump Installation
Pump Coupling Assembly
Ground Control Panel
9.20.1 Ground Control Panel Installation
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.21.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub (2WD for RT)
10.1.2 Drive Hub (4WD for RT)
10.1.3 DRIVE HUB (FOR ERT)
10.1.4 Drive Motor (Sauer)
10.2.1 Scissor Arm Assembly
Platform Control Station
Hydraulic Cylinders
10.4.1 Cylinder Repair
10.4.2 Cylinder Assemblies
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
12.1.1 Hydraulic Schematics (for RT)
12.1.2 Hydraulic Schematics (for ERT)
Electrical Schematics
12.2.1 Electrical Schematic (For RT)
12.2.2 Electrical Schematic (For ERT)
- SuperPac Parts Manual
- StratoLift Parts Manual
